Armbianmonitor:
Hi everyone,
My name is Gabriel and I am a new person in the community.
After installing ARMBIAN (Armbian_5.91_Clearfogbase_Debian_stretch_default_4.14.135) with the Mini PCI Express Marvel 88SE9215, I got a problem with my Clearfog Pro-A1 revision-2.1. It did not work properly like 88SE9215 did not show me my disks. My Idea is to deploy my NAS server with OMV.
I tried to compile the kernel so many times with different modules like SATA, PATA, and AHCI but it did not work also. I guess that my u-boot is not setup properly because I was reading a couple post about it and it’s working to everyone.
Someone can give me a favor pls and tell me your ideas to try to solve that problem
Thanks.
Logs:
Armbianmonitor:  http://ix.io/201C
root@clearfogbase:~# lspci
00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6828 (rev 0a)
00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6828 (rev 0a)
02:00.0 SATA controller: Marvell Technology Group Ltd. Device 9215 (rev 11)
root@clearfogbase:~# lspci -nv
00:02.0 0604: 11ab:6828 (rev 0a) (prog-if 00 [Normal decode])
        Flags: fast devsel
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        Prefetchable memory behind bridge: 00000000-000fffff
        Capabilities: [40] Express Root Port (Slot+), MSI 00
        Capabilities: [100] Advanced Error Reporting
00:03.0 0604: 11ab:6828 (rev 0a) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        I/O behind bridge: 00010000-00010fff
        Memory behind bridge: e0000000-e00fffff
02:00.0 0106: 1b4b:9215 (rev 11) (prog-if 01 [AHCI 1.0])
        Subsystem: 1b4b:9215
        Flags: bus master, fast devsel, latency 0, IRQ 53
        I/O ports at 10020
  I/O ports at 10030
        I/O ports at 10028
        I/O ports at 10034
        I/O ports at 10000
        Memory at e0040000 (32-bit, non-prefetchable)
        Expansion ROM at e0000000
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [70] Express Legacy Endpoint, MSI 00
        Capabilities: [e0] SATA HBA v0.0
        Kernel driver in use: ahci
Booting from Clearfog
U-Boot SPL 2018.01-02337-gdc4398fdb8 (May 14 2018 - 19:03:16)
High speed PHY - Version: 2.0
Detected Device ID 6828
board SerDes lanes topology details:
 | Lane #  | Speed |  Type       |
 |   0    |  3   |  SATA0       |
 |   1    |  0   |  SGMII1      |
 |   2    |  5   |  PCIe1       |
 |   3    |  5   |  USB3 HOST1  |
 |   4    |  5   |  PCIe2       |
 |   5    |  0   |  SGMII2      |
PCIe, Idx 1: detected no link
PCIe, Idx 2: detected no link
High speed PHY - Ended Successfully
DDR3 Training Sequence - Ver TIP-1.29.0
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
Trying to boot from SPI
U-Boot 2018.01-02337-gdc4398fdb8 (May 14 2018 - 19:03:16 +0200), Build: jenkins-u-boot-clearfog-model=pro,variant=spi-10
SoC:   MV88F6828-?? (a) at 1600 MHz
DRAM:  1 GiB (800 MHz, 32-bit, ECC not enabled)
MMC:   mv_sdh: 0
SF: Detected w25q32bv with page size 256 Bytes, erase size 4 KiB, total 4 MiB
Model: SolidRun Clearfog
Board: SolidRun ClearFog Pro
SCSI:  SATA link 0 timeout.
AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
Net:   eth1: ethernet@70000, eth2: ethernet@30000, eth3: ethernet@34000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0(part 0) is current device
** No partition table - mmc 0 **
starting USB...
USB0:   Register 2000120 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
Device 0: device type unknown
... is now current device
** Bad device usb 0 **
scanning bus for devices...
Found 0 device(s).
Hey
there are multiple things you need to check.
Are you using Clearfog Pro or Base? In the title you write Pro but from the Logs it looks like you are using a Base image. This might cause problems.
Apart from that check the position of the mPCIe card vs. the kernel and uboot you are using. Use this table as a guide: https://docs.google.com/spreadsheets/d/1VggzrfFibH0cmpSGW2FyoJW-d936Y2amwwKutUwX4-8/edit#gid=0
Greetings,
count-doku
This is not our boot loader. You need updated one and did you try with kernel 4.19.y?
