Kernel 5.3.y has just been labelled as EOL which was anyway expected to happen soon and most of our "current" kernels are already at 5.4.y ... Is sunxi/sunx64 ready for this upgrade?
Don't care about 5.5.y at this moment which means DEV branch can remain as is or if someone out of the regulars take it further.
  • Igor changed the title to Switching sunxi current to 5.4.y
Expand
I will spend sometime during next 2 weeks to migrate DEV to @megi 's 5.5.y branch ...
Few findings - also with other 5.4.y kernels:
- Orangepi3 = broken network
- Opi Lite crashing wifi
- Teres A64 = doesn't boot / no hdmi ?
- Tinkerboard 5.4.y = no HDMI
Expand
Thanks Igor for the info. i thought i broke my board when the Ethernet stop working after flashing a new image.
Expand
Isn't those problems related to NetworkManager ?
On my board, since I'm using almost every time "old school" /etc/network/interface, I've disabled NetworkManager and I don't have any network issues and boards are up since more than 3 weeks ...
Expand
At least for Opi3 I don't think so:
[   17.213687] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1
[   17.222692] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[   17.386257] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1
[   17.395289] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[   17.428555] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1
[   17.437574] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[   17.466272] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1
[   17.475285] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[   17.504444] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1
[   17.513515] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
Expand
Ah ! I was using WiFi ... But I just plugged ETH and don't see the issue ... Maybe issue is been introduced later than my 5.4.1 built on Dec 5th ...
And one more findings. I used DT found on LE from @jernej and it shows the same symptoms while LibreELEC (2019-12-20) works fine.
