maya.b Posted December 17, 2019 Posted December 17, 2019 Hi, I was just setting up a new armbian build environment following the usual github instructions on a bionic 18.04.3 system. Running ./compile.sh (alone or with any configuration) generates the following error: [ o.k. ] Checking for external GCC compilers [ .... ] downloading using torrent network [ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz ] [ error ] ERROR in function download_and_verify [ general.sh:1026 ] [ error ] verification failed From the output/debug/output.log Displaying message: Checking for external GCC compilers info Displaying message: downloading using torrent network gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz gpg: error reading key: No public key gpg: DBG: locking for '/media/psf/ssd1TB/armbian/cache/.gpg/gnupg_spawn_dirmngr_sentinel.lock' done via O_EXCL gpg: connecting dirmngr at '/media/psf/ssd1TB/armbian/cache/.gpg/S.dirmngr' failed: IPC connect call failed gpg: keyserver receive failed: No dirmngr gpg: error reading key: No public key gpg: DBG: locking for '/media/psf/ssd1TB/armbian/cache/.gpg/gnupg_spawn_dirmngr_sentinel.lock' done via O_EXCL gpg: connecting dirmngr at '/media/psf/ssd1TB/armbian/cache/.gpg/S.dirmngr' failed: IPC connect call failed gpg: keyserver receive failed: No dirmngr gpg: assuming signed data in '/media/psf/ssd1TB/armbian/cache/toolchains/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz' gpg: Signature made Tue 19 Nov 2013 09:00:03 AM GMT gpg: using RSA key D47877808F427EAF gpg: Can't check signature: No public key Displaying message: ERROR in function download_and_verify general.sh:1026 err Displaying message: verification failed err Displaying message: Process terminated info Any suggestions? M.
maya.b Posted December 17, 2019 Author Posted December 17, 2019 Yes, same errors. Have also had a quick look for public keys to add to gpg's key manager but no luck so far.
Igor Posted December 17, 2019 Posted December 17, 2019 On 12/17/2019 at 5:13 PM, maya.b said: Have also had a quick look for public keys to add to gpg's key manager but no luck so far. Expand Try running with a parameter USE_TORRENT="no" or put that to userpatches/config-example
maya.b Posted December 17, 2019 Author Posted December 17, 2019 Still fails on installing the toolchain with the same gpg error as above. Including output/debug/output.log
Igor Posted December 17, 2019 Posted December 17, 2019 OK, then I will need to recreate ... What about apt install dirmngr + run again.
Igor Posted December 17, 2019 Posted December 17, 2019 ./compile docker is one possible workaround ...
maya.b Posted December 17, 2019 Author Posted December 17, 2019 will give that a go - will take a while to setup, the vagrant option (what I used to use) is misbehaving but will start a separate thread on that.
Igor Posted December 17, 2019 Posted December 17, 2019 On 12/17/2019 at 5:36 PM, maya.b said: the vagrant option Expand https://github.com/armbian/build/issues/1658
maya.b Posted December 17, 2019 Author Posted December 17, 2019 The vagrant issues in that thread look familiar, The docker build is proceding so am guessing it's one of the dependancies that got installed in the docker container. PGP validation seems to working without issue but still going. From past experience, if it's installing the toolchain without issue, it's fine. Thanks!
Igor Posted December 17, 2019 Posted December 17, 2019 On 12/17/2019 at 5:41 PM, maya.b said: The docker build is proceding so am guessing it's one of the dependancies that got installed in the docker container. PGP validation seems to working without issue but still going. Expand I will check native build later on since it should work. Is that a clean Ubuntu 18.04 build that you are using?
maya.b Posted December 17, 2019 Author Posted December 17, 2019 Yes, the native is a clean 18.04 with kernel: Linux 5.0.0-37-generic #40~18.04.1-Ubuntu SMP Thu Nov 14 12:06:39 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
maya.b Posted December 17, 2019 Author Posted December 17, 2019 ack! spoke to soon. closer: Displaying message: Building deb linux-u-boot-current-nanopim4_19.11.4_arm64.deb info dpkg-deb: error: control directory has bad permissions 700 (must be >=0755 and <=0775) Displaying message: ERROR in function compile_uboot compilation.sh:257 err
Igor Posted December 17, 2019 Posted December 17, 2019 I made two tests: 1. Building on Ubuntu Xenial inside Docker (succeded) 2. Clean Ubuntu 18.04 mini + standard system utils, native build (succeded)
maya.b Posted December 17, 2019 Author Posted December 17, 2019 Just created a new native VM 18.04 to build in. Works fine on the VMs local storage. Same failures with a remote ext4 mount. Time to buy more local storage.
maya.b Posted December 17, 2019 Author Posted December 17, 2019 docker build on storage host slooooowly coming along .... sigh.
FrikoAnPulento Posted December 1, 2020 Posted December 1, 2020 Hello, same problem here. I've manually downloaded files, manually uncompressed them and added .download-complete file and then run compile again. Now it works, but would be nice to fix it. If you need more info about the problem just ask P.S. I can say that I had to download toolchains from browser, because wget got several download errors (probably due to connection issue). Could be related to the problem?
balbes150 Posted December 1, 2020 Posted December 1, 2020 This may be related to something, but I stopped loading rootfs caches during the build (the system has to build everything itself from packages).
Igor Posted December 1, 2020 Posted December 1, 2020 We recently made some improvements and I hope this will not happen again. https://github.com/armbian/build/pull/2400 1
