ayeah Posted April 29, 2016 Posted April 29, 2016 hi im newbie OrangePI, how to make WiFiUSB work Bus 002 Device 002: ID 148f:7601 Ralink Technology, Corp. I try this step https://github.com/pvaret/rtl8192cu-fixesbut get error on this cmd sudo apt-get install git linux-headers-generic build-essential dkms root@orangepipc:~# git clone https://github.com/pvaret/rtl8192cu-fixes.git Cloning into 'rtl8192cu-fixes'... remote: Counting objects: 438, done. remote: Total 438 (delta 0), reused 0 (delta 0), pack-reused 438 Receiving objects: 100% (438/438), 1.80 MiB | 240.00 KiB/s, done. Resolving deltas: 100% (223/223), done. Checking connectivity... done. root@orangepipc:~# sudo dkms add ./rtl8192cu-fixes sudo: dkms: command not found root@orangepipc:~# sudo apt-get install git linux-headers-generic build-essential dkms Reading package lists... Done Building dependency tree Reading state information... Done Package linux-headers-generic is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'linux-headers-generic' has no installation candidate please somebody help?!
Igor Posted April 29, 2016 Posted April 29, 2016 You followed wrong how-to. Check our manual section and search forum if you are here first time. # this is needed now since there are some problems, otherwise this is not needed cd /usr/src/linux-headers-$(uname -r) make m=scripts # return to source dir and execute make ARCH=arm or just make is usually all you need to do if you use Armbian.
martinayotte Posted April 29, 2016 Posted April 29, 2016 Also, I don't think RTL8192 would be any help here, as you mentioned "148f:7601 Ralink". This driver is part of the Mainline, but I don't think it is part of Legacy. /lib/modules/4.4.5-sunxi/kernel/drivers/net/wireless/mediatek/mt7601u/mt7601u.ko
Igor Posted April 29, 2016 Posted April 29, 2016 Than following this recipe might be useful: https://github.com/igorpecovnik/lib/blob/master/extras/mt7601.sh Anyway, both drivers should come with Armbian image.
