Hi!
If start with g12a-x96-max.dtb ethernet works and no sound, with sm1-sei610 no ethernet and sound works.
I tried to exchange sections of dts files between version (two way), but when I use DTC to convert to dtb, so many conflicts of phandle address already used. How to solve?!
Hi!
Updating... I copy ethernet sections from g12-x96-max.dts to sm1-sei610.dts and now booting with sm1-sei610.dtb eth can work, but sound not detected... Maybe conflict with both or I made something wrong?
Solved removing two references from audio-controller -> pinctrl-0 that was in conflict with ethernet.
3 hours ago, almotra said:
hello,
why share .dts?
how to convert it to .dtb?
can you share .dtb please ?
dtc -I dts -O dtb -o output.dtb input.dts
i'm trying to activate bluetooth any clue on how to update dtb?
it seems to be rtl 8822cs
Edited by rforcen
I'm looking for the same thing and also to get WiFi working on my box. Ethernet is working though.
i'm working on it, both dtb & firmware,
i've just tried with 88x2ce, compiled & installed, dbt to compatible="realtek, rtl88x2ce";
but no luck yet.:wacko:
Ok... keep me posted on it. Would really like to get WiFi and BT working. Been searching all over the place for solutions but no luck so far.
I don't know if this helps but I got this...
root@arm-64:root# udevadm info /sys/bus/sdio/devices/* | paste
P: /devices/platform/soc/ffe03000.sd/mmc_host/mmc0/mmc0:0001/mmc0:0001:1
L: 0
E: DEVPATH=/devices/platform/soc/ffe03000.sd/mmc_host/mmc0/mmc0:0001/mmc0:0001:1
E: OF_NAME=wifi
E: OF_FULLNAME=/soc/sd@ffe03000/wifi@1
E: OF_COMPATIBLE_0=brcm,bcm4329-fmac
E: OF_COMPATIBLE_N=1
E: SDIO_CLASS=07
E: SDIO_ID=024C:C822
E: MODALIAS=sdio:c07v024CdC822
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=8387683
E: ID_SDIO_CLASS_FROM_DATABASE=WLAN interface
L: 0
E: OF_NAME=wifi
E: SDIO_CLASS=07
E: SUBSYSTEM=sdio
this is related to the current .dbt used, in fact the compatible line states:
compatible = "brcm,bcm4329-fmac";
the x96max2+ is a rtl88x2cs wifi+bt buldle
dumping hw from android 9 provides:
rtl88x2cs: /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
attached is the complete hw info i have extracted from android
============ start debug info ============
libhd version 21.70u (arm) [6472]
using /var/lib/hardware
kernel version is 4.9
debug = 0xff7ffff7
probe = 0x15938fcda8107cf9fffe (+memory +pci +isapnp +net +floppy +misc +misc.serial +misc.par +misc.floppy +serial +cpu +bios +monitor +mouse +scsi +usb -usb.mods +modem +modem.usb +parallel +parallel.lp +parallel.zip -isa -isa.isdn +isdn +kbd +prom +sbus +int -braille -braille.alva -braille.fhp -braille.ht -ignx11 +sys -bios.vbe -isapnp.old -isapnp.new -isapnp.mod -braille.baum -manual +fb +pppoe -scan +pcmcia +fork -parallel.imm +s390 +cpuemu -sysfs -s390disks +udev +block +block.cdrom +block.part +edd +edd.mod -bios.ddc -bios.fb -bios.mode +input +block.mods +bios.vesa -cpuemu.debug -scsi.noserial +wlan -bios.crc -hal +bios.vram +bios.acpi -bios.ddc.ports=0 +modules.pata -net.eeprom +x86emu=dump -max -lxrc)
shm: shmget failed (errno 38)
shm: failed to get shm segment; will not fork
>> hal.1: read hal data
>> floppy.1: get nvram
>> floppy.2: klog info
>> sys.1: cpu
>> misc.9: kernel log
>> misc.1: misc data
>> misc.1.1: open serial
>> misc.1.2: open parallel
>> misc.2.1: io
>> misc.2.2: dma
>> misc.2.3: irq
----- /proc/ioports -----
----- /proc/ioports end -----
----- /proc/interrupts -----
   19:    1304403     629727     749231     783503     GIC-0  27 Level     arch_timer
   21:          2      31412      34951      19548     GIC-0  92 Edge      Meson TimerF
   22:     327434          0          0          0     GIC-0 192 Level     ffe40000.bifrost
   23:        504          0          0          0     GIC-0 193 Level     ffe40000.bifrost
   24:     129329          0          0          0     GIC-0 194 Level     ffe40000.bifrost
   26:          2          0          0          0     GIC-0 241 Edge
   27:          2          0          0          0     GIC-0 242 Edge
   28:      25400          0          0          0     GIC-0  40 Edge      eth0
   29:      17150          0          0          0     GIC-0  62 Level     xhci-hcd:usb1
   34:          0          0          0          0     GIC-0  71 Edge      ffd1c000.i2c
   36:        753          0          0          0     GIC-0 225 Edge      meson_uart
   41:      35608          0          0          0     GIC-0 184 Edge
   50:          0          0          0          0     GIC-0 228 Edge      keypad
   51:     527947          0          0          0     GIC-0  58 Edge      meson_uart
   52:          3          0          0          0     GIC-0  89 Edge      hdmitx
   54:          9          0          0          0     GIC-0 235 Edge      hdmi_aocecb
   58:          0          0          0          0     GIC-0 178 Edge      ge2d
   59:     283085          0          0          0     GIC-0  35 Edge      osd-vsync, lcd_vsync, vsync
   62:          0          0          0          0     GIC-0  75 Edge      vdec-0
   63:        724          0          0          0     GIC-0  76 Edge      vdec-1
   66:     283084          0          0          0     GIC-0 121 Edge      rdma
   67:          0          0          0          0     GIC-0  88 Edge      osd-vsync-viu2, lcd_vsync2
   68:          1          0          0          0     GIC-0 230 Edge      ff80014c.meson-irblaster
   69:     111307          0          0          0     GIC-0 223 Edge      meson-aml-mmc
   70:       8964          0          0          0     GIC-0 222 Edge      meson-aml-mmc
   71:     424368          0          0          0     GIC-0 221 Level     meson-aml-mmc
   73:         31          0          0          0     GIC-0  83 Edge      dmc_monitor
   74:          0          0          0          0     GIC-0 212 Edge      aml-aes, aml-sha
   75:        720          0          0          0     GIC-0  78 Edge      pre_di
   76:          0          0          0          0     GIC-0  72 Edge      post_di
   77:       5063          0          0          0     GIC-0  67 Edge      ff634800.p_tsensor
   78:         47          0          0          0     GIC-0  68 Edge      ff634c00.d_tsensor
  IPI0:          0          0          0          0  CPU wakeup interrupts
  IPI1:          0         78        154         86  Timer broadcast interrupts
  IPI2:     721819     949861     931469     952772  Rescheduling interrupts
  IPI3:       3686       3419       2210       3920  Function call interrupts
  IPI4:          0          0          0          0  CPU stop interrupts
  IPI5:     202350     152156     160168     158896  IRQ work interrupts
  IPI6:          0          0          0          0  completion interrupts
  Err:          0
----- /proc/interrupts end -----
----- /proc/dma -----
----- /proc/dma end -----
>> misc.3: FPU
>> misc.3.1: DMA
>> misc.3.2: PIC
>> misc.3.3: timer
>> misc.3.4: RTC
>> cpu.1: cpuinfo
----- /proc/cpuinfo -----
  processor    : 0
  model name    : ARMv7 Processor rev 0 (v7l)
  BogoMIPS    : 76.32
  Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm aes pmull sha1 sha2 crc32
  CPU implementer    : 0x41
  CPU architecture: 7
  CPU variant    : 0x1
  CPU part    : 0xd05
  CPU revision    : 0
  processor    : 1
  BogoMIPS    : 76.32
  CPU architecture: 7
  CPU variant    : 0x1
  CPU part    : 0xd05
  CPU revision    : 0
  processor    : 2
  BogoMIPS    : 76.32
  CPU architecture: 7
  CPU variant    : 0x1
  CPU part    : 0xd05
  CPU revision    : 0
  processor    : 3
  BogoMIPS    : 76.32
  CPU architecture: 7
  CPU variant    : 0x1
  CPU part    : 0xd05
  CPU revision    : 0
  Serial        : 2b0c100001262c0000103838574b5250
  Hardware    : Amlogic
----- /proc/cpuinfo end -----
>> memory.1: main memory size
  kcore mem:  0x0
  klog mem 0: 0x0
  klog mem 1: 0x0
  klog mem:   0x0
  bios mem:   0x0
  meminfo:    0xed203000
  xen balloon:    0x0
>> pci.1: sysfs drivers
----- sysfs driver list (id 0x15510e2d4b3dc717) -----
   ammvdec_mpeg4: module = amvdec_mmpeg4
     amvdec_h265: module = amvdec_h265
   pwm-regulator: /devices/platform/pwmao_d-regulator
       reg-dummy: /devices/platform/reg-dummy
       meson-i2c: /devices/platform/soc/ffd00000.cbus/ffd1c000.i2c
        codec_mm: /devices/platform/codec_mm
amlogic, ddr-bandwidth: /devices/platform/ff638000.ddr_bandwidth
    amlogic-rdma: /devices/platform/rdma
        codec_io: /devices/platform/codec_io
    amvdec_mjpeg: module = amvdec_mjpeg
       meson-pwm: /devices/platform/soc/ff800000.aobus/ff802000.pwm
       meson-pwm: /devices/platform/soc/ffd00000.cbus/ffd19000.pwm
         aml_dma: /devices/platform/ff63e000.aml_dma
          bt-dev: /devices/platform/bt-dev
      amvenc_avc: /devices/platform/amvenc_avc
      amvenc_avc: module = encoder
   meson-cooldev: /devices/platform/meson-cooldev@0
     aml_aes_dma: /devices/platform/ff63e000.aml_dma/ff63e000.aml_dma:aml_aes
   ammvdec_mjpeg: module = amvdec_mmjpeg
         galcore: module = galcore
aml-audio-controller: /devices/platform/soc/ff660000.audiobus
           dummy: /devices/platform/dummy
            vout: /devices/platform/vout
            mali: /devices/platform/ffe40000.bifrost
            mali: module = mali_kbase
audio-ddr-manager: /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:ddr_manager
             VAD: /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:vad
    meson6-dwmac: /devices/platform/ff3f0000.ethernet
   cpufreq-meson: /devices/platform/cpufreq-meson
          clkmsr: /devices/platform/soc/ffd00000.cbus/ffd18004.meson_clk_msr
aml_amdolby_vision_driver: /devices/platform/amdolby_vision
amlogic-new-usb2-v2: /devices/platform/ffe09000.usb2phy
     dmc_monitor: /devices/platform/dmc_monitor
    ammvdec_h265: module = amvdec_h265
         ion_dev: /devices/platform/soc/soc:ion_dev
     aml_sha_dma: /devices/platform/ff63e000.aml_dma/ff63e000.aml_dma:aml_sha
    audio-clocks: /devices/platform/soc/ff660000.audiobus/ff660000.audio_clocks
     ammvdec_vp9: module = amvdec_vp9
       meson-vfd: /devices/platform/meson-vfd
   asoc-aml-card: /devices/platform/auge_sound
            vdin: /devices/platform/vdin0
            vdin: /devices/platform/vdin1
        aml_vdac: /devices/platform/vdac
           viuin: /devices/platform/viuin.0
  amvdec_h264mvc: module = amvdec_h264mvc
 meson_irblaster: /devices/platform/ff80014c.meson-irblaster
       leds-gpio: /devices/platform/gpioleds
         HevcEnc: module = vpu
         HevcEnc: /devices/platform/hevc_enc
       amlvideo2: /devices/platform/amlvideo2_1
       amlvideo2: /devices/platform/amlvideo2_0
          secmon: /devices/platform/secmon
       unifykeys: /devices/platform/unifykey
       meson_mhu: /devices/platform/ff63c400.mhu
            vdec: /devices/platform/vdec
            vdec: module = decoder_common
       snd_spdif: /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:spdif@1
       snd_spdif: /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:spdif@0
           cectx: /devices/platform/ff80023c.aocec
        ionvideo: /devices/platform/ionvideo
        aml_vecm: /devices/platform/amlvecm
             vpu: /devices/platform/vpu
     amvdec_real: module = amvdec_real
   meson-tsensor: /devices/platform/ff634c00.d_tsensor
   meson-tsensor: /devices/platform/ff634800.p_tsensor
      meson_uart: /devices/platform/soc/ff800000.aobus/ff803000.serial
      meson_uart: /devices/platform/ffd24000.serial
      alarmtimer: /devices/platform/alarmtimer
      amvdec_vp9: module = amvdec_vp9
   meson-aml-mmc: /devices/platform/ffe07000.emmc
   meson-aml-mmc: /devices/platform/ffe03000.sdio
   meson-aml-mmc: /devices/platform/ffe05000.sd
amlogic, sm1-powerctrl: /devices/platform/ff8000e8.power_ctrl
   dummy-battery: /devices/platform/dummy-battery
         cvbsout: /devices/platform/cvbsout
       meson-rng: /devices/platform/ff630218.rng
     amvdec_h264: module = amvdec_h264
     aml-restart: /devices/platform/aml_reboot
          aml-bl: /devices/platform/backlight
 aml_codec_T9015: /devices/platform/ff632000.t9015
      lcd_extern: /devices/platform/lcd_extern
     amvdec_avs2: module = amvdec_avs2
  auge_snd_iomap: /devices/platform/aml_snd_iomap
         Effects: /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:effect
       armv7-pmu: /devices/platform/ff634680.arm_pmu
         cpuinfo: /devices/platform/cpu_info
   amvdec_mpeg12: module = amvdec_mpeg12
        aml_vrtc: /devices/platform/rtc
meson-g12a-pinctrl: /devices/platform/pinctrl@ff800014
meson-g12a-pinctrl: /devices/platform/pinctrl@ff634480
            EARC: /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:earc
         snd_tdm: /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:tdm@1
         snd_tdm: /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:tdm@2
         snd_tdm: /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:tdm@0
      amvdec_avs: module = amvdec_avs
   dummy-charger: /devices/platform/dummy-charger
        pm-meson: /devices/platform/aml_pm
    meson-remote: /devices/platform/ff808040.rc
        amvideom: /devices/platform/meson-amvideom
     deinterlace: /devices/platform/deinterlace
    ammvdec_h264: module = amvdec_mh264
        loopback: /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:loopback@0
        amhdmitx: /devices/platform/amhdmitx
      amvdec_vc1: module = amvdec_vc1
       meson_wdt: /devices/platform/ffd0f0d0.watchdog
           mdump: /devices/platform/ff6345e0.ram-dump
     mesonstream: module = stream_input
     mesonstream: /devices/platform/mesonstream
        meson-fb: /devices/platform/fb
        xhci-hcd: /devices/platform/ff500000.dwc3/xhci-hcd.0.auto
    ammvdec_avs2: module = amvdec_avs2
  amlogic-canvas: /devices/platform/ff638000.canvas
        mesonlcd: /devices/platform/ffd07000.lcd
amlogic-new-usb3-v2: /devices/platform/ffe09080.usb3phy
     securitykey: /devices/platform/securitykey
   snd-soc-dummy: /devices/platform/snd-soc-dummy
         ramoops: /devices/platform/7400000.ramoops
   iomap_version: /devices/platform/cpu_iomap
         snd_pdm: /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:pdm
            dwc3: /devices/platform/ff500000.dwc3
        aml_wifi: /devices/platform/wifi
     amlogic-dvb: module = aml_hardware_dmx
audio_data_debug: /devices/platform/audio_data
    amvdec_mpeg4: module = amvdec_mpeg4
            ge2d: /devices/platform/ff940000.ge2d
  ammvdec_mpeg12: module = amvdec_mmpeg12
           vout2: /devices/platform/vout2
         psmouse: module = psmouse
           r8169: module = r8169
          8139cp: module = 8139cp
         8139too: module = 8139too
RTL8211F Gigabit Ethernet: /devices/platform/ff3f0000.ethernet/mdio_bus/stmmac-0/stmmac-0:00
RTL8211F Gigabit Ethernet: /devices/platform/ff3f0000.ethernet/mdio_bus/stmmac-0/stmmac-0:07
          mmcblk: /devices/platform/ffe05000.sd/mmc_host/sd/sd:1234
          mmcblk: /devices/platform/ffe07000.emmc/mmc_host/emmc/emmc:0001
     hid-generic: /devices/virtual/misc/uhid/0005:05AC:023C.0002
     hid-generic: /devices/virtual/misc/uhid/0005:046D:B008.0001
           usbfs: module = usbcore
        uvcvideo: module = uvcvideo
          usbhid: module = usbhid
   snd-usb-audio: module = snd_usb_audio
     usb-storage: module = usb_storage
            xpad: module = xpad
         cdc_ncm: module = cdc_ncm
             usb: /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1
             usb: /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb2
             hub: /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/1-0:1.0
             hub: module = usbcore
             hub: /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb2/2-0:1.0
         cx231xx: module = cx231xx
            asix: module = asix
----- sysfs driver list end -----
>> pci.2: get sysfs pci data
sysfs: no such bus: pci
---------- PCI raw data ----------
---------- PCI raw data end ----------
>> pci.4: build list
>> pci.3: macio
sysfs: no such bus: macio
>> pci.4: vio
sysfs: no such bus: vio
>> pci.5: xen
sysfs: no such bus: xen
>> pci.6: ps3
sysfs: no such bus: ps3_system_bus
>> pci.7: platform
  platform device: name = ffd0f0d0.watchdog
    path = /devices/platform/ffd0f0d0.watchdog
    type = "watchdog", modalias = "of:NwatchdogT<NULL>Camlogic,_meson-wdt", driver = "meson_wdt"
  platform device: name = ff630218.defendkey
    path = /devices/platform/ff630218.defendkey
    type = "defendkey", modalias = "of:NdefendkeyT<NULL>Camlogic,_defendkey", driver = ""
  platform device: name = ff63e000.aml_dma:aml_aes
    path = /devices/platform/ff63e000.aml_dma/ff63e000.aml_dma:aml_aes
    type = "aml_aes", modalias = "of:Naml_aesT<NULL>Camlogic,aes_g12a_dma", driver = "aml_aes_dma"
  platform device: name = ff940000.ge2d
    path = /devices/platform/ff940000.ge2d
    type = "ge2d", modalias = "of:Nge2dT<NULL>Camlogic,_ge2d-sm1", driver = "ge2d"
  platform device: name = ff660000.audiobus:tdm@1
