Hi there,
I'm trying to run compile.sh since several days as mentioned in the instructions with Vagrant but no success so far.
1.
https://docs.armbian.com/Developer-Guide_Using-Vagrant/
Vagrant Guest steps
Instruction tells cd armbian but it is cd /vagrant
2.
First run of ./compile.sh stops because the following packages signature could not be verified.
Downloading the following packages manually, unpacking them in cache/toolchain and creating a .download-complete file fixed this issue.
All other following packages were installed automatically.
gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz
gcc-linaro-arm-none-eabi-4.8-2014.04_linux.tar.xz
3.
I want to compile a 3.4'er Kernel fpr bananapi
After selecting "bananapi" and "default" it is compiling a while and then complains:
[ error ] ERROR in function compile_uboot [ compilation.sh:211 ]
[ error ] U-boot file not found [ u-boot-sunxi-with-spl.bin ]
[ o.k. ] Process terminated
I'm stuck now. Any help is appreciated.
output.log
Ca you provide the file output/debug/compilation.log to see why u-boot-sunxi-with-spl.bin is not found ?
Perhaps Vagrant is broken or your manual intervention were not correct? Can you try building under Docker or manually inside VM?
According to this log, this is were it is really failing :
  SHIPPED dts/dt.dtb
  FDTGREP dts/dt-spl.dtb
  CAT     u-boot-dtb.bin
  COPY    u-boot.dtb
  COPY    u-boot.bin
  MKIMAGE u-boot.img
./tools/mkimage: Can't map u-boot.img: Invalid argument
make: *** [u-boot.img] Error 1
make: *** Waiting for unfinished jobs....
Makefile:1090: recipe for target 'u-boot.img' failed
I don't know why ... We need to investigate ...
His build system was not installed clearly so its possible that things are missing ... and I cant't reproduce this error on native build (cleaning source caches before). It works.
