Added and it works, thanks Jernej. I also pushed to repository that you can test:
apt-get update && apt-get upgrade
@Jernej and @Igor
Thank you, the solution works for OPI LITE.
@Igor
- Please disable gmac in orangepilite.fex as it creates non-existing eth0 interface
[gmac0]
gmac_used = 0
gmac_power1 =
- enable 8189fs in /etc/modules-load.d/modules.conf
#-------------- working internal wifi
8189fs
WIFI is stable, Iperf shows similar performance to USB-dongles on OPI LITE/ONE ( 75 mbps ) in noisy environment. :)
This has already been done in board.conf so on existing images this step has to be done by hand I would assume. Disabling eth0 is a good idea (@Igor: I'll send a PR later regarding firstrun since some things might now not work any more, can then adjust the fex file too if you want).
@rodolfo: Could you have a look regarding AP and monitoring mode as asked/outlined (by jernej) here: http://forum.armbian.com/index.php/topic/942-rebuild-rtl8189es-from-git-for-opi/?view=getlastpost ?
@tkaiser, @igor, @jernej
AP (master) mode and monitor mode both work
Working tested AP mode
sudo nano /etc/default/hostapd
DAEMON_CONF="/etc/hostapd.conf"
sudo nano /etc/hostapd.conf
ssid=xx_opilite1_xx
interface=wlan0
hw_mode=g
channel=5
driver=nl80211
logger_syslog=0
logger_syslog_level=0
wmm_enabled=1
ieee80211n=1
wpa=3
preamble=1
#wpa_psk=66eb31d2b48d19ba216f2e50c6831ee11be98e2fa3a8075e30b866f4a5ccda27
wpa_passphrase='12345678'
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=0
noscan=1
#ht_capab=[HT40-][sHORT-GI-40][sHORT-GI-40][DSSS_CCK-40]
country_code=CH
#ieee80211d=1
sudo nano /etc/network/interfaces
allow-hotplug wlan0
   iface wlan0 inet static
        address 192.168.4.171
        netmask 255.255.255.0
        network 192.168.4.0
Testing monitor mode
A new virtual interface needs to be created for monitor mode
sudo iw phy phy0 interface add wlan1 type monitor
sudo ifconfig wlan1 192.168.5.171
sudo iwlist wlan1 scan
( ---> list of scanned SSIDs, just to show interface is up )
:) enjoy
@igor
The MAC still seems to be newly created on each restart and udev-rules force a change in interface name ( wlan1 instead of wlan0 )
Quick and dirty workaround :
sudo rm /etc/udev/rules.d/70-persistent-net.rules
sudo echo # >/etc/udev/rules.d/75-persistent-net-generator.rules
Now for 8189es - is it best to use this source - with config change of course
You can't. Driver has some generic code but chip dependant code is only for 8189fs. AFAIK, 8189es driver, which you added today, is the latest one.
What an amazing team! Thank all of you so much for all the work... I did a fresh install on one of my OPi Lites and wireless is up and running in no time - and it works pretty damn good, much better than a RPi3 sitting in the exact same spot on my bench!
I have OPI lite wifi. I flashes with last image 5.14 and can only get wifi using no authentication method. No WEP, no WPA. I tried differents images but no luck. I tested server and desktop version with same result: can only be associated when the router has no encryption at all, i.e. open wifi. My OPI show rtl8189fs driver.
regards,
regards,
It connects to WPA for sure. I don't have any other network and it connects fine. If you are using WICD, make sure you change:
wpa_driver = none
in settings.
We are working on to change network manager.
wpa_driver = none
in settings.
Thank you for your answer, also "none" did the job.
regards,
hi. I have a similar problem
with wifi on OPI Lite. the device sees the SSID, but cannot connect to the router. by trial and error found that by substituting in the settings of Wicd WPA suplicant driwer = none working network connection wpa-psk only encryption method WPA. network connection with WPA2 encryption, or no encryption ends with the message "bad password". is [Armbian_5.14_Orangepilite_Debian_jessie_3.4.112_desktop] , string [wpa_driver = none] the config Wicd is already there.
with android image i can connect to same router (wpa2-psk) with no problem.
Hi All.
I confirm that hostapd master work with internal wifi of Orangepi Lite and rodolfo configuration.
Just a point of attention if you want try with 12345678 password you need to put :
wpa_passphrase=12345678
in place of
If not you will lose many time to undestand why it doesn't works :P
Can anyone comment on the range of an OPi Lite with the onboard wireless in Access Point mode?  Some of the small external-antenna-less RTL8188CUS chipset USB WiFi adapaters only have a 10-20 meter range for acceptable speeds.  Since the OPi Lite has the physical external antenna, has anyone done any tests on throughput at various distances on the Lite (barring excessive interferenence or excessive number of obstacles)?
Hello @ll,
i am now trying to get this 8189ftv to work in hostapd with 150mbps brutto. Did anyone of you get this device to worj with that speed? According to my other post here in the forum i am only getting 72.2 mbps even with a patched hostapd version where the neighbor scan is disabled.
In this case the opi tells me that hostapd is running with 150mbps but clients are also only connecting with 72.2mbps.
my question to you guys also did these tests: did anyone get more speed than 72.2 mbps in brutto?
The range is also not really good with the standard antenna. Only getting 6mbps brutto after 2 walls indoor and 10 meters distance.
This belongs to the orange pi pc plus, but it is using the same 8189ftv.
THX
Update:
I bought another Orange Pi Plus 2E and it works perfectly the wifi, the other one that I have and for which I opened this post is defective.
