Jerry Jyrer Posted July 31, 2019 Posted July 31, 2019 Anyone gets Nanopo M4 on-board bluetooth working. Any pointer would be appreciated. Here are what I did: - install Bluetooth component from armbian-config $ sudo service bluetooth status ● bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled) Active: active (running) since Wed 2019-07-31 15:59:27 PDT; 9s ago Docs: man:bluetoothd(8) Main PID: 14661 (bluetoothd) Status: "Running" Tasks: 1 (limit: 4558) Memory: 2.1M CGroup: /system.slice/bluetooth.service └─14661 /usr/lib/bluetooth/bluetoothd Jul 31 15:59:27 nanopim4 systemd[1]: Starting Bluetooth service... Jul 31 15:59:27 nanopim4 bluetoothd[14661]: Bluetooth daemon 5.50 Jul 31 15:59:27 nanopim4 systemd[1]: Started Bluetooth service. Jul 31 15:59:27 nanopim4 bluetoothd[14661]: Starting SDP server Jul 31 15:59:27 nanopim4 bluetoothd[14661]: kernel lacks bnep-protocol support Jul 31 15:59:27 nanopim4 bluetoothd[14661]: System does not support network plugin Jul 31 15:59:27 nanopim4 bluetoothd[14661]: Bluetooth management interface 1.10 initialized $ sudo hcitool dev Devices: $ sudo rfkill list 0: bt_default: Bluetooth Soft blocked: no Hard blocked: no 1: phy0: Wireless LAN Soft blocked: no Hard blocked: no 2: brcmfmac-wifi: Wireless LAN Soft blocked: no Hard blocked: no $ uname -a Linux nanopim4 4.4.179-rk3399 #1 SMP Thu Jun 27 23:31:19 CEST 2019 aarch64 GNU/Linux $ cat /etc/os-release PRETTY_NAME="Debian GNU/Linux 10 (buster)" NAME="Debian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/"
Jerry Jyrer Posted July 31, 2019 Author Posted July 31, 2019 One more, in case it might help: $ sudo dmesg | grep blue [ 3.016666] of_get_named_gpiod_flags: parsed 'uart_rts_gpios' property of node '/wireless-bluetooth[0]' - status (0) [ 3.016670] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83. [ 3.016675] of_get_named_gpiod_flags: can't parse 'BT,power_gpio' property of node '/wireless-bluetooth[0]' [ 3.016686] of_get_named_gpiod_flags: parsed 'BT,reset_gpio' property of node '/wireless-bluetooth[0]' - status (0) [ 3.016689] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9. [ 3.016700] of_get_named_gpiod_flags: parsed 'BT,wake_gpio' property of node '/wireless-bluetooth[0]' - status (0) [ 3.016703] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90. [ 3.016713] of_get_named_gpiod_flags: parsed 'BT,wake_host_irq' property of node '/wireless-bluetooth[0]' - status (0) [ 3.016716] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
Igor Posted August 1, 2019 Posted August 1, 2019 I used (Bionic) image from the download section and I could navigate KODI via Bluetooth enabled mouse ... Which image did you used? Have you mage some upgrade from Stretch to Buster? Where is your armbianmonitor -u (which can perhaps tell more).
Jerry Jyrer Posted August 1, 2019 Author Posted August 1, 2019 48 minutes ago, Igor said: I used (Bionic) image from the download section and I could navigate KODI via Bluetooth enabled mouse ... Which image did you used? Have you mage some upgrade from Stretch to Buster? Where is your armbianmonitor -u (which can perhaps tell more). I think I saw Buster available on the Download page but what I did was simply change /etc/apt/sources.list and apt update & upgrade. Something similar to: https://linuxconfig.org/how-to-upgrade-debian-9-stretch-to-debian-10-buster somehow armbianmonitor -u returned empty string for me. I did something similar here: http://sprunge.us/yK0GdC Thanks for your help.
Igor Posted August 1, 2019 Posted August 1, 2019 1 hour ago, Jerry Jyrer said: was simply change /etc/apt/sources.list and apt update & upgrade. Simply implement this https://github.com/armbian/build/commit/1541de32b85fa81c82bb549b67a91746ae33230c#diff-fd85d58c8bb1c2923d75fd40b35d907f or start with a clean build if that will give you too much trouble.
