surya96 Posted December 29, 2019 Share Posted December 29, 2019 I just successfully installed Armbian buster, when I run apt-get update the message appears: root@aml:~# apt-get update Err:1 http://security.debian.org buster/updates InRelease Could not connect to prod.debian.map.fastly.net:80 (151.101.8.204). - connect (111: Connection refused) Cannot initiate the connection to prod.debian.map.fastly.net:80 (2a04:4e42:2::204). - connect (101: Network is unreachable) Could not connect to security.debian.org:80 (133.242.99.74). - connect (111: Connection refused) Cannot initiate the connection to security.debian.org:80 (2401:2500:103:11a::74). - connect (101: Network is unreachable) Err:2 http://httpredir.debian.org/debian buster InRelease Could not connect to httpredir.debian.org:80 (151.101.10.133). - connect (111: Connection refused) Cannot initiate the connection to httpredir.debian.org:80 (2a04:4e42:2::645). - connect (101: Network is unreachable) Err:3 http://httpredir.debian.org/debian buster-updates InRelease Cannot initiate the connection to httpredir.debian.org:80 (2a04:4e42:2::645). - connect (101: Network is unreachable) Err:4 http://httpredir.debian.org/debian buster-backports InRelease Cannot initiate the connection to httpredir.debian.org:80 (2a04:4e42:2::645). - connect (101: Network is unreachable) Reading package lists... Done W: Failed to fetch http://httpredir.debian.org/debian/dists/buster/InRelease Could not connect to httpredir.debian.org:80 (151.101.10.133). - connect (111: Connection refused) Cannot initiate the connection to httpredir.debian.org:80 (2a04:4e42:2::645). - connect (101: Network is unreachable) W: Failed to fetch http://httpredir.debian.org/debian/dists/buster-updates/InRelease Cannot initiate the connection to httpredir.debian.org:80 (2a04:4e42:2::645). - connect (101: Network is unreachable) W: Failed to fetch http://httpredir.debian.org/debian/dists/buster-backports/InRelease Cannot initiate the connection to httpredir.debian.org:80 (2a04:4e42:2::645). - connect (101: Network is unreachable) W: Failed to fetch http://security.debian.org/dists/buster/updates/InRelease Could not connect to prod.debian.map.fastly.net:80 (151.101.8.204). - connect (111: Connection refused) Cannot initiate the connection to prod.debian.map.fastly.net:80 (2a04:4e42:2::204). - connect (101: Network is unreachable) Could not connect to security.debian.org:80 (133.242.99.74). - connect (111: Connection refused) Cannot initiate the connection to security.debian.org:80 (2401:2500:103:11a::74). - connect (101: Network is unreachable) W: Some index files failed to download. They have been ignored, or old ones used instead. root@aml:~# ping google.com PING google.com (216.239.38.120) 56(84) bytes of data. 64 bytes from any-in-2678.1e100.net (216.239.38.120): icmp_seq=1 ttl=57 time=18.4 ms 64 bytes from any-in-2678.1e100.net (216.239.38.120): icmp_seq=2 ttl=57 time=18.5 ms 64 bytes from any-in-2678.1e100.net (216.239.38.120): icmp_seq=3 ttl=57 time=18.4 ms 64 bytes from any-in-2678.1e100.net (216.239.38.120): icmp_seq=4 ttl=57 time=18.2 ms 64 bytes from any-in-2678.1e100.net (216.239.38.120): icmp_seq=5 ttl=57 time=18.2 ms --- google.com ping statistics --- 6 packets transmitted, 5 received, 16.6667% packet loss, time 12ms rtt min/avg/max/mdev = 18.162/18.338/18.484/0.208 ms even though the connection is good, ping to google smoothly. Can anyone help? Link to comment Share on other sites More sharing options...
martinayotte Posted December 29, 2019 Share Posted December 29, 2019 There was an announcement yesterday about a server maintenance . Maybe you should try again ... Link to comment Share on other sites More sharing options...
Igor Posted December 29, 2019 Share Posted December 29, 2019 26 minutes ago, martinayotte said: Maybe you should try again ... Its (his) general networking problem (update to Debian servers are broken) or he was using previous Orangepi 3 / One+ image that have broken network .. since he didn't even tell which board (I suspect some not supported random TV box due to aml as a hostname) is using its impossible to give any hints. Not to mention that he already tried to contact me in person before ... Link to comment Share on other sites More sharing options...
