aaditya Posted November 24, 2019 Posted November 24, 2019 Hi, Tested the current build (Armbian_19.11.3_Rockpi-4b_buster_current_5.3.11_desktop.7z) on a Rock Pi 4 v1.3. Working well so far the past couple of hours. Its an amazing feeling to be able to run the mainline kernel with so little issues. Some minor things: The Red Led keeps on blinking with this build. Earlier it only blinked if there was error while booting. New to this board, so this maybe incorrect. I booted up Radxa image and there also red light was blinking. Sound via 3.5 mm jack not working. Inserted earphone, no output. Sound via HDMI works. Thanks for your work. Edit- System info: aaditya@rockpi:~$ inxi -Fxz System: Host: rockpi Kernel: 5.3.11-rockchip64 aarch64 bits: 64 compiler: gcc v: 8.3.0 Desktop: Xfce 4.12.4 Distro: Armbian GNU/Linux 10 (buster) Machine: Type: ARM Device System: Radxa ROCK Pi 4 details: N/A serial: <filter> CPU: Topology: 6-Core (2-Die) model: N/A variant-1: cortex-a53 variant-2: cortex-a72 bits: 64 type: MCP MCM arch: ARMv8 rev: 4 features: Use -f option to see features bogomips: 0 Speed: 1800 MHz min/max: 408/1512:2016 MHz Core speeds (MHz): 1: 408 2: 408 3: 408 4: 408 5: 1800 6: 1800 Graphics: Device-1: display-subsystem driver: rockchip_drm v: N/A bus ID: N/A Device-2: rk3399-dw-hdmi driver: dwhdmi_rockchip v: N/A bus ID: N/A Device-3: rk3399-mali driver: panfrost v: kernel bus ID: N/A Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev resolution: 1920x1080~60Hz OpenGL: renderer: llvmpipe (LLVM 7.0 128 bits) v: 3.3 Mesa 18.3.6 direct render: Yes Audio: Device-1: rk3399-dw-hdmi driver: dwhdmi_rockchip bus ID: N/A Device-2: simple-audio-card driver: asoc_simple_card bus ID: N/A Sound Server: ALSA v: k5.3.11-rockchip64 Network: Device-1: rk3399-gmac driver: rk_gmac_dwmac v: N/A port: N/A bus ID: N/A IF: eth0 state: down mac: <filter> IF-ID-1: dummy0 state: down mac: <filter> IF-ID-2: wlan0 state: up mac: <filter> Drives: Local Storage: total: 44.52 GiB used: 15.60 GiB (35.1%) ID-1: /dev/mmcblk1 model: EB1QT size: 29.81 GiB ID-2: /dev/sda type: USB vendor: Transcend model: JetFlash Transcend 16GB size: 14.70 GiB Partition: ID-1: / size: 28.98 GiB used: 3.16 GiB (10.9%) fs: ext4 dev: /dev/mmcblk1p1 ID-2: /var/log size: 48.4 MiB used: 4.2 MiB (8.6%) fs: ext4 dev: /dev/zram0 Sensors: Missing: Required tool sensors not installed. Check --recommends Info: Processes: 183 Uptime: 6m Memory: 3.78 GiB used: 534.1 MiB (13.8%) Init: systemd Compilers: gcc: 8.3.0 Shell: bash v: 5.0.3 inxi: 3.0.32 dmesg attached. dmesg-armbian-buster-current-rockpi4.txt
mo123 Posted November 25, 2019 Posted November 25, 2019 Check if this patch is missing from the mainline kernel perhaps, it's responsible for the headphone jack. https://github.com/radxa/kernel/commit/cc4fef39f29bda97ba1d9129d897e77d08ccf096
aaditya Posted November 25, 2019 Author Posted November 25, 2019 1 hour ago, mo123 said: Check if this patch is missing from the mainline kernel perhaps, it's responsible for the headphone jack. https://github.com/radxa/kernel/commit/cc4fef39f29bda97ba1d9129d897e77d08ccf096 Hi mo123, Thanks for the comment. Indeed, in the mainline kernel the above code is not present. There are some other changes too, related to i2s0 in the Radxa kernel which are not present in mainline. Radxa (4.4): https://github.com/radxa/kernel/blob/cc4fef39f29bda97ba1d9129d897e77d08ccf096/arch/arm64/boot/dts/rockchip/rockpi-4b-linux.dts Mainline(5.3): https://github.com/torvalds/linux/blob/549dcdafe793000fbe38914a1f231d3c6034a6ec/arch/arm64/boot/dts/rockchip/rk3399-rock-pi-4.dts