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:tdm@1
    type = "tdm", modalias = "of:NtdmT<NULL>Camlogic,_sm1-snd-tdmb", driver = "snd_tdm"
  platform device: name = reg-dummy
    path = /devices/platform/reg-dummy
    type = "", modalias = "platform:reg-dummy", driver = "reg-dummy"
  platform device: name = codec_mm
    path = /devices/platform/codec_mm
    type = "codec_mm", modalias = "of:Ncodec_mmT<NULL>Camlogic,_codec,_mm", driver = "codec_mm"
  platform device: name = codec_io
    path = /devices/platform/codec_io
    type = "codec_io", modalias = "of:Ncodec_ioT<NULL>Camlogic,_codec_io", driver = "codec_io"
  platform device: name = cpu_iomap
    path = /devices/platform/cpu_iomap
    type = "cpu_iomap", modalias = "of:Ncpu_iomapT<NULL>Camlogic,_iomap", driver = "iomap_version"
  platform device: name = 7400000.ramoops
    path = /devices/platform/7400000.ramoops
    type = "ramoops", modalias = "of:NramoopsT<NULL>Cramoops", driver = "ramoops"
  platform device: name = amlvideo2_1
    path = /devices/platform/amlvideo2_1
    type = "amlvideo2_1", modalias = "of:Namlvideo2_1T<NULL>Camlogic,_amlvideo2", driver = "amlvideo2"
  platform device: name = vcodec_dec
    path = /devices/platform/vcodec_dec
    type = "vcodec_dec", modalias = "of:Nvcodec_decT<NULL>Camlogic,_vcodec-dec", driver = ""
  platform device: name = ffe40000.bifrost
    path = /devices/platform/ffe40000.bifrost
    type = "bifrost", modalias = "of:NbifrostT<NULL>Carm,malit60xCarm,malit6xxCarm,mali-midgard", driver = "mali"
  platform device: name = ffd00000.cbus
    path = /devices/platform/soc/ffd00000.cbus
    type = "cbus", modalias = "of:NcbusT<NULL>Csimple-bus", driver = ""
  platform device: name = ff660000.audiobus:spdif@1
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:spdif@1
    type = "spdif", modalias = "of:NspdifT<NULL>Camlogic,_sm1-snd-spdif-b", driver = "snd_spdif"
  platform device: name = bt-dev
    path = /devices/platform/bt-dev
    type = "bt-dev", modalias = "of:Nbt-devT<NULL>Camlogic,_bt-dev", driver = "bt-dev"
  platform device: name = amvenc_avc
    path = /devices/platform/amvenc_avc
    type = "amvenc_avc", modalias = "of:Namvenc_avcT<NULL>Camlogic,_amvenc_avc", driver = "amvenc_avc"
  platform device: name = ff630218.rng
    path = /devices/platform/ff630218.rng
    type = "rng", modalias = "of:NrngT<NULL>Camlogic,meson-rng", driver = "meson-rng"
  platform device: name = ff80023c.aocec
    path = /devices/platform/ff80023c.aocec
    type = "aocec", modalias = "of:NaocecT<NULL>Camlogic,_aocec-sm1", driver = "cectx"
  platform device: name = amlvecm
    path = /devices/platform/amlvecm
    type = "amlvecm", modalias = "of:NamlvecmT<NULL>Camlogic,_vecm", driver = "aml_vecm"
  platform device: name = dummy
    path = /devices/platform/dummy
    type = "dummy", modalias = "of:NdummyT<NULL>Camlogic,_aml_dummy_codec", driver = "dummy"
  platform device: name = vout
    path = /devices/platform/vout
    type = "vout", modalias = "of:NvoutT<NULL>Camlogic,_vout", driver = "vout"
  platform device: name = cpufreq-meson
    path = /devices/platform/cpufreq-meson
    type = "cpufreq-meson", modalias = "of:Ncpufreq-mesonT<NULL>Camlogic,_cpufreq-meson", driver = "cpufreq-meson"
  platform device: name = audio_data
    path = /devices/platform/audio_data
    type = "audio_data", modalias = "of:Naudio_dataT<NULL>Camlogic,_audio_data", driver = "audio_data_debug"
  platform device: name = ff800000.aobus
    path = /devices/platform/soc/ff800000.aobus
    type = "aobus", modalias = "of:NaobusT<NULL>Csimple-bus", driver = ""
  platform device: name = wifi
    path = /devices/platform/wifi
    type = "wifi", modalias = "of:NwifiT<NULL>Camlogic,_aml_wifi", driver = "aml_wifi"
  platform device: name = dmc_monitor
    path = /devices/platform/dmc_monitor
    type = "dmc_monitor", modalias = "of:Ndmc_monitorT<NULL>Camlogic,_dmc_monitor", driver = "dmc_monitor"
  platform device: name = meson-vfd
    path = /devices/platform/meson-vfd
    type = "meson-vfd", modalias = "of:Nmeson-vfdT<NULL>Camlogic,aml_vfd", driver = "meson-vfd"
  platform device: name = ff500000.dwc3
    path = /devices/platform/ff500000.dwc3
    type = "dwc3", modalias = "of:Ndwc3T<NULL>Csynopsys,_dwc3", driver = "dwc3"
  platform device: name = meson-amvideom
    path = /devices/platform/meson-amvideom
    type = "meson-amvideom", modalias = "of:Nmeson-amvideomT<NULL>Camlogic,_amvideom", driver = "amvideom"
  platform device: name = regulatory.0
    path = /devices/platform/regulatory.0
    type = "", modalias = "platform:regulatory", driver = ""
  platform device: name = ff634680.arm_pmu
    path = /devices/platform/ff634680.arm_pmu
    type = "arm_pmu", modalias = "of:Narm_pmuT<NULL>Carm,cortex-a15-pmu", driver = "armv7-pmu"
  platform device: name = viuin.0
    path = /devices/platform/viuin.0
    type = "", modalias = "platform:viuin", driver = "viuin"
  platform device: name = ff638000.ddr_bandwidth
    path = /devices/platform/ff638000.ddr_bandwidth
    type = "ddr_bandwidth", modalias = "of:Nddr_bandwidthT<NULL>Camlogic,_ddr-bandwidth", driver = "amlogic, ddr-bandwidth"
  platform device: name = ff63c400.mhu
    path = /devices/platform/ff63c400.mhu
    type = "mhu", modalias = "of:NmhuT<NULL>Camlogic,_meson_mhu", driver = "meson_mhu"
  platform device: name = aml_pm
    path = /devices/platform/aml_pm
    type = "aml_pm", modalias = "of:Naml_pmT<NULL>Camlogic,_pm", driver = "pm-meson"
  platform device: name = ffd07000.lcd
    path = /devices/platform/ffd07000.lcd
    type = "lcd", modalias = "of:NlcdT<NULL>Camlogic,_lcd-sm1", driver = "mesonlcd"
  platform device: name = cpu_ver_name
    path = /devices/platform/cpu_ver_name
    type = "cpu_ver_name", modalias = "of:Ncpu_ver_nameT<NULL>Camlogic,_cpu-major-id-sm1", driver = ""
  platform device: name = linux,picdec
    path = /devices/platform/linux,picdec
    type = "linux,picdec", modalias = "of:Nlinux,picdecT<NULL>Cshared-dma-pool", driver = ""
  platform device: name = secmon
    path = /devices/platform/secmon
    type = "secmon", modalias = "of:NsecmonT<NULL>Camlogic,_secmon", driver = "secmon"
  platform device: name = ff660000.audiobus:ddr_manager
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:ddr_manager
    type = "ddr_manager", modalias = "of:Nddr_managerT<NULL>Camlogic,_sm1-audio-ddr-manager", driver = "audio-ddr-manager"
  platform device: name = ff660000.audio_clocks
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audio_clocks
    type = "audio_clocks", modalias = "of:Naudio_clocksT<NULL>Camlogic,_sm1-audio-clocks", driver = "audio-clocks"
  platform device: name = ff803000.serial
    path = /devices/platform/soc/ff800000.aobus/ff803000.serial
    type = "serial", modalias = "of:NserialT<NULL>Camlogic,_meson-uart", driver = "meson_uart"
  platform device: name = soc
    type = "soc", modalias = "of:NsocT<NULL>Csimple-bus", driver = ""
  platform device: name = aml_snd_iomap
    path = /devices/platform/aml_snd_iomap
    type = "aml_snd_iomap", modalias = "of:Naml_snd_iomapT<NULL>Camlogic,_snd-iomap", driver = "auge_snd_iomap"
  platform device: name = vdec
    path = /devices/platform/vdec
    type = "vdec", modalias = "of:NvdecT<NULL>Camlogic,_vdec", driver = "vdec"
  platform device: name = ff802000.pwm
    path = /devices/platform/soc/ff800000.aobus/ff802000.pwm
    type = "pwm", modalias = "of:NpwmT<NULL>Camlogic,g12a-ao-pwm", driver = "meson-pwm"
  platform device: name = ionvideo
    path = /devices/platform/ionvideo
    type = "ionvideo", modalias = "of:NionvideoT<NULL>Camlogic,_ionvideo", driver = "ionvideo"
  platform device: name = vpu
    path = /devices/platform/vpu
    type = "vpu", modalias = "of:NvpuT<NULL>Camlogic,_vpu-sm1", driver = "vpu"
  platform device: name = ff3f0000.ethernet
    path = /devices/platform/ff3f0000.ethernet
    type = "ethernet", modalias = "of:NethernetT<NULL>Camlogic,_g12a-eth-dwmacCsnps,dwmac", driver = "meson6-dwmac"
    is net: sf_eth_net = /sys/devices/platform/ff3f0000.ethernet/net
  platform device: name = soc:ion_dev
    path = /devices/platform/soc/soc:ion_dev
    type = "ion_dev", modalias = "of:Nion_devT<NULL>Camlogic,_ion_dev", driver = "ion_dev"
  platform device: name = aml_reboot
    path = /devices/platform/aml_reboot
    type = "aml_reboot", modalias = "of:Naml_rebootT<NULL>Caml,_reboot", driver = "aml-restart"
  platform device: name = ff660000.audiobus:pdm
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:pdm
    type = "pdm", modalias = "of:NpdmT<NULL>Camlogic,_sm1-snd-pdm", driver = "snd_pdm"
  platform device: name = psci
    path = /devices/platform/psci
    type = "psci", modalias = "of:NpsciT<NULL>Carm,psci-0.2", driver = ""
  platform device: name = unifykey
    path = /devices/platform/unifykey
    type = "unifykey", modalias = "of:NunifykeyT<NULL>Camlogic,_unifykey", driver = "unifykeys"
  platform device: name = vdin0
    path = /devices/platform/vdin0
    type = "vdin0", modalias = "of:Nvdin0T<NULL>Camlogic,_vdin", driver = "vdin"
  platform device: name = alarmtimer
    path = /devices/platform/alarmtimer
    type = "", modalias = "platform:alarmtimer", driver = "alarmtimer"
  platform device: name = ffd18004.meson_clk_msr
    path = /devices/platform/soc/ffd00000.cbus/ffd18004.meson_clk_msr
    type = "meson_clk_msr", modalias = "of:Nmeson_clk_msrT<NULL>Camlogic,_sm1-measure", driver = "clkmsr"
  platform device: name = ff63c000.hiubus
    path = /devices/platform/soc/ff63c000.hiubus
    type = "hiubus", modalias = "of:NhiubusT<NULL>Csimple-bus", driver = ""
  platform device: name = pinctrl@ff800014
    path = /devices/platform/pinctrl@ff800014
    type = "pinctrl", modalias = "of:NpinctrlT<NULL>Camlogic,meson-g12a-aobus-pinctrl", driver = "meson-g12a-pinctrl"
  platform device: name = ff660000.audiobus:loopback@0
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:loopback@0
    type = "loopback", modalias = "of:NloopbackT<NULL>Camlogic,_sm1-loopbacka", driver = "loopback"
  platform device: name = vdac
    path = /devices/platform/vdac
    type = "vdac", modalias = "of:NvdacT<NULL>Camlogic,_vdac-sm1", driver = "aml_vdac"
  platform device: name = ff8000e8.power_ctrl
    path = /devices/platform/ff8000e8.power_ctrl
    type = "power_ctrl", modalias = "of:Npower_ctrlT<NULL>Camlogic,_sm1-powerctrl", driver = "amlogic, sm1-powerctrl"
  platform device: name = ffd1f000.i2c
    path = /devices/platform/soc/ffd00000.cbus/ffd1f000.i2c
    type = "i2c", modalias = "of:Ni2cT<NULL>Camlogic,meson-g12a-i2c", driver = ""
  platform device: name = ff634c00.d_tsensor
    path = /devices/platform/ff634c00.d_tsensor
    type = "d_tsensor", modalias = "of:Nd_tsensorT<NULL>Camlogic,_r1p1-tsensor", driver = "meson-tsensor"
  platform device: name = pwmao_d-regulator
    path = /devices/platform/pwmao_d-regulator
    type = "pwmao_d-regulator", modalias = "of:Npwmao_d-regulatorT<NULL>Cpwm-regulator", driver = "pwm-regulator"
  platform device: name = ff660000.audiobus:tdm@2
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:tdm@2
    type = "tdm", modalias = "of:NtdmT<NULL>Camlogic,_sm1-snd-tdmc", driver = "snd_tdm"
  platform device: name = ff400000.dwc2_a
    path = /devices/platform/ff400000.dwc2_a
    type = "dwc2_a", modalias = "of:Ndwc2_aT<NULL>Camlogic,_dwc2", driver = ""
  platform device: name = dummy-battery
    path = /devices/platform/dummy-battery
    type = "dummy-battery", modalias = "of:Ndummy-batteryT<NULL>Camlogic,_dummy-battery", driver = "dummy-battery"
  platform device: name = fb
    path = /devices/platform/fb
    type = "fb", modalias = "of:NfbT<NULL>Camlogic,_meson-sm1", driver = "meson-fb"
  platform device: name = cvbsout
    path = /devices/platform/cvbsout
    type = "cvbsout", modalias = "of:NcvbsoutT<NULL>Camlogic,_cvbsout-sm1", driver = "cvbsout"
  platform device: name = ffd0f190.timer_bc
    path = /devices/platform/ffd0f190.timer_bc
    type = "timer_bc", modalias = "of:Ntimer_bcT<NULL>Carm,_meson-bc-timer", driver = ""
  platform device: name = ffd24000.serial
    path = /devices/platform/ffd24000.serial
  platform device: name = cpu_opp_table0
    path = /devices/platform/cpu_opp_table0
    type = "cpu_opp_table0", modalias = "of:Ncpu_opp_table0T<NULL>Coperating-points-v2", driver = ""
  platform device: name = jtag
    path = /devices/platform/jtag
    type = "jtag", modalias = "of:NjtagT<NULL>Camlogic,_jtag", driver = ""
  platform device: name = ff660000.audiobus:tdm@0
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:tdm@0
    type = "tdm", modalias = "of:NtdmT<NULL>Camlogic,_sm1-snd-tdma", driver = "snd_tdm"
    type = "aml_dma", modalias = "of:Naml_dmaT<NULL>Camlogic,aml_txlx_dma", driver = "aml_dma"
  platform device: name = rdma
    path = /devices/platform/rdma
    type = "rdma", modalias = "of:NrdmaT<NULL>Camlogic,_meson,_rdma", driver = "amlogic-rdma"
  platform device: name = ff660000.audiobus:vad
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:vad
    type = "vad", modalias = "of:NvadT<NULL>Camlogic,_snd-vad", driver = "VAD"
  platform device: name = lcd_extern
    path = /devices/platform/lcd_extern
    type = "lcd_extern", modalias = "of:Nlcd_externT<NULL>Camlogic,_lcd_extern", driver = "lcd_extern"
  platform device: name = amlvideo2_0
    path = /devices/platform/amlvideo2_0
    type = "amlvideo2_0", modalias = "of:Namlvideo2_0T<NULL>Camlogic,_amlvideo2", driver = "amlvideo2"
  platform device: name = ff660000.audiobus:spdif@0
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:spdif@0
    type = "spdif", modalias = "of:NspdifT<NULL>Camlogic,_sm1-snd-spdif-a", driver = "snd_spdif"
  platform device: name = timer
    path = /devices/platform/timer
    type = "timer", modalias = "of:NtimerT<NULL>Carm,armv7-timer", driver = ""
  platform device: name = amdolby_vision
    path = /devices/platform/amdolby_vision
    type = "amdolby_vision", modalias = "of:Namdolby_visionT<NULL>Camlogic,_dolby_vision_sm1", driver = "aml_amdolby_vision_driver"
  platform device: name = ffe07000.emmc
    path = /devices/platform/ffe07000.emmc
    type = "emmc", modalias = "of:NemmcT<NULL>Camlogic,_meson-mmc-sm1", driver = "meson-aml-mmc"
  platform device: name = ff638000.canvas
    path = /devices/platform/ff638000.canvas
    type = "canvas", modalias = "of:NcanvasT<NULL>Camlogic,_meson,_canvas", driver = "amlogic-canvas"
  platform device: name = cpu_info
    path = /devices/platform/cpu_info
    type = "cpu_info", modalias = "of:Ncpu_infoT<NULL>Camlogic,_cpuinfo", driver = "cpuinfo"
  platform device: name = dummy-charger
    path = /devices/platform/dummy-charger
    type = "dummy-charger", modalias = "of:Ndummy-chargerT<NULL>Camlogic,_dummy-charger", driver = "dummy-charger"
  platform device: name = ffe03000.sdio
    path = /devices/platform/ffe03000.sdio
    type = "sdio", modalias = "of:NsdioT<NULL>Camlogic,_meson-mmc-sm1", driver = "meson-aml-mmc"
  platform device: name = ff63e000.aml_dma:aml_sha
    path = /devices/platform/ff63e000.aml_dma/ff63e000.aml_dma:aml_sha
    type = "aml_sha", modalias = "of:Naml_shaT<NULL>Camlogic,sha_dma", driver = "aml_sha_dma"
  platform device: name = deinterlace
    path = /devices/platform/deinterlace
    type = "deinterlace", modalias = "of:NdeinterlaceT<NULL>Camlogic,_deinterlace", driver = "deinterlace"
  platform device: name = amhdmitx
    path = /devices/platform/amhdmitx
    type = "amhdmitx", modalias = "of:NamhdmitxT<NULL>Camlogic,_amhdmitx", driver = "amhdmitx"
  platform device: name = meson-cooldev@0
    path = /devices/platform/meson-cooldev@0
    type = "meson-cooldev", modalias = "of:Nmeson-cooldevT<NULL>Camlogic,_meson-cooldev", driver = "meson-cooldev"
  platform device: name = ffe09000.usb2phy
    path = /devices/platform/ffe09000.usb2phy
    type = "usb2phy", modalias = "of:Nusb2phyT<NULL>Camlogic,_amlogic-new-usb2-v2", driver = "amlogic-new-usb2-v2"
  platform device: name = hevc_enc
    path = /devices/platform/hevc_enc
    type = "hevc_enc", modalias = "of:Nhevc_encT<NULL>Ccnm,_HevcEnc", driver = "HevcEnc"
  platform device: name = mesonstream
    path = /devices/platform/mesonstream
    type = "mesonstream", modalias = "of:NmesonstreamT<NULL>Camlogic,_codec,_streambuf", driver = "mesonstream"
  platform device: name = ffd19000.pwm
    path = /devices/platform/soc/ffd00000.cbus/ffd19000.pwm
    type = "pwm", modalias = "of:NpwmT<NULL>Camlogic,g12a-ee-pwm", driver = "meson-pwm"
  platform device: name = auge_sound
    path = /devices/platform/auge_sound
    type = "auge_sound", modalias = "of:Nauge_soundT<NULL>Camlogic,_g12a-sound-card", driver = "asoc-aml-card"
  platform device: name = ff100000.galcore
    path = /devices/platform/ff100000.galcore
    type = "galcore", modalias = "of:NgalcoreT<NULL>Camlogic,_galcore", driver = ""
  platform device: name = Fixed MDIO bus.0
    path = /devices/platform/Fixed MDIO bus.0
    type = "", modalias = "platform:Fixed MDIO bus", driver = ""
