golfsmith Posted October 9, 2019 Posted October 9, 2019 Hi, I built Armbian (bionic) from source for Orange Pi PC 2 and everything went through fine. I burn to SD card and load it on the board and it boots well. Then I use "root" to login and forced to change password from default 1234 to somepass. Everything seemed fine until I tried to login with the new password (old password failed to work anymore). The errors are in following screen shot. Kinda new to this stuff, not sure how to fix it. Tried to connect to serial port but somehow a couple of TTL cable all failed to work. Still struggling. Please help!
062621AM Posted October 9, 2019 Posted October 9, 2019 Did you create new user? Can try login the new user? Possible that you enabled Caps Lock when you set new password?
Igor Posted October 9, 2019 Posted October 9, 2019 Exec format error on those files is not normal. Either file system or your build is corrupted or its failed SD card.
golfsmith Posted October 15, 2019 Author Posted October 15, 2019 I have been playing with it and still no luck. Now I have a even more weird problem. To summarize what I did in the following: 1. Started off with the log in problem as stated in the question, I then went ahead to download the official Ubuntu build for PC2 and I don't even see the out put to monitor. The monitor has no output. Originally I thought it would be my monitor problem as this is a different one I used. 2. Then I took the PC2 (and a Prime) to the monitor that used to work (just can not log in) and weird enough that there is no output. So I thought maybe the official build does not work, then I switched to use the SD card from my own build (use to book fine just not able to log in) and it didn't show anything either. 3. Then I used the SD card used to boot fine for both PC2 and Prime, both failed to display anything on the monitor. So now I got stuck at using both official images and my own built images for both PC2 and Prime, non works. I am intrigued There must be something very basic I have missed. Any suggestions what to do next?
Igor Posted October 15, 2019 Posted October 15, 2019 On 10/9/2019 at 6:36 AM, golfsmith said: Tried to connect to serial port but somehow a couple of TTL cable all failed to work. You will get nowhere without serial console. This possible error shows something on the screen if at least boot loader is read from the card.
