Building 4.19.y kernel for Tinkerboard
I'm trying to build 4.19 kernel modules for Tinkerboard with Armbian's build script (https://github.com/armbian/build).
But when I chose the board 'Tinkerboard' from the Armbian building script CUI menu, the output ko files were all built for 4.4.
How can I create 4.19 ko files for Tinkerboard?
I tried to put userpatches/lib.config in order to overwrite KERNELBRANCH with tag:v4.19.y but not luck.
The error was shown below:
[ o.k. ] Using config file [ /vagrant/userpatches/config-example.conf ]
[ o.k. ] Preparing [ host ]
[ o.k. ] Build host OS release [ bionic ]
[ o.k. ] Syncing clock [ host ]
[ o.k. ] Checking for external GCC compilers
(snip)
grep: Makefile: No such file or directory
sed: can't read Makefile: No such file or directory
grep: /home/ubuntu/armbian/cache/sources/linux-rockchip/v4.19.y/Makefile: No such file or directory
[ .... ] Compressing sources for the linux-source package
 570KiB [ 264MiB/s] [======================================================================================>                          ] 77%
cp: cannot stat 'COPYING': No such file or directory
[ o.k. ] Compiling default kernel [ 0 ]
[ o.k. ] Compiler version [ arm-linux-gnueabihf-gcc 7.4.1 ]
[ o.k. ] Using kernel config file [ config/kernel/linux-rockchip-default.config ]
make: *** No rule to make target 'oldconfig'.  Stop.
make: *** No rule to make target 'menuconfig'.  Stop.
[ o.k. ] Exporting new kernel config [ /home/ubuntu/armbian/output/config/linux-rockchip-default.config ]
[ error ] ERROR in function compile_kernel [ compilation.sh:382 ]
[ error ] Kernel was not built [ @host ]
[ o.k. ] Process terminated
Any suggestions/helps are appreciated.
Thanks.
Edited by daisuke
7 hours ago, Werner said:
How did you get your board on Linux 4.19.x if the build script offers you 4.4?
https://github.com/armbian/build/blob/master/config/sources/rockchip.conf#L32
NEXT kernel is 4.19.y but you have to choose it when building.
1. Start from clean unchanged build
2. After you select Tinkerboard select "NEXT"
Edit: Vagrant? https://github.com/armbian/build/issues/1599