    type = "audiobus", modalias = "of:NaudiobusT<NULL>Camlogic,_audio-controllerCsimple-bus", driver = "aml-audio-controller"
  platform device: name = picdec
    path = /devices/platform/picdec
    type = "picdec", modalias = "of:NpicdecT<NULL>Camlogic,_picdec", driver = ""
  platform device: name = gpioleds
    path = /devices/platform/gpioleds
    type = "gpioleds", modalias = "of:NgpioledsT<NULL>Cgpio-leds", driver = "leds-gpio"
  platform device: name = securitykey
    path = /devices/platform/securitykey
    type = "securitykey", modalias = "of:NsecuritykeyT<NULL>Caml,_securitykey", driver = "securitykey"
  platform device: name = ff634400.periphs
    path = /devices/platform/soc/ff634400.periphs
    type = "periphs", modalias = "of:NperiphsT<NULL>Csimple-bus", driver = ""
  platform device: name = snd-soc-dummy
    path = /devices/platform/snd-soc-dummy
    type = "", modalias = "platform:snd-soc-dummy", driver = "snd-soc-dummy"
  platform device: name = vdin1
    path = /devices/platform/vdin1
    type = "vdin1", modalias = "of:Nvdin1T<NULL>Camlogic,_vdin", driver = "vdin"
  platform device: name = ff808040.rc
    path = /devices/platform/ff808040.rc
    type = "rc", modalias = "of:NrcT<NULL>Camlogic,_aml_remote", driver = "meson-remote"
  platform device: name = ff660000.audiobus:effect
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:effect
    type = "effect", modalias = "of:NeffectT<NULL>Camlogic,_snd-effect-v3", driver = "Effects"
  platform device: name = backlight
    path = /devices/platform/backlight
    type = "backlight", modalias = "of:NbacklightT<NULL>Camlogic,_backlight-sm1", driver = "aml-bl"
  platform device: name = ffe09080.usb3phy
    path = /devices/platform/ffe09080.usb3phy
    type = "usb3phy", modalias = "of:Nusb3phyT<NULL>Camlogic,_amlogic-new-usb3-v2", driver = "amlogic-new-usb3-v2"
  platform device: name = ff660000.audiobus:earc
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:earc
    type = "earc", modalias = "of:NearcT<NULL>Camlogic,_sm1-snd-earc", driver = "EARC"
  platform device: name = xhci-hcd.0.auto
    path = /devices/platform/ff500000.dwc3/xhci-hcd.0.auto
    type = "", modalias = "platform:xhci-hcd", driver = "xhci-hcd"
    is usb
    is xhci
  platform device: name = ppmgr
    path = /devices/platform/ppmgr
    type = "ppmgr", modalias = "of:NppmgrT<NULL>Camlogic,_ppmgr", driver = ""
  platform device: name = ffd1c000.i2c
    path = /devices/platform/soc/ffd00000.cbus/ffd1c000.i2c
    type = "i2c", modalias = "of:Ni2cT<NULL>Camlogic,meson-g12a-i2c", driver = "meson-i2c"
  platform device: name = ff632000.t9015
    path = /devices/platform/ff632000.t9015
    type = "t9015", modalias = "of:Nt9015T<NULL>Camlogic,_aml_codec_T9015", driver = "aml_codec_T9015"
  platform device: name = ff80014c.meson-irblaster
    path = /devices/platform/ff80014c.meson-irblaster
    type = "meson-irblaster", modalias = "of:Nmeson-irblasterT<NULL>Camlogic,_meson_irblaster", driver = "meson_irblaster"
  platform device: name = ff660000.audiobus:resample@0
    path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:resample@0
    type = "resample", modalias = "of:NresampleT<NULL>Camlogic,_sm1-resample", driver = ""
  platform device: name = pinctrl@ff634480
    path = /devices/platform/pinctrl@ff634480
    type = "pinctrl", modalias = "of:NpinctrlT<NULL>Camlogic,meson-g12a-periphs-pinctrl", driver = "meson-g12a-pinctrl"
  platform device: name = rtc
    path = /devices/platform/rtc
    type = "rtc", modalias = "of:NrtcT<NULL>Camlogic,_aml_vrtc", driver = "aml_vrtc"
  platform device: name = ff634800.p_tsensor
    path = /devices/platform/ff634800.p_tsensor
    type = "p_tsensor", modalias = "of:Np_tsensorT<NULL>Camlogic,_r1p1-tsensor", driver = "meson-tsensor"
  platform device: name = ff6345e0.ram-dump
    path = /devices/platform/ff6345e0.ram-dump
    type = "ram-dump", modalias = "of:Nram-dumpT<NULL>Camlogic,_ram_dump", driver = "mdump"
  platform device: name = ffe05000.sd
    path = /devices/platform/ffe05000.sd
    type = "sd", modalias = "of:NsdT<NULL>Camlogic,_meson-mmc-sm1", driver = "meson-aml-mmc"
  platform device: name = vout2
    path = /devices/platform/vout2
    type = "vout2", modalias = "of:Nvout2T<NULL>Camlogic,_vout2", driver = "vout2"
>> pci.8: of_platform
sysfs: no such bus: of_platform
>> pci.9: vm
sysfs: no such bus: vm
>> pci.10: virtio
sysfs: no such bus: virtio
>> pci.11: ibmebus
sysfs: no such bus: ibmebus
>> pci.12: uisvirtpci
sysfs: no such bus: uisvirtpci
>> pci.13: mmc
  mmc device: name = sd:1234
    path = /devices/platform/ffe05000.sd/mmc_host/sd/sd:1234
    driver = "mmcblk"
    index = -1
    type = "SD"
  mmc device: name = emmc:0001
    path = /devices/platform/ffe07000.emmc/mmc_host/emmc/emmc:0001
    driver = "mmcblk"
    index = -1
    type = "MMC"
  mmc device: name = sdio:0001
    path = /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001
    driver = "(null)"
    index = -1
    type = "SDIO"
>> pci.14: sdio
  sdio device: name = sdio:0001:1
    path = /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
    driver = "rtl88x2cs"
    modalias = "sdio:c07v024CdC822"
    vendor = 588
    device = 51234
>> pci.15: nd
sysfs: no such bus: nd
>> pci.16: visorbus
sysfs: no such bus: visorbus
>> pci.17: mdio
  mdio device: name = stmmac-0:00
    path = /devices/platform/ff3f0000.ethernet/mdio_bus/stmmac-0/stmmac-0:00
  mdio device: name = stmmac-0:07
    path = /devices/platform/ff3f0000.ethernet/mdio_bus/stmmac-0/stmmac-0:07
>> monitor.1: ddc
>> monitor.2: bios
>> monitor.3: pci
>> monitor.4: internal db
>> monitor.5: prom
>> pcmcia.1: sysfs drivers
>> pcmcia.2: pcmcia
sysfs: no such bus: pcmcia
>> pcmcia.3: pcmcia ctrl
sysfs: no such class: pcmcia_socket
>> serial.1: read info
----- serial info -----
----- serial info end -----
>> serial.2: build list
>> misc.5: misc data
----- misc resources -----
irq:0 19 (  3466864) "27 Level     arch_timer"
irq:0 21 (    85913) "92 Edge      Meson TimerF"
irq:0 22 (   327434) "192 Level     ffe40000.bifrost"
irq:0 23 (      504) "193 Level     ffe40000.bifrost"
irq:0 24 (   129329) "194 Level     ffe40000.bifrost"
irq:0 26 (        2) "241 Edge    "
irq:0 27 (        2) "242 Edge    "
irq:0 28 (    25400) "40 Edge      eth0"
irq:0 29 (    17150) "62 Level     xhci-hcd:usb1"
irq:0 34 (        0) "71 Edge      ffd1c000.i2c"
irq:0 36 (      753) "225 Edge      meson_uart"
irq:0 41 (    35608) "184 Edge    "
irq:0 50 (        0) "228 Edge      keypad"
irq:0 51 (   527947) "58 Edge      meson_uart"
irq:0 52 (        3) "89 Edge      hdmitx"
irq:0 54 (        9) "235 Edge      hdmi_aocecb"
irq:0 58 (        0) "178 Edge      ge2d"
irq:0 59 (   283085) "35 Edge      osd-vsync" "lcd_vsync" "vsync"
irq:0 62 (        0) "75 Edge      vdec-0"
irq:0 63 (      724) "76 Edge      vdec-1"
irq:0 66 (   283084) "121 Edge      rdma"
irq:0 67 (        0) "88 Edge      osd-vsync-viu2" "lcd_vsync2"
irq:0 68 (        1) "230 Edge      ff80014c.meson-irblaster"
irq:0 69 (   111307) "223 Edge      meson-aml-mmc"
irq:0 70 (     8964) "222 Edge      meson-aml-mmc"
irq:0 71 (   424368) "221 Level     meson-aml-mmc"
irq:0 73 (       31) "83 Edge      dmc_monitor"
irq:0 74 (        0) "212 Edge      aml-aes" "aml-sha"
irq:0 75 (      720) "78 Edge      pre_di"
irq:0 76 (        0) "72 Edge      post_di"
irq:0 77 (     5063) "67 Edge      ff634800.p_tsensor"
irq:0 78 (       47) "68 Edge      ff634c00.d_tsensor"
----- misc resources end -----
>> parallel.1: pp mod
>> parallel.2.1: lp read info
>> parallel.2.2: lp read info
>> parallel.2.3: lp read info
----- parallel info -----
----- parallel info end -----
>> block.1: block modules
>> block.2: sysfs drivers
>> block.3: cdrom
----- /proc/sys/dev/cdrom/info -----
drive name:
drive speed:
drive # of slots:
Can close tray:
Can open tray:
Can lock tray:
Can change speed:
Can select disk:
Can read multisession:
Can read MCN:
Reports media changed:
Can play audio:
Can write CD-R:
Can write CD-RW:
Can read DVD:
Can write DVD-R:
Can write DVD-RAM:
Can read MRW:
Can write MRW:
Can write RAM:
----- /proc/sys/dev/cdrom/info end -----
>> block.4: partition
----- /proc/partitions -----
     1        0       4096 ram0
     1        1       4096 ram1
     1        2       4096 ram2
     1        3       4096 ram3
     1        4       4096 ram4
     1        5       4096 ram5
     1        6       4096 ram6
     1        7       4096 ram7
     1        8       4096 ram8
     1        9       4096 ram9
     1       10       4096 ram10
     1       11       4096 ram11
     1       12       4096 ram12
     1       13       4096 ram13
     1       14       4096 ram14
     1       15       4096 ram15
   252        0     262144 zram0
   179        0   61071360 mmcblk0
   179        1       4096 mmcblk0p1
   179        2      65536 mmcblk0p2
   179        3    1146880 mmcblk0p3
   179        4       8192 mmcblk0p4
   179        5       8192 mmcblk0p5
   179        6      24576 mmcblk0p6
   179        7       8192 mmcblk0p7
   179        8       8192 mmcblk0p8
   179        9       8192 mmcblk0p9
   179       10      16384 mmcblk0p10
   179       11      16384 mmcblk0p11
   179       12      16384 mmcblk0p12
   179       13      16384 mmcblk0p13
   179       14       2048 mmcblk0p14
   179       15      32768 mmcblk0p15
   179       16    1146880 mmcblk0p16
   179       17     131072 mmcblk0p17
   179       18    1310720 mmcblk0p18
   179       19     131072 mmcblk0p19
   179       20   56788992 mmcblk0p20
   179       96       4096 mmcblk0rpmb
   179       64       4096 mmcblk0boot1
   179       32       4096 mmcblk0boot0
   179      128    7563264 mmcblk1
   179      129     524288 mmcblk1p1
   179      130      32768 mmcblk1p2
----- /proc/partitions end -----
disks:
  ram0
  ram1
  ram2
  ram3
  ram4
  ram5
  ram6
  ram7
  ram8
  ram9
  ram10
  ram11
  ram12
  ram13
  ram14
  ram15
  zram0
  mmcblk0
  mmcblk0rpmb
  mmcblk0boot1
  mmcblk0boot0
  mmcblk1
partitions:
  mmcblk0p1
  mmcblk0p2
  mmcblk0p3
  mmcblk0p4
  mmcblk0p5
  mmcblk0p6
  mmcblk0p7
  mmcblk0p8
  mmcblk0p9
  mmcblk0p10
  mmcblk0p11
  mmcblk0p12
  mmcblk0p13
  mmcblk0p14
  mmcblk0p15
  mmcblk0p16
  mmcblk0p17
  mmcblk0p18
  mmcblk0p19
  mmcblk0p20
  mmcblk1p1
  mmcblk1p2
>> block.5: get sysfs block dev data
-----  lsscsi -----
-----  lsscsi end -----
  block: name = ram11, path = /class/block/ram11
    dev = 1:11
    range = 1
>> block.5: /dev/ram11
  block: name = ram2, path = /class/block/ram2
    dev = 1:2
    range = 1
>> block.5: /dev/ram2
  block: name = logo, path = /class/block/logo
    dev = 179:5
  block: name = vendor, path = /class/block/vendor
    dev = 179:16
  block: name = loop1, path = /class/block/loop1
    dev = 7:8
    range = 8
  block: name = param, path = /class/block/param
    dev = 179:10
  block: name = reserved, path = /class/block/reserved
    dev = 179:2
  block: name = ram0, path = /class/block/ram0
    dev = 1:0
    range = 1
>> block.5: /dev/ram0
  block: name = mmcblk0rpmb, path = /class/block/mmcblk0rpmb
    dev = 179:96
    range = 32
    block device: bus = block, bus_id = mmcblk0 driver = (null)
      path = /devices/platform/ffe07000.emmc/mmc_host/emmc/emmc:0001/block/mmcblk0
>> block.5: /dev/mmcblk0rpmb
  block: name = dtbo, path = /class/block/dtbo
    dev = 179:8
  block: name = ram9, path = /class/block/ram9
    dev = 1:9
    range = 1
>> block.5: /dev/ram9
  block: name = misc, path = /class/block/misc
    dev = 179:7
  block: name = tee, path = /class/block/tee
    dev = 179:15
  block: name = system, path = /class/block/system
    dev = 179:18
  block: name = ram7, path = /class/block/ram7
    dev = 1:7
    range = 1
>> block.5: /dev/ram7
  block: name = loop6, path = /class/block/loop6
    dev = 7:48
    range = 8
  block: name = mmcblk1p1, path = /class/block/mmcblk1p1
    dev = 179:129
  block: name = mmcblk1, path = /class/block/mmcblk1
    dev = 179:128
    range = 32
    block device: bus = mmc, bus_id = sd:1234 driver = mmcblk
>> block.5: /dev/mmcblk1
  block: name = ram14, path = /class/block/ram14
    dev = 1:14
    range = 1
>> block.5: /dev/ram14
  block: name = cri_data, path = /class/block/cri_data
    dev = 179:9
  block: name = product, path = /class/block/product
    dev = 179:19
  block: name = metadata, path = /class/block/metadata
    dev = 179:13
  block: name = ram5, path = /class/block/ram5
    dev = 1:5
    range = 1
>> block.5: /dev/ram5
  block: name = md0, path = /class/block/md0
    dev = 9:0
    range = 1
  block: name = loop4, path = /class/block/loop4
    dev = 7:32
    range = 8
  block: name = mmcblk0boot0, path = /class/block/mmcblk0boot0
    dev = 179:32
    range = 32
>> block.5: /dev/mmcblk0boot0
  block: name = ram12, path = /class/block/ram12
    dev = 1:12
    range = 1
>> block.5: /dev/ram12
  block: name = bootloader, path = /class/block/bootloader
    dev = 179:1
  block: name = ram3, path = /class/block/ram3
    dev = 1:3
    range = 1
>> block.5: /dev/ram3
  block: name = loop2, path = /class/block/loop2
    dev = 7:16
    range = 8
  block: name = vbmeta, path = /class/block/vbmeta
    dev = 179:14
  block: name = ram10, path = /class/block/ram10
    dev = 1:10
    range = 1
>> block.5: /dev/ram10
  block: name = odm, path = /class/block/odm
    dev = 179:17
  block: name = ram1, path = /class/block/ram1
    dev = 1:1
    range = 1
>> block.5: /dev/ram1
  block: name = loop0, path = /class/block/loop0
    dev = 7:0
    range = 8
  block: name = cache, path = /class/block/cache
    dev = 179:3
  block: name = ram8, path = /class/block/ram8
    dev = 1:8
    range = 1
>> block.5: /dev/ram8
  block: name = data, path = /class/block/data
    dev = 179:20
  block: name = loop7, path = /class/block/loop7
    dev = 7:56
    range = 8
  block: name = mmcblk1p2, path = /class/block/mmcblk1p2
    dev = 179:130
  block: name = ram15, path = /class/block/ram15
    dev = 1:15
    range = 1
>> block.5: /dev/ram15
  block: name = env, path = /class/block/env
    dev = 179:4
  block: name = ram6, path = /class/block/ram6
    dev = 1:6
    range = 1
>> block.5: /dev/ram6
  block: name = zram0, path = /class/block/zram0
    dev = 252:0
    range = 1
>> block.5: /dev/zram0
  block: name = recovery, path = /class/block/recovery
    dev = 179:6
  block: name = loop5, path = /class/block/loop5
    dev = 7:40
    range = 8
  block: name = mmcblk0boot1, path = /class/block/mmcblk0boot1
    dev = 179:64
    range = 32
>> block.5: /dev/mmcblk0boot1
  block: name = mmcblk0, path = /class/block/mmcblk0
    dev = 179:0
    range = 32
    block device: bus = mmc, bus_id = emmc:0001 driver = mmcblk
  block: name = boot, path = /class/block/boot
    dev = 179:11
  block: name = ram13, path = /class/block/ram13
    dev = 1:13
    range = 1
>> block.5: /dev/ram13
  block: name = ram4, path = /class/block/ram4
    dev = 1:4
    range = 1
>> block.5: /dev/ram4
  block: name = rsv, path = /class/block/rsv
    dev = 179:12
  block: name = loop3, path = /class/block/loop3
    dev = 7:24
    range = 8
>> scsi.1: scsi modules
>> scsi.2: scsi tape
sysfs: no such class: scsi_tape
>> scsi.3: scsi generic
sysfs: no such class: scsi_generic
>> usb.1: sysfs drivers
>> usb.2: usb
  usb dev: /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1
  usb dev: /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb2
  usb device: name = usb1
    path = /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1
  usb device: name = 1-0:1.0
    path = /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/1-0:1.0
    modalias = "usb:v1D6Bp0002d0409dc09dsc00dp01ic09isc00ip00in00"
    bInterfaceNumber = 0
    bInterfaceClass = 9
    bInterfaceSubClass = 0
    bInterfaceProtocol = 0
    if: 1-0:1.0 @ /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1
    bDeviceClass = 9
    bDeviceSubClass = 0
    bDeviceProtocol = 1
    idVendor = 0x1d6b
    idProduct = 0x0002
    manufacturer = "Linux 4.9.113 xhci-hcd"
    product = "xHCI Host Controller"
    serial = "xhci-hcd.0.auto"
    bcdDevice = 0409
    speed = "480"
  usb device: name = usb2
    path = /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb2
  usb device: name = 2-0:1.0
    path = /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb2/2-0:1.0
    modalias = "usb:v1D6Bp0003d0409dc09dsc00dp03ic09isc00ip00in00"
    bInterfaceClass = 9
    if: 2-0:1.0 @ /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb2
    bDeviceClass = 9
    bDeviceSubClass = 0
    bDeviceProtocol = 3
    idVendor = 0x1d6b
    idProduct = 0x0003
    bcdDevice = 0409
    speed = "5000"
>> usb.3.1: joydev mod
>> usb.3.2: evdev mod
>> usb.3.3: input
  input: name = event5, path = /devices/virtual/misc/uhid/0005:05AC:023C.0002/input/input5/event5
    dev = 13:69
    input device: bus = hid, bus_id = 0005:05AC:023C.0002 driver = hid-generic
  input: name = input3, path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:vad/input/input3
    no dev - ignored
