hoffi77 Posted September 26, 2019 Posted September 26, 2019 Hi, at first thank your for your great work! I've successfully created an wifi hotspot on nanopiM4 using "Armbian_5.95_Nanopim4_Debian_buster_default_4.4.190" with armbian-config utitlity. After the tool is finished I can connect to the hotspot and it shares the internet connection.. However - when I reboot the system the hotspot still works and I can connect but I have no connection to the internet anymore. The nonopi itself has connection to internet, I checked that. Do you have any sugestions? Thank you in andvance! Christian
Igor Posted September 26, 2019 Posted September 26, 2019 7 hours ago, hoffi77 said: Do you have any sugestions? Try running: iptables-restore /etc/iptables.ipv4.nat
hoffi77 Posted September 26, 2019 Author Posted September 26, 2019 Iptables with working internet connection root@nanopim4:~# iptables -S -v -P INPUT ACCEPT -c 569 45493 -P FORWARD ACCEPT -c 0 0 -P OUTPUT ACCEPT -c 427 43610 -A FORWARD -i eth0 -o wlan0 -m state --state RELATED,ESTABLISHED -c 0 0 -j ACCEPT -A FORWARD -i wlan0 -o eth0 -c 0 0 -j ACCEPT Iptables after reboot cho@nanopim4:~$ sudo iptables -S -v -P INPUT ACCEPT -c 7 376 -P FORWARD ACCEPT -c 0 0 -P OUTPUT ACCEPT -c 6 1024 But if I try iptables-restore /etc/iptables.ipv4.nat It gives me: root@nanopim4:~# iptables-restore /etc/iptables.ipv4.nat iptables-restore v1.8.2 (nf_tables): line 3: CHAIN_UPDATE failed (No such file or directory): chain PREROUTING line 4: CHAIN_UPDATE failed (No such file or directory): chain INPUT line 5: CHAIN_UPDATE failed (No such file or directory): chain POSTROUTING line 6: CHAIN_UPDATE failed (No such file or directory): chain OUTPUT And does not change the iptables :-/ The filecontents: root@nanopim4:~# cat /etc/iptables.ipv4.nat # Generated by xtables-save v1.8.2 on Thu Sep 26 16:51:01 2019 *nat :PREROUTING ACCEPT [0:0] :INPUT ACCEPT [0:0] :POSTROUTING ACCEPT [0:0] :OUTPUT ACCEPT [0:0] -A POSTROUTING -o eth0 -j MASQUERADE COMMIT # Completed on Thu Sep 26 16:51:01 2019 # Generated by xtables-save v1.8.2 on Thu Sep 26 16:51:01 2019 *filter :INPUT ACCEPT [0:0] :FORWARD ACCEPT [0:0] :OUTPUT ACCEPT [0:0] -A FORWARD -i eth0 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT -A FORWARD -i wlan0 -o eth0 -j ACCEPT COMMIT # Completed on Thu Sep 26 16:51:01 2019
Igor Posted September 26, 2019 Posted September 26, 2019 < fell out somewhere iptables-restore < /etc/iptables.ipv4.nat
hoffi77 Posted September 26, 2019 Author Posted September 26, 2019 Same :-/ cho@nanopim4:~$ sudo iptables-restore < /etc/iptables.ipv4.nat iptables-restore v1.8.2 (nf_tables): line 3: CHAIN_UPDATE failed (No such file or directory): chain PREROUTING line 4: CHAIN_UPDATE failed (No such file or directory): chain INPUT line 5: CHAIN_UPDATE failed (No such file or directory): chain POSTROUTING line 6: CHAIN_UPDATE failed (No such file or directory): chain OUTPUT
hoffi77 Posted September 26, 2019 Author Posted September 26, 2019 Got it! The kernel is using nftables already by default, had to go for legacy support: cho@nanopim4:~$ sudo update-alternatives --set iptables /usr/sbin/iptables-legacy update-alternatives: using /usr/sbin/iptables-legacy to provide /usr/sbin/iptables (iptables) in manual mode cho@nanopim4:~$ sudo iptables-restore < /etc/iptables.ipv4.nat cho@nanopim4:~$ sudo iptables -S -v -P INPUT ACCEPT -c 76 4801 -P FORWARD ACCEPT -c 0 0 -P OUTPUT ACCEPT -c 76 14496 -A FORWARD -i eth0 -o wlan0 -m state --state RELATED,ESTABLISHED -c 0 0 -j ACCEPT -A FORWARD -i wlan0 -o eth0 -c 0 0 -j ACCEPT It works now Thx!
