rpav Posted January 1, 2020 Posted January 1, 2020 Armbianmonitor: http://ix.io/2654 After few hours wlan0 lost connection for unknown reason (reason=0) and then it looks like some kernel module crash. Is it driver problem? Any suggestion will be very appreciated! Dec 31 19:22:05 tns_3np wpa_supplicant[1097]: wlan0: CTRL-EVENT-DISCONNECTED bssid=40:b0:76:58:52:d8 reason=0 locally_generated=1 Dec 31 19:22:05 tns_3np wpa_supplicant[1097]: p2p-dev-wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD Dec 31 19:22:05 tns_3np wpa_supplicant[1097]: p2p-dev-wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=CZ Dec 31 19:22:05 tns_3np NetworkManager[812]: <info> [1577816525.4151] device (wlan0): supplicant interface state: completed -> disconnected Dec 31 19:22:05 tns_3np NetworkManager[812]: <info> [1577816525.5139] device (wlan0): supplicant interface state: disconnected -> scanning Dec 31 19:22:05 tns_3np wpa_supplicant[1097]: wlan0: Trying to associate with SSID 'U6' Dec 31 19:22:06 tns_3np NetworkManager[812]: <info> [1577816526.0339] device (wlan0): supplicant interface state: scanning -> associating Dec 31 19:22:06 tns_3np wpa_supplicant[1097]: wlan0: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=16 Dec 31 19:22:06 tns_3np NetworkManager[812]: <info> [1577816526.8275] device (wlan0): supplicant interface state: associating -> disconnected Dec 31 19:22:07 tns_3np NetworkManager[812]: <info> [1577816527.3281] device (wlan0): supplicant interface state: disconnected -> scanning Dec 31 19:22:07 tns_3np wpa_supplicant[1097]: wlan0: Trying to associate with SSID 'U6' Dec 31 19:22:07 tns_3np NetworkManager[812]: <info> [1577816527.8392] device (wlan0): supplicant interface state: scanning -> associating Dec 31 19:22:12 tns_3np wpa_supplicant[1097]: wlan0: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=16 Dec 31 19:22:12 tns_3np NetworkManager[812]: <info> [1577816532.3947] device (wlan0): supplicant interface state: associating -> disconnected Dec 31 19:22:13 tns_3np NetworkManager[812]: <info> [1577816533.3951] device (wlan0): supplicant interface state: disconnected -> scanning Dec 31 19:22:14 tns_3np wpa_supplicant[1097]: wlan0: Trying to associate with SSID 'U6' Dec 31 19:22:14 tns_3np NetworkManager[812]: <info> [1577816534.0850] device (wlan0): supplicant interface state: scanning -> associating Dec 31 19:22:15 tns_3np kernel: ------------[ cut here ]------------ Dec 31 19:22:15 tns_3np kernel: WARNING: CPU: 1 PID: 5127 at net/wireless/sme.c:756 __cfg80211_connect_result+0x3e4/0x410 [cfg80211] Dec 31 19:22:15 tns_3np kernel: Modules linked in: zstd zram snd_soc_hdmi_codec brcmfmac brcmutil cfg80211 rfkill snd_soc_simple_card sun8i_codec_analog snd_soc_simple_card_utils sun8i_adda_pr_regmap sun4i_i2s snd_soc_core snd_pcm_dmaengine lima snd_pcm dw_hdmi_cec dw_hdmi_i2s_audio snd_timer ch341 gpu_sched usbserial snd soundcore sun4i_gpadc_iio industrialio cpufreq_dt usb_f_acm u_serial g_serial libcomposite Dec 31 19:22:15 tns_3np kernel: CPU: 1 PID: 5127 Comm: kworker/u8:1 Not tainted 5.3.9-sunxi64 #19.11.3 Dec 31 19:22:15 tns_3np kernel: Hardware name: OrangePi Zero Plus2 (DT) Dec 31 19:22:15 tns_3np kernel: Workqueue: cfg80211 cfg80211_event_work [cfg80211] Dec 31 19:22:15 tns_3np kernel: pstate: 40000005 (nZcv daif -PAN -UAO) Dec 31 19:22:15 tns_3np kernel: pc : __cfg80211_connect_result+0x3e4/0x410 [cfg80211] Dec 31 19:22:15 tns_3np kernel: lr : __cfg80211_connect_result+0x3e4/0x410 [cfg80211] Dec 31 19:22:15 tns_3np kernel: sp : ffff000012643ca0 Dec 31 19:22:15 tns_3np kernel: x29: ffff000012643ca0 x28: 0000000000000000 Dec 31 19:22:15 tns_3np kernel: x27: 0000000000000060 x26: dead000000000100 Dec 31 19:22:15 tns_3np kernel: x25: dead000000000122 x24: 0000000000000000 Dec 31 19:22:15 tns_3np kernel: x23: ffff000012643ce8 x22: 0000000000000000 Dec 31 19:22:15 tns_3np kernel: x21: ffff000010e886c8 x20: ffff800014803818 Dec 31 19:22:15 tns_3np kernel: x19: ffff800016966008 x18: 00000000fffffff0 Dec 31 19:22:15 tns_3np kernel: x17: 0000000000000000 x16: 0000000000000000 Dec 31 19:22:15 tns_3np kernel: x15: ffff000010ea2aa8 x14: ffff000010f3f10a Dec 31 19:22:15 tns_3np kernel: x13: 0000000000000000 x12: ffff000010f3e000 Dec 31 19:22:15 tns_3np kernel: x11: ffff000010ea2000 x10: ffff000010f3e750 Dec 31 19:22:15 tns_3np kernel: x9 : 