  input: name = event3, path = /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:vad/input/input3/event3
    dev = 13:67
    input device: bus = platform, bus_id = ff660000.audiobus:vad driver = VAD
  input: name = mice, path = /devices/virtual/input/mice
    dev = 13:63
  input: name = input1, path = /devices/platform/ff808040.rc/input/input1
    no dev - ignored
  input: name = event1, path = /devices/platform/ff808040.rc/input/input1/event1
    dev = 13:65
    input device: bus = platform, bus_id = ff808040.rc driver = meson-remote
  input: name = mouse0, path = /devices/platform/ff808040.rc/input/input1/mouse0
    dev = 13:32
  input: name = input4, path = /devices/virtual/misc/uhid/0005:046D:B008.0001/input/input4
    no dev - ignored
  input: name = event4, path = /devices/virtual/misc/uhid/0005:046D:B008.0001/input/input4/event4
    dev = 13:68
    input device: bus = hid, bus_id = 0005:046D:B008.0001 driver = hid-generic
  input: name = input2, path = /devices/virtual/input/input2
    no dev - ignored
  input: name = event2, path = /devices/virtual/input/input2/event2
    dev = 13:66
    input device: bus = input, bus_id = input2 driver = (null)
  input: name = mouse1, path = /devices/virtual/misc/uhid/0005:046D:B008.0001/input/input4/mouse1
    dev = 13:33
  input: name = input0, path = /devices/platform/meson-vfd/input/input0
    no dev - ignored
  input: name = event0, path = /devices/platform/meson-vfd/input/input0/event0
    dev = 13:64
    input device: bus = platform, bus_id = meson-vfd driver = meson-vfd
  input: name = input5, path = /devices/virtual/misc/uhid/0005:05AC:023C.0002/input/input5
    no dev - ignored
>> usb.3.4: lp
sysfs: no such class: usb
>> usb.3.5: serial
>> modem.1: serial
>> mouse.2: serial
>> input.1: joydev mod
>> input.1.1: evdev mod
>> input.2: input
----- /proc/bus/input/devices -----
  I: Bus=0010 Vendor=0001 Product=0001 Version=0100
  N: Name="vfd_keypad"
  P: Phys=vfd_keypad/input0
  S: Sysfs=/devices/platform/meson-vfd/input/input0
  U: Uniq=
  H: Handlers=kbd event0
  B: PROP=0
  B: EV=100003
  B: KEY=c0000 0 0 0 0 0 0 0 800 1c0000 0 0 10000000
  N: Name="aml_keypad"
  P: Phys=keypad/input0
  S: Sysfs=/devices/platform/ff808040.rc/input/input1
  U: Uniq=
  H: Handlers=kbd mouse0 event1
  B: PROP=0
  B: EV=7
  B: KEY=ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff 0 0 70000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff fffffffe
  B: REL=103
  I: Bus=0010 Vendor=1b8e Product=0cec Version=0001
  N: Name="cec_input"
  P: Phys=
  S: Sysfs=/devices/virtual/input/input2
  U: Uniq=
  H: Handlers=kbd event2
  B: PROP=0
  B: EV=3
  B: KEY=1 0 0 0 0 100000 0 0 0
  N: Name="vad_keypad"
  P: Phys=vad_keypad/input3
  S: Sysfs=/devices/platform/soc/ff660000.audiobus/ff660000.audiobus:vad/input/input3
  U: Uniq=
  H: Handlers=kbd event3
  B: PROP=0
  B: EV=3
  I: Bus=0005 Vendor=046d Product=b008 Version=0018
  N: Name="Bluetooth Laser Travel Mouse"
  P: Phys=
  S: Sysfs=/devices/virtual/misc/uhid/0005:046D:B008.0001/input/input4
  U: Uniq=00:1f:20:0f:98:3c
  H: Handlers=mouse1 event4
  B: PROP=0
  B: EV=17
  B: KEY=ff0000 0 0 0 0 0 0 0 0
  B: REL=143
  B: MSC=10
  I: Bus=0005 Vendor=05ac Product=023c Version=0002
  N: Name="Bluetooth 3.0 Keyboard"
  P: Phys=
  S: Sysfs=/devices/virtual/misc/uhid/0005:05AC:023C.0002/input/input5
  U: Uniq=20:14:12:0f:e9:90
  H: Handlers=kbd leds event5
  B: PROP=0
  B: EV=12001b
  B: KEY=20 0 0 0 0 0 0 400000 0 0 0 10000 2000007 ff9f307a c9405fff febeffdf ffefffff ffffffff fffffffe
  B: ABS=f00 0
  B: MSC=10
  B: LED=1f
----- /proc/bus/input/devices end -----
bus = 16, name = vfd_keypad
  handlers = kbd event0
  key = 000c00000000000000000000000000000000000000000000000000000000000000000800001c0000000000000000000010000000
  mouse buttons = 0
  mouse wheels = 0
  is_mouse = 0
  is_joystick = 0
unknown non-USB input device
bus = 16, name = aml_keypad
  handlers = kbd mouse0 event1
  key = ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff000000000000000000070000fffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffe
  rel = 00000103
  mouse buttons = 3
  mouse wheels = 1
  is_mouse = 1
  is_joystick = 0
bus = 16, name = cec_input
  handlers = kbd event2
  key = 000000010000000000000000000000000000000000100000000000000000000000000000
  mouse buttons = 0
  mouse wheels = 0
  is_mouse = 0
  is_joystick = 0
bus = 16, name = vad_keypad
  handlers = kbd event3
  mouse buttons = 0
  mouse wheels = 0
  is_mouse = 0
  is_joystick = 0
bus = 5, name = Bluetooth Laser Travel Mouse
  handlers = mouse1 event4
  key = 00ff00000000000000000000000000000000000000000000000000000000000000000000
  rel = 00000143
  mouse buttons = 8
  mouse wheels = 2
  is_mouse = 1
  is_joystick = 0
bus = 5, name = Bluetooth 3.0 Keyboard
  handlers = kbd leds event5
  key = 00000020000000000000000000000000000000000000000000000000004000000000000000000000000000000001000002000007ff9f307ac9405ffffebeffdfffeffffffffffffffffffffe
  abs = 00000f0000000000
  mouse buttons = 0
  mouse wheels = 0
  is_mouse = 0
  is_joystick = 0
>> kbd.2: uml
>> cpu.1: cpuinfo
  processor    : 0
  BogoMIPS    : 76.32
  CPU architecture: 7
  CPU variant    : 0x1
  CPU part    : 0xd05
  CPU revision    : 0
  processor    : 1
  BogoMIPS    : 76.32
  CPU architecture: 7
  CPU variant    : 0x1
  CPU part    : 0xd05
  CPU revision    : 0
  processor    : 2
  BogoMIPS    : 76.32
  CPU architecture: 7
  CPU variant    : 0x1
  CPU part    : 0xd05
  CPU revision    : 0
  processor    : 3
  BogoMIPS    : 76.32
  CPU architecture: 7
  CPU variant    : 0x1
  CPU part    : 0xd05
  CPU revision    : 0
  Hardware    : Amlogic
>> kbd.3: serial console
>> fb.1: read info
>> net.1: get network data
  net interface: name = sit0, path = /class/net/sit0
    type = 776
    hw_addr = 00:00:00:00
  sit0: ethtool permanent hw address[4]: 00:00:00:00
    ethtool private flags: 0
  net interface: name = eth0, path = /class/net/eth0
    type = 1
    carrier = 1
    hw_addr = 90:0e:b3:1d:20:fe
    net device: path = /devices/platform/ff3f0000.ethernet
    net driver: name = meson6-dwmac, path = /bus/platform/drivers/meson6-dwmac
  eth0: ethtool permanent hw address[6]: 00:00:00:00:00:00
  net interface: name = ip6_vti0, path = /class/net/ip6_vti0
    type = 769
    hw_addr = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
  ip6_vti0: ethtool permanent hw address[16]: 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
  net interface: name = p2p0, path = /class/net/p2p0
    type = 1
    carrier = 0
    hw_addr = 82:9f:9b:90:19:74
    net device: path = /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
    net driver: name = rtl88x2cs, path = /bus/sdio/drivers/rtl88x2cs
  p2p0: ethtool permanent hw address[6]: 82:9f:9b:90:19:74
  net interface: name = tunl0, path = /class/net/tunl0
    type = 768
  tunl0: ethtool permanent hw address[4]: 00:00:00:00
  net interface: name = wlan0, path = /class/net/wlan0
    type = 1
    carrier = 0
    hw_addr = 80:9f:9b:90:19:74
  wlan0: ethtool permanent hw address[6]: 80:9f:9b:90:19:74
  net interface: name = ip6tnl0, path = /class/net/ip6tnl0
    type = 769
  ip6tnl0: ethtool permanent hw address[16]: 0a:90:88:19:2e:d7:00:00:00:00:00:00:00:00:00:00
    GDRVINFO ethtool error: Operation not supported on transport endpoint
  net interface: name = ip_vti0, path = /class/net/ip_vti0
    type = 768
  ip_vti0: ethtool permanent hw address[4]: 00:00:00:00
  net interface: name = lo, path = /class/net/lo
    type = 772
    carrier = 1
  lo: ethtool permanent hw address[6]: 00:00:00:00:00:00
  sit0: GLINK ethtool error: Operation not supported on transport endpoint
  ip6_vti0: GLINK ethtool error: Operation not supported on transport endpoint
  tunl0: GLINK ethtool error: Operation not supported on transport endpoint
  ip6tnl0: GLINK ethtool error: Operation not supported on transport endpoint
  ip_vti0: GLINK ethtool error: Operation not supported on transport endpoint
>> pppoe.1: looking for pppoe
>> pppoe.2: discovery
eth0: socket failed: m
p2p0: socket failed: m
>> wlan.1: detecting wlan features
*** device p2p0 is wireless ***
>> isdn.1: list
>> dsl.1: list
>> int.2: cdrom
>> int.3: media
>> int.4.1: /dev/ram11
  read_block0: open(/dev/ram11) failed
>> int.4.2: /dev/ram2
  read_block0: open(/dev/ram2) failed
>> int.4.3: /dev/ram0
  read_block0: open(/dev/ram0) failed
>> int.4.4: /dev/mmcblk0rpmb
  read_block0: open(/dev/mmcblk0rpmb) failed
>> int.4.5: /dev/ram9
  read_block0: open(/dev/ram9) failed
>> int.4.6: /dev/ram7
  read_block0: open(/dev/ram7) failed
>> int.4.7: /dev/mmcblk1
  read_block0: open(/dev/mmcblk1) failed
>> int.4.8: /dev/ram14
  read_block0: open(/dev/ram14) failed
>> int.4.9: /dev/ram5
  read_block0: open(/dev/ram5) failed
>> int.4.10: /dev/mmcblk0boot0
  read_block0: open(/dev/mmcblk0boot0) failed
>> int.4.11: /dev/ram12
  read_block0: open(/dev/ram12) failed
>> int.4.12: /dev/ram3
  read_block0: open(/dev/ram3) failed
>> int.4.13: /dev/ram10
  read_block0: open(/dev/ram10) failed
>> int.4.14: /dev/ram1
  read_block0: open(/dev/ram1) failed
>> int.4.15: /dev/ram8
  read_block0: open(/dev/ram8) failed
>> int.4.16: /dev/ram15
  read_block0: open(/dev/ram15) failed
>> int.4.17: /dev/ram6
  read_block0: open(/dev/ram6) failed
>> int.4.18: /dev/zram0
  read_block0: open(/dev/zram0) failed
>> int.4.19: /dev/mmcblk0boot1
  read_block0: open(/dev/mmcblk0boot1) failed
>> int.4.20: /dev/mmcblk0
  read_block0: open(/dev/mmcblk0) failed
>> int.4.21: /dev/ram13
  read_block0: open(/dev/ram13) failed
>> int.4.22: /dev/ram4
  read_block0: open(/dev/ram4) failed
>> int.4: floppy
>> int.6: mouse
>> int.7: hdb
>> int.7.1: modules
>> int.8: usbscsi
>> int.9: hotplug
>> int.10: modem
>> int.11: wlan
>> int.12: udev
-----  udevinfo -----
-----  udevinfo end -----
>> int.13: device names
>> int.16: parent
  prop read: rdCR.n_7QNeEnh23 (failed)
  old prop read: rdCR.n_7QNeEnh23 (failed)
  prop read: rdCR.CxwsZFjVASF (failed)
  old prop read: rdCR.CxwsZFjVASF (failed)
  prop read: PP78.TfPFe67fIBB (failed)
  old prop read: PP78.TfPFe67fIBB (failed)
  prop read: IiIy.vcc7vMyNqX6 (failed)
  old prop read: IiIy.vcc7vMyNqX6 (failed)
  prop read: M8Ep._NN+DZ1HDn4 (failed)
  old prop read: M8Ep._NN+DZ1HDn4 (failed)
  prop read: CgKD.TzQFl_vZhO4 (failed)
  old prop read: CgKD.TzQFl_vZhO4 (failed)
  prop read: TIBi.VoJli79_k95 (failed)
  old prop read: TIBi.VoJli79_k95 (failed)
  prop read: +vYY.OeWlO7L59hD (failed)
  old prop read: +vYY.OeWlO7L59hD (failed)
  prop read: VVOc.Fxp0d3BezAE (failed)
  old prop read: VVOc.Fxp0d3BezAE (failed)
  prop read: 7tlP.Fxp0d3BezAE (failed)
  old prop read: 7tlP.Fxp0d3BezAE (failed)
  prop read: CWFH.Fxp0d3BezAE (failed)
  old prop read: CWFH.Fxp0d3BezAE (failed)
  prop read: ni5P.Fxp0d3BezAE (failed)
  old prop read: ni5P.Fxp0d3BezAE (failed)
  prop read: XOSI.Fxp0d3BezAE (failed)
  old prop read: XOSI.Fxp0d3BezAE (failed)
  prop read: d1y9.Fxp0d3BezAE (failed)
  old prop read: d1y9.Fxp0d3BezAE (failed)
  prop read: kLao.Fxp0d3BezAE (failed)
  old prop read: kLao.Fxp0d3BezAE (failed)
  prop read: 685D.SE1wIdpsiiC (failed)
  old prop read: 685D.SE1wIdpsiiC (failed)
  prop read: ZJLH.SE1wIdpsiiC (failed)
  old prop read: ZJLH.SE1wIdpsiiC (failed)
  prop read: s19p.Fxp0d3BezAE (failed)
  old prop read: s19p.Fxp0d3BezAE (failed)
  prop read: UPWc.Fxp0d3BezAE (failed)
  old prop read: UPWc.Fxp0d3BezAE (failed)
  prop read: Hj0w.Fxp0d3BezAE (failed)
  old prop read: Hj0w.Fxp0d3BezAE (failed)
  prop read: ygeg.Fxp0d3BezAE (failed)
  old prop read: ygeg.Fxp0d3BezAE (failed)
  prop read: a20U.Fxp0d3BezAE (failed)
  old prop read: a20U.Fxp0d3BezAE (failed)
  prop read: 2K8Y.Fxp0d3BezAE (failed)
  old prop read: 2K8Y.Fxp0d3BezAE (failed)
  prop read: ghVL.Fxp0d3BezAE (failed)
  old prop read: ghVL.Fxp0d3BezAE (failed)
  prop read: 4DCE.Fxp0d3BezAE (failed)
  old prop read: 4DCE.Fxp0d3BezAE (failed)
  prop read: JDPt.Fxp0d3BezAE (failed)
  old prop read: JDPt.Fxp0d3BezAE (failed)
  prop read: xamg.Fxp0d3BezAE (failed)
  old prop read: xamg.Fxp0d3BezAE (failed)
  prop read: OKyR.Fxp0d3BezAE (failed)
  old prop read: OKyR.Fxp0d3BezAE (failed)
  prop read: kuG_.Fxp0d3BezAE (failed)
  old prop read: kuG_.Fxp0d3BezAE (failed)
  prop read: HAKk.Fxp0d3BezAE (failed)
  old prop read: HAKk.Fxp0d3BezAE (failed)
  prop read: l7UW.SE1wIdpsiiC (failed)
  old prop read: l7UW.SE1wIdpsiiC (failed)
  prop read: CJka.SE1wIdpsiiC (failed)
  old prop read: CJka.SE1wIdpsiiC (failed)
  prop read: fU_e.SE1wIdpsiiC (failed)
  old prop read: fU_e.SE1wIdpsiiC (failed)
  prop read: 6gEj.SE1wIdpsiiC (failed)
  old prop read: 6gEj.SE1wIdpsiiC (failed)
  prop read: ZrUn.SE1wIdpsiiC (failed)
  old prop read: ZrUn.SE1wIdpsiiC (failed)
  prop read: 01lr.SE1wIdpsiiC (failed)
  old prop read: 01lr.SE1wIdpsiiC (failed)
  prop read: iTwK.SE1wIdpsiiC (failed)
  old prop read: iTwK.SE1wIdpsiiC (failed)
  prop read: AfAP.SE1wIdpsiiC (failed)
  old prop read: AfAP.SE1wIdpsiiC (failed)
  prop read: dqQT.SE1wIdpsiiC (failed)
  old prop read: dqQT.SE1wIdpsiiC (failed)
  prop read: 8vbH.SE1wIdpsiiC (failed)
  old prop read: 8vbH.SE1wIdpsiiC (failed)
  prop read: b4sL.SE1wIdpsiiC (failed)
  old prop read: b4sL.SE1wIdpsiiC (failed)
  prop read: 2G6Q.SE1wIdpsiiC (failed)
  old prop read: 2G6Q.SE1wIdpsiiC (failed)
  prop read: VRMU.SE1wIdpsiiC (failed)
  old prop read: VRMU.SE1wIdpsiiC (failed)
  prop read: yccY.SE1wIdpsiiC (failed)
  old prop read: yccY.SE1wIdpsiiC (failed)
  prop read: Posc.SE1wIdpsiiC (failed)
  old prop read: Posc.SE1wIdpsiiC (failed)
  prop read: sz6h.SE1wIdpsiiC (failed)
  old prop read: sz6h.SE1wIdpsiiC (failed)
  prop read: ZQIA.SE1wIdpsiiC (failed)
  old prop read: ZQIA.SE1wIdpsiiC (failed)
  prop read: 0cYE.SE1wIdpsiiC (failed)
  old prop read: 0cYE.SE1wIdpsiiC (failed)
  prop read: TnoI.SE1wIdpsiiC (failed)
  old prop read: TnoI.SE1wIdpsiiC (failed)
  prop read: YVjZ.SE1wIdpsiiC (failed)
  old prop read: YVjZ.SE1wIdpsiiC (failed)
  prop read: Psuk.Fxp0d3BezAE (failed)
  old prop read: Psuk.Fxp0d3BezAE (failed)
  prop read: 1EGY.Fxp0d3BezAE (failed)
  old prop read: 1EGY.Fxp0d3BezAE (failed)
  prop read: k4bc.uJrfcCKKe8E (failed)
  old prop read: k4bc.uJrfcCKKe8E (failed)
  prop read: pBe4.PKweOZjtk19 (failed)
  old prop read: pBe4.PKweOZjtk19 (failed)
  prop read: EXC1.+49ps10DtUF (failed)
  old prop read: EXC1.+49ps10DtUF (failed)
  prop read: AH6Q.fmuzbyZs2b0 (failed)
  old prop read: AH6Q.fmuzbyZs2b0 (failed)
  prop read: 3FDI.40rJcU_YN61 (failed)
  old prop read: 3FDI.40rJcU_YN61 (failed)
  prop read: rdCR.j8NaKXDZtZ6 (failed)
  old prop read: rdCR.j8NaKXDZtZ6 (failed)
  prop read: wkFv.j8NaKXDZtZ6 (failed)
  old prop read: wkFv.j8NaKXDZtZ6 (failed)
  prop read: +rIN.j8NaKXDZtZ6 (failed)
  old prop read: +rIN.j8NaKXDZtZ6 (failed)
  prop read: 4zLr.j8NaKXDZtZ6 (failed)
  old prop read: 4zLr.j8NaKXDZtZ6 (failed)
  prop read: wl2P.nfEXJulusj6 (failed)
  old prop read: wl2P.nfEXJulusj6 (failed)
  prop read: usDW.ndpeucax6V1 (failed)
  old prop read: usDW.ndpeucax6V1 (failed)
  prop read: qdX2.GSopYcFr9cF (failed)
  old prop read: qdX2.GSopYcFr9cF (failed)
  prop read: pG9W.ndpeucax6V1 (failed)
  old prop read: pG9W.ndpeucax6V1 (failed)
  prop read: OgUs.GSopYcFr9cF (failed)
  old prop read: OgUs.GSopYcFr9cF (failed)
  prop read: AYEt.QXn1l67RSa1 (failed)
  old prop read: AYEt.QXn1l67RSa1 (failed)
  prop read: HtAv.GSopYcFr9cF (failed)
  old prop read: HtAv.GSopYcFr9cF (failed)
  prop read: b8Rv.GSopYcFr9cF (failed)
  old prop read: b8Rv.GSopYcFr9cF (failed)
  prop read: ZsBS.GQNx7L4uPNA (failed)
  old prop read: ZsBS.GQNx7L4uPNA (failed)
----- kernel log -----
  <7>[ 4314.048269@3]     sysclk(12288000)
  <7>[ 4314.048272@3]     sysclk_bclk_ratio(4)
  <7>[ 4314.048275@3]     bclk(3072000)
  <7>[ 4314.048277@3]     bclk_lrclk_ratio(64)
  <7>[ 4314.048280@3]     lrclk(48000)
  <7>[ 4314.048283@3]     tx_mask(0x3)
  <7>[ 4314.048285@3]     rx_mask(0x3)
  <7>[ 4314.048288@3]     slots(2)
  <7>[ 4314.048290@3]     slot_width(32)
  <7>[ 4314.048293@3]     lane_mask_in(0x2)
  <7>[ 4314.048295@3]     lane_mask_out(0x1)
  <7>[ 4314.048298@3]     lane_oe_mask_in(0x0)
  <7>[ 4314.048301@3]     lane_oe_mask_out(0x0)
  <7>[ 4314.048303@3]     lane_lb_mask_in(0x0)
  <7>[ 4314.048306@3] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
  <7>[ 4314.048309@3] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
  <7>[ 4314.048313@3] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
  <7>[ 4314.048317@3] aml_dai_set_clkdiv, div 4, clksel(1)
  <7>[ 4314.048326@3] aml_dai_set_bclk_ratio, select I2S mode
  <7>[ 4314.048338@3] aml_dai_tdm_hw_params(), enable mclk for TDM-B
  <7>[ 4314.048387@3] aml_tdm_prepare(), reset fddr
  <7>[ 4314.048405@3] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
  <7>[ 4314.048413@3] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
  <7>[ 4314.048425@3] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
  <7>[ 4314.048695@3] tdm playback mute: 0, lane_cnt = 8
