zanzibar Posted October 24, 2019 Posted October 24, 2019 Hello, I am using up to date Armbian - Debian Buster with Armbian Linux 4.19.69-meson64 Linux version 4.19.69-meson64 (root@builder) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.95 SMP PREEMPT Mon Sep 2 01:21:39 CEST 2019. I have encountered Ethernet interface lockup on medium traffic (after 30s-120s when copying big files from external usb disk by sshfs - 240Mb/s). At high/medium Ethernet traffic the issue always occurs. It is most likely caused by some kernel update because I didn't have such problem before. Similar issue: https://github.com/rockchip-linux/kernel/issues/27 [ 1584.165514] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: discard [ 1689.827553] ------------[ cut here ]------------ [ 1689.827600] NETDEV WATCHDOG: eth0 (meson8b-dwmac): transmit queue 0 timed out [ 1689.827721] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:461 dev_watchdog+0x2b4/0x2c0 [ 1689.827736] Modules linked in: uas nf_log_ipv4 nf_log_common nft_limit xt_tcpudp xt_multiport xt_LOG xt_limit xt_conntrack nft_counter nft_chain_nat_ipv4 ipt_MASQUERADE nf_nat_ipv4 nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nft_compat nf_tables nfnetlink meson_rng rng_core scpi_hwmon meson_gxbb_wdt ip_tables x_tables realtek [ 1689.827866] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.19.69-meson64 #5.95 [ 1689.827871] Hardware name: Hardkernel ODROID-C2 (DT) [ 1689.827881] pstate: 20000005 (nzCv daif -PAN -UAO) [ 1689.827892] pc : dev_watchdog+0x2b4/0x2c0 [ 1689.827901] lr : dev_watchdog+0x2b4/0x2c0 [ 1689.827906] sp : ffff000008003da0 [ 1689.827912] x29: ffff000008003da0 x28: 0000000000000005 [ 1689.827926] x27: 0000000000000020 x26: 00000000ffffffff [ 1689.827939] x25: 0000000000000140 x24: ffff800071250480 [ 1689.827952] x23: ffff80007125045c x22: ffff800070ca5940 [ 1689.827965] x21: ffff000008e77000 x20: ffff800071250000 [ 1689.827978] x19: 0000000000000000 x18: ffffffffffffffff [ 1689.827991] x17: 0000000000000000 x16: 0000000000000000 [ 1689.828004] x15: ffff000008e93000 x14: 00000000fffffff0 [ 1689.828017] x13: ffff000008f2786a x12: ffff000008e93000 [ 1689.828030] x11: 0000000000000000 x10: ffff000008f26000 [ 1689.828043] x9 : 0000000000000000 x8 : 0000000000000001 [ 1689.828055] x7 : 0000000000000000 x6 : 0000000000000123 [ 1689.828068] x5 : 0000000000000000 x4 : 0000000000000001 [ 1689.828080] x3 : 0000000000000000 x2 : ffff000008e7c358 [ 1689.828093] x1 : 2481295eb9750900 x0 : 0000000000000000 [ 1689.828105] Call trace: [ 1689.828117] dev_watchdog+0x2b4/0x2c0 [ 1689.828131] call_timer_fn+0x20/0x78 [ 1689.828143] expire_timers+0xa4/0xb0 [ 1689.828154] run_timer_softirq+0xe4/0x1a0 [ 1689.828164] __do_softirq+0x10c/0x200 [ 1689.828174] irq_exit+0xac/0xc0 [ 1689.828186] __handle_domain_irq+0x60/0xb0 [ 1689.828194] gic_handle_irq+0x58/0xa8 [ 1689.828201] el1_irq+0xb0/0x128 [ 1689.828212] arch_cpu_idle+0x10/0x18 [ 1689.828220] do_idle+0x1d4/0x298 [ 1689.828229] cpu_startup_entry+0x20/0x28 [ 1689.828243] rest_init+0xcc/0xd8 [ 1689.828256] start_kernel+0x3d4/0x400 [ 1689.828269] ---[ end trace b79bbf67547ae10f ]--- [ 1689.828334] meson8b-dwmac c9410000.ethernet eth0: Reset adapter. [ 1689.909766] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=37) [ 1689.922902] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found [ 1689.922925] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW [ 1693.046757] meson8b-dwmac c9410000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [ 1737.955616] meson8b-dwmac c9410000.ethernet eth0: Reset adapter. [ 1738.037764] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=37) [ 1738.050715] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found [ 1738.050737] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW [ 1741.822114] meson8b-dwmac c9410000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
matt407 Posted October 25, 2019 Posted October 25, 2019 I see this behaviour with 4.19.69-meson64, too. Switched back to 4.19.57-meson64.
matt407 Posted November 27, 2019 Posted November 27, 2019 Does anyone see this behavior on Kernel 5.3x?
guidol Posted November 27, 2019 Posted November 27, 2019 Hmmm. I dont use sshfs - but samba/cifs and I copied -rwxrwxrwx 1 root root 1031158598 Nov 12 2015 Starfighter.mp4 from my video-share [ 6151.533916] CIFS: Attempting to mount //192.168.6.xxx/video without any errors to the local sdcard. I did compile today the following current version: Armbian Buster with Linux 5.3.13-meson64 package bsp-kernel[19.11.3] u-boot[19.11.3] dtb[19.11.3] firmware[19.11.3] config[19.11.3] branch[current] 1
matt407 Posted November 30, 2019 Posted November 30, 2019 Thank you, 5.3.11-meson64 runs fine for two days now!
guidol Posted December 1, 2019 Posted December 1, 2019 compiled today Armbian_19.11.3_Odroidc2_buster_dev_5.4.1.img and it does boot and doesnt hang/timeout at a 350MB cifs/samba copy Now in test as a second Pihole. armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/23hZ
zanzibar Posted December 1, 2019 Author Posted December 1, 2019 Issue fixed with Armbian (19.11.3) and kernel upgrade to 5.3.11. 1
