Adrian Cable Posted July 28, 2021 Posted July 28, 2021 14 minutes ago, Igor said: Put few thousands on our account if you have such ideas or hire someone to get you that information. We have shared all we know - we always do that. To get a better information, to find a bug, additional time has to be lost. Perhaps a day is enough, perhaps a week wont. And we have other, much more important things to do. We would improve this service, but you don't care so ... @Igor - I have just put a few thousands on your account. Can I therefore kindly a request a withdrawal of the "you don't care" part of the above? Thank you. 1 Quote
Igor Posted July 28, 2021 Posted July 28, 2021 20 minutes ago, Adrian Cable said: Thank you. Likewise! 0 Quote
Adrian Cable Posted July 28, 2021 Posted July 28, 2021 2 minutes ago, Igor said: Likewise! You are (very genuinely) welcome! 1 Quote
lpirl Posted January 7, 2022 Posted January 7, 2022 For those who end up here via search engines: On a NanoPI M4V2 (RK3399) I activated the `tuned` profile "latency-performance" for my use case without the intention to address this issue. Thus, by coincidence, I recognized that the issue apparently disappeared (or got a lot less frequent, at least, since it hasn't appeared in the last 12 hours). I don't have the time/priority to track down which of the settings actually helped but it should be the governor or cstate settings. 0 Quote
geckow Posted August 31, 2022 Posted August 31, 2022 Thank you @lpirlfor your tip, unfortunately it did not work on my Orange Pi PC (H3 CPU), running Armbian 22.05.1 Bullseye with Linux 5.15.43-sunxi. Here is what I tried (as root) : apt install tuned tuned-utils tuned-utils-systemtap tuned-adm profile latency-performance reboot It happens since I changed my ISP (and the router they provide). I tried all ethernet ports, but unfortunately nothing worked @guidolwas right, I will try to put a switch between the router and the OPi to see if it gets better! 0 Quote
serg_stetsuk Posted January 4, 2023 Posted January 4, 2023 Hi All. I have nanopi-neo with exactly the same problem. What I've found is that link may be established if i turn off autonegotiation on my PC and force 10Half mode. However it is still not fully functional. I can seed Rx packets are growing as well as Tx packets. But there are no packets actually transmitted (checked with wireshark on PC). I can experiment. Can anyone suggest what should I try to troubleshoot? 0 Quote
kbhuinfo Posted January 21, 2023 Posted January 21, 2023 On an orange pi one I notice the same regularly: │Jan 21 15:50:25 a-m kernel: [ 1757.658898] dwmac-sun8i 1c30000.ethernet eth0: Link is Down │ │Jan 21 15:50:27 a-m NetworkManager[1119]: <info> [1674312627.1444] device (eth0): carrier: link connected ... I can test with multiple samples. 0 Quote
Dav Posted May 21, 2024 Posted May 21, 2024 Hi there. I have a Pine A64(+) board (https://pine64.org/documentation/Pine_A64/) I have been experiencing this issue since last year. I updated the SO (armbian version + kernel) several times and it didn't resolve the issue. It happens randomly. The CPU and storage are not overheated (30º C each) and I tested all physical components (board, ethernet wire, switch, ...) ambianmonitor -u -> https://paste.armbian.com/arozepuxen Things I tested for now: - Daily reboot. Sometimes eth0 is not wake up after boot and I have to physically power-toggle the board. - Stay on latest raspbian release (24.2.1) + latest kernel (6.6.16) + latest uboot. Same issue. - Stay on latest raspbian release (24.2.1) + legacy kernel (6.1.77) + latest uboot. Same issue. - Armbian 23.11.1 Jammy with Linux 6.1.63-current-sunxi64 was also some time the SO in the board. Same issue. - Also I set the segmentation and MTU as here but same issue: Notes: - CPU is "on demand". That's also why the temperature is OK. - Somehow is only 100Mbits available (the board has gigabit port). By the way, is not my concerning now. - https://github.com/jwrdegoede/rtl8189ES_linux/tree/rtl8189fs I saw this driver. Is this an option? Should I try? Any idea? Should I totally rebuild the microsd SO from zero with an ARMBIAN from 2021 or so? Any other suggestion? The board is totally unstable as it currently is and I guess is software related (driver maybe) Thank you. 0 Quote