  <6>[ 4314.057091@3] asoc-aml-card auge_sound: tdm playback enable
  <7>[ 4314.057146@3] spdif_a is set to enable
  <6>[ 4317.192772@2] asoc-aml-card auge_sound: tdm playback stop
  <7>[ 4317.192872@2] spdif_a is set to disable
  <7>[ 4318.133296@3] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
  <6>[ 4318.133338@3] aml_dai_tdm_hw_free(), disable mclk for TDM-B
  <7>[ 4318.133468@3] tdm playback mute: 1, lane_cnt = 8
  <7>[ 4318.134281@3] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
  <38>[ 4358.182605@1] type=1400 audit(1596269966.517:3383): avc: denied { getattr } for pid=9100 comm="oot.browserfree" path="/proc/vmstat" dev="proc" ino=4026532011 scontext=u:r:untrusted_app_27:s0:c512,c768 tcontext=u:object_r:proc_vmstat:s0 tclass=file permissive=1
  <38>[ 4358.200171@1] type=1400 audit(1596270026.517:3384): avc: denied { open } for pid=9100 comm="oot.browserfree" path="/proc/vmstat" dev="proc" ino=4026532011 scontext=u:r:untrusted_app_27:s0:c512,c768 tcontext=u:object_r:proc_vmstat:s0 tclass=file permissive=1
  <38>[ 4358.223005@1] type=1400 audit(1596270026.517:3384): avc: denied { open } for pid=9100 comm="oot.browserfree" path="/proc/vmstat" dev="proc" ino=4026532011 scontext=u:r:untrusted_app_27:s0:c512,c768 tcontext=u:object_r:proc_vmstat:s0 tclass=file permissive=1
  <38>[ 4358.245479@1] type=1400 audit(1596270026.517:3385): avc: denied { getattr } for pid=9100 comm="oot.browserfree" path="/proc/vmstat" dev="proc" ino=4026532011 scontext=u:r:untrusted_app_27:s0:c512,c768 tcontext=u:object_r:proc_vmstat:s0 tclass=file permissive=1
  <38>[ 4411.902892@0] type=1400 audit(1596270026.517:3385): avc: denied { getattr } for pid=9100 comm="oot.browserfree" path="/proc/vmstat" dev="proc" ino=4026532011 scontext=u:r:untrusted_app_27:s0:c512,c768 tcontext=u:object_r:proc_vmstat:s0 tclass=file permissive=1
  <38>[ 4411.921353@1] type=1400 audit(1596270080.237:3386): avc: denied { read } for pid=13416 comm="hwinfo" name="version" dev="proc" ino=4026531977 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc_version:s0 tclass=file permissive=1
  <4>[ 4411.930553@2] audit: audit_lost=2584 audit_rate_limit=5 audit_backlog_limit=64
  <3>[ 4411.930556@2] audit: rate limit exceeded
  <38>[ 4411.954075@1] type=1400 audit(1596270080.237:3386): avc: denied { read } for pid=13416 comm="hwinfo" name="version" dev="proc" ino=4026531977 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc_version:s0 tclass=file permissive=1
  <38>[ 4411.975878@1] type=1400 audit(1596270080.237:3387): avc: denied { open } for pid=13416 comm="hwinfo" path="/proc/version" dev="proc" ino=4026531977 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc_version:s0 tclass=file permissive=1
  <38>[ 4411.999059@1] type=1400 audit(1596270080.237:3387): avc: denied { open } for pid=13416 comm="hwinfo" path="/proc/version" dev="proc" ino=4026531977 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc_version:s0 tclass=file permissive=1
  <38>[ 4412.021829@1] type=1400 audit(1596270080.237:3388): avc: denied { getattr } for pid=13416 comm="hwinfo" path="/proc/version" dev="proc" ino=4026531977 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc_version:s0 tclass=file permissive=1
  <38>[ 4412.044463@1] type=1400 audit(1596270080.237:3388): avc: denied { getattr } for pid=13416 comm="hwinfo" path="/proc/version" dev="proc" ino=4026531977 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc_version:s0 tclass=file permissive=1
  <38>[ 4412.067542@1] type=1400 audit(1596270080.237:3389): avc: denied { syslog_read } for pid=13416 comm="hwinfo" scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:kernel:s0 tclass=system permissive=1
  <38>[ 4412.086717@1] type=1400 audit(1596270080.237:3389): avc: denied { syslog_read } for pid=13416 comm="hwinfo" scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:kernel:s0 tclass=system permissive=1
  <38>[ 4412.104275@1] type=1400 audit(1596270080.265:3390): avc: denied { read } for pid=13416 comm="hwinfo" name="ioports" dev="proc" ino=4026532001 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
  <38>[ 4567.260061@3] type=1400 audit(1596270080.265:3392): avc: denied { getattr } for pid=13416 comm="hwinfo" path="/proc/ioports" dev="proc" ino=4026532001 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
  <38>[ 4567.277116@3] type=1400 audit(1596270235.589:3409): avc: denied { syslog_read } for pid=14494 comm="hwinfo" scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:kernel:s0 tclass=system permissive=1
  <38>[ 4567.295705@3] type=1400 audit(1596270235.589:3409): avc: denied { syslog_read } for pid=14494 comm="hwinfo" scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:kernel:s0 tclass=system permissive=1
  <38>[ 4567.313566@3] type=1400 audit(1596270235.601:3410): avc: denied { read } for pid=14494 comm="hwinfo" name="ioports" dev="proc" ino=4026532001 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
  <38>[ 4567.335221@3] type=1400 audit(1596270235.601:3410): avc: denied { read } for pid=14494 comm="hwinfo" name="ioports" dev="proc" ino=4026532001 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
  <38>[ 4567.356536@3] type=1400 audit(1596270235.601:3411): avc: denied { open } for pid=14494 comm="hwinfo" path="/proc/ioports" dev="proc" ino=4026532001 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
  <38>[ 4567.379280@3] type=1400 audit(1596270235.601:3411): avc: denied { open } for pid=14494 comm="hwinfo" path="/proc/ioports" dev="proc" ino=4026532001 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
  <38>[ 4567.400561@3] type=1400 audit(1596270235.601:3412): avc: denied { getattr } for pid=14494 comm="hwinfo" path="/proc/ioports" dev="proc" ino=4026532001 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
  <4>[ 4567.448821@2] audit: audit_lost=2600 audit_rate_limit=5 audit_backlog_limit=64
  <38>[ 4567.448900@1] type=1400 audit(1596270235.601:3412): avc: denied { getattr } for pid=14494 comm="hwinfo" path="/proc/ioports" dev="proc" ino=4026532001 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
  <38>[ 4567.448938@1] type=1400 audit(1596270235.781:3413): avc: denied { read } for pid=14494 comm="hwinfo" name="net" dev="sysfs" ino=10220 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_net:s0 tclass=dir permissive=1
  <3>[ 4567.493877@2] audit: rate limit exceeded
----- kernel log end -----
----- /proc/modules -----
  8822cs 2994176 0 - Live 0x00000000 (O)
  galcore 311296 0 - Live 0x00000000 (O)
  aml_hardware_dmx 139264 0 - Live 0x00000000 (O)
  atbm8881_fe 118784 0 - Live 0x00000000 (O)
  vpu 40960 0 - Live 0x00000000 (O)
  encoder 45056 0 - Live 0x00000000 (O)
  amvdec_avs2 176128 0 - Live 0x00000000 (O)
  amvdec_vp9 139264 0 - Live 0x00000000 (O)
  amvdec_vc1 49152 0 - Live 0x00000000 (O)
  amvdec_real 32768 0 - Live 0x00000000 (O)
  amvdec_mmpeg4 32768 0 - Live 0x00000000 (O)
  amvdec_mpeg4 49152 0 - Live 0x00000000 (O)
  amvdec_mmpeg12 36864 0 - Live 0x00000000 (O)
  amvdec_mpeg12 81920 0 - Live 0x00000000 (O)
  amvdec_mmjpeg 24576 0 - Live 0x00000000 (O)
  amvdec_mjpeg 32768 0 - Live 0x00000000 (O)
  amvdec_h265 126976 0 - Live 0x00000000 (O)
  amvdec_h264mvc 49152 0 - Live 0x00000000 (O)
  amvdec_mh264 147456 0 - Live 0x00000000 (O)
  amvdec_h264 114688 0 - Live 0x00000000 (O)
  amvdec_avs 57344 0 - Live 0x00000000 (O)
  stream_input 155648 11 aml_hardware_dmx,amvdec_avs2,amvdec_vp9,amvdec_real,amvdec_mmpeg12,amvdec_mpeg12,amvdec_h265,amvdec_h264mvc,amvdec_mh264,amvdec_h264,amvdec_avs, Live 0x00000000 (O)
  decoder_common 151552 17 encoder,amvdec_avs2,amvdec_vp9,amvdec_vc1,amvdec_real,amvdec_mmpeg4,amvdec_mpeg4,amvdec_mmpeg12,amvdec_mpeg12,amvdec_mmjpeg,amvdec_mjpeg,amvdec_h265,amvdec_h264mvc,amvdec_mh264,amvdec_h264,amvdec_avs,stream_input, Live 0x00000000 (O)
  firmware 24576 18 encoder,amvdec_avs2,amvdec_vp9,amvdec_vc1,amvdec_real,amvdec_mmpeg4,amvdec_mpeg4,amvdec_mmpeg12,amvdec_mpeg12,amvdec_mmjpeg,amvdec_mjpeg,amvdec_h265,amvdec_h264mvc,amvdec_mh264,amvdec_h264,amvdec_avs,stream_input,decoder_common, Live 0x00000000 (O)
  media_clock 36864 13 aml_hardware_dmx,vpu,encoder,amvdec_avs2,amvdec_vp9,amvdec_mpeg12,amvdec_h265,amvdec_mh264,amvdec_h264,amvdec_avs,stream_input,decoder_common,firmware, Live 0x00000000 (O)
  tb_detect 20480 0 - Live 0x00000000 (O)
  mali_kbase 471040 30 - Live 0x00000000 (O)
----- /proc/modules end -----
  used irqs: 19,21,22,23,24,26,27,28,29,34,36,41,50,51,52,54,58,59,62,63
=========== end debug info ============
01: None 00.0: 10107 System
  [Created at sys.61]
  Unique ID: rdCR.n_7QNeEnh23
  Hardware Class: system
  Model: "System"
  Config Status: cfg=new, avail=yes, need=no, active=unknown
06: None 00.0: 10102 Main Memory
  [Created at memory.74]
  Unique ID: rdCR.CxwsZFjVASF
  Hardware Class: memory
  Model: "Main Memory"
  Memory Range: 0x00000000-0xed202fff (rw)
  Memory Size: 3 GB + 768 MB
07: None 00.0: 0200 Ethernet controller
  [Created at pci.1017]
  Unique ID: PP78.TfPFe67fIBB
  SysFS ID: /devices/platform/ff3f0000.ethernet
  SysFS BusID: ff3f0000.ethernet
  Hardware Class: network
  Model: "ARM Ethernet controller"
  Device: "ARM Ethernet controller"
  Driver: "meson6-dwmac"
  Device File: eth0
  HW Address: 90:0e:b3:1d:20:fe
  Link detected: yes
  Module Alias: "of:NethernetT<NULL>Camlogic,_g12a-eth-dwmacCsnps,dwmac"
08: None 00.0: 0c03 USB Controller (XHCI)
  [Created at pci.1049]
  Unique ID: IiIy.vcc7vMyNqX6
  SysFS ID: /devices/platform/ff500000.dwc3/xhci-hcd.0.auto
  SysFS BusID: xhci-hcd.0.auto
  Hardware Class: usb controller
  Model: "ARM USB XHCI controller"
  Device: "ARM USB XHCI controller"
  Driver: "xhci-hcd"
  Module Alias: "platform:xhci-hcd"
09: MMC 00.0: 11700 MMC Controller
  [Created at pci.1867]
  Unique ID: M8Ep._NN+DZ1HDn4
  SysFS ID: /devices/platform/ffe05000.sd/mmc_host/sd/sd:1234
  SysFS BusID: sd:1234
  Model: "MMC Controller"
  Vendor: int 0x6015
  Device: int 0x0001 "MMC Controller"
  Driver: "mmcblk"
10: MMC 00.0: 11700 MMC Controller
  Unique ID: CgKD.TzQFl_vZhO4
  SysFS ID: /devices/platform/ffe07000.emmc/mmc_host/emmc/emmc:0001
  SysFS BusID: emmc:0001
  Vendor: int 0x6015
  Device: int 0x0000 "MMC Controller"
  Driver: "mmcblk"
11: MMC 00.0: 11700 MMC Controller
  Unique ID: TIBi.VoJli79_k95
  SysFS ID: /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001
  SysFS BusID: sdio:0001
  Vendor: int 0x6015
  Device: int 0x0002 "MMC Controller"
12: SDIO 00.0: 0282 WLAN controller
  [Created at pci.1939]
  Unique ID: +vYY.OeWlO7L59hD
  Parent ID: TIBi.VoJli79_k95
  SysFS ID: /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
  SysFS BusID: sdio:0001:1
  Model: "WLAN controller"
  Vendor: sdio 0x024c
  Device: sdio 0xc822
  Driver: "rtl88x2cs"
  Device File: p2p0
  Features: WLAN
  HW Address: 82:9f:9b:90:19:74
  Permanent HW Address: 82:9f:9b:90:19:74
  Link detected: no
  WLAN channels: 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
  WLAN frequencies: 2.412 2.417 2.422 2.427 2.432 2.437 2.442 2.447 2.452 2.457 2.462 2.467 2.472 5.18 5.2 5.22 5.24 5.26 5.28 5.3 5.32 5.5 5.52 5.54 5.56 5.58 5.6 5.62 5.64 5.66 5.68 5.7
  WLAN bitrates: 1 2 5.5 11
  WLAN encryption modes: TKIP CCMP
  WLAN authentication modes: open wpa-psk wpa-eap
  Module Alias: "sdio:c07v024CdC822"
  Attached to: #11 (MMC Controller)
13: None 00.0: 10600 Disk
  [Created at block.245]
  Unique ID: VVOc.Fxp0d3BezAE
  SysFS ID: /class/block/ram11
  Hardware Class: disk
  Model: "Disk"
  Device File: /dev/ram11
  Device Number: block 1:11
  Drive status: no medium
14: None 00.0: 10600 Disk
  Unique ID: 7tlP.Fxp0d3BezAE
  SysFS ID: /class/block/ram2
  Model: "Disk"
  Device File: /dev/ram2
  Device Number: block 1:2
15: None 00.0: 10600 Disk
  Unique ID: CWFH.Fxp0d3BezAE
  SysFS ID: /class/block/ram0
  Model: "Disk"
  Device File: /dev/ram0
  Device Number: block 1:0
16: None 00.0: 10600 Disk
  Unique ID: ni5P.Fxp0d3BezAE
  Parent ID: CgKD.TzQFl_vZhO4
  SysFS ID: /class/block/mmcblk0rpmb
  SysFS BusID: mmcblk0
  SysFS Device Link: /devices/platform/ffe07000.emmc/mmc_host/emmc/emmc:0001/block/mmcblk0
  Model: "Disk"
  Driver: "mmcblk"
  Device File: /dev/mmcblk0rpmb
  Device Number: block 179:96-179:127
  Attached to: #10 (MMC Controller)
17: None 00.0: 10600 Disk
  Unique ID: XOSI.Fxp0d3BezAE
  SysFS ID: /class/block/ram9
  Model: "Disk"
  Device File: /dev/ram9
  Device Number: block 1:9
18: None 00.0: 10600 Disk
  Unique ID: d1y9.Fxp0d3BezAE
  SysFS ID: /class/block/ram7
  Model: "Disk"
  Device File: /dev/ram7
  Device Number: block 1:7
19: None 00.0: 10600 Disk
  Unique ID: kLao.Fxp0d3BezAE
  Parent ID: M8Ep._NN+DZ1HDn4
  SysFS ID: /class/block/mmcblk1
  SysFS Device Link: /devices/platform/ffe05000.sd/mmc_host/sd/sd:1234
  Model: "Disk"
  Driver: "meson-aml-mmc", "mmcblk"
  Device File: /dev/mmcblk1
  Device Number: block 179:128-179:159
  Attached to: #9 (MMC Controller)
20: None 00.0: 11300 Partition
  [Created at block.434]
  Unique ID: 685D.SE1wIdpsiiC
  Parent ID: kLao.Fxp0d3BezAE
  SysFS ID: /class/block/mmcblk1/mmcblk1p1
  Hardware Class: partition
  Model: "Partition"
  Device File: /dev/mmcblk1p1
  Attached to: #19 (Disk)
21: None 00.0: 11300 Partition
  Unique ID: ZJLH.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk1/mmcblk1p2
  Model: "Partition"
  Device File: /dev/mmcblk1p2
22: None 00.0: 10600 Disk
  Unique ID: s19p.Fxp0d3BezAE
  SysFS ID: /class/block/ram14
  Model: "Disk"
  Device File: /dev/ram14
  Device Number: block 1:14
23: None 00.0: 10600 Disk
  Unique ID: UPWc.Fxp0d3BezAE
  SysFS ID: /class/block/ram5
  Model: "Disk"
  Device File: /dev/ram5
  Device Number: block 1:5
24: None 00.0: 10600 Disk
  Unique ID: Hj0w.Fxp0d3BezAE
  SysFS ID: /class/block/mmcblk0boot0
  Model: "Disk"
  Driver: "mmcblk"
  Device File: /dev/mmcblk0boot0
  Device Number: block 179:32-179:63
25: None 00.0: 10600 Disk
  Unique ID: ygeg.Fxp0d3BezAE
  SysFS ID: /class/block/ram12
  Model: "Disk"
  Device File: /dev/ram12
  Device Number: block 1:12
26: None 00.0: 10600 Disk
  Unique ID: a20U.Fxp0d3BezAE
  SysFS ID: /class/block/ram3
  Model: "Disk"
  Device File: /dev/ram3
  Device Number: block 1:3
27: None 00.0: 10600 Disk
  Unique ID: 2K8Y.Fxp0d3BezAE
  SysFS ID: /class/block/ram10
  Model: "Disk"
  Device File: /dev/ram10
  Device Number: block 1:10
28: None 00.0: 10600 Disk
  Unique ID: ghVL.Fxp0d3BezAE
  Model: "Disk"
29: None 00.0: 10600 Disk
  Unique ID: 4DCE.Fxp0d3BezAE
  SysFS ID: /class/block/ram8
  Model: "Disk"
  Device File: /dev/ram8
  Device Number: block 1:8
30: None 00.0: 10600 Disk
  Unique ID: JDPt.Fxp0d3BezAE
  SysFS ID: /class/block/ram15
  Model: "Disk"
  Device File: /dev/ram15
  Device Number: block 1:15
31: None 00.0: 10600 Disk
  Unique ID: xamg.Fxp0d3BezAE
  SysFS ID: /class/block/ram6
  Model: "Disk"
  Device File: /dev/ram6
  Device Number: block 1:6
32: None 00.0: 10600 Disk
  Unique ID: OKyR.Fxp0d3BezAE
  SysFS ID: /class/block/zram0
  Model: "Disk"
  Device File: /dev/zram0
  Device Number: block 252:0
33: None 00.0: 10600 Disk
  Unique ID: kuG_.Fxp0d3BezAE
  SysFS ID: /class/block/mmcblk0boot1
  Model: "Disk"
  Driver: "mmcblk"
  Device File: /dev/mmcblk0boot1
  Device Number: block 179:64-179:95
34: None 00.0: 10600 Disk
  Unique ID: HAKk.Fxp0d3BezAE
  Model: "Disk"
  Device Number: block 179:0-179:31
35: None 00.0: 11300 Partition
  Unique ID: l7UW.SE1wIdpsiiC
  Parent ID: HAKk.Fxp0d3BezAE
  SysFS ID: /class/block/mmcblk0/mmcblk0p1
  Model: "Partition"
  Device File: /dev/mmcblk0p1
  Attached to: #34 (Disk)
36: None 00.0: 11300 Partition
  Unique ID: CJka.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p2
  Model: "Partition"
  Device File: /dev/mmcblk0p2
37: None 00.0: 11300 Partition
  Unique ID: fU_e.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p3
  Model: "Partition"
  Device File: /dev/mmcblk0p3
38: None 00.0: 11300 Partition
  Unique ID: 6gEj.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p4
  Model: "Partition"
  Device File: /dev/mmcblk0p4
39: None 00.0: 11300 Partition
  Unique ID: ZrUn.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p5
  Model: "Partition"
  Device File: /dev/mmcblk0p5
40: None 00.0: 11300 Partition
  Unique ID: 01lr.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p6
  Model: "Partition"
  Device File: /dev/mmcblk0p6
41: None 00.0: 11300 Partition
  Unique ID: iTwK.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p7
  Model: "Partition"
  Device File: /dev/mmcblk0p7
42: None 00.0: 11300 Partition
  Unique ID: AfAP.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p8
  Model: "Partition"
  Device File: /dev/mmcblk0p8
43: None 00.0: 11300 Partition
  Unique ID: dqQT.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p9
  Model: "Partition"
  Device File: /dev/mmcblk0p9
44: None 00.0: 11300 Partition
  Unique ID: 8vbH.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p10
  Model: "Partition"
  Device File: /dev/mmcblk0p10
45: None 00.0: 11300 Partition
