Dmitriy Zhuk Posted July 24, 2019 Posted July 24, 2019 Hello. I try to use waveshare 5inch touchscreen. But, while u-boot, it works. And after starting kernel, there is no output. My image is Armbian_5.90_Orangepipcplus_Ubuntu_xenial_default_3.4.113_desktop.img (ubuntu 16.04) Thank you for any help. This is video:
Igor Posted July 24, 2019 Posted July 24, 2019 25 minutes ago, Dmitriy Zhuk said: Thank you for any help. Try modern kernel - it will probably work there.
Dmitriy Zhuk Posted July 24, 2019 Author Posted July 24, 2019 I can't find image with desktop version on page https://www.armbian.com/orange-pi-pc-plus/#kernels-archive Armbian Bionic mainline based kernel 4.19.y Server or light desktop usage scenarios. High level of software maturity After downloading, and unpacking, I see server version of Bionic. Where is desktop version?
guidol Posted July 24, 2019 Posted July 24, 2019 9 minutes ago, Dmitriy Zhuk said: I can't find image with desktop version on page https://www.armbian.com/orange-pi-pc-plus/#kernels-archive Where is desktop version? At https://dl.armbian.com/orangepipcplus/archive/ I also did found only desktop images with the legacy 3.4-kernel Maybe @Igor means that with the newer kernel you could see the console after the kernel-start?
Igor Posted July 24, 2019 Posted July 24, 2019 2 minutes ago, guidol said: means that with the newer kernel you could see the console after the kernel-start? Exactly. You can enable server on any CLI image -> armbian-config -> system -> enable minimal or full desktop
Dmitriy Zhuk Posted July 24, 2019 Author Posted July 24, 2019 17 minutes ago, Igor said: CLI image -> armbian-config -> system -> enable minimal or full desktop Where and how should I do it?
martinayotte Posted July 24, 2019 Posted July 24, 2019 5 minutes ago, Dmitriy Zhuk said: Where and how should I do it? As it said : run "armbian-config", select menu "system" and "install minimal desktop" ...
Dmitriy Zhuk Posted July 26, 2019 Author Posted July 26, 2019 I successfully run desktop version of Bionic. And touchscreen works perfect with new version of kernel. But, in that version of kernel, there is no sound. On previous version of kernel (Ubuntu 16.04) sound was good. Why? Do I have to make some settings?
Dmitriy Zhuk Posted July 27, 2019 Author Posted July 27, 2019 I've found out, that system does not have hardware output except dummy. Why? I try to google: But it does not help me.