Dav Posted June 3, 2024 Posted June 3, 2024 (edited) Update: I "fixed it" with https://mmonit.com/wiki/Monit/Installationmonit Basically, each 60 seconds it will check if my "eth0" ethernet interface is up. If not, it tries to wake it up. If for some reason, the port/board cannot wake up the ethernet interface... I have a secondary check (ping Google DNS IP 10 times in a row -> one per minute). If 10/10 failed, it reboots the board. Is not ideal, but now I have a "hands free" board. This is in a countryside, so before this "patch", I had to take my car to manually power-cycle the board hahaha Here you have, the config I used: Quote /etc/monit/monitrc ## Start Monit in the background (run as a daemon): # set daemon 60 # check services at 60 seconds intervals with start delay 120 # optional: delay the first check by 2-minutes (by # # default Monit check immediately after Monit start) # set log /var/log/monit.log set idfile /var/lib/monit/id set statefile /var/lib/monit/state set eventqueue basedir /var/lib/monit/events # set the base directory where events will be stored slots 100 # optionally limit the queue size ############################################################################### ## Services ############################################################################### ## check network eth0 with interface eth0 start program = "/sbin/ifconfig eth0 up" stop program = "/sbin/ifconfig eth0 down" if link down then restart check host 8.8.8.8 with address 8.8.8.8 if failed ping count 10 size 128 with timeout 10 seconds then exec "/usr/sbin/reboot" I hope this can be helpful to somebody. Regards Edited June 3, 2024 by Dav 0 Quote
Dancer Posted July 22, 2024 Posted July 22, 2024 Hi! I had the same problem on OrangePI PC Plus. I have tried different images, settings, and power supply but nothing helps. Then I checked my router Netis(N1) and I found my OrangePI in DHCP clients with another IP. Not static IP that I set manually. Maybe It was IP conflict between the static IP I set on the device and the DHCP IP router had in memory. I reserved IP on the router directly for the specific OrangePI Mac address. After this ethernet works stable for the 16 hours. 0 Quote
Albert Jin Posted December 19, 2025 Posted December 19, 2025 Here is my findings and solution. Hope this also solves your problem. When the network hangs, I can see that IPv4 address is lost using "ip a" on the console. I then check "journalctl -b -e" for logging and obviously it's a consequence of dhcp4 failure. Dec 19 22:54:10 pbsbc01h3 dhclient[4720]: DHCPREQUEST for 192.168.2.190 on eth0 to 192.168.2.55 port 67 (xid=0xb07e1eb) Dec 19 22:54:10 pbsbc01h3 dhclient[4720]: DHCPACK of 192.168.2.190 from 192.168.2.55 (xid=0xebe1070b) Dec 19 22:54:10 pbsbc01h3 NetworkManager[5189]: <error> [1766156050.2239] dhcp4 (eth0): error -111 dispatching events Dec 19 22:54:10 pbsbc01h3 NetworkManager[5189]: <info> [1766156050.2243] dhcp4 (eth0): state changed bound -> fail Dec 19 22:54:10 pbsbc01h3 NetworkManager[5189]: <info> [1766156050.2248] device (eth0): DHCPv4: trying to acquire a new lease within 90 seconds Dec 19 22:54:10 pbsbc01h3 dhclient[4720]: bound to 192.168.2.190 -- renewal in 288 seconds. With the help from ChatGPT, I modify "/etc/dhcp/dhclient.conf" with the following and the problem is gone. timeout 5; retry 60; reboot 10; 0 Quote
eselarm Posted December 19, 2025 Posted December 19, 2025 (edited) This is based on mines, running Armbian Trixie: - NM can work without dhclient, it has it DHCP internally as well. So maybe look at that instead of AI with old info and certainly no clue about a specific SBC - modern kernel it is end0 - systemd-networkd is also an option - you also might use ifupdown still, also not needed, NM can do internally as well Edited December 19, 2025 by eselarm 0 Quote