  Unique ID: b4sL.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p11
  Model: "Partition"
  Device File: /dev/mmcblk0p11
46: None 00.0: 11300 Partition
  Unique ID: 2G6Q.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p12
  Model: "Partition"
  Device File: /dev/mmcblk0p12
47: None 00.0: 11300 Partition
  Unique ID: VRMU.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p13
  Model: "Partition"
  Device File: /dev/mmcblk0p13
48: None 00.0: 11300 Partition
  Unique ID: yccY.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p14
  Model: "Partition"
  Device File: /dev/mmcblk0p14
49: None 00.0: 11300 Partition
  Unique ID: Posc.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p15
  Model: "Partition"
  Device File: /dev/mmcblk0p15
50: None 00.0: 11300 Partition
  Unique ID: sz6h.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p16
  Model: "Partition"
  Device File: /dev/mmcblk0p16
51: None 00.0: 11300 Partition
  Unique ID: ZQIA.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p17
  Model: "Partition"
  Device File: /dev/mmcblk0p17
52: None 00.0: 11300 Partition
  Unique ID: 0cYE.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p18
  Model: "Partition"
  Device File: /dev/mmcblk0p18
53: None 00.0: 11300 Partition
  Unique ID: TnoI.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p19
  Model: "Partition"
  Device File: /dev/mmcblk0p19
54: None 00.0: 11300 Partition
  Unique ID: YVjZ.SE1wIdpsiiC
  SysFS ID: /class/block/mmcblk0/mmcblk0p20
  Model: "Partition"
  Device File: /dev/mmcblk0p20
55: None 00.0: 10600 Disk
  Unique ID: Psuk.Fxp0d3BezAE
  SysFS ID: /class/block/ram13
  Model: "Disk"
  Device File: /dev/ram13
  Device Number: block 1:13
56: None 00.0: 10600 Disk
  Unique ID: 1EGY.Fxp0d3BezAE
  SysFS ID: /class/block/ram4
  Model: "Disk"
  Device File: /dev/ram4
  Device Number: block 1:4
57: USB 00.0: 10a00 Hub
  [Created at usb.122]
  Unique ID: k4bc.uJrfcCKKe8E
  Parent ID: IiIy.vcc7vMyNqX6
  SysFS ID: /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/1-0:1.0
  SysFS BusID: 1-0:1.0
  Hardware Class: hub
  Model: "Linux Foundation 2.0 root hub"
  Hotplug: USB
  Vendor: usb 0x1d6b "Linux Foundation"
  Device: usb 0x0002 "2.0 root hub"
  Revision: "4.09"
  Serial ID: "xhci-hcd.0.auto"
  Driver: "hub"
  Driver Modules: "usbcore"
  Speed: 480 Mbps
  Module Alias: "usb:v1D6Bp0002d0409dc09dsc00dp01ic09isc00ip00in00"
  Attached to: #8 (USB Controller)
58: USB 00.0: 10a00 Hub
  Unique ID: pBe4.PKweOZjtk19
  SysFS ID: /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb2/2-0:1.0
  SysFS BusID: 2-0:1.0
  Hardware Class: hub
  Model: "Linux Foundation 3.0 root hub"
  Hotplug: USB
  Device: usb 0x0003 "3.0 root hub"
  Revision: "4.09"
  Driver: "hub"
  Module Alias: "usb:v1D6Bp0003d0409dc09dsc00dp03ic09isc00ip00in00"
59: PS/2 00.0: 10800 Keyboard
  [Created at input.226]
  Unique ID: EXC1.+49ps10DtUF
  Hardware Class: keyboard
  Model: "aml_keypad"
  Vendor: 0x0001
  Device: 0x0001 "aml_keypad"
  Compatible to: int 0x0211 0x0001
  Device File: /dev/input/event1
  Device Number: char 13:65
  Driver Info #0:
    XkbRules: xfree86
60: PS/2 00.0: 10500 PS/2 Mouse
  [Created at input.249]
  Unique ID: AH6Q.fmuzbyZs2b0
  Hardware Class: mouse
  Model: "Bluetooth Laser Travel Mouse"
  Vendor: 0x046d
  Device: 0xb008 "Bluetooth Laser Travel Mouse"
  Compatible to: int 0x0210 0x0028
  Device File: /dev/input/mice (/dev/input/mouse1)
  Device Files: /dev/input/mice, /dev/input/mouse1, /dev/input/event4
  Device Number: char 13:63 (char 13:33)
  Driver Info #0:
    Buttons: 8
    Wheels: 2
    XFree86 Protocol: explorerps/2
    GPM Protocol: exps2
61: PS/2 00.0: 10800 Keyboard
  Unique ID: 3FDI.40rJcU_YN61
  Model: "Bluetooth 3.0 Keyboard"
  Vendor: 0x05ac
  Device: 0x023c "Bluetooth 3.0 Keyboard"
  Device File: /dev/input/event5
  Device Number: char 13:69
  Driver Info #0:
    XkbRules: xfree86
62: None 00.0: 10103 CPU
  [Created at cpu.275]
  Unique ID: rdCR.j8NaKXDZtZ6
  Hardware Class: cpu
  Arch: ARM
  Vendor: "ARM Limited"
  Model: 1.0.0 ""
  Platform: "Amlogic"
  Features: half,thumb,fastmult,vfp,edsp,neon,vfpv3,tls,vfpv4,idiva,idivt,vfpd32,lpae,evtstrm,aes,pmull,sha1,sha2,crc32,
  BogoMips: 76.32
63: None 01.0: 10103 CPU
  Unique ID: wkFv.j8NaKXDZtZ6
  Hardware Class: cpu
  Arch: ARM
  Model: 1.0.0 ""
  Platform: "Amlogic"
  Features: half
  BogoMips: 76.32
64: None 02.0: 10103 CPU
  Unique ID: +rIN.j8NaKXDZtZ6
  Hardware Class: cpu
  Arch: ARM
  Model: 1.0.0 ""
  Platform: "Amlogic"
  Features: half
  BogoMips: 76.32
65: None 03.0: 10103 CPU
  Unique ID: 4zLr.j8NaKXDZtZ6
  Hardware Class: cpu
  Arch: ARM
  Model: 1.0.0 ""
  Platform: "Amlogic"
  Features: half
  BogoMips: 76.32
66: None 00.0: 10781 Network Interface
  [Created at net.126]
  Unique ID: wl2P.nfEXJulusj6
  SysFS ID: /class/net/sit0
  Hardware Class: network interface
  Model: "Network Interface"
  Device File: sit0
67: None 00.0: 10701 Ethernet
  Unique ID: usDW.ndpeucax6V1
  Parent ID: PP78.TfPFe67fIBB
  SysFS ID: /class/net/eth0
  SysFS Device Link: /devices/platform/ff3f0000.ethernet
  Model: "Ethernet network interface"
  Device File: eth0
  Link detected: yes
  Attached to: #7 (Ethernet controller)
68: None 00.0: 10780 Network Interface
  Unique ID: qdX2.GSopYcFr9cF
  SysFS ID: /class/net/ip6_vti0
  Device File: ip6_vti0
69: None 00.0: 10701 Ethernet
  Unique ID: pG9W.ndpeucax6V1
  Parent ID: +vYY.OeWlO7L59hD
  SysFS ID: /class/net/p2p0
  SysFS Device Link: /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
  Driver: "rtl88x2cs"
  Device File: p2p0
  Link detected: no
  Attached to: #12 (WLAN controller)
70: None 00.0: 10780 Network Interface
  Unique ID: OgUs.GSopYcFr9cF
  SysFS ID: /class/net/tunl0
  Device File: tunl0
71: None 00.0: 1070a WLAN
  Unique ID: AYEt.QXn1l67RSa1
  SysFS ID: /class/net/wlan0
  Model: "WLAN network interface"
  Driver: "rtl88x2cs"
  Device File: wlan0
  HW Address: 80:9f:9b:90:19:74
  Permanent HW Address: 80:9f:9b:90:19:74
  Link detected: no
72: None 00.0: 10780 Network Interface
  Unique ID: HtAv.GSopYcFr9cF
  SysFS ID: /class/net/ip6tnl0
  Device File: ip6tnl0
  Permanent HW Address: 0a:90:88:19:2e:d7:00:00:00:00:00:00:00:00:00:00
73: None 00.0: 10780 Network Interface
  Unique ID: b8Rv.GSopYcFr9cF
  SysFS ID: /class/net/ip_vti0
  Device File: ip_vti0
74: None 00.0: 10700 Loopback
  Unique ID: ZsBS.GQNx7L4uPNA
  SysFS ID: /class/net/lo
  Model: "Loopback network interface"
  Device File: lo
  Link detected: yes
--------------- dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.113 (yxt-rd01@yxtrd01-Super-Server) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02) ) #3 SMP PREEMPT Sat Jun 20 11:31:57 CST 2020
[    0.000000] CPU: ARMv7 Processor [411fd050] revision 0 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt:Machine model: Amlogic
[    0.000000] Reserved memory: created CMA memory pool at 0x05000000, size 4 MiB
[    0.000000] OF: reserved mem: initialized node linux,secmon, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0xdf800000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node linux,meson-fb, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x78000000, size 128 MiB
[    0.000000] OF: reserved mem: initialized node linux,ion-dev, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0xee000000, size 40 MiB
[    0.000000] OF: reserved mem: initialized node linux,di_cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: regions without no-map are not yet supported
[    0.000000] Reserved memory: created CMA memory pool at 0x64c00000, size 308 MiB
[    0.000000] OF: reserved mem: initialized node linux,codec_mm_cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node linux,codec_mm_reserved, compatible id amlogic, codec-mm-reserved
[    0.000000] Reserved memory: created CMA memory pool at 0xea000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node linux,vdin0_cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0xe6000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node linux,vdin1_cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0xe4000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node linux,vm0_cma, compatible id shared-dma-pool
[    0.000000] cma: Reserved 8 MiB at 0xe3800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 985088
[    0.000000] free_area_init_node: node 0, pgdat c1729040, node_mem_map ee1e1000
[    0.000000] Normal zone: 1534 pages used for memmap
[    0.000000] Normal zone: 0 pages reserved
[    0.000000] Normal zone: 196352 pages, LIFO batch:31
[    0.000000] HighMem zone: 788736 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 15 pages/cpu @ee168000 s32140 r8192 d21108 u61440
[    0.000000] pcpu-alloc: s32140 r8192 d21108 u61440 alloc=15*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 983554
[    0.000000] Kernel command line: init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xff803000 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 otg_device=0 reboot_mode_android=normal logo=osd0,loaded,0x3d800000 vout=576cvbs,enable panel_type=lcd_1 lcd_ctrl=0x00000000 hdmitx=,444,8bit hdmimode=1080p60hz frac_rate_policy=1 hdmi_read_edid=1 cvbsmode=576cvbs osd_reverse=0 video_reverse=0 irq_check_en=0 androidboot.selinux=permissive androidboot.firstboot=0 jtag=disable androidboot.hardware=amlogic androidboot.serialno=1234567890 mac=90:0e:b3:1d:20:fe androidboot.mac=90:0e:b3:1d:20:fe ro rootwait skip_initramfs androidboot.dtbo_idx=0 --cmdline root=/dev/mmcblk0p18 buildvariant=userdebug
[    0.000000] fb: osd0
[    0.000000] fb: loaded
[    0.000000] fb: 0x3d800000
[    0.000000] vout: 576cvbs
[    0.000000] vout: enable: 1
[    0.000000] lcd: panel_type: lcd_1
[    0.000000] lcd: lcd_ctrl: 0x00000000
[    0.000000] vout: get hdmimode: 1080p60hz
[    0.000000] hdmitx: hdmitx boot frac_rate_policy: 1
[    0.000000] vout: get cvbsmode: 576cvbs
[    0.000000] vpp_axis_reverse: bootargs is 0
[    0.000000] DI: di_read_canvas_reverse: bootargs is 0.
[    0.000000] phlock_phase_config: bootargs is 0.
[    0.000000] jtag: jtag select disable
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 3212300K/3940352K available (13312K kernel code, 1250K rwdata, 4892K rodata, 1024K init, 1339K bss, 56308K reserved, 671744K cma-reserved, 2487296K highmem)
[    0.000000] Virtual kernel memory layout:\x0a    vector  : 0xffff0000 - 0xffff1000   (   4 kB)\x0a    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)\x0a    vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)\x0a    lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)\x0a    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)\x0a    modules : 0xbc000000 - 0xbfe00000   (  62 MB)\x0a      .text : 0xc0108000 - 0xc0f00000   (14304 kB)\x0a      .init : 0xc1500000 - 0xc1600000   (1024 kB)\x0a      .data : 0xc1600000 - 0xc1738bf8   (1251 kB)\x0a       .bss : 0xc173a000 - 0xc1888c04   (1340 kB)
[    0.000000] 0, addr:c0bb8280 +  154, aml_cma_alloc_post_hook
[    0.000000] 1, addr:c069d5d0 +   4c, dma_alloc_from_contiguous
[    0.000000] 2, addr:c0398428 +  27c, cma_alloc
[    0.000000] 3, addr:c0392960 +  2f4, __kmalloc_track_caller
[    0.000000] 4, addr:c038fc14 +  298, kmem_cache_alloc
[    0.000000] 5, addr:c038f8c0 +  2b0, kmem_cache_alloc_trace
[    0.000000] 6, addr:c038f5cc +  2f4, __kmalloc
[    0.000000] 7, addr:c038f55c +   70, __slab_alloc.constprop.10
[    0.000000] 8, addr:c038f1e8 +  374, ___slab_alloc.constprop.11
[    0.000000] 9, addr:c038d18c +  3ac, new_slab
[    0.000000] 10, addr:c038153c +   44, vmalloc
[    0.000000] 11, addr:c03814f8 +   44, vzalloc
[    0.000000] 12, addr:c0380f5c +  258, __vmalloc_node_range
[    0.000000] 13, addr:c0368000 +  114, kmalloc_order_trace
[    0.000000] 14, addr:c0367eac +  154, kmalloc_order
[    0.000000] 15, addr:c034a38c +  164, __alloc_page_frag
[    0.000000] 16, addr:c034a348 +   44, alloc_pages_exact
[    0.000000] 17, addr:c034a324 +   24, get_zeroed_page
[    0.000000] 18, addr:c034a2e8 +   3c, __get_free_pages
[    0.000000] 19, addr:c0349360 +  f88, __alloc_pages_nodemask
[    0.000000] 20, addr:c0219760 +   4c, cma_allocator_alloc
[    0.000000] 21, addr:c0219678 +   e8, __alloc_from_contiguous
[    0.000000] 22, addr:c0219200 +   58, arm_dma_alloc
[    0.000000] 23, addr:c0218e68 +  34c, __dma_alloc
[    0.000000] zone:Normal, spaned pages:196352, total:196352
[    0.000000] zone:HighMem, spaned pages:788736, total:985088
[    0.000000] page_trace_pre_work, trace buffer:edc00000, size:3c2000, used:edfc2000, end:ee000000
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] \x09Build-time adjustment of leaf fanout to 32.
[    0.000000] \x09RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=4
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
[    0.000000] g12a_aoclkc_init: register ao clk ok!
[    0.000000] Meson chip version = RevC (2B:C - 10:0)
[    0.000000] meson_g12a_sdemmc_init: register amlogic sdemmc clk
[    0.000000] meson_g12a_gpu_init: register meson gpu clk
[    0.000000] meson_g12a_media_init: register meson media clk
[    0.000000] meson_g12a_misc_init: register amlogic g12a misc clks
[    0.000000] meson_g12a_misc_init: done.
[    0.000000] g12a_clkc_init initialization complete
[    0.000000] sm1 clk probe ok
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000018] Switching to timer-based delay loop, resolution 41ns
[    0.000060] meson_bc_timer: mclk->mux_reg =f080c190,mclk->reg =f080e194
[    0.000680] Console: colour dummy device 80x30
[    0.000703] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000719] pid_max: default: 32768 minimum: 301
[    0.000792] thread_stack_cache_init, vmap:c0127900, bitmap:c012c400, cache page:e3400
[    0.000806] thread_stack_cache_init, allocation vm area:c0129040, addr:bc000000, size:3001000
[    0.000859] Security Framework initialized
[    0.000869] SELinux:  Initializing.
[    0.000913] SELinux:  Starting in permissive mode
[    0.000956] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000971] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001696] CPU: Testing write buffer coherency: ok
[    0.001730] ftrace: allocating 43410 entries in 128 pages
[    0.084846] sched-energy: CPU device node has no sched-energy-costs
[    0.084864] CPU0: update cpu_capacity 1024
[    0.084871] CPU0: thread 0, cpu 0, socket 0, mpidr 81000000
[    0.084898] Setting up static identity map for 0x200000 - 0x200058
[    0.129566] secmon: can't fine clear_range
[    0.177537] CPU1: update cpu_capacity 1024
[    0.177543] CPU1: thread 0, cpu 1, socket 0, mpidr 81000100
[    0.209628] CPU2: update cpu_capacity 1024
[    0.209632] CPU2: thread 0, cpu 2, socket 0, mpidr 81000200
[    0.241742] CPU3: update cpu_capacity 1024
[    0.241746] CPU3: thread 0, cpu 3, socket 0, mpidr 81000300
[    0.241848] Brought up 4 CPUs
[    0.241877] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.241883] CPU: All CPU(s) started in SVC mode.
[    0.242757] addr:bc045cce is in kernel, size fix 4096->10, data:mode=0755
[    0.242888] devtmpfs: initialized
[    0.270748] VFP support v0.3: implementor 41 architecture 3 part 40 variant 5 rev 2
[    0.271243] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.271265] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.271447] pinctrl core: initialized pinctrl subsystem
[    0.272606] NET: Registered protocol family 16
[    0.275736] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.275747] schedtune: init normalization constants...
[    0.275754] schedtune: no energy model data
[    0.275758] schedtune: disabled!
[    0.289446] cpuidle: using governor menu
[    0.289570] register canvas platform driver
[    0.289619] register rdma platform driver
[    0.289665] aml_vdac_init: module init
[    0.292656] clkmsr: clkmsr: driver init
[    0.292664] codec_mm_module_init
[    0.292729] media_configs_system_init
[    0.293268] pstore: using zlib compression
[    0.293932] console [pstore-1] enabled
[    0.293972] pstore: Registered ramoops as persistent store backend
[    0.293985] ramoops: attached 0x100000@0x7400000, ecc: 0/0
[    0.293996] ramoops: ramoops_io_en:0 1 old:0x0 ftrace_size:0x40000
[    0.296109] aml_iomap: amlogic iomap probe done
[    0.296697] vpu: driver version: v20190314(10-sm1)
[    0.296713] vpu: load vpu_clk: 666666667Hz(7)
[    0.296914] vpu: clktree_init
[    0.297003] vpu: vpu_probe OK
[    0.301621] clkmsr: msr_clk_reg0=f09c0004,msr_clk_reg2=f09c200c
[    0.301643] clkmsr: msr_ring_reg0=f09c45fc
[    0.308604] aml_vdac_probe:probe start.cpu_id:8,name:meson-sm1-vdac
[    0.308852] aml_vdac_probe: ok
[    0.309035] canvas_probe reg=ff638000,size=2000
[    0.309061] canvas maped reg_base =f09c6000
[    0.317874] rdma_probe,cpu_type:1, ver:0, len:8
[    0.318123] rdma_register, rdma_table_addr f09e9000 rdma_table_addr_phy e3840000 reg_buf ed710000
[    0.318135] rdma_register success, handle 1 table_size 32768
[    0.318144] set_rdma_handle video rdma handle = 1.