serge.lenz Posted December 8, 2019 Posted December 8, 2019 Hello, Can somebody help me to boot Armbian with mainline kernel on Rock Pi 4B v1.3? I tried several Armbian images but noone boots. The Radxa Linux images is working without problem. So downloaded Armbian_19.11.3_Rockpi-4b_buster_current_5.3.11_desktop.7z and extracted .img. Then using dd I write it on SD card (I use USB cardreader so device is /dev/sdd). dd if=Armbian_19.11.3_Rockpi-4b_buster_current_5.3.11_desktop.img of=/dev/sdd bs=1M sync sync I have connected serial console and this is last lines of output: - cut - Boot1: 2018-04-08, version: 1.12 CPUId = 0x0 ChipType = 0x10, 219 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=29600MB FwPartOffset=2000 , 100000 mmc0:cmd5,32 SdmmcInit=0 0 BootCapSize=0 UserCapSize=30528MB FwPartOffset=2000 , 0 StorageInit ok = 183254 LoadTrustBL Addr:0x4000 No find trust.img! LoadTrustBL error:-3 LoadTrustBL No find bl30.bin Load uboot, ReadLba = 2000 hdr 00000000031907e0 + 0x0:0x50,0x41,0x52,0x4d,0x50,0x01,0x00,0x00,0x46,0x49,0x52,0x4d,0x57,0x41,0x52,0x45, Load OK, addr=0x200000, size=0xa6f2c RunBL31 0x10000 NOTICE: BL31: v1.3(debug):65aa5ce NOTICE: BL31: Built : 10:47:37, Jun 19 2018 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1151): pd status 3e INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64) INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2 INF [0x0] TEE-CORE:init_teecore:83: teecore inits done INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2014.10-RK3399-06-03326-g0212c98-dirty (Nov 03 2018 - 14:00:25) CPU: rk3399 cpu version = 0 CPU's clock information: aplll = 816000000HZ apllb = 24000000HZ gpll = 800000000HZ aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ cpll = 800000000HZ dpll = 800000000HZ vpll = 24000000HZ npll = 24000000HZ ppll = 676000000HZ Board: Rockchip platform Board Uboot as second level loader DRAM: Found dram banks: 1 Adding bank:0000000000200000(00000000ffe00000) Reserve memory for trust os. dram reserve bank: base = 0x08400000, size = 0x01e00000 128 MiB SdmmcInit = 0 0 SDCard Update. storage init OK! Using default environment GetParam W: Invalid Parameter's tag (0x00000000)! Invalid parameter No pmic detect. CPU's clock information: aplll = 816000000HZ apllb = 24000000HZ gpll = 800000000HZ aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ cpll = 800000000HZ dpll = 800000000HZ vpll = 24000000HZ npll = 24000000HZ ppll = 676000000HZ misc partition not found! SecureBootEn = 0, SecureBootLock = 0 #Boot ver: 0000-00-00#0.00 empty serial no. normal boot. no fuel gauge found no fuel gauge found read logo on state from dts [0] no fuel gauge found 'recovery' does not seem to be a partition nor an address Unable to boot:recovery try to start backup 'backup' does not seem to be a partition nor an address Unable to boot:backup try to start rockusb - cut - Kernel not even started. One thing: I have eMMC module installed but it empty now, may be its important? What I can do to boot it?
Igor Posted December 9, 2019 Posted December 9, 2019 7 hours ago, serge.lenz said: may be its important? You are not booting Armbian but your "empty" eMMC. Remove it for now. 1
