sveni_lee Posted August 16, 2019 Share Posted August 16, 2019 Armbianmonitor: http://ix.io/1RSm Hi, I have a Opi zero 512 and did a fresh install Debian Buster with Armbian Linux 4.19.59-sunxi I installes the Linux-Kernel but I run into problems with compiling a driver. outdoorpi@orangepizero:~/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd$ sudo make KERNELDIR=/usr/src/linux-source-4.19.57-sunxi64 make -C /usr/src/linux-source-4.19.57-sunxi64 M=/home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd modules make[1]: Entering directory '/usr/src/linux-source-4.19.57-sunxi64' CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/driver.o /bin/sh: 1: scripts/basic/fixdep: Exec format error make[2]: *** [scripts/Makefile.build:304: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/driver.o] Error 2 make[2]: *** Deleting file '/home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/driver.o' make[1]: *** [Makefile:1517: _module_/home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd] Error 2 make[1]: Leaving directory '/usr/src/linux-source-4.19.57-sunxi64' make: *** [Makefile:61: default] Error 2 outdoorpi@orangepizero:~/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd$ it seems to be a problem with cross compiling but how to solve it? Link to comment Share on other sites More sharing options...
drice Posted August 16, 2019 Share Posted August 16, 2019 I ran into the same issue a while ago. This occurs because the binaries in the scripts folder are x86_64 format. As I recall, this can be fixed by the following, but I can't test it now: cd /usr/src/linux-source-4.19.57-sunxi64 make clean make scripts If it doesn't work I can test in a few hours. Link to comment Share on other sites More sharing options...
sveni_lee Posted August 16, 2019 Author Share Posted August 16, 2019 seems not to work for me... compiling maybe works but in the end I got... outdoorpi@orangepizero:~/usb-redirector-linux-armeb-gnueabihf$ sudo ./installer.sh install-server *** Installing USB Redirector for Linux v3.8 *** Destination dir: /usr/local/usb-redirector *** Checking installation... *** Detecting system... *** distribution: debian *** kernel: 4.19.59-sunxi *** Compiling kernel module... *** Kernel module successfully compiled *** Creating directories... *** Preparing scripts... *** Copying files... *** Setting up init script... *** Starting daemon... *** Please allow incoming connections on 32032 port for USB Sever to be able to accept connections from remote clients. *** INSTALLATION SUCCESSFUL! To uninstall, run /usr/local/usb-redirector/uninstall.sh outdoorpi@orangepizero:~/usb-redirector-linux-armeb-gnueabihf$ installation works but when I start the program outdoorpi@orangepizero:/usr/local/usb-redirector/bin$ sudo usbsrv -l /usr/local/bin/usbsrv: 1: /usr/local/bin/usbsrv: Syntax error: word unexpected (expecting ")") outdoorpi@orangepizero:/usr/local/usb-redirector/bin$ so same problem as before... Link to comment Share on other sites More sharing options...
drice Posted August 16, 2019 Share Posted August 16, 2019 8 minutes ago, sveni_lee said: so same problem as before... Completely different problem, in fact. Your first post showed a problem with compilation, and now your second post shows a problem running the software you have compiled. 10 minutes ago, sveni_lee said: /usr/local/bin/usbsrv: Syntax error: word unexpected (expecting ")") Check this file and see what's wrong. I don't know what this software is so I can't give any suggestions. Link to comment Share on other sites More sharing options...
sveni_lee Posted August 16, 2019 Author Share Posted August 16, 2019 I'm not sure if copiling runs well... Spoiler outdoorpi@orangepizero:~/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd$ sudo make KERNELDIR=/usr/src/linux-source-4.19.57-sunxi64 make -C /usr/src/linux-source-4.19.57-sunxi64 M=/home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd modules make[1]: Entering directory '/usr/src/linux-source-4.19.57-sunxi64' CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.o /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c: In function ‘lIIlIIIIl’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:66:76: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] ,lIlII);break;}}while((0x1ec1+1500-0x249d));if(lIlII!=(0x12c5+471-0x149c)){if( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:67:27: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IIlIIIl)cdev_del(IIlIIIl);if(IIIlllI!=MKDEV((0xe80+959-0x123f), ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:67:27: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:68:76: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ (0xe59+4859-0x2154)))unregister_chrdev_region(IIIlllI,(0x1b64+832-0x1da5));if( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:68:76: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:69:32: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IlIIlII)class_destroy(IlIIlII);IIlIIIl=NULL;IIIlllI=MKDEV((0x713+2471-0x10ba), ^~~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c: In function ‘lllIIlIl’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:74:10: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IIlIIIl);if(IIIlllI!=MKDEV((0x16bf+2937-0x2238),(0x67a+5289-0x1b23))) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:75:44: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ unregister_chrdev_region(IIIlllI,lIIIllII);if(IlIIlII)class_destroy(IlIIlII); ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c: In function ‘IIIIlIII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:167:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(IlIlIlII<(0xc89+2829-0x1796)||IlIlIlII>=lIIIllII)return-EINVAL;if(IIlllIll< ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:167:67: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(IlIlIlII<(0xc89+2829-0x1796)||IlIlIlII>=lIIIllII)return-EINVAL;if(IIlllIll< ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:167:67: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:168:55: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ (0xdaa+3267-0x1a6d)||IIlllIll>=lIIIllII)return-EINVAL;if(IlIlIlII>IIlllIll) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:168:55: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:169:15: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ return-EINVAL;mutex_lock(&lllllll);for(i=IlIlIlII;i<=IIlllIll;i++){if(llIIlllI[i ^~~~~~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c: In function ‘IIIIlllIl’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:219:53: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IIIIII*IIlII;mutex_lock(&lllllll);IIlII=llIIlllI[m];if(IIlII&&IIlII->ops. ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/cdev.c:220:46: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IlIIIIll)IIlII->ops.IlIIIIll(IIlII->context);mutex_unlock(&lllllll);if(IIlII){ ^~~~~~~~~~~~ CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_loader.o /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_loader.c: In function ‘llIllIlll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_loader.c:87:28: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] ;INIT_LIST_HEAD(&IIlIllll);if(copy_from_user(&IllllllI,lIIll,sizeof(IllllllI))) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_loader.c:88:15: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ return-EFAULT;IIlIllII=lIIll+IllllllI.IIIlIl.IlIIlIl;if(lIIll+sizeof(IllllllI)> ^~~~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_loader.c:88:54: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] return-EFAULT;IIlIllII=lIIll+IllllllI.IIIlIl.IlIIlIl;if(lIIll+sizeof(IllllllI)> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_loader.c:89:24: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IIlIllII)return-EINVAL;lIIll+=sizeof(IllllllI);llIIl( ^~~~~ CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.o /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c: In function ‘lIlIlllll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:142:42: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] __user*ioctl){IIIIl lllllI;IIIIl lIIIIII;if(get_user(lllllI,&ioctl->IIIlIl. ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:143:45: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IlIIlIl)<(0x116f+3463-0x1ef6))return-EFAULT;if(lllllI!=sizeof(struct IIIllIlll)) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:143:45: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:144:15: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ return-EINVAL;if(get_user(lIIIIII,&ioctl->lIIIIII)<(0x644+6378-0x1f2e))return- ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c: In function ‘lIllIlIIl’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:147:36: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] ioctl){IIIIl lllllI;IIIIl IllIllIl;if(get_user(lllllI,&ioctl->IIIlIl.IlIIlIl)< ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:148:34: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ (0x387+1209-0x840))return-EFAULT;if(lllllI!=sizeof(struct IIIllIllI))return- ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c: In function ‘IIIllIIII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:151:78: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] int IIIllIIII(struct IIIlI*IIIll,struct lllIIIIll __user*ioctl){IIIIl lllllI;if( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:152:73: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ get_user(lllllI,&ioctl->IIIlIl.IlIIlIl)<(0xad4+193-0xb95))return-EFAULT;if( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:152:73: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:153:48: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ lllllI!=sizeof(struct lllIIIIll))return-EINVAL;IlllIlIlI(IIIll,IIIll->IIlllIII); ^~~~~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c: In function ‘lIIIlIIll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:155:43: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] __user*ioctl){IIIIl lllllI;IIIIl llIlIlll;if(get_user(lllllI,&ioctl->IIIlIl. ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:156:42: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IlIIlIl)<(0x93+2901-0xbe8))return-EFAULT;if(lllllI!=sizeof(*ioctl))return-EINVAL ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:157:27: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] ;llIlIlll=IIIll->IlIIIIlI;if(put_user(llIlIlll,&ioctl->llIlIlll)< ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:158:35: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ (0xf10+1459-0x14c3))return-EFAULT;return(0x981+5979-0x20dc);}long lIlIlIIIl(void ^~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c: In function ‘IlIIIIllI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:376:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(usb_pipein(pipe))IIllIIII|=USB_DIR_IN;usb_reset_endpoint(IlllI->IIIll->lllll, ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:376:42: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(usb_pipein(pipe))IIllIIII|=USB_DIR_IN;usb_reset_endpoint(IlllI->IIIll->lllll, ^~~~~~~~~~~~~~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c: In function ‘IIIlIlIlI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:438:72: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] )(IlllI+(0x27b+3631-0x10a9));IlIlI->lllII.Status=-(0x1de2+1020-0x21dd);if(IlllI ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:440:24: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ llIIIIlI(IlllI->IIIll);if(usb_lock_device_for_reset(IlllI->IIIll->lllll,NULL)>= ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c: In function ‘lllIIlIII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:822:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(usb_pipein(llIII->pipe))IlIlI->IIllI.IIlIII.llIIlI+=IlIlI->IIllI.lllIl;IlIlI ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:822:75: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(usb_pipein(llIII->pipe))IlIlI->IIllI.IIlIII.llIIlI+=IlIlI->IIllI.lllIl;IlIlI ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c: In function ‘lllIIlIlI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:863:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(unlikely(list_empty(&IlllI->lIllIl)))return NULL;llllIl=IlllI; ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:863:53: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(unlikely(list_empty(&IlllI->lIllIl)))return NULL;llllIl=IlllI; ^~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c: In function ‘IIllIlIl’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:944:56: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] usb_interface*interface=lIIIl->actconfig->interface[i];if(interface==NULL) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_stub.c:945:10: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ continue;if(interface->cur_altsetting==NULL)continue;Illll( ^~ CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_vbus.o CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_vstub.o /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_vstub.c: In function ‘IIIIIIllI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_vstub.c:94:47: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] ioctl){IIIIl lllllI;IIIIl devnum;IIIIl busnum;if(get_user(lllllI,&ioctl->IIIlIl. ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_vstub.c:95:44: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IlIIlIl)<(0x844+6933-0x2359))return-EFAULT;if(lllllI!=sizeof(struct llIlllIII)) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_vstub.c:95:44: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_vstub.c:96:15: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ return-EINVAL;IllIIllll(llllI,&busnum,&devnum);if(put_user(busnum,&ioctl->busnum ^~~~~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_vstub.c:96:48: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] return-EINVAL;IllIIllll(llllI,&busnum,&devnum);if(put_user(busnum,&ioctl->busnum ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_vstub.c:97:37: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ )<(0x37d+7528-0x20e5))return-EFAULT;if(put_user(devnum,&ioctl->devnum)< ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_vstub.c:97:37: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/minor_vstub.c:98:35: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ (0x201d+472-0x21f5))return-EFAULT;return(0x1ab8+2826-0x25c2);}long IIlIlIlll( ^~~~~~ CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.o /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c: In function ‘IlIIIlllI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:150:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(lIlIlIllI)usb_deregister(&lllIIIl);if(IIIIIIIl){IIlIIllI(IIIIIIIl);IIIIIIIl= ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:150:39: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(lIlIlIllI)usb_deregister(&lllIIIl);if(IIIIIIIl){IIlIIllI(IIIIIIIl);IIIIIIIl= ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c: In function ‘IlIIllII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:311:79: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] llllIIIlI[usb_pipeendpoint(pipe)]);}int IlIIllII(struct IIIlI*IIIll,int pipe){if ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:312:46: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ (!usb_pipeisoc(pipe))return(0xc56+926-0xff4);if(usb_pipein(pipe))return(--IIIll ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c: In function ‘lIllllIlI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:314:71: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] usb_pipeendpoint(pipe)]);}void lIllllIlI(struct IIIlI*IIIll,int pipe){if(! ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:315:27: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ usb_pipeisoc(pipe))return;if(usb_pipein(pipe))IIIll->llIlIlIll[usb_pipeendpoint( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c: In function ‘lllIIllI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:317:64: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] (0xec9+2604-0x18f5);}int lllIIllI(struct IIIlI*IIIll,int pipe){if(!usb_pipeisoc( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:318:34: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ pipe))return(0x1c0f+1419-0x219a);if(usb_pipein(pipe))return IIIll->IlIllIII[ ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c: In function ‘lIIIlIlI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:320:56: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] void lIIIlIlI(struct IIIlI*IIIll,int pipe,int lIlIlll){if(!usb_pipeisoc(pipe)) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:321:8: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ return;if(usb_pipein(pipe))IIIll->IlIllIII[usb_pipeendpoint(pipe)]=lIlIlll;else ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c: In function ‘lIIllIll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:383:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(llllIl->endpoint!=IllIlI->cur_altsetting->endpoint[i].desc.bEndpointAddress) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:384:10: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ continue;IlllIll=atomic_xchg(&llllIl->state,IIIlIll); ^~~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:385:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(IlllIll==IIIlIll||IlllIll==llIIlIIIl)continue;llllIl->IlIIIlI=IlIIIlI; ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:385:50: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(IlllIll==IIIlIll||IlllIll==llIIlIIIl)continue;llllIl->IlIIIlI=IlIIIlI; ^~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c: In function ‘IIlIlIIll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:408:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(llllIl->endpoint!=endpoint)continue;IlllIll=atomic_xchg(&llllIl->state, ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:408:40: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(llllIl->endpoint!=endpoint)continue;IlllIll=atomic_xchg(&llllIl->state, ^~~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c: In function ‘IIlIIllll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:431:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(llllIl==lIlIIII)continue;if(llllIl->IllIl==IllIl){if(atomic_xchg(&llllIl-> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/stub.c:431:29: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(llllIl==lIlIIII)continue;if(llllIl->IllIl==IllIl){if(atomic_xchg(&llllIl-> ^~ CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.o /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘lIIIlIIlI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:678:43: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] {int i;int lIIlllIII=(0x17af+3209-0x2438);if(!test_bit(HCD_FLAG_HW_ACCESSIBLE,& ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:679:21: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IlIII->flags))break;for(i=(0xb6d+1624-0x11c5);i<IlIlIll;i++){if(lIIII->lIlllI[i] ^~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘IlllIIIII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:812:68: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IlIllI(lIIII->lllIlIlI):NULL;spin_lock_irqsave(&lIIII->lock,flags);if(lIlIlIII) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:813:28: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ spin_lock(&lIlIlIII->lock);lIlII=-ENOENT;for(lIllI=(0xb35+1494-0x110b);lIllI< ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘lIlllllII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:871:36: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] ,lIllI);if(lIIII==NULL)return NULL;if(lIllI<=(0x6c4+7530-0x242e)||lIllI>IlIlIll) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:872:13: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ return NULL;lIllI--; ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘IIllIlIII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1024:79: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] static inline size_t IIllIlIII(struct urb*lIlll,void*IlIIl){int i;void*lIIlll;if ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1025:52: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ (!lIlll->transfer_buffer)return(0x277+6542-0x1c05);lIIlll=IlIIl;for(i= ^~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘lIIIIlIl’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1158:67: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] static inline int lIIIIlIl(struct urb*lIlll,void*IlIIl,int lIIlI){if(!lIIlI) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1159:26: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ return(0x154+1790-0x852);if(!lIlll->transfer_buffer)return-EINVAL;memcpy(lIlll-> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘IIIIlllI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1161:65: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] ,struct urb*lIlll,int lIIlI){if(!lIIlI)return(0x344+1434-0x8de);if(!lIlll-> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1162:31: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ transfer_buffer)return-EINVAL;memcpy(IlIIl,lIlll->transfer_buffer,lIIlI);return ^~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘IllIlllII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1163:75: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] lIIlI;}static inline int IllIlllII(struct urb*lIlll,void*IlIIl,int lIIlI){if(! ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1164:34: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ lIIlI)return(0x135a+4540-0x2516);if(!lIlll->setup_packet)return-EINVAL;memcpy( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘IIlIIlIII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1166:71: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IlIIl,struct urb*lIlll,int lIIlI){if(!lIIlI)return(0x483+6261-0x1cf8);if(!lIlll ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1167:30: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ ->setup_packet)return-EINVAL;memcpy(IlIIl,lIlll->setup_packet,lIIlI);return ^~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘llIIIIIll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1168:68: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] lIIlI;}static inline size_t llIIIIIll(void*IlIIl,struct urb*lIlll){if(!lIlll-> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1169:42: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ transfer_buffer)return(0x21c6+31-0x21e5);return lIIlllll(lIlll->iso_frame_desc, ^~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘IlIllIlII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1192:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(IIIIlllI((char*)IlIIl+IlIlI->lllII.llIIlI,lllIII->lIlll,lllIII->lIlll-> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1193:60: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ transfer_buffer_length)<(0x1ab8+2239-0x2377))return-EINVAL;IlIlI->lllII.llIIlI+= ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘IlllIlIIl’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1204:27: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] usb_pipeout(lIlll->pipe)){if(IIIIlllI((char*)IlIIl+lIIIIIl,lIlll,lIlll-> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1205:60: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ transfer_buffer_length)<(0x1109+2839-0x1c20))return-EINVAL;IlIlI->lllII.llIIlI+= ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘IlIlIIIIl’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1234:30: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(usb_pipeout(lIlll->pipe)){if(IIIIlllI((char*)IlIIl+lIIIIIl,lIlll,lIlll-> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1235:60: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ transfer_buffer_length)<(0x170f+3954-0x2681))return-EINVAL;IlIlI->lllII.llIIlI+= ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘IlllIIIll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1254:44: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] lllIIII=(0x1650+269-0x175d);}if(!IlIIIIIl){if(IIIIlllI((char*)IlIIl+lIIIIIl, ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1255:72: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ lIlll,lIlll->transfer_buffer_length)<(0x304+7299-0x1f87))return-EINVAL;IlIlI-> ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘lIIIIlllI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1287:73: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] );break;case PIPE_CONTROL:lIlII=IIlIIlIII(&llIllI,lIlll,sizeof(llIllI));if(lIlII ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1288:29: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ <(0x104d+1264-0x153d))break;if(lIlII!=sizeof(llIllI)){lIlII=-EINVAL;break;}if( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘llIIIllll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1337:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(usb_pipein(lIlll->pipe))llIlIllIl(lIlll,IlIlIIlll);return lIlII;}static ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1337:55: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(usb_pipein(lIlll->pipe))llIlIllIl(lIlll,IlIlIIlll);return lIlII;}static ^~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘IlllIII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1438:78: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IlIlllI);break;case IlIlllI:if(IIIIIl==IllIlIII)lllllIl(lIIII,lIllI,IIlllIl);if( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1439:47: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IIIIIl==llllIlll)lllllIl(lIIII,lIllI,llIlIIl);break;case llIlIIl:if(IIIIIl== ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1439:66: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IIIIIl==llllIlll)lllllIl(lIIII,lIllI,llIlIIl);break;case llIlIIl:if(IIIIIl== ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1440:39: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IllIlIII)lllllIl(lIIII,lIllI,IIlllIl);if(IIIIIl==IllIIlII)lllllIl(lIIII,lIllI, ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1441:78: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IlIlllI);if(IIIIIl==IIlIlIII)lllllIl(lIIII,lIllI,IlIllIl);break;case IlIllIl:if( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1442:47: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IIIIIl==IllIlIII)lllllIl(lIIII,lIllI,IIlllIl);if(IIIIIl==IllIIlII)lllllIl(lIIII, ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1443:65: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] lIllI,IlIlllI);if(IIIIIl==llllIlll)lllllIl(lIIII,lIllI,llIlIIl);if(IIIIIl== ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1444:42: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IlIIllllI)lllllIl(lIIII,lIllI,IIIIlllll);break;case IIIIlllll:if(IIIIIl== ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1444:63: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IlIIllllI)lllllIl(lIIII,lIllI,IIIIlllll);break;case IIIIlllll:if(IIIIIl== ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1445:39: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IllIlIII)lllllIl(lIIII,lIllI,IIlllIl);if(IIIIIl==IllIIlII)lllllIl(lIIII,lIllI, ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1446:59: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IlIlllI);if(IIIIIl==llllIlll)lllllIl(lIIII,lIllI,llIlIIl);if(IIIIIl==IIIlIIIIl|| ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1447:49: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IIIIIl==lIIIIIIII)lllllIl(lIIII,lIllI,llllIlIl);break;case llllIlIl:if(IIIIIl== ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1447:69: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IIIIIl==lIIIIIIII)lllllIl(lIIII,lIllI,llllIlIl);break;case llllIlIl:if(IIIIIl== ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1448:39: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IllIlIII)lllllIl(lIIII,lIllI,IIlllIl);if(IIIIIl==IllIIlII)lllllIl(lIIII,lIllI, ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1449:59: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IlIlllI);if(IIIIIl==llllIlll)lllllIl(lIIII,lIllI,llIlIIl);if(IIIIIl==IIlIlIII) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1450:30: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ lllllIl(lIIII,lIllI,IlIllIl);break;}}static inline int IllIIIlI(int speed){ ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘lllllIl’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1456:58: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] lIllI]=lIlllIl;lIIII->IIllllI[lIllI]=(0xb91+4595-0x1d84);if(lIIlIIIl==llIlIIl) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1457:45: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ lIIII->lIlllI[lIllI]|=USB_PORT_STAT_C_RESET;if(lIIlIIIl==llllIlIl)lIIII->lIlllI[ ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1463:63: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] ->llIIlII[lIllI]=USB_PORT_STAT_POWER|USB_PORT_STAT_CONNECTION;if(lIIlIIIl== ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1464:58: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IIlllIl)lIIII->lIlllI[lIllI]|=USB_PORT_STAT_C_CONNECTION;break;case llIlIIl: ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c: In function ‘IIlIIII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1518:78: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] IIlllIl);if(IIIIIl==llllIlll)IllIIIl(lIIII,lIllI,llIlIIl);break;case IIlllIl:if( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1519:48: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IIIIIl==IIIllllI)IllIIIl(lIIII,lIllI,IllIllII);if(IIIIIl==IllllIII)IllIIIl(lIIII ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1526:72: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] lIIII,lIllI,IllIllII);if(IIIIIl==IllIlIII)IllIIIl(lIIII,lIllI,IIlllIl);if(IIIIIl ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1527:41: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ ==llllIlll)IllIIIl(lIIII,lIllI,llIlIIl);if(IIIIIl==lllllIIl&&IIIlIlI== ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1545:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(IIIIIl==IIIllllI)IllIIIl(lIIII,lIllI,IllIllII);if(IIIIIl==IllIlIII)IllIIIl( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/vhci.c:1545:51: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(IIIIIl==IIIllllI)IllIIIl(lIIII,lIllI,IllIllII);if(IIIIIl==IllIlIII)IllIIIl( ^~ CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.o /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c: In function ‘IllIIIIII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:50:59: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] struct usb_host_config*IllIIIIII(struct usb_device*lIIIl){if(lIIIl->actconfig) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:51:25: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ return lIIIl->actconfig;if(lIIIl->descriptor.bNumConfigurations&&lIIIl->config) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:51:25: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:52:43: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ return&lIIIl->config[(0x1bef+325-0x1d34)];return NULL;} ^~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c: In function ‘llIIllllI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:55:23: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] (0x403+6893-0x1ef0)]){if(config->interface[(0x4e0+4873-0x17e9)]->cur_altsetting) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:56:63: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ return config->interface[(0x2a5+8023-0x21fc)]->cur_altsetting;if(config-> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c: In function ‘IlIlIIIlI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:90:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(lIIllIIl)*lIIllIIl=(0x95b+6752-0x23bb);if(llIIIlII)*llIIIlII= ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:90:43: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(lIIllIIl)*lIIllIIl=(0x95b+6752-0x23bb);if(llIIIlII)*llIIIlII= ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:93:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(lIIllIIl)*lIIllIIl=IlIll->desc.bInterfaceClass;if(llIIIlII)*llIIIlII=IlIll-> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:93:51: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(lIIllIIl)*lIIllIIl=IlIll->desc.bInterfaceClass;if(llIIIlII)*llIIIlII=IlIll-> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:97:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(lIIllIIl)*lIIllIIl=lIIIl->descriptor.bDeviceClass;if(llIIIlII)*llIIIlII=lIIIl ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:97:54: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(lIIllIIl)*lIIllIIl=lIIIl->descriptor.bDeviceClass;if(llIIIlII)*llIIIlII=lIIIl ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c: In function ‘llllllllI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:243:77: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] struct lIlIl*llllllllI(struct lIlIl*IlllI,gfp_t llIlI){struct lIlIl*IIIllII;if( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:245:13: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ return NULL;IIIllII=IllIlIl(IlllI->lllllI,llIlI);if(IIIllII){memset(IIIllII, ^~~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c: In function ‘lIIlllll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:346:69: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] unsigned int length=IllIIlll?IIllIIl->actual_length:IIllIIl->length;if(length&& ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/utils.c:348:36: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ memmove(IlIlIIIl,llIlIIIIl,length);IlIlIIIl+=length;lIlII+=length;IIllIIl++;} ^~~~~~~~ CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.o /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c: In function ‘IIIlIIllI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:34:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(lIlII<(0x170+960-0x530))break;llIII->lIlIIl[i]=IIIIlIl(lIIIIIll-> ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:34:34: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(lIlII<(0x170+960-0x530))break;llIII->lIlIIl[i]=IIIIlIl(lIIIIIll-> ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c: In function ‘lIIllIIlI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:102:76: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] );for(i=(0x165d+3850-0x2567),IIlIIl=(0x4f4+2159-0xd63);i<llIII->lIIlI;i++){if( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:103:43: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ llIII->status!=(0x1bfa+2173-0x2477))break;llIII->lIlIIl[i]->dev=llIII->llIIIl; ^~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c: In function ‘llllllIII’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:123:64: warning: this ‘for’ clause does not guard... [-Wmisleading-indentation] ,lIlII);return lIlII;}int llllllIII(struct lllIIl*llIII){int i;for(i= ^~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:124:70: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘for’ (0xff1+4197-0x2056);i<llIII->lIIlI;i++)usb_get_urb(llIII->lIlIIl[i]);return ^~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c: In function ‘IIIIllIll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:157:45: warning: this ‘for’ clause does not guard... [-Wmisleading-indentation] struct lllIIl*llIII,struct urb*lIlll){int i;for(i=(0x2d+3678-0xe8b);i<llIII-> ^~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:158:44: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘for’ lIIlI;i++)if(llIII->lIlIIl[i]==lIlll)break;return(i==llIII->lIIlI)?- ^~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c: In function ‘IIlIIlIll’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:167:78: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] "\x75\x73\x62\x64\x5f\x62\x63\x5f\x61\x6c\x6c\x6f\x63\x3a\x20\x2b\x2b" "\n");if( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:168:69: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ unlikely(IIIllIIl==(0xa79+4137-0x1aa2)))return-(0x1463+1030-0x1868);if(unlikely( ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:168:69: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:169:56: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ length==(0x116b+416-0x130b)))return-(0x10f+3195-0xd89);lllllllI=llIlIIII-( ^~~~~~~~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c: In function ‘llIIIlllI’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:206:68: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if((IIIlIIIl+IIIIlII[i].Length)>llIlIIII||IIIlIllI){size_t IlIIlll;if(IIIlIllI) ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/urb_chain.c:207:29: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ IIIlIIIl+=IIIIlII[i].Length;IlIIlll=min(IIIlIIIl,length);llIII->transfer_buffer[ ^~~~~~~ CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/sg.o CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/loader.o /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/loader.c: In function ‘IlIlllIl’: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/loader.c:141:1: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if(IlIll->dev.driver==NULL)continue;if(to_usb_driver(IlIll->dev.driver)!=& ^~ /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/loader.c:141:37: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if(IlIll->dev.driver==NULL)continue;if(to_usb_driver(IlIll->dev.driver)!=& ^~ CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/driver.o LD [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/tusbd.o Building modules, stage 2. MODPOST 1 modules CC /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/tusbd.mod.o LD [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/tusbd.ko make[1]: Leaving directory '/usr/src/linux-source-4.19.57-sunxi64' outdoorpi@orangepizero:~/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd$ Link to comment Share on other sites More sharing options...
Igor Posted August 16, 2019 Share Posted August 16, 2019 http://ix.io/1RTz No problems at all - perhaps you downloaded wrong sources? root@orangepizeroplus:~/usb-redirector-linux-arm64# ./installer.sh install *** Installing USB Redirector for Linux v3.8 *** Destination dir: /usr/local/usb-redirector *** Checking installation... *** Detecting system... *** distribution: debian *** kernel: 4.19.67-sunxi64 *** Compiling kernel module... *** Kernel module successfully compiled *** Creating directories... *** Preparing scripts... *** Copying files... *** Setting up init script... *** Starting daemon... *** Please allow incoming connections on 32032 port for USB Sever to be able to accept connections from remote clients. *** INSTALLATION SUCCESSFUL! To uninstall, run /usr/local/usb-redirector/uninstall.sh Operational: usbsrv -l ================= USB SERVER OPERATION SUCCESSFUL =============== List of local USB devices: 1: 802.11ac NIC Realtek Composite USB Device (s/n: 123456) Vid: 0bda Pid: b82c Port: 3-1 Status: plugged ===================== ======================= =================== Link to comment Share on other sites More sharing options...
sveni_lee Posted August 16, 2019 Author Share Posted August 16, 2019 will try later with arm64 maybe that will solf the problrm outdoorpi@orangepizero:~/usb-redirector-linux-arm64$ sudo ./installer.sh install-server [sudo] password for outdoorpi: *** Installing USB Redirector for Linux v3.8 *** Destination dir: /usr/local/usb-redirector *** Checking installation... *** Detecting system... *** distribution: debian *** kernel: 4.19.59-sunxi *** Cleaning up installation... *** *** INSTALLATION FAILED! ??? Kernel sources or kernel headers directory not found. Please install the corresponding package first. outdoorpi@orangepizero:~/usb-redirector-linux-arm64$ Link to comment Share on other sites More sharing options...
sveni_lee Posted August 16, 2019 Author Share Posted August 16, 2019 did not work for me... outdoorpi@orangepizero:~/usb-redirector-linux-arm64$ sudo ./installer.sh install-server [sudo] password for outdoorpi: *** Installing USB Redirector for Linux v3.8 *** Destination dir: /usr/local/usb-redirector *** Checking installation... *** Detecting system... *** distribution: debian *** kernel: 4.19.59-sunxi *** Compiling kernel module... *** Kernel module successfully compiled *** Creating directories... *** Preparing scripts... *** Copying files... *** Setting up init script... *** Starting daemon... *** Please allow incoming connections on 32032 port for USB Sever to be able to accept connections from remote clients. *** INSTALLATION SUCCESSFUL! To uninstall, run /usr/local/usb-redirector/uninstall.sh outdoorpi@orangepizero:~/usb-redirector-linux-arm64$ cd /usr/local/usb-redirector/bin/ outdoorpi@orangepizero:/usr/local/usb-redirector/bin$ usbsrv -l -bash: /usr/local/bin/usbsrv: cannot execute binary file: Exec format error outdoorpi@orangepizero:/usr/local/usb-redirector/bin$ sudo usbsrv -l /usr/local/bin/usbsrv: 3: /usr/local/bin/usbsrv: Syntax error: "(" unexpected outdoorpi@orangepizero:/usr/local/usb-redirector/bin$ Link to comment Share on other sites More sharing options...
drice Posted August 16, 2019 Share Posted August 16, 2019 Why are you compiling the arm64 version on Orange Pi Zero? Why did you use 64-bit kernel headers to compile the 32-bit version? I didn't notice at first you were using the wrong kernel headers. Orange Pi Zero is H2+ which is 32 bit. Link to comment Share on other sites More sharing options...
sveni_lee Posted August 17, 2019 Author Share Posted August 17, 2019 I installed the kernel-source and kernel-headers with ambian-config and used first the version usb-redirector-linux-armeb-gnueabihf.tar.gz but always run in the same error... So I really do not know what to next... Link to comment Share on other sites More sharing options...
drice Posted August 18, 2019 Share Posted August 18, 2019 On 8/16/2019 at 4:17 AM, sveni_lee said: KERNELDIR=/usr/src/linux-source-4.19.57-sunxi64 I don't know how you ended up with this version of the kernel source installed on the 32-bit Orange Pi Zero, but you should start over with everything and make sure that you use usb-redirector-linux-armeb-gnueabihf with 32-bit kernel source (i.e., KERNELDIR=/usr/src/linux-source-4.19.57-sunxi). Do not use arm64 usb-redirector and do not use sunxi64 kernel source. Do not randomly try different things. The combination I listed is the only combination that will work. If you don't have those items installed, you need to get the installed. You can't substitute other similar items for those. Link to comment Share on other sites More sharing options...
sveni_lee Posted August 18, 2019 Author Share Posted August 18, 2019 if I install Kernel via armbian-config it installs linux-source-4.19.57-sunxi64 Kernel source. So how can I get the right kernel.source? Link to comment Share on other sites More sharing options...
