1 hour ago, sunshinetime said:
I've been running into an issue where the kernel starts throwing error messages
For start, upgrade to latest kernel + update u-boot and then try to reproduce this problem.
Hi Igor,
Thanks for your suggestions. I've tried to update the kernel as suggested in the page you linked to but I get an error: "Test install failed. Can't change firmware"
The contents of /tmp/switch_kernel.log are this:
linux-image-current-sunxi=19.11.3 linux-dtb-current-sunxi=19.11.3 linux-u-boot-olinuxino-a20-current
Any suggestions on how to continue from there?
Strange. Do you have network connection at the time you were trying to upgrade?
You just also try to make a fresh build on a separate SD card to see if that works.
I am getting the same error saying "Test install failed. Can't change firmware" when I try to upgrade to kernel 5.3.9 and the file /tmp/switch_kernel.log contains just one line:
linux-image-current-sunxi=19.11.3 linux-dtb-current-sunxi=19.11.3 linux-u-boot-bananapi-current
