fips Posted June 29, 2015 Posted June 29, 2015 Hi, tried to find files for motd but /etc/motd is empty. Can you tell me where to configure motd? Thanks
Igor Posted June 29, 2015 Posted June 29, 2015 MOTD is generated within /etc/initd.d/armhwinfo while information bar below is generated within /etc/bash.bashrc.custom
ClockworkOrangePi Posted August 4, 2015 Posted August 4, 2015 MOTD is generated within /etc/initd.d/armhwinfo while information bar below is generated within /etc/bash.bashrc.custom I have associated question: while I login through SSH on OrangePi with Jessie onboard armhwinfo script is executed flawlessly. However, while login localy, directly to the machine, I am gettin "last login" message, then "Linux orangepi 3.4.108-orangepi #16 SMP PREMPT (...)" line and then the loand&temps line. It seems that locally the toilet banner is substituted with kernel info line. I've read that in Jessie ssh and local motds are separated. How can we change the local then? Thanks.
ClockworkOrangePi Posted August 5, 2015 Posted August 5, 2015 Well it's not a big deal so don't mind me - just wanted to correct a cosmetic thing...
dion Posted February 5, 2017 Posted February 5, 2017 Realise this is an old thread - but as it was one of the first results in Google for this topic, I thought I'd update it with my (rather blunt) solution. 1) The script that produces the hardware info is located in /etc/update-motd.d - and is named "30-sysinfo". Remove it (and if you like, the other scripts in there). 2) Edit /etc/pam.d/login and /etc/pam.d/ssh - comment out the line that reads "session optional pam_motd.so motd=/run/motd.dynamic" Result: Editing /etc/motd now does the right thing - and my system no longer hangs for 30 seconds upon login simply to produce a colour ASCII art banner that tells me what CPU I'm running and what IP I'm logging in from.
Igor Posted February 6, 2017 Posted February 6, 2017 Result: Editing /etc/motd now does the right thing - and my system no longer hangs for 30 seconds upon login simply to produce a colour ASCII art banner that tells me what CPU I'm running and what IP I'm logging in from. None of mentioned thing eats much time., login takes around 1-2 seconds on an fully booted system. Measured on old A20 board ... (only) when system still loads, this can takes 10s or more.
sooperior Posted February 6, 2017 Posted February 6, 2017 Realise this is an old thread - but as it was one of the first results in Google for this topic, I thought I'd update it with my (rather blunt) solution. 1) The script that produces the hardware info is located in /etc/update-motd.d - and is named "30-sysinfo". Remove it (and if you like, the other scripts in there). 2) Edit /etc/pam.d/login and /etc/pam.d/ssh - comment out the line that reads "session optional pam_motd.so motd=/run/motd.dynamic" Result: Editing /etc/motd now does the right thing - and my system no longer hangs for 30 seconds upon login simply to produce a colour ASCII art banner that tells me what CPU I'm running and what IP I'm logging in from. Alternatively, you can do chmod -x 30-sysinfo or any other script you want to disable. The effect is the same as removing but you keep the file in case you want it in the future
gnasch Posted February 6, 2017 Posted February 6, 2017 And waiting / hanging for 30s awfully smells like waiting for DNS to resolve something and running into a timeout. This does not happen here, please check. gnasch
