Андрей Исаев Posted January 15, 2020 Posted January 15, 2020 Armbianmonitor: http://ix.io/27uB fbtft_device - remove after kernel 5.4. How connect SPI TFT to Orange PI PC+ box? ------------------------------------------------------------------------ Welcome to Armbian buster with Linux 5.4.8-sunxi System load: 0.30 0.11 0.04 Up time: 1 min Memory usage: 9 % of 998MB IP: 192.168.0.106 192.168.0.104 CPU temp: 49°C Usage of /: 2% of 59G Last login: Wed Jan 15 19:37:39 2020 from 192.168.0.140 elephant@pls-home:~$ sudo modprobe fbtft_device rotate=90 name=piscreen speed=16000000 gpios=reset:2,dc:71 txbuflen=32768 fps=25 [sudo] password for elephant: modprobe: FATAL: Module fbtft_device not found in directory /lib/modules/5.4.8-sunxi
martinayotte Posted January 15, 2020 Posted January 15, 2020 10 minutes ago, Андрей Исаев said: modprobe: FATAL: Module fbtft_device not found in directory /lib/modules/5.4.8-sunxi Are you sure ? Module seems to be named fbtft.ko, so do "modprobe fbtft" instead ...
Андрей Исаев Posted January 16, 2020 Author Posted January 16, 2020 in https://github.com/notro/fbtft/wiki- writen -> fbtft_device and flexfb are gone in 5.4 module fbtft has one prameters "debug" (modinfo fbtftf)
Андрей Исаев Posted January 16, 2020 Author Posted January 16, 2020 Where images with kernel 4.xxx ? In archive i found only kernel 5.xxx
Igor Posted January 16, 2020 Posted January 16, 2020 8 hours ago, Андрей Исаев said: Where images with kernel 4.xxx ? In archive i found only kernel 5.xxx https://dl.armbian.com/_old/ contain older images. Otherwise you can perhaps just switch kernel to 4.19.y with armbian-config -> alternative kernels.
shaddow501 Posted February 4, 2020 Posted February 4, 2020 Hello, I have this issue, anyone have an idea? root@orangepilite2:src/linux-headers-5.3.9-sunxi64 # make scripts root@orangepilite2:src/linux-headers-5.3.9-sunxi64 # make modules_prepare make[1]: *** No rule to make target 'arch/arm64/kernel/vdso/vdso.lds', needed by 'arch/arm64/kernel/vdso/vdso.so.dbg'. Stop. make: *** [arch/arm64/Makefile:176: vdso_prepare] Error 2
