epik Posted March 31, 2020 Share Posted March 31, 2020 may be it will help : i havent asound.conf in /etc/ , i have several sound card installed or detected ( correct me if necessary ) 0 : dummy 1: loopback 2: realtek 5651co with armbian 20.02.06 , if i stay on sound , default sink, a file appears and i can see that the 3 built- in are " state : suspended" 0 Quote Link to comment Share on other sites More sharing options...
epik Posted March 31, 2020 Share Posted March 31, 2020 i v got some news !!! i ve succed having sound thru a bluetooth speakers .... nothing to do, just detect it and select your speaker in your settings and it s done ... jack and hdmi are still down .. 0 Quote Link to comment Share on other sites More sharing options...
VyacheslavS Posted March 31, 2020 Share Posted March 31, 2020 1 hour ago, epik said: i ve succed having sound thru a bluetooth speakers .... Do it and show it uname -a ? My Bluetooth only works on kernel 4.4, but not on 5.4. 0 Quote Link to comment Share on other sites More sharing options...
epik Posted March 31, 2020 Share Posted March 31, 2020 10 minutes ago, VyacheslavS said: Do it and show it uname -a ? My Bluetooth only works on kernel 4.4, but not on 5.4. actually the official ( on armbian.com ) armbian buster image 20.02.6 use kernel 4.4.213 and so is my uname -a .. it should be fine for your speaker 0 Quote Link to comment Share on other sites More sharing options...
VyacheslavS Posted March 31, 2020 Share Posted March 31, 2020 51 minutes ago, epik said: actually the official ( on armbian.com ) armbian buster image 20.02.6 use kernel 4.4.213 and so is my uname -a .. it should be fine for your speaker Look there: https://dl.armbian.com/orangepi4/archive/ Armbian_20.02.6_Orangepi4_buster_current_5.4.27_desktop.7z Works faster than on armbian buster image 20.02.6 use kernel 4.4.213, but there are problems with wi-fi, bluetooth. 0 Quote Link to comment Share on other sites More sharing options...
epik Posted March 31, 2020 Share Posted March 31, 2020 17 minutes ago, VyacheslavS said: Look there: https://dl.armbian.com/orangepi4/archive/ Armbian_20.02.6_Orangepi4_buster_current_5.4.27_desktop.7z i ve installed this one , the last on your link page .. https://dl.armbian.com/orangepi4/archive/Armbian_20.02.6_Orangepi4_buster_legacy_4.4.213.7z actually i dont need speed , just stability and compatibility ... 0 Quote Link to comment Share on other sites More sharing options...
VyacheslavS Posted April 1, 2020 Share Posted April 1, 2020 17 hours ago, epik said: i ve installed this one , the last on your link page .. https://dl.armbian.com/orangepi4/archive/Armbian_20.02.6_Orangepi4_buster_legacy_4.4.213.7z actually i dont need speed , just stability and compatibility ... Here I agree. But with the kernel 5.4 Panfrost is already working, and I was very interested to feel how it works. 0 Quote Link to comment Share on other sites More sharing options...
epik Posted April 1, 2020 Share Posted April 1, 2020 13 minutes ago, VyacheslavS said: Here I agree. But with the kernel 5.4 Panfrost is already working, and I was very interested to feel how it works. i ve tried 5.4 thru the nicoD tutorial "build armbian with panfrost" but the opi4 setup is way far to be stable ... so i went back on k4.4 wich is , to me , the one that gives me best results on HD graphics .. dont know why since mali t862 is build on panfrost but .. 4.4 is what works better at this moment .. if you have succeed on k5.4 with HD on VLC for example, please tell me how , im very insterested in that 0 Quote Link to comment Share on other sites More sharing options...
FredrikA Posted April 2, 2020 Share Posted April 2, 2020 On 3/27/2020 at 3:31 PM, FredrikA said: @IanHI am connected wireless (only), due to lacking ethernet in the living room. I still get some crashes on ethernet in dmesg. I am running: uname -a Linux orangepi4 4.4.213-rk3399 #15 SMP Thu Mar 19 21:33:44 CET 2020 aarch64 GNU/Linux (Armbian_20.02.5_Orangepi4_buster_legacy_4.4.213) I wonder if anyone knows how to get the Gyrfalcon Lightspeeur 2801S running in armbian? Also want to make the RPI monitor look nice, including core voltages, does anyone knows which voltage regulators go where? I found four regulators with suspected cpu voltages, but have no clue on how they are connected /sys/devices/platform/vdd-log/regulator/regulator.8/microvolts /sys/devices/platform/ff3c0000.i2c/i2c-0/0-001b/regulator/regulator.9/microvolts /sys/devices/platform/ff3c0000.i2c/i2c-0/0-001b/regulator/regulator.10/microvolts /sys/devices/platform/ff3c0000.i2c/i2c-0/0-0041/regulator/regulator.24/microvolts I will answer my own question. After adding voltage debug to statistics I have concluded that regulator 10 is for the four ARM A53 and regulator 23 is for the two ARM A72. if anyone interested files here https://github.com/Freddan-67/rpimonitor-armbian.git 1 Quote Link to comment Share on other sites More sharing options...