Jerry Jyrer Posted August 1, 2019 Author Posted August 1, 2019 10 hours ago, Igor said: Simply implement this https://github.com/armbian/build/commit/1541de32b85fa81c82bb549b67a91746ae33230c#diff-fd85d58c8bb1c2923d75fd40b35d907f or start with a clean build if that will give you too much trouble. Thanks Igor. Pretty newbie here. I changed to nightly firmware and upgrade there to $ uname -a Linux nanopim4 5.1.0-rk3399 #5.91.190708 SMP Tue Jul 9 07:58:42 CEST 2019 aarch64 GNU/Linux Things are still not working. Here is $ sudo armbianmonitor -u (it works now :)) http://ix.io/1Qi6 Thanks for your helps.
Igor Posted August 1, 2019 Posted August 1, 2019 2 hours ago, Jerry Jyrer said: Pretty newbie here Use image from the download section and stay away from nightly / beta sections if you want that things works.
Jerry Jyrer Posted August 1, 2019 Author Posted August 1, 2019 34 minutes ago, Igor said: Use image from the download section and stay away from nightly / beta sections if you want that things works. sir, yes sir. : ) I'll definitely try to flash the image from the download section to a new SDCard to just check if BT comes back to work and report here when I get a chance. By the way, do you have any suggestion for me to just update the core parts in my existing system with the image from the download section? I have things setup already and its kind of painful to re-config things from a fresh install.
Igor Posted August 2, 2019 Posted August 2, 2019 6 hours ago, Jerry Jyrer said: to just update the core parts I already told you exactly what you have to do, but can't guide in case of troubles. Also you have to remain on stock/legacy kernel. With development kernels (5.1.y) you are on your own. This recipe might work or not.
Jerry Jyrer Posted August 2, 2019 Author Posted August 2, 2019 I got the bluetooth working with a fresh install from the download section to a new microSDCard. I have rootfs installed in my external hdd. So, I did similar procedures in what nand-sata-install is doing except formatting the external hdd (rootfs). Basically, - setting the correct UUID and others in /boot/armbianEnv.txt $ mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr - setting the correct UUID and mount locations in /etc/fstab The system boots fine. Other things seem to be working okay. BUT the bluetooth is not working : ( Here is $ sudo armbianmonitor -u http://ix.io/1Qkq Helps are appreciated.
Jerry Jyrer Posted August 2, 2019 Author Posted August 2, 2019 1 hour ago, Igor said: I already told you exactly what you have to do, but can't guide in case of troubles. Also you have to remain on stock/legacy kernel. With development kernels (5.1.y) you are on your own. This recipe might work or not. Thank you Igor. I finally got it work. Basically, follow your guidance: $vi /lib/systemd/system/ [Unit] Description=Bluetooth nanopi After=bluetooth.target [Service] Type=forking ExecStartPre=/bin/echo 1 > /sys/class/rfkill/rfkill0/state ExecStart=/usr/bin/hciattach /dev/ttyS0 bcm43xx 115200 > /dev/null TimeoutSec=0 RemainAfterExit=yes SysVStartPriority=99 [Install] WantedBy=multi-user.target $ sudo systemctl --no-reload enable nanopi-bluetooth.service $ sudo systemctl start nanopi-bluetooth.service BT is working now. : ) Trying to get my generic gamepad to work is another story : ( But at least, it's connected. 1
SergiiG Posted March 7, 2020 Posted March 7, 2020 Hello All, Just quick question, I hope some of your will be able to answer. I was running Armbian Bionic on legacy kernel for a year on my NanoPi M4 (verion 1) and was able to enable the nanopi-bluetooth.service.. Now I have upgraded to Buster server with kernel 5.4 - and cannot get Bluetooth working. I guess this is my mistake to go for server image, and maybe bluetooth is not included in this image by default. So my question is should I go back to legacy kernel, or desktop version with 5.4 kernel will be fine, and bluetooth will work with that image. I run my NanoPi M4 as headless server, but still need wifi and bluetooth - so that is why I went for Buster server. I do not really want to try all the images myself, because a lot of important services are running on my SBC so I want to make this last shot right now, and choose right here (with WiFi and Bluetooth working, without graphical interface): - go back to images based on legacy kernel - use desktop buster image on kernel 5.4 - stay on my current image of Buster server kernel 5.4 and add Bluetooth service myself (if someone can point me into solution). will appreciate any help here, thanks.
