Skip to content
View in the app
Armbian Community Forums
Replace the kernel to the custom compiled kernel
Featured Replies
First of all sorry for the newbie's question.
I compiled a kernel with custom configuration to use this instruction: https://docs.armbian.com/Developer-Guide_Build-Preparation/
OS: Ubuntu Bionic 18.04 x64
apt -y install git
git clone https://github.com/armbian/build
cd build
./compile.sh \
BOARD=orangepizero \
BRANCH=default \
BUILD_DESKTOP=no \
KERNEL_ONLY=yes \
KERNEL_CONFIGURE=yes
After the kernel build is complete, the output directory contains
output/config
linux-sun8i-default.config
output/debs
/extra
armbian-config_5.99_all.deb
armbian-firmware-full_5.99_all.deb
armbian-firmware_5.99_all.deb
linux-headers-sun8i_5.99_armhf.deb
linux-image-sun8i_5.99_armhf.deb
linux-source-default-sun8i_5.99_all.deb
linux-u-boot-orangepizero_5.99_armhf.deb
Copied to the device this files
Executed
sudo dpkg -i linux-headers-sun8i_5.99_armhf.deb
sudo dpkg -i linux-image-sun8i_5.99_armhf.deb
The kernel hasn't changed.
Could you explain how to replace the kernel on the device, please?
Thank you very much for your reply.
  • Author
4 hours ago, Igor said:
what have you changed?
I tried to compile kernel with following configuration: https://criu.org/Linux_kernel
General setup options
CONFIG_CHECKPOINT_RESTORE=y (Checkpoint/restore support)
Networking support -> Networking options options for sock-diag subsystem
CONFIG_UNIX_DIAG=y (Unix domain sockets -> UNIX: socket monitoring interface)
CONFIG_INET_DIAG=y (TCP/IP networking -> INET: socket monitoring interface)
CONFIG_INET_UDP_DIAG=y (TCP/IP networking -> INET: socket monitoring interface -> UDP: socket monitoring interface)
CONFIG_NETFILTER_XT_MARK=y (Networking support -> Networking options -> Network packet filtering framework (Netfilter)   -> Core Netfilter Configuration -> Netfilter Xtables support (required for ip_tables)
  -> nfmark target and match support)
CONFIG_TUN=y (Device Driver -> Network device support -> Universal TUN/TAP device driver support)
7 hours ago, Qwalcon said:
BRANCH=default \
The problem might be here. Branch default is legacy kernel version 3.4.y which is EOL. Features which you need might not be supported and we are also officially ditching it next week.
NEXT is 4.19.y which will be upgraded to 5.3.y soon.
  • Author
Thank you very much for you answer.
I choose NEXT. The kernel was replaced.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