VyacheslavS Posted April 2, 2020 Share Posted April 2, 2020 2 hours ago, FredrikA said: if anyone interested files here https://github.com/Freddan-67/rpimonitor-armbian.git Good work! 0 Quote Link to comment Share on other sites More sharing options...
haajee Posted April 2, 2020 Share Posted April 2, 2020 I read a lot of stability problems... What do you all use for power supply? A USB charger is not the same a power supply. Special is the are USB-C PD chargers. See also this. Since i use on all my orange pi´s a simple cheap 5v 3A like hese power supply it works all smooth and very stable. I also tested some USB-C cables with USB PD chargers or quick charge chargers. And a lot of time it won´t boot of it freezes... 0 Quote Link to comment Share on other sites More sharing options...
iamdrq Posted April 3, 2020 Share Posted April 3, 2020 sound fixed 2 Quote Link to comment Share on other sites More sharing options...
FredrikA Posted April 3, 2020 Share Posted April 3, 2020 17 hours ago, VyacheslavS said: Good work! Thank you. 0 Quote Link to comment Share on other sites More sharing options...
FredrikA Posted April 3, 2020 Share Posted April 3, 2020 9 hours ago, haajee said: I read a lot of stability problems... What do you all use for power supply? A USB charger is not the same a power supply. Special is the are USB-C PD chargers. See also this. Since i use on all my orange pi´s a simple cheap 5v 3A like hese power supply it works all smooth and very stable. I also tested some USB-C cables with USB PD chargers or quick charge chargers. And a lot of time it won´t boot of it freezes... I have no stability problem, since I got a cooling fan. I am using an OKDO usb-c power supply (the company that makes the PSU for raspberry pi). It has real 3A supply. I had it halt twice before Once because overheating Once because memory was exhausted when I tried to build tensorflow. 1 Quote Link to comment Share on other sites More sharing options...
VyacheslavS Posted April 5, 2020 Share Posted April 5, 2020 On 4/3/2020 at 9:24 AM, iamdrq said: sound fixed How do I apply this to the installed kernel 5.4.28? I tried to compile dtb, but I get an error: $ dtc -I dts -O dtb -o orangepi4-i2s_8ch_mclk.dtb orangepi4-i2s_8ch_mclk.dts Error: orangepi4-i2s_8ch_mclk.dts:11.28-29 syntax error FATAL ERROR: Unable to parse input tree 0 Quote Link to comment Share on other sites More sharing options...
iamdrq Posted April 5, 2020 Share Posted April 5, 2020 13 minutes ago, VyacheslavS said: How do I apply this to the installed kernel 5.4.28? I tried to compile dtb, but I get an error: $ dtc -I dts -O dtb -o orangepi4-i2s_8ch_mclk.dtb orangepi4-i2s_8ch_mclk.dts Error: orangepi4-i2s_8ch_mclk.dts:11.28-29 syntax error FATAL ERROR: Unable to parse input tree the orangepi4-rt5651.patch include rt5651.c, so not only need use dts overlay. Do you use the patch rebuild kernel ? 0 Quote Link to comment Share on other sites More sharing options...
VyacheslavS Posted April 5, 2020 Share Posted April 5, 2020 3 minutes ago, iamdrq said: Do you use the patch rebuild kernel ? No yet, I tried to compile dtb for the kernel from the repository. Can I ask you for a ready-made kernel with patches? 0 Quote Link to comment Share on other sites More sharing options...
iamdrq Posted April 5, 2020 Share Posted April 5, 2020 8 minutes ago, VyacheslavS said: No yet, I tried to compile dtb for the kernel from the repository. Can I ask you for a ready-made kernel with patches? Yes,please back up your old files orangepi4-sound-bt.zip 1 Quote Link to comment Share on other sites More sharing options...
piter75 Posted April 5, 2020 Share Posted April 5, 2020 On 4/3/2020 at 4:24 AM, iamdrq said: sound fixed Well done! I have added your patches with minor tweaks to the Armbian build system - it will be available in the images from the download area... at some point ;-) 3 Quote Link to comment Share on other sites More sharing options...
VyacheslavS Posted April 5, 2020 Share Posted April 5, 2020 3 hours ago, iamdrq said: Yes,please back up your old files There is sound through the 3.5 mm jack. Good work! 0 Quote Link to comment Share on other sites More sharing options...
haajee Posted April 5, 2020 Share Posted April 5, 2020 On 4/3/2020 at 8:12 AM, FredrikA said: I have no stability problem, since I got a cooling fan. I am using an OKDO usb-c power supply (the company that makes the PSU for raspberry pi). It has real 3A supply. I had it halt twice before Once because overheating Once because memory was exhausted when I tried to build tensorflow. Always good to share this troubles. :) Learn from mistakes from others, you couldn't make them all by yourself. :P And trust me: i make a lot. ;) 0 Quote Link to comment Share on other sites More sharing options...