0000000000000000 x8 : 0000000000000001 Dec 31 19:22:15 tns_3np kernel: x7 : 0000000000000177 x6 : 0000000000000001 Dec 31 19:22:15 tns_3np kernel: x5 : 0000000000000000 x4 : 0000000000000000 Dec 31 19:22:15 tns_3np kernel: x3 : 0000000000000000 x2 : 55d5bdb4c7283400 Dec 31 19:22:15 tns_3np kernel: x1 : 0000000000000000 x0 : 0000000000000024 Dec 31 19:22:15 tns_3np kernel: Call trace: Dec 31 19:22:15 tns_3np kernel: __cfg80211_connect_result+0x3e4/0x410 [cfg80211] Dec 31 19:22:15 tns_3np kernel: cfg80211_process_wdev_events+0x170/0x200 [cfg80211] Dec 31 19:22:15 tns_3np kernel: cfg80211_process_rdev_events+0x38/0x90 [cfg80211] Dec 31 19:22:15 tns_3np kernel: cfg80211_event_work+0x1c/0x30 [cfg80211] Dec 31 19:22:15 tns_3np kernel: process_one_work+0x1ec/0x370 Dec 31 19:22:15 tns_3np kernel: worker_thread+0x4c/0x4f8 Dec 31 19:22:15 tns_3np kernel: kthread+0x120/0x128 Dec 31 19:22:15 tns_3np kernel: ret_from_fork+0x10/0x18 Dec 31 19:22:15 tns_3np kernel: ---[ end trace 68a221c4c355f325 ]--- Dec 31 19:22:15 tns_3np wpa_supplicant[1097]: wlan0: Associated with 00:00:00:00:00:00 Dec 31 19:22:15 tns_3np NetworkManager[812]: <info> [1577816535.6614] device (wlan0): supplicant interface state: associating -> associated Dec 31 19:22:16 tns_3np NetworkManager[812]: <info> [1577816536.5019] device (wlan0): supplicant interface state: associated -> 4-way handshake Dec 31 19:22:19 tns_3np wpa_supplicant[1097]: wlan0: CTRL-EVENT-DISCONNECTED bssid=00:00:00:00:00:00 reason=2 locally_generated=1 Dec 31 19:22:19 tns_3np wpa_supplicant[1097]: wlan0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect Dec 31 19:22:19 tns_3np wpa_supplicant[1097]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="U6" auth_failures=1 duration=10 reason=WRONG_KEY Dec 31 19:22:19 tns_3np NetworkManager[812]: <warn> [1577816539.5258] sup-iface[0xaaab1e196810,wlan0]: connection disconnected (reason -2) Dec 31 19:22:19 tns_3np wpa_supplicant[1097]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="U6" auth_failures=2 duration=20 reason=CONN_FAILED Dec 31 19:22:19 tns_3np wpa_supplicant[1097]: p2p-dev-wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD Dec 31 19:22:19 tns_3np NetworkManager[812]: <info> [1577816539.5304] device (wlan0): supplicant interface state: 4-way handshake -> disconnected Dec 31 19:22:19 tns_3np wpa_supplicant[1097]: p2p-dev-wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=CZ Dec 31 19:22:19 tns_3np NetworkManager[812]: <info> [1577816539.5367] device (wlan0): Activation: (wifi) disconnected during association, asking for new key Dec 31 19:22:19 tns_3np NetworkManager[812]: <info> [1577816539.5375] device (wlan0): state change: activated -> need-auth (reason 'supplicant-disconnect') [100 60 8] Dec 31 19:22:19 tns_3np NetworkManager[812]: <info> [1577816539.5388] manager: NetworkManager state is now CONNECTING Dec 31 19:22:19 tns_3np dbus[746]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' Dec 31 19:22:19 tns_3np systemd[1]: Starting Network Manager Script Dispatcher Service... Dec 31 19:22:19 tns_3np NetworkManager[812]: <warn> [1577816539.5792] device (wlan0): No agents were available for this request. Dec 31 19:22:19 tns_3np NetworkManager[812]: <info> [1577816539.5795] device (wlan0): state change: need-auth -> failed (reason 'no-secrets') [60 120 7] Dec 31 19:22:19 tns_3np NetworkManager[812]: <info> [1577816539.5813] manager: NetworkManager state is now DISCONNECTED Dec 31 19:22:19 tns_3np NetworkManager[812]: <warn> [1577816539.5847] device (wlan0): Activation: failed for connection 'U6' Dec 31 19:22:19 tns_3np NetworkManager[812]: <info> [1577816539.5899] device (wlan0): state change: failed -> disconnected (reason 'none') [120 30 0] Dec 31 19:22:19 tns_3np avahi-daemon[2380]: Withdrawing address record for 192.168.62.13 on wlan0. Dec 31 19:22:19 tns_3np avahi-daemon[2380]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.62.13. Dec 31 19:22:19 tns_3np avahi-daemon[2380]: Interface wlan0.IPv4 no longer relevant for mDNS.
Werner Posted January 1, 2020 Posted January 1, 2020 5.3.x has been superseded by current stable and upcoming LTS kernel 5.4.x. Have you tried to update your kernel to the current current branch? You can use armbian-config for that FYI: You can use the spoiler for longer pastes of log files and similar to keep posts more clear
