Why do you say that H3 doesn't support device tree yet ?
It does, but not using Legacy !
But maybe you mean it doesn't support "overlays" yet ...
I plug the GPS module PPS output to OPiOne's GPIO pin PG09,
modify fex file to release PG09 from GPIO,
and then run gpsd,  PPS worked!
It's very strange, no any device tree setup.
modify fex file like this:
[uart1]
uart_used = 1
uart_port = 1
# 2 for 2-wire
uart_type = 2
uart_tx = port:PG06<2><1><default><default>
uart_rx = port:PG07<2><1><default><default>
[gpio_para]
gpio_used = 1
gpio_num = 16
#gpio_pin_17 = port:PG09<0><default><default><0>
#for UART1
#gpio_pin_18 = port:PG06<1><default><default><default>
#gpio_pin_19 = port:PG07<1><default><default><default>
Wow :)
What is then the algorithm counting pins?
PA = 0
PB = 1
PC = 2
PD = 3
PE = 4
PF = 5
PG = 6
Physical pin 18 this PC07 pin H3
PC07 = 32*2 + 7 = 71
This is the correct understanding?
  On 9/7/2016 at 5:36 AM, StaLeWaR said:
Wow :)
PA = 0
PB = 1
PC = 2
PD = 3
PE = 4
PF = 5
PG = 6
Yeah, you're so smart .