Jack953 Posted April 5, 2020 Author Share Posted April 5, 2020 Now, I'm scared to test the mpcie expansion board ! because it doesn't have an external power connector. The board power supply is 3A, OP4 uses around 2,5A. I want to test a LTE modem, but the modem alone uses up to 2A (the expansion board supports modems since it has a sim card slot). I'm scared to test even without the sim. And even if I use a 6A power supply, can the OP4 power circuit handle this power ? What could I do ? 0 Quote Link to comment Share on other sites More sharing options...
FredrikA Posted April 6, 2020 Share Posted April 6, 2020 14 hours ago, Jack953 said: Now, I'm scared to test the mpcie expansion board ! because it doesn't have an external power connector. The board power supply is 3A, OP4 uses around 2,5A. I want to test a LTE modem, but the modem alone uses up to 2A (the expansion board supports modems since it has a sim card slot). I'm scared to test even without the sim. And even if I use a 6A power supply, can the OP4 power circuit handle this power ? What could I do ? You can measure the power consumption and see if you are at risk. I can try to see if I can find my clamp ampere meter, I got it around somewhere, maybe I can make some measurement. If you are at risk, the processor cores draws a lot more when at high frequency, maybe you could implement a more restrictive throttling. 1 Quote Link to comment Share on other sites More sharing options...
VyacheslavS Posted April 6, 2020 Share Posted April 6, 2020 1 hour ago, FredrikA said: You can measure the power consumption and see if you are at risk. I measured the consumption of the OP4 board: 1.Loading the operating system Spoiler 2.The system is loaded, there is no application load Spoiler 3. 7z benchmark. Maximum CPU load. Spoiler 2 Quote Link to comment Share on other sites More sharing options...
VyacheslavS Posted April 6, 2020 Share Posted April 6, 2020 Today I enjoyed the sound from OPi4 via 3.5 Jack. The rt5651 codec transmits sound very well. Thank you again @iamdrq! The audio output was via Alsa, because Pulseaudio is not the quality I would like to get. Headphones: Sony mh755 Player: DeadBeef Format music: FLAC Spoiler Sound via Bluetooth also works great! 0 Quote Link to comment Share on other sites More sharing options...
Jack953 Posted April 6, 2020 Author Share Posted April 6, 2020 5 hours ago, VyacheslavS said: I measured the consumption of the OP4 board... Thank you, very usefull, I guess its safe to test, when doing nothing. But its a risk when both devices are on high load. 1 Quote Link to comment Share on other sites More sharing options...
haajee Posted April 17, 2020 Share Posted April 17, 2020 I am a little bit flabbergasted. In thought: i download the Android 9 / TV image from the Rockpi site for the Rock Pi 4 who has also a RK3399 chipset. So i did and flashed it to a SD card and put in the Orange Pi 4. Ethernet activity and link lights up and a red light. Nothing looks happen but there was a lot of traffic. So i disconnected the power supply and back in and... Rock Pi Kernel on my TV. Than the Android Booting logo and there was Android itself. Tries a few things but looks like mostly all things work. Bluetooth works, sound works, wifi works. When i look by the buildnumber i see also: RK3399-Pi. Without Rock Pi or something. So it looks like just a universal image. But the Rock Pi android version is a lot more up to date. Oh there is one thing what not works. When i choose for restart by shutdown it hangs and do i need to remove and replug the power supply again.... 0 Quote Link to comment Share on other sites More sharing options...
Jack953 Posted April 19, 2020 Author Share Posted April 19, 2020 Happy to see a new image, can you guys make a buster / buster minimal please ? 0 Quote Link to comment Share on other sites More sharing options...
haajee Posted April 21, 2020 Share Posted April 21, 2020 On 4/19/2020 at 2:18 PM, Jack953 said: Happy to see a new image, can you guys make a buster / buster minimal please ? You mean an buster with the 5.x kernel without desktop i think? I am waiting also therefore. There is a version with kernel 4.x and i i try to upgrade the kernel there goes something wrong. So from me also the question for a buster server version with kernel 5.x And yes i have donated For the people who are interested, Geekworm have a metal case for the OrangePi 4. https://nl.aliexpress.com/item/4000899514401.html 0 Quote Link to comment Share on other sites More sharing options...
Vishnu Das Posted April 24, 2020 Share Posted April 24, 2020 Hi, are both the blue coloured USB ports on Orange Pi 4 USB 3.0 compliant ? 0 Quote Link to comment Share on other sites More sharing options...