[    0.319467] aml_snd_reg_map[0], reg:ff661000, size:400
[    0.319489] aml_snd_reg_map[1], reg:ff660000, size:1000
[    0.319509] aml_snd_reg_map[2], reg:ff661400, size:400
[    0.319531] aml_snd_reg_map[3], reg:ff662000, size:1000
[    0.319552] aml_snd_reg_map[4], reg:ffd01000, size:1000
[    0.319572] aml_snd_reg_map[5], reg:ff661800, size:400
[    0.319590] aml_snd_reg_map[6], reg:ff663800, size:30
[    0.319608] aml_snd_reg_map[7], reg:ff663c00, size:20
[    0.319630] aml_snd_reg_map[8], reg:ff663e00, size:10
[    0.319639] amlogic auge_snd_iomap probe done
[    0.322206] cvbs_out: cvbsout_probe, cpu_id:7,name:meson-sm1-cvbsout
[    0.322230] cvbs_out: clk path:0
[    0.322239] cvbs_out: error: failed to get vdac_config
[    0.322396] vout: vout1: register server: cvbs_vout_server
[    0.322407] cvbs_out: register cvbs module server ok
[    0.322418] vout: vout2: register server: cvbs_vout2_server
[    0.322426] cvbs_out: register cvbs module vout2 server ok
[    0.322438] cvbs_out: chrdev devno 264241152 for disp
[    0.322720] cvbs_out: create cdev cvbs
[    0.322731] cvbs_out: cvbsout_probe OK
[    0.323412] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma
[    0.323514] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma
[    0.323524] codec_mm_probe ok
[    0.580488] vgaarb: loaded
[    0.580840] SCSI subsystem initialized
[    0.581155] usbcore: registered new interface driver usbfs
[    0.581226] usbcore: registered new interface driver hub
[    0.581342] usbcore: registered new device driver usb
[    0.581511] Linux video capture interface: v2.00
[    0.581649] pps_core: LinuxPPS API ver. 1 registered
[    0.581658] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.581697] PTP clock support registered
[    0.582545] secmon: reserve_mem_size:0x300000
[    0.582648] secmon secmon: assigned reserved memory node linux,secmon
[    0.583024] secmon: get page:ee27f000, 5000
[    0.583038] secmon: share in base: 0xc50fe000, share out base: 0xc50ff000
[    0.583046] secmon: phy_in_base: 0x50fe000, phy_out_base: 0x50ff000
[    0.583550] fb: osd_init_module
[    0.584061] fb: viu vsync irq: 59
[    0.584084] fb: viu2 vsync irq: 67
[    0.584205] 0x000000d8:Y=d8,U=0,V=0
[    0.584215] 0x000000d9:Y=d9,U=0,V=0
[    0.584223] 0x000000da:Y=da,U=0,V=0
[    0.584231] 0x000000db:Y=db,U=0,V=0
[    0.584240] 0x000000dc:Y=dc,U=0,V=0
[    0.584248] 0x000000dd:Y=dd,U=0,V=0
[    0.584648] fb: osd_rdma_init: rdma_table p=0xe3848000,op=0xe3848000 , v=0xf0ad3000
[    0.584690] rdma_register, rdma_table_addr f0ad5000 rdma_table_addr_phy e3849000 reg_buf ed066000
[    0.584700] rdma_register success, handle 2 table_size 4096
[    0.584711] fb: osd_rdma_init:osd rdma handle = 2.
[    0.584730] fb: mem_size: 0x800000
[    0.584738] fb: mem_size: 0x1980000
[    0.584746] fb: mem_size: 0x100000
[    0.584753] fb: mem_size: 0x100000
[    0.584761] fb: mem_size: 0x800000
[    0.584824] meson-fb fb: assigned reserved memory node linux,meson-fb
[    0.584836] fb: reserved memory base:0xdf800000, size:800000
[    0.585234] vout: error: invalid vinfo1. current vmode is not supported
[    0.585250] fb: init fbdev bpp is:32
[    0.586893] fb: set osd0 reverse as NONE
[    0.586917] vout: error: invalid vinfo1. current vmode is not supported
[    0.591047] fb: osd probe OK
[    0.591890] hdmitx: system: amhdmitx_probe start
[    0.591902] hdmitx: system: Ver: 20190624
[    0.591933] hdmitx: system: hdmitx_device.chip_type : 12
[    0.591973] hdmitx: system: not find match pwr-ctl
[    0.592016] hdmitx: system: not find drm_amhdmitx
[    0.592045] hdmitx: system: hpd irq = 52
[    0.592164] hdmitx: system: hdcp22_tx_skp failed to probe
[    0.592177] hdmitx: system: hdcp22_tx_esm failed to probe
[    0.592706] vout: vout1: register server: hdmitx_vout_server
[    0.592719] vout: vout2: register server: hdmitx_vout2_server
[    0.593491] hdmitx: hdmitx20: Mapped PHY: 0xffd00000
[    0.593518] hdmitx: hdmitx20: Mapped PHY: 0xff634400
[    0.593537] hdmitx: hdmitx20: Mapped PHY: 0xff900000
[    0.593553] hdmitx: hdmitx20: Mapped PHY: 0xff800000
[    0.593564] hdmitx: hdmitx20: Mapped PHY: 0xff63c000
[    0.593574] hdmitx: hdmitx20: Mapped PHY: 0xffd00000
[    0.593583] hdmitx: hdmitx20: Mapped PHY: 0xff608000
[    0.593595] hdmitx: hdmitx20: Mapped PHY: 0xff600000
[    0.593618] hdmitx: hdmitx20: Mapped PHY: 0xffe01000
[    0.593636] hdmitx: hw: hdmitx_get_format:0x0
[    0.593645] hdmitx: hw: P_HHI_HDMI_CLK_CNTL :0x100
[    0.593655] hdmitx: hw: P_HHI_HDMI_PLL_CNTL :0xda0504f7
[    0.593892] hdmitx: hw: avmute set to 1
[    0.593903] hdmitx: system: fmt_attr 444,8bit
[    0.594009] hdmitx: system: amhdmitx_probe end
[    0.594740] lcd: driver version: 20181012(8-sm1)
[    0.594892] lcd: detect mode: tablet, fr_auto_policy: 0, key_valid: 0
[    0.595178] lcd: lcd_clktree_probe
[    0.595190] lcd: status: 0
[    0.595202] vout: vout1: register server: lcd_vout_server
[    0.595213] vout: vout2: register server: lcd_vout2_server
[    0.595224] lcd: lcd_get_config from dts
[    0.595240] lcd: no range_setting
[    0.595300] lcd: P070ACB_FT, mipi, 8bit, 600x1024
[    0.595318] lcd: pixel_clk = 49.434MHz, bit_rate = 395.472MHz
[    0.595638] lcd: lcd_fops_create OK
[    0.595652] vout: error: invalid vinfo1. current vmode is not supported
[    0.595662] fb: current vmode=invalid, cmd: 0x20000
[    0.595684] lcd: request lcd_vsync_irq successful
[    0.595703] lcd: request lcd_vsync2_irq successful
[    0.595712] lcd: lcd_probe ok
[    0.596146] vout: create vout attribute OK
[    0.596310] vout: vout_fops_create OK
[    0.596322] vout: vout1: register server: nulldisp_vout_server
[    0.596447] vout: tvout monitor interval:500(ms), timeout cnt:20
[    0.596481] cvbs_out: mode is 1,sync_duration_den=1,sync_duration_num=50
[    0.596510] cvbs_out: vdac open.0 = 0x8f6001, 0x0
[    0.596521] \x0avdac_enable: on:1,module_sel:8
[    0.596535] cvbs_out: already display in uboot
[    0.596545] vout: init mode 576cvbs set ok
[    0.596553] vout: aml_tvout_mode_monitor
[    0.596573] vout: aml_vout_probe OK
[    0.597349] chip type:0x2b
[    0.597764] NO valid ramdump args:0 0
[    0.598903] VFD Driver
[    0.599313] sm1628_init+++++++++++
[    0.599328] ---MDrv_FrontPnl_Init---.
[    0.599339] ---MDrv_TM1623_Init---++++++++++++.
[    0.599359] ---MDrv_TM1623_WriteData---++++++++++++.
[    0.599404] ---MDrv_TM1623_WriteData---++++++++++++.
[    0.599447] ---MDrv_TM1623_ShowBoot---++++++++++++.
[    0.606449] ---MDrv_TM1623_Write_Adr_Data---++++++++++++.
[    0.606494] ---MDrv_TM1623_WriteData---++++++++++++.
[    0.606540] ---MDrv_TM1623_WriteData---++++++++++++.
[    0.606585] ---MDrv_TM1623_WriteData---++++++++++++.
[    0.606628] ---MDrv_TM1623_WriteData---++++++++++++.
[    0.606668] ---hardware_init---0++++++++++++.
[    0.606678] vfd_ioremap--------sync time--------------
[    0.606785] power vfd key(116) registed.
[    0.606796] volumn-up vfd key(114) registed.
[    0.606805] volumn-down vfd key(115) registed.
[    0.606813] menu vfd key(139) registed.
[    0.606822] up vfd key(402) registed.
[    0.606830] down vfd key(403) registed.
[    0.606838] enter vfd key(28) registed.
[    0.606912] device_create_file completed \x0d
[    0.607180] input: vfd_keypad as /devices/platform/meson-vfd/input/input0
[    0.607191] input_register_device completed \x0d
[    0.607216] vfd config major:244\x0d
[    0.607776] Advanced Linux Sound Architecture Driver Initialized.
[    0.608605] Bluetooth: Core ver 2.22
[    0.608725] NET: Registered protocol family 31
[    0.608735] Bluetooth: HCI device and connection manager initialized
[    0.608755] Bluetooth: HCI socket layer initialized
[    0.608773] Bluetooth: L2CAP socket layer initialized
[    0.608821] Bluetooth: SCO socket layer initialized
[    0.609602] NetLabel: Initializing
[    0.609625] NetLabel:  domain hash size = 128
[    0.609634] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.609719] NetLabel:  unlabeled traffic allowed by default
[    0.613526] clocksource: Switched to clocksource arch_sys_counter
[    0.691974] VFS: Disk quotas dquot_6.6.0
[    0.692102] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.708141] dtv_dmd:[amldtvdemod..]aml_dtvdemod_init.
[    0.708165] jtag: module init
[    0.708688] jtag: ao gpios not specified
[    0.708723] jtag: probe of jtag failed with error -22
[    0.709282] NET: Registered protocol family 2
[    0.710456] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.710535] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.710615] TCP: Hash tables configured (established 8192 bind 8192)
[    0.710722] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.710771] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.710967] NET: Registered protocol family 1
[    0.711013] PCI: CLS 0 bytes, default 64
[    0.714028] wifi: power_on_pin_OD = 0;
[    0.714073] aml_wifi wifi: [wifi_dev_probe] no power_on_pin2
[    0.714330] aml_wifi wifi: [pwm_double_channel_conf_dt] wifi pwm dt ok
[    0.714369] aml_wifi wifi: [pwm_double_channel_conf] wifi pwm conf ok
[    0.714382] aml_wifi wifi: [wifi_dev_probe] dhd_static_buf setup
[    0.714393] Wifi: bcmdhd_init_wlan_mem: bcmdhd_init_wlan_mem 1.579.77.41.9
[    0.715211] Wifi: bcmdhd_init_wlan_mem: bcmdhd_init_wlan_mem prealloc ok
[    0.715228] aml_wifi wifi: [wifi_dev_probe] interrupt_pin=483
[    0.715240] aml_wifi wifi: [wifi_dev_probe] irq_num=0, irq_trigger_type=1
[    0.715250] aml_wifi wifi: [wifi_dev_probe] power_on_pin=482
[    0.715260] aml_wifi wifi: [wifi_dev_probe] clock_32k_pin=0
[    0.715651] aml_wifi wifi: [wifi_setup_dt] wifi_setup_dt
[    0.715818] aml_wifi wifi: [wifi_setup_dt] irq num is:(79)
[    0.715831] aml_wifi wifi: [wifi_setup_dt] interrupt_pin(483)
[    0.715858] aml_wifi wifi: [wifi_setup_dt] power_on_pin(482)
[    0.719858] enable_pmuserenr_all() start
[    0.719893] enable_pmuserenr_all() end
[    0.719925] hw perfevents: clusterb_enabled = 0
[    0.719938] hw perfevents: cpumasks 0xf, 0x0
[    0.719988] hw perfevents: cluster A irq = 25
[    0.720110] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.726112] audit: initializing netlink subsys (disabled)
[    0.726252] audit: type=2000 audit(0.668:1): initialized
[    0.727466] workingset: timestamp_bits=30 max_order=20 bucket_order=0
[    0.737945] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.738347] exFAT: Version 1.2.9
[    0.739847] Registering sdcardfs 0.1
[    0.740253] ntfs: driver 2.1.32 [Flags: R/O].
[    0.740642] jffs2: version 2.2. (NAND) (SUMMARY)  \xc2\xa9 2001-2006 Red Hat, Inc.
[    0.741741] fuse init (API version 7.26)
[    0.742955] SELinux:  Registering netfilter hooks
[    0.749950] NET: Registered protocol family 38
[    0.749992] Key type asymmetric registered
[    0.750002] Asymmetric key parser 'x509' registered
[    0.750198] bounce: pool size: 64 pages
[    0.750242] clear:2a000000, free:2a000000, tick:148375 us
[    0.750505] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
[    0.750518] io scheduler noop registered (default)
[    0.750526] io scheduler deadline registered
[    0.750560] io scheduler cfq registered
[    0.762914] random: fast init done
[    0.762967] random: crng init done
[    0.774881] brd: module loaded
[    0.781665] loop: module loaded
[    0.782510] zram: Added device: zram0
[    0.782891] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.783917] libphy: Fixed MDIO Bus: probed
[    0.784231] tun: Universal TUN/TAP device driver, 1.6
[    0.784240] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.785173] REG0:Addr = f0e9c540
[    0.785193] ee eth reset:Addr = f0e9e008
[    0.785212] read auto_cali_idx fail
[    0.786325] meson6-dwmac ff3f0000.ethernet: no reset control found
[    0.786341] stmmac - user ID: 0x11, Synopsys ID: 0x37
[    0.786351] Ring mode enabled
[    0.786361] DMA HW capability register supported
[    0.786370] Normal descriptors
[    0.786380] RX Checksum Offload Engine supported
[    0.786388] \x09COE Type 2
[    0.786395] TX Checksum insertion supported
[    0.786404] Wake-Up On Lan supported
[    0.786469] Enable RX Mitigation via HW Watchdog Timer
[    0.789742] libphy: stmmac: probed
[    0.789758] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[    0.789769] eth%d: PHY ID 001cc916 at 7 IRQ POLL (stmmac-0:07)
[    0.791433] PPP generic driver version 2.4.2
[    0.791681] PPP BSD Compression module registered
[    0.791691] PPP Deflate Compression module registered
[    0.791719] PPP MPPE Compression module registered
[    0.791729] NET: Registered protocol family 24
[    0.791839] usbcore: registered new interface driver asix
[    0.791940] usbcore: registered new interface driver ax88179_178a
[    0.792007] usbcore: registered new interface driver cdc_ether
[    0.792085] usbcore: registered new interface driver net1080
[    0.792151] usbcore: registered new interface driver cdc_subset
[    0.792213] usbcore: registered new interface driver zaurus
[    0.792295] usbcore: registered new interface driver cdc_ncm
[    0.792973] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.792986] ehci-pci: EHCI PCI platform driver
[    0.793052] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.793082] ohci-pci: OHCI PCI platform driver
[    0.793932] usbcore: registered new interface driver cdc_acm
[    0.793945] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.794027] usbcore: registered new interface driver usb-storage
[    0.794162] usbcore: registered new interface driver usbserial
[    0.794221] usbcore: registered new interface driver pl2303
[    0.794283] usbserial: USB Serial support registered for pl2303
[    0.794752] mousedev: PS/2 mouse device common for all mice
[    0.795209] usbcore: registered new interface driver xpad
[    0.795365] i2c /dev entries driver
[    0.795626] IR NEC protocol handler initialized
[    0.795637] IR RC5(x/sz) protocol handler initialized
[    0.795645] IR RC6 protocol handler initialized
[    0.795652] IR JVC protocol handler initialized
[    0.795661] IR Sony protocol handler initialized
[    0.795669] IR SANYO protocol handler initialized
[    0.795677] IR Sharp protocol handler initialized
[    0.795685] IR MCE Keyboard/mouse protocol handler initialized
[    0.795692] IR XMP protocol handler initialized
[    0.795791] usbcore: registered new interface driver uvcvideo
[    0.795800] USB Video Class driver (1.1.1)
[    0.795890] usbcore: registered new interface driver cx231xx
[    0.795902] md: linear personality registered for level -1
[    0.796514] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    0.796704] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[    0.796749] Bluetooth: HCI UART driver ver 2.3
[    0.796762] Bluetooth: HCI UART protocol H4 registered
[    0.797061] cpuidle: enable-method property 'psci' found operations
[    0.797230] cpuidle: enable-method property 'psci' found operations
[    0.797368] cpuidle: enable-method property 'psci' found operations
[    0.797494] cpuidle: enable-method property 'psci' found operations
[    0.798906] ledtrig-cpu: registered to indicate activity on CPUs
[    0.799362] hidraw: raw HID events driver (C) Jiri Kosina
[    0.799932] usbcore: registered new interface driver usbhid
[    0.799943] usbhid: USB HID core driver
[    0.800146] ashmem: initialized
[    0.801488] value of voltage_tolerance 0
[    0.801547] meson_cpufreq_init:don't find the node <dynamic_gp1_clk>
[    0.801556] value of gp1_clk_target 0
[    0.802822] cpu cpu0: meson_cpufreq_init: CPU 0 initialized
[    0.804182] ff803000.serial: clock gate not found
[    0.804223] meson_uart ff803000.serial: ==uart0 reg addr = f0eb3000
[    0.804279] ff803000.serial: ttyS0 at MMIO 0xff803000 (irq = 36, base_baud = 1500000) is a meson_uart
[    0.804299] meson_uart ff803000.serial: ttyS0 use xtal(24M) 24000000 change 0 to 115200
[    3.204775] console [ttyS0] enabled
[    3.209197] meson_uart ffd24000.serial: ==uart1 reg addr = f0eb5000
[    3.214840] ffd24000.serial: ttyS1 at MMIO 0xffd24000 (irq = 51, base_baud = 1500000) is a meson_uart
[    3.225973] amlogic-new-usb2-v2 ffe09000.usb2phy: USB2 phy probe:phy_mem:0xffe09000, iomap phy_base:0xf0ed8000
[    3.234905] amlogic-new-usb3-v2 ffe09080.usb3phy: USB3 phy probe:phy_mem:0xffe09080, iomap phy_base:0xf0ee3080
[    3.245323] meson-g12a-pinctrl pinctrl@ff634480: pin GPIOZ_0 already requested by ff3f0000.ethernet; cannot claim for ffd1f000.i2c
[    3.256321] meson-g12a-pinctrl pinctrl@ff634480: pin-1 (ffd1f000.i2c) status -22
[    3.263879] meson-g12a-pinctrl pinctrl@ff634480: could not request pin 1 (GPIOZ_0) from group i2c0_sda_z0  on device pinctrl-meson
[    3.275727] meson-i2c ffd1f000.i2c: Error applying setting, reverse things back
[    3.283203] meson-i2c: probe of ffd1f000.i2c failed with error -22
[    3.291174] Error: Driver 'meson_reset' is already registered, aborting...
[    3.297056] aml_dma ff63e000.aml_dma: Aml dma
[    3.303760] aml_aes_dma ff63e000.aml_dma:aml_aes: Aml AES_dma
[    3.310796] aml_sha_dma ff63e000.aml_dma:aml_sha: Aml SHA1/SHA224/SHA256 dma
[    3.314505] meson-remote: Driver init
[    3.318113] meson-remote: remote_probe
[    3.321888] meson-remote ff808040.rc: protocol = 0x1
[    3.326949] meson-remote ff808040.rc: led_blink = 1
[    3.331967] meson-remote ff808040.rc: led_blink_frq  = 100
[    3.337629] meson-remote ff808040.rc: platform_data irq =50
[    3.343377] meson-remote ff808040.rc: custom_number = 3
[    3.348714] meson-remote ff808040.rc: ptable->map_size = 50
[    3.354414] meson-remote ff808040.rc: ptable->custom_name = amlogic-remote-1
[    3.361637] meson-remote ff808040.rc: ptable->custom_code = 0xfb04
[    3.367936] meson-remote ff808040.rc: ptable->release_delay = 80
[    3.374098] meson-remote ff808040.rc: fn_key_scancode not config yet
[    3.380609] meson-remote ff808040.rc: cursor_left_scancode not config yet
[    3.387552] meson-remote ff808040.rc: cursor_right_scancode not config yet
[    3.394541] meson-remote ff808040.rc: cursor_up_scancode not config yet
[    3.401318] meson-remote ff808040.rc: cursor_down_scancode not config yet
[    3.408234] meson-remote ff808040.rc: cursor_ok_scancode not config yet
[    3.415015] meson-remote ff808040.rc: ptable->map_size = 45
[    3.420734] meson-remote ff808040.rc: ptable->custom_name = amlogic-remote-2
[    3.427909] meson-remote ff808040.rc: ptable->custom_code = 0xfe01
[    3.434233] meson-remote ff808040.rc: ptable->release_delay = 80
[    3.440421] meson-remote ff808040.rc: ptable->map_size = 17
[    3.446109] meson-remote ff808040.rc: ptable->custom_name = amlogic-remote-3
[    3.453299] meson-remote ff808040.rc: ptable->custom_code = 0xbd02
[    3.459628] meson-remote ff808040.rc: ptable->release_delay = 80
[    3.465797] meson-remote ff808040.rc: fn_key_scancode not config yet
[    3.472281] meson-remote ff808040.rc: cursor_left_scancode not config yet
[    3.479213] meson-remote ff808040.rc: cursor_right_scancode not config yet
[    3.486248] meson-remote ff808040.rc: cursor_up_scancode not config yet
[    3.492994] meson-remote ff808040.rc: cursor_down_scancode not config yet
[    3.499944] meson-remote ff808040.rc: cursor_ok_scancode not config yet
[    3.506691] meson-remote ff808040.rc: default protocol = 0x1 and id = 0
[    3.513449] meson-remote ff808040.rc: reg=0x0, val=0x1f40190
[    3.519254] meson-remote ff808040.rc: reg=0x4, val=0x12c00c8
[    3.525076] meson-remote ff808040.rc: reg=0x8, val=0x960050
[    3.530781] meson-remote ff808040.rc: reg=0xc, val=0x480028
[    3.536499] meson-remote ff808040.rc: reg=0x10, val=0x70fa0013
[    3.542496] meson-remote ff808040.rc: reg=0x18, val=0x8616800
[    3.548375] meson-remote ff808040.rc: reg=0x1c, val=0x9f00
[    3.554007] meson-remote ff808040.rc: reg=0x20, val=0x0
[    3.559381] meson-remote ff808040.rc: reg=0x24, val=0x0
[    3.564769] meson-remote ff808040.rc: reg=0x28, val=0x0
[    3.571187] input: aml_keypad as /devices/platform/ff808040.rc/input/input1
[    3.579029] meson-remote: IR XMP protocol handler initialized
[    3.585800] ion_dev soc:ion_dev: assigned reserved memory node linux,ion-dev
[    3.590836] ge2d: ge2d_init_module
[    3.594168] ge2d: ge2d_dev major:235
[    3.597993] ge2d: clock source clk_ge2d_gate ed088900
[    3.602865] ge2d: clock clk_ge2d source ed088340
[    3.607586] ge2d: clock source clk_vapb_0 ed088500
[    3.612508] ge2d: ge2d init clock is 500000000 HZ, VPU clock is 666666656 HZ
[    3.619790] ge2d: ge2d clock is 499 MHZ
[    3.623715] ge2d: find address resource
[    3.627697] ge2d: map io source 0xff940000,size=65536 to 0xf1010000
[    3.634086] ge2d: reserved mem init failed
[    3.638347] ge2d: ge2d: pdev=ed6e8000, irq=58, clk=ed088900
[    3.644106] ge2d: ge2d start monitor
[    3.648291] ge2d: ge2d workqueue monitor start
[    3.648318] [tsync_pcr_init]init success.
[    3.648509] amvideom vsync irq: 59
[    3.649162] create_ge2d_work_queue video task ok
[    3.649202] hdmitx: hdcp: hdmitx_hdcp_init
[    3.649762] vout: vout2: create vout2 attribute OK
[    3.649887] vout: vout2: vout2_fops_create OK
[    3.650041] vout: vout2: clktree_init
[    3.650045] vout: vout2: register server: nulldisp_vout2_server
[    3.650169] vout: vout2: init mode null set ok
[    3.650170] vout: vout2: aml_vout2_probe OK
[    3.650284] DI: di_module_init ok.
[    3.650287] DI: di_module_init: major 509
[    3.650645] deinterlace deinterlace: assigned reserved memory node linux,di_cma
[    3.650648] di:flag_cma=1
[    3.650652] DI: CMA size 0x2800000.
[    3.650669] pre_irq:75
[    3.650676] post_irq:76
[    3.650679] DI: di_probe allocate rdma channel 0.
[    3.650684] di_get_vpu_clkb: get clk vpu error.
[    3.650687] DI: vpu clkb <334000000, 667000000>
[    3.650718] get clkb rate:333333328
[    3.650724] DI:enable vpu clkb.
[    3.650738] 0x000000e1:Y=e1,U=0,V=0
[    3.650741] 0x000000e2:Y=e2,U=0,V=0
[    3.650742] 0x000000e3:Y=e3,U=0,V=0
[    3.650744] 0x000000f0:Y=f0,U=0,V=0
[    3.650747] 0x000000f1:Y=f1,U=0,V=0
[    3.650748] 0x000000f2:Y=f2,U=0,V=0
[    3.650751] 0x000000f3:Y=f3,U=0,V=0
[    3.650752] 0x000000f4:Y=f4,U=0,V=0
[    3.650753] 0x000000f5:Y=f5,U=0,V=0
[    3.650754] 0x000000f6:Y=f6,U=0,V=0
[    3.650759] 0x000000f7:Y=f7,U=0,V=0
[    3.650760] 0x000000f8:Y=f8,U=0,V=0
[    3.650762] 0x000000f9:Y=f9,U=0,V=0
[    3.650763] 0x000000fa:Y=fa,U=0,V=0
[    3.650764] 0x000000fb:Y=fb,U=0,V=0
[    3.650767] 0x000000fc:Y=fc,U=0,V=0
[    3.650774] 0x000000fd:Y=fd,U=0,V=0
[    3.650775] 0x000000fe:Y=fe,U=0,V=0
[    3.650776] 0x000000ff:Y=ff,U=0,V=0
[    3.650777] 0x0000003a:Y=3a,U=0,V=0
[    3.650779] 0x0000003b:Y=3b,U=0,V=0
[    3.650780] 0x0000003c:Y=3c,U=0,V=0
[    3.650783] 0x0000003d:Y=3d,U=0,V=0
[    3.650784] 0x0000003e:Y=3e,U=0,V=0
[    3.650785] 0x0000003f:Y=3f,U=0,V=0
[    3.650787] DI: support multi decoding 61~62~63.
[    3.650986] DI: di_probe:Di use HRTIMER
[    3.651109] di_probe:ok
[    3.651200] vdin_drv_init: major 508
[    3.652436] rdma_register, rdma_table_addr f0efb000 rdma_table_addr_phy e384a000 reg_buf cb2f9400
[    3.652438] rdma_register success, handle 3 table_size 512
[    3.652441] vdin_drv_probe:vdin.0 rdma hanld 3.
[    3.652673] vdin vdin0: assigned reserved memory node linux,vdin0_cma
[    3.652675] \x0a vdin memory resource done.
[    3.652678] vdin0 cma_mem_size = 64 MB
[    3.652682] vdin0 irq: 56 rdma irq: 2
[    3.652684] set_canvas_manual = 0
[    3.652686] no urgent_en found
[    3.652718] get fclk_div5 err
[    3.652720] vdin_drv_probe: vdin cannot get msr clk !!!
[    3.652744] vdin_drv_probe: driver initialized ok
[    3.652828] rdma_register, rdma_table_addr f0efd000 rdma_table_addr_phy e384b000 reg_buf cb2f9800
[    3.652831] rdma_register success, handle 4 table_size 512
[    3.652832] vdin_drv_probe:vdin.1 rdma hanld 4.
[    3.653009] vdin vdin1: assigned reserved memory node linux,vdin1_cma
[    3.653010] \x0a vdin memory resource done.
[    3.653013] vdin1 cma_mem_size = 64 MB
[    3.653016] vdin1 irq: 57 rdma irq: 4
[    3.653017] set_canvas_manual = 0
[    3.653019] no urgent_en found
[    3.653044] get fclk_div5 err
[    3.653047] vdin_drv_probe: vdin cannot get msr clk !!!
[    3.653056] vdin_debugfs_init only support debug vdin0 1
[    3.653058] vdin_drv_probe: driver initialized ok
[    3.653181] vdin_drv_init: vdin driver init done
[    3.653184] [viuin..]viuin_init_module viuin module init
[    3.653426] [viuin..]viuin_probe probe ok.
[    3.653985] [RX]-hdmirx: hdmirx_init.
[    3.653988] ESM HLD: Initializing...
[    3.654127] tvin_afe: tvafe_drv_init: major 506
[    3.654470] tvin_afe: tvafe_drv_init.
[    3.654634] tvafe_vbi: vbi: vbi_init.
[    3.654825] amvdec_csi module: init.
[    3.654829] amvdec_csi_init_module:major 504
[    3.654978] amvdec_csi module: init. ok
[    3.654982] amlvid:info: amlvideo_init called
[    3.654983] amlvid:info: amlvideo_create_instance called
[    3.655000] amlvid:info: v4l2_dev.name=:amlvideo-000
[    3.655172] amlvideo-000: V4L2 device registered as video10
[    3.655173] amlvid:info: amlvideo_create_instance called
[    3.655175] amlvid:info: v4l2_dev.name=:amlvideo-001
[    3.655291] amlvideo-001: V4L2 device registered as video23
[    3.655438] amlvideo2 probe called
[    3.655603] amlvideo2_create_node
[    3.655604] amlvideo2: V4L2 device registered as video11
[    3.655629] amlvideo2 probe called
[    3.655786] amlvideo2_create_node
[    3.655786] amlvideo2: V4L2 device registered as video12
[    3.655835] PPMGRDRV: warn: ppmgr module init func called
[    3.655981] PPMGRDRV: info: ppmgr_driver_probe called
[    3.656054] PPMGRDRV: info: ppmgr_dev major:503
[    3.656253] ppmgr: probe of ppmgr failed with error -22
[    3.656910] ionvideo-000: V4L2 device registered as video13
[    3.657034] ionvideo-001: V4L2 device registered as video14
[    3.657140] ionvideo-002: V4L2 device registered as video15
[    3.657247] ionvideo-003: V4L2 device registered as video16
[    3.657364] ionvideo-004: V4L2 device registered as video17
[    3.657479] ionvideo-005: V4L2 device registered as video18
[    3.657628] ionvideo-006: V4L2 device registered as video19
[    3.657735] ionvideo-007: V4L2 device registered as video20
[    3.657861] ionvideo-008: V4L2 device registered as video21
[    3.657863] ionvid: info: Video Technology Magazine Ion Video
[    3.657864] ionvid: info: Capture Board ver 1.0 successfully loaded
[    3.658113] picdec: picdec_driver_probe called.
[    3.658346] picdec: probe of picdec failed with error -22
[    3.658540] videosync_create_instance dev_s cb305400,dev_s->dev ed5cccc0
[    3.658542] videosync_create_instance reg videosync.0
[    3.658627] aml_vecm_init:module init
[    3.658630] videosync_thread started
[    3.658866] \x0a VECM probe start
[    3.659128] vlock_status_init vlock_en:0
[    3.659150] Can't find  wb_sel.
[    3.659153] hdr:Can't find  cfg_en_osd_100.
[    3.659158] amlogic, vecm
[    3.659158] vlock dt support: 1
[    3.659159] vlock dt new_fsm: 0
[    3.659160] vlock dt hwver: 0
[    3.659161] vlock dt phlock_en: 0
[    3.659164] Can't find  vlock_en.
[    3.659165] Can't find  vlock_mode.
[    3.659166] Can't find  vlock_pll_m_limit.
[    3.659168] Can't find  vlock_line_limit.
[    3.659196] param_config vlock_en:0
[    3.659201] aml_vecm_probe: ok
[    3.659249] amdolby_vision_init:module init
[    3.659605] \x0a amdolby_vision probe start & ver: 20181220
[    3.659611] \x0a cpu_id=2 tvmode=0
[    3.659749] dolby_vision_init_receiver(dvel)
[    3.659755] dolby_vision_init_receiver: dvel
[    3.660023] amdolby_vision_probe: ok
[    3.660092] prime_sl module init
[    3.660536] vm_init .
[    3.661476] meson-mmc: mmc driver version: 3.02, 2017-05-15: New Emmc Host Controller
[    3.662409] meson-mmc: >>>>>>>>hostbase f102b000, dmode
[    3.662661] meson-mmc: actual_clock :400000, HHI_nand: 0x80
[    3.662664] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x1000033c
[    3.707162] meson-mmc: meson_mmc_probe() : success!
[    3.711467] meson-mmc: >>>>>>>>hostbase f10b5000, dmode
[    3.711503] meson-mmc: gpio_cd = 1ca
[    3.750561] meson-mmc: meson_mmc_probe() : success!
[    3.752210] meson-mmc: >>>>>>>>hostbase f113f000, dmode
[    3.752504] meson-mmc: actual_clock :400000, HHI_nand: 0x80
[    3.752507] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x1000033c
[    3.782658] hdmitx: system: irq 2 0
[    3.789541] meson-mmc: meson_mmc_probe() : success!
[    3.789810] amlogic mtd driver init
[    3.790501] aml_vrtc rtc: rtc core: registered aml_vrtc as rtc0
[    3.791200] cectx ff80023c.aocec: cec driver date:2019/6/13:early suspend not report pw status\x0a
[    3.791439] cectx ff80023c.aocec: compatible:amlogic, aocec-sm1
[    3.791442] cectx ff80023c.aocec: cecb_ver:0x2
[    3.791444] cectx ff80023c.aocec: line_reg:0x1
[    3.791446] cectx ff80023c.aocec: line_bit:0x3
[    3.791448] cectx ff80023c.aocec: ee_to_ao:0x1
[    3.791595] input: cec_input as /devices/virtual/input/input2
[    3.791726] cectx ff80023c.aocec: not find 'port_num'
[    3.791729] cectx ff80023c.aocec: using cec:1
[    3.791758] cectx ff80023c.aocec: no hdmirx regs
[    3.791761] cectx ff80023c.aocec: no hhi regs
[    3.791767] cectx ff80023c.aocec: not find 'output'
[    3.791774] cec: wake up flag:0
[    3.793238] cectx ff80023c.aocec: irq cnt:2
[    3.793485] cectx ff80023c.aocec: wakeup_reason:0x0
[    3.793589] cectx ff80023c.aocec: cev val1: 0x0;val2: 0x0
[    3.793593] cectx ff80023c.aocec: aml_cec_probe success end
[    3.793935] unifykey: storage in base: 0xc5000000
[    3.793938] unifykey: storage out base: 0xc5040000
[    3.793940] unifykey: storage block base: 0xc5080000
[    3.793942] unifykey: probe done!
[    3.794328] unifykey: no efuse-version set, use default value: -1
[    3.794330] unifykey: key unify config unifykey-num is 16
[    3.794386] unifykey: key unify fact unifykey-num is 16
[    3.794394] unifykey: unifykey_devno: 1f000000
[    3.794605] unifykey: device unifykeys created ok
[    3.794652] unifykey: aml_unifykeys_init done!
[    3.794813] meson ts init
[    3.794867] tsensor id: 0
[    3.795017] tsensor trim info: 0xfa008027!
[    3.795019] tsensor hireboot: 0xc0ff2a90
[    3.795090] meson ts init
[    3.795105] tsensor id: 1
[    3.795216] tsensor trim info: 0xfa000020!
[    3.795218] tsensor hireboot: 0xc0ff2a70
[    3.795305] audio_dsp: [dsp]register dsp to char divece(257)
[    3.795491] amaudio: amaudio: driver amaudio init!
[    3.795848] amaudio: amaudio_init - amaudio: driver amaudio succuess!
[    3.796426] sysled: module init
[    3.796592] sysled: cust gpio register
[    3.796726] meson_wdt ffd0f0d0.watchdog: start watchdog
[    3.796729] meson_wdt ffd0f0d0.watchdog: creat work queue for watch dog
[    3.796996] meson_wdt ffd0f0d0.watchdog: AML Watchdog Timer probed done
[    3.797614] amlogic rfkill init
[    3.797756] enter bt_probe of_node
[    3.797776] not get gpio_en
[    3.797786] power on valid level is high
[    3.797786] bt: power_on_pin_OD = 0;
[    3.797789] bt: power_off_flag = 1;
[    3.797790] dis power down = 0;
[    3.825725] BLASTER Driver Init
[    3.826134] irblaster: probe
[    3.826841] dmc_monitor_probe
[    3.827802] aml_atvdemod_init: OK, atv demod version: V2.04.
[    3.827949] defendkey ff630218.defendkey: Reserved memory is not enough!
[    3.827960] defendkey: probe of ff630218.defendkey failed with error -22
[    3.828328] usbcore: registered new interface driver snd-usb-audio
[    3.829349] aml_codec_T9015 ff632000.t9015: aml_T9015_audio_codec_probe
[    3.829368] T9015 acodec used by auge, tdmout:1
[    3.831601] asoc debug: aml_audio_controller_probe-127
[    3.833275] aml_tdm_platform_probe, tdm ID = 0, lane_cnt = 2
[    3.833297] snd_tdm ff660000.audiobus:tdm@0: lane_mask_out = 0, lane_oe_mask_out = 0
[    3.833433] aml_tdm_platform_probe(), share en = 1
[    3.833434] No channel mask node Channel_Mask
[    3.833698] aml_tdm_platform_probe, tdm ID = 1, lane_cnt = 8
[    3.833763] TDM id 1 samesource_sel:3
[    3.833772] snd_tdm ff660000.audiobus:tdm@1: lane_mask_out = 1, lane_oe_mask_out = 0
[    3.833997] TDM id 1 output clk enable:1
[    3.834024] aml_tdm_platform_probe(), share en = 1
[    3.834024] No channel mask node Channel_Mask
[    3.834038] TDM id 1 tuning clk enable:1
[    3.834195] aml_tdm_platform_probe, tdm ID = 2, lane_cnt = 4
[    3.834211] snd_tdm ff660000.audiobus:tdm@2: lane_mask_out = 0, lane_oe_mask_out = 0
[    3.834375] aml_tdm_platform_probe(), share en = 1
[    3.834375] No channel mask node Channel_Mask
[    3.835141] aml_spdif_platform_probe, spdif ID = 0
[    3.835478] SPDIF id 0 asrc_id:0 auto_asrc:0
[    3.835549] Spdif id 0 tuning clk enable:1
[    3.835552] spdifout_play_with_zerodata, spdif id:0 enable:0
[    3.835557] spdif_a fifo ctrl, frddr:0 type:3, 32 bits, chmask 0x3, swap 0x10
[    3.835563] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[    3.835572] hdmitx: audio: aout notify format CT_PCM
[    3.835577] spdif_a is set to enable
[    3.835587] aml_spdif_platform_probe, register soc platform
[    3.835620] aml_spdif_platform_probe, spdif ID = 1
[    3.835676] spdifout_play_with_zerodata, spdif id:1 enable:0
[    3.835680] spdif_b fifo ctrl, frddr:0 type:3, 32 bits, chmask 0x3, swap 0x10
[    3.835685] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[    3.835692] spdif_b is set to enable
[    3.835701] aml_spdif_platform_probe, register soc platform
[    3.836475] default set lane_mask_in as all lanes.
[    3.836478] aml_pdm_platform_probe pdm filter mode from dts:1
[    3.836488] aml_pdm_platform_probe, register soc platform
[    3.836921] audio_ddr_mngr: 0, irqs toddr 37, frddr 41
[    3.836924] audio_ddr_mngr: 1, irqs toddr 38, frddr 42
[    3.836927] audio_ddr_mngr: 2, irqs toddr 39, frddr 43
[    3.836929] audio_ddr_mngr: 3, irqs toddr 40, frddr 44
[    3.837346] \x09datain_src:4, datain_chnum:2, datain_chumask:3
[    3.837347] \x09datalb_src:1, datalb_chnum:2, datalb_chmask:3
[    3.837349] \x09datain_lane_mask:0x1, datalb_lane_mask:0x1
[    3.837350] datalb_format: 1, chmask for lanes: 0x3
[    3.837607] loopback_platform_probe, p_loopback->id:0 register soc platform
[    3.838346] effect_platform_probe, line:565
[    3.838480] eqdrc_clk_set, src pll:399999993, clk:199999997
[    3.838484] effect_platform_probe \x09 module:1, lane_mask:1, ch_mask:3
[    3.839310] vad_platform_probe vad data source sel:4, level:1
[    3.839473] input: vad_keypad as /devices/platform/soc/ff660000.audiobus/ff660000.audiobus:vad/input/input3
[    3.840012] