Aux Posted January 27, 2020 Posted January 27, 2020 Hello everyone, my system is - Armbian Linux 4.18.8-odroidc2. Nextcloud is installed on this board and as data drive is a Lexar 64GB usb stick. I now have an SSD hard drive with two partitions, I had moved the system from the SD card to the first partition on the SSD. The second partition is called nextcloud and is a data drive. Everything works fine so far, but Armbian does not boot without the USB stick, it is not mounted either, it just has to be in the usb slot, otherwise the armbian will not boot. I need your help because I don't know what to do next. root@Nextcloud:~# blkid /dev/mmcblk1p1: UUID="4722b364-ae1f-42d6-ad8f-831b86997837" TYPE="ext4" PARTUUID="0d190000-01" /dev/sda1: LABEL="nextcloud" UUID="9c28c313-0a91-448e-8860-5b5b556fe997" TYPE="ext4" PARTUUID="2d9b74a1-01" /dev/zram0: LABEL="log2ram" UUID="68ac2f41-766b-4114-bb03-0f8fc4d79bc4" TYPE="ext4" /dev/sdb1: UUID="0e03b1d7-41f8-4dbf-a64e-3f3488680c66" TYPE="ext4" PARTUUID="6360b330-01" /dev/sdb2: LABEL="nextcloud" UUID="87febe4c-9c3b-45e4-88e9-48980982259d" UUID_SUB="49841a53-4daa-49bc-a715-982610ccbee0" TYPE="btrfs" PARTUUID="6360b330-02" /dev/zram1: UUID="297d0640-b74c-4e87-a55b-065bd5ab633c" TYPE="swap" /dev/mmcblk1: PTUUID="0d190000" PTTYPE="dos" fstab: tmpfs /tmp tmpfs defaults,nosuid 0 0 UUID=4722b364-ae1f-42d6-ad8f-831b86997837 /media/mmcboot ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 /media/mmcboot/boot /boot none bind 0 0 UUID=0e03b1d7-41f8-4dbf-a64e-3f3488680c66 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 UUID=87febe4c-9c3b-45e4-88e9-48980982259d /media/nextcloud btrfs defaults,noatime,rw 0 0
Igor Posted January 27, 2020 Posted January 27, 2020 Providing logs with armbianmonitor -u significantly raises chances that issue is getting addressed. Board obviously boots without changing anything ... moving to bug tracker. 5 minutes ago, Aux said: Armbian Linux 4.18.8-odroidc2 That's few years old Armbian which could have been fixed a long time ago. Please try to recreate this situation on a freshly installation.
Aux Posted January 27, 2020 Author Posted January 27, 2020 First thank you @Igor for your reply! armbianmonitor -u log: http://ix.io/28tq 45 minutes ago, Igor said: That's few years old Armbian which could have been fixed a long time ago. Please try to recreate this situation on a freshly installation. should i make a completely new install? hmm .... then I have to set up Nextcloud again, right?
Igor Posted January 27, 2020 Posted January 27, 2020 41 minutes ago, Aux said: should i make a completely new install? No, issue is not C2, nor exactly Armbian specific. Probably you are pointing to wrong UUID for / device in armbianEnv.txt on your boot media ...
Aux Posted January 27, 2020 Author Posted January 27, 2020 5 minutes ago, Igor said: No, issue is not C2, nor exactly Armbian specific. Probably you are pointing to wrong UUID for / device in armbianEnv.txt on your boot media ... i think the armbianEnv.txt is ok, it refers to the first partition of the SSD. The system also boots correctly but only if a USB stick is inserted. when i remove the stick system no longer boots. Once the system has booted, I can remove the USB stick. armbianEnv.txt: verbosity=1 rootdev=UUID=0e03b1d7-41f8-4dbf-a64e-3f3488680c66 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u should I do system upgrade like "dist-upgrade"?
Igor Posted January 27, 2020 Posted January 27, 2020 2 minutes ago, Aux said: armbianEnv.txt: Is this the one read by boot script located on the SD card? 3 minutes ago, Aux said: should I do system upgrade like "dist-upgrade"? From older images you need to do this: but in case you have doing manual changes to the fstab and system in general, it can fail.
Aux Posted January 27, 2020 Author Posted January 27, 2020 5 minutes ago, Igor said: Is this the one read by boot script located on the SD card? Yes
Aux Posted January 27, 2020 Author Posted January 27, 2020 (edited) Switched to Armbian Linux 4.19.69-meson64 - no change. Switched to Armbian stretch with Linux 5.3.11-meson64 - no change either. The system simply needs the pendrive - very, very strange. Armbian stretch with Linux 5.4.12-meson64 also did not change anything Is the boot.cmd ok? Spoiler # DO NOT EDIT THIS FILE # # Please edit /boot/armbianEnv.txt to set supported parameters # setenv load_addr "0x44000000" setenv initrd_high "0xffffffff" setenv fdt_high "0xffffffff" setenv overlay_error "false" # default values setenv rootdev "/dev/mmcblk0p1" setenv verbosity "1" setenv console "serial" setenv rootfstype "ext4" setenv docker_optimizations "on" if test -e ${devtype} ${devnum} ${prefix}armbianEnv.txt; then load ${devtype} ${devnum} ${load_addr} ${prefix}armbianEnv.txt env import -t ${load_addr} ${filesize} fi # get PARTUUID of first partition on SD/eMMC it was loaded from # mmc 0 is always mapped to device u-boot (2016.09+) was loaded from if test "${devtype}" = "mmc"; then part uuid mmc ${devnum}:1 partuuid; fi if test "${console}" = "display" || test "${console}" = "both"; then setenv consoleargs "console=tty1"; fi setenv bootargs "root=${rootdev} rootwait rootfstype=${rootfstype} panic=10 ${consoleargs} consoleblank=0 loglevel=${verbosity} ubootpart=${partuuid} usb-storage.quirks=${usbstoragequirks} ${extraargs} ${extraboardargs}" if test "${docker_optimizations}" = "on"; then setenv bootargs "${bootargs} cgroup_enable=memory swapaccount=1"; fi load ${devtype} ${devnum} ${ramdisk_addr_r} ${prefix}uInitrd load ${devtype} ${devnum} ${kernel_addr_r} ${prefix}Image load ${devtype} ${devnum} ${fdt_addr_r} ${prefix}dtb/${fdtfile} fdt addr ${fdt_addr_r} fdt resize 65536 for overlay_file in ${overlays}; do if load ${devtype} ${devnum} ${load_addr} ${prefix}dtb/amlogic/overlay/${overlay_prefix}-${overlay_file}.dtbo; then echo "Applying kernel provided DT overlay ${overlay_prefix}-${overlay_file}.dtbo" fdt apply ${load_addr} || setenv overlay_error "true" fi done for overlay_file in ${user_overlays}; do if load ${devtype} ${devnum} ${load_addr} ${prefix}overlay-user/${overlay_file}.dtbo; then echo "Applying user provided DT overlay ${overlay_file}.dtbo" fdt apply ${load_addr} || setenv overlay_error "true" fi done if test "${overlay_error}" = "true"; then echo "Error applying DT overlays, restoring original DT" load ${devtype} ${devnum} ${fdt_addr_r} ${prefix}dtb/${fdtfile} else if load ${devtype} ${devnum} ${load_addr} ${prefix}dtb/amlogic/overlay/${overlay_prefix}-fixup.scr; then echo "Applying kernel provided DT fixup script (${overlay_prefix}-fixup.scr)" source ${load_addr} fi if test -e ${devtype} ${devnum} ${prefix}fixup.scr; then load ${devtype} ${devnum} ${load_addr} ${prefix}fixup.scr echo "Applying user provided fixup script (fixup.scr)" source ${load_addr} fi fi booti ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} # Recompile with: # mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr Edited January 27, 2020 by TRS-80 put code in spoiler
Aux Posted January 27, 2020 Author Posted January 27, 2020 Now it is really fun, I put a bluetooth USB adapter in the USB-Slot instead of the USB-stick and the system also boots. It seems as if the system needs some USB device then the boot is activated. The system will not boot without a Bluetooth USB-adapter or without a Lexar USB-stick. Does anyone have an explanation for this?
Igor Posted January 27, 2020 Posted January 27, 2020 3 minutes ago, Aux said: Does anyone have an explanation for this? USB issues on Odroid C2 are know but not this weird We need someone to recreate, then this issue will become interested. If this is happening just to you it can be something wrong with your HW ... 1
Aux Posted January 27, 2020 Author Posted January 27, 2020 I can live with a bluetooth adapter inside. It would be stupid if the USB stick had to be inside otherwise. I would say that the issue is considered complete. Thanks @Igor for the care! 1