Werner Posted August 18, 2019 Share Posted August 18, 2019 Check your kernel version using uname -r Then install the proper source with apt install linux-source-4.19.62-next-sunxi (where 4.19.62 has to be replaced with your actual kernel version). Why armbian-config is installing 64bit kernel sources on a 32bit I cannot tell... Link to comment Share on other sites More sharing options...
sveni_lee Posted August 18, 2019 Author Share Posted August 18, 2019 thanks for that... outdoorpi@orangepizero:~$ uname -r 4.19.59-sunxi outdoorpi@orangepizero:~$ could not find kernel-source outdoorpi@orangepizero:~$ sudo apt install linux-source-4.19.59-next-sunxi Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package linux-source-4.19.59-next-sunxi E: Couldn't find any package by glob 'linux-source-4.19.59-next-sunxi' E: Couldn't find any package by regex 'linux-source-4.19.59-next-sunxi' outdoorpi@orangepizero:~$ Link to comment Share on other sites More sharing options...
Igor Posted August 18, 2019 Share Posted August 18, 2019 4 minutes ago, sveni_lee said: sudo apt install linux-source-4.19.59-next-sunxi https://apt.armbian.com/pool/main/l/ .59 does not exists and this is correct name: sudo apt install linux-source-4.19.63-next Link to comment Share on other sites More sharing options...
sveni_lee Posted August 18, 2019 Author Share Posted August 18, 2019 1 minute ago, Igor said: sudo apt install linux-source-4.19.63-next outdoorpi@orangepizero:~$ sudo apt install linux-source-4.19.63-next Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package linux-source-4.19.63-next E: Couldn't find any package by glob 'linux-source-4.19.63-next' E: Couldn't find any package by regex 'linux-source-4.19.63-next' outdoorpi@orangepizero:~$ has the same effect for me... or should I install by "hand"? Link to comment Share on other sites More sharing options...
Werner Posted August 18, 2019 Share Posted August 18, 2019 Someone else had this issue as well. For unknown reason there are no sources for images built around 4.19.59. Their solution was to downgrade to .57 as this kernel had provided sources. In any case the kernel you are actually running has to match the sources you are utilizing to build modules. So you may want to install these to packages: linux-source-4.19.62-next-sunxi linux-image-next-sunxi The linux-image-next-sunxi package by description currently containing a 4.19.62 image so it matches. I wonder that the board is still on .57. Did you ever do a standard apt update && apt upgrade? Link to comment Share on other sites More sharing options...
sveni_lee Posted August 18, 2019 Author Share Posted August 18, 2019 7 minutes ago, Werner said: So you may want to install these to packages: linux-source-4.19.62-next-sunxi linux-image-next-sunxi okay, would like to install those packages, but how can I update to this kernel? 8 minutes ago, Werner said: I wonder that the board is still on .57. Did you ever do a standard apt update && apt upgrade? yes but still on the same kernel... Link to comment Share on other sites More sharing options...
Werner Posted August 18, 2019 Share Posted August 18, 2019 When installing linux-image-next-sunxi apt will get rid of the .57 kernel and replace it with the .62 kernel. Reboot the board afterwards and you should see the effect. Link to comment Share on other sites More sharing options...
sveni_lee Posted August 18, 2019 Author Share Posted August 18, 2019 okay after reboot and sudo apt-get install linux-source-4.19.62-next-sunxi i got the right kernel-source outdoorpi@orangepizero:/usr/src$ ls -la total 409096 drwxrwxr-x 2 root root 4096 Aug 18 08:51 . drwxr-xr-x 10 root root 4096 Jul 15 08:50 .. -rw-rw-r-- 1 root root 418864896 Jul 31 20:02 linux-source-4.19.62-sunxi.tar.xz -rw-rw-r-- 1 root root 33776 Jul 31 20:02 linux-sunxi-next_4.19.62_5.92_config.xz outdoorpi@orangepizero:/usr/src$ so what next? only unpack the linux-source-4.19.62-sunxi.tar.xz or is there more to do? Link to comment Share on other sites More sharing options...
Werner Posted August 18, 2019 Share Posted August 18, 2019 Besides unpacking you may need to create a symlink called linux if the compiler does not find the sources by itself. Just give it a shot beforehand and if it does not work assuming the unpacked folder has the name below us this command inside /usr/src/ ln -s linux-source-4.19.62-sunxi linux Link to comment Share on other sites More sharing options...
sveni_lee Posted August 18, 2019 Author Share Posted August 18, 2019 I do not understand what I'm doing wrong. outdoorpi@orangepizero:/usr/src$ sudo ./installer.sh install-server sudo: ./installer.sh: command not found outdoorpi@orangepizero:/usr/src$ cd ~ outdoorpi@orangepizero:~$ cd usb-redirector-linux-armeb-gnueabihf/ outdoorpi@orangepizero:~/usb-redirector-linux-armeb-gnueabihf$ sudo ./installer.sh install-server *** Installing USB Redirector for Linux v3.8 *** Destination dir: /usr/local/usb-redirector *** Checking installation... *** Detecting system... *** distribution: debian *** kernel: 4.19.62-sunxi *** Compiling kernel module... *** Cleaning up installation... *** *** Installation failed! ??? Cannot compile kernel module. Installation terminated. See buildlog.txt file for more information. outdoorpi@orangepizero:~/usb-redirector-linux-armeb-gnueabihf$ buidlog.txt: make -C /usr/src/linux-source-4.19.62-sunxi M=/home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd modules make[1]: Entering directory '/usr/src/linux-source-4.19.62-sunxi' CC [M] /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/driver.o /bin/sh: 1: scripts/basic/fixdep: Exec format error make[2]: *** [scripts/Makefile.build:304: /home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/driver.o] Error 2 make[2]: *** Deleting file '/home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd/driver.o' make[1]: *** [Makefile:1517: _module_/home/outdoorpi/usb-redirector-linux-armeb-gnueabihf/files/modules/src/tusbd] Error 2 make[1]: Leaving directory '/usr/src/linux-source-4.19.62-sunxi' make: *** [Makefile:61: default] Error 2 Link to comment Share on other sites More sharing options...
Werner Posted August 18, 2019 Share Posted August 18, 2019 /bin/sh: 1: scripts/basic/fixdep: Exec format error I am actually not that deep in this, though I guess armhf and armeb are incompatible architectures... Link to comment Share on other sites More sharing options...
sveni_lee Posted August 18, 2019 Author Share Posted August 18, 2019 same without "eb"... make -C /usr/src/linux-source-4.19.62-sunxi M=/home/outdoorpi/usb-redirector-linux-arm-gnueabihf/files/modules/src/tusbd modules make[1]: Entering directory '/usr/src/linux-source-4.19.62-sunxi' CC [M] /home/outdoorpi/usb-redirector-linux-arm-gnueabihf/files/modules/src/tusbd/driver.o /bin/sh: 1: scripts/basic/fixdep: Exec format error make[2]: *** [scripts/Makefile.build:304: /home/outdoorpi/usb-redirector-linux-arm-gnueabihf/files/modules/src/tusbd/driver.o] Error 2 make[2]: *** Deleting file '/home/outdoorpi/usb-redirector-linux-arm-gnueabihf/files/modules/src/tusbd/driver.o' make[1]: *** [Makefile:1517: _module_/home/outdoorpi/usb-redirector-linux-arm-gnueabihf/files/modules/src/tusbd] Error 2 make[1]: Leaving directory '/usr/src/linux-source-4.19.62-sunxi' make: *** [Makefile:61: default] Error 2 Link to comment Share on other sites More sharing options...
drice Posted August 18, 2019 Share Posted August 18, 2019 3 hours ago, sveni_lee said: /bin/sh: 1: scripts/basic/fixdep: Exec format error You have seen this error before. Do you not remember? Look at post #2. Link to comment Share on other sites More sharing options...
sveni_lee Posted August 18, 2019 Author Share Posted August 18, 2019 yes but I used a other package of USB-Redirection... without usb-redirector-linux-arm-gnueabihf. but same error... Link to comment Share on other sites More sharing options...
drice Posted August 18, 2019 Share Posted August 18, 2019 Did you rebuild the scripts as shown in post #2? Are you sure it's the same error? Scripts must always be rebuilt when compiling natively because the kernel package is built on x86_64 so the binaries in that directory will be x86_64 format and must be rebuilt for execution on ARM. Link to comment Share on other sites More sharing options...
sveni_lee Posted August 19, 2019 Author Share Posted August 19, 2019 I did it again... outdoorpi@orangepizero:/usr/src/linux-source-4.19.62-sunxi$ sudo make clean [sudo] password for outdoorpi: outdoorpi@orangepizero:/usr/src/linux-source-4.19.62-sunxi$ sudo make scripts HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o YACC scripts/kconfig/zconf.tab.c LEX scripts/kconfig/zconf.lex.c HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf scripts/kconfig/conf --syncconfig Kconfig HOSTCC scripts/dtc/dtc.o HOSTCC scripts/dtc/flattree.o HOSTCC scripts/dtc/fstree.o HOSTCC scripts/dtc/data.o HOSTCC scripts/dtc/livetree.o HOSTCC scripts/dtc/treesource.o HOSTCC scripts/dtc/srcpos.o HOSTCC scripts/dtc/checks.o HOSTCC scripts/dtc/util.o LEX scripts/dtc/dtc-lexer.lex.c YACC scripts/dtc/dtc-parser.tab.h HOSTCC scripts/dtc/dtc-lexer.lex.o YACC scripts/dtc/dtc-parser.tab.c HOSTCC scripts/dtc/dtc-parser.tab.o HOSTLD scripts/dtc/dtc HOSTCC scripts/mod/mk_elfconfig CC scripts/mod/empty.o MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/modpost.o CC scripts/mod/devicetable-offsets.s HOSTCC scripts/mod/file2alias.o HOSTCC scripts/mod/sumversion.o HOSTLD scripts/mod/modpost HOSTCC scripts/selinux/genheaders/genheaders HOSTCC scripts/selinux/mdp/mdp HOSTCC scripts/bin2c HOSTCC scripts/kallsyms seems to be worked... I changed the installer.sh of usb-redirector-linux-arm-gnueabihf # KERNELDIR=/lib/modules/`uname -r`/build KERNELDIR=/usr/src/linux-source-4.19.62-sunxi start the installer.sh outdoorpi@orangepizero:~/usb-redirector-linux-arm-gnueabihf$ sudo ./installer.sh install-server *** Installing USB Redirector for Linux v3.8 *** Destination dir: /usr/local/usb-redirector *** Checking installation... *** Detecting system... *** distribution: debian *** kernel: 4.19.62-sunxi *** Compiling kernel module... *** Kernel module successfully compiled *** Creating directories... *** Preparing scripts... *** Copying files... *** Setting up init script... *** Starting daemon... *** Please allow incoming connections on 32032 port for USB Sever to be able to accept connections from remote clients. *** INSTALLATION SUCCESSFUL! To uninstall, run /usr/local/usb-redirector/uninstall.sh outdoorpi@orangepizero:~/usb-redirector-linux-arm-gnueabihf$ seems also to be worked. tried to start usb-redirector: outdoorpi@orangepizero:/usr/local/usb-redirector/bin$ sudo ./usbsrv -l ******************** ERROR *********************** Cannot connect to USB Redirector daemon. Please make sure usbsrvd is loaded. If the module is not loaded, please contact our support team. Error log can be found at /var/log/usbsrvd.log **************** **************** **************** outdoorpi@orangepizero:/usr/local/usb-redirector/bin$ /var/log/usbsrvd.log Aug 19, 2019 07:03:36 Daemon startup Aug 19, 2019 07:03:40 Daemon can not be started! Error 0 Module 0x0003 Line 24 Aug 19, 2019 07:03:40 Daemon shutdown Link to comment Share on other sites More sharing options...
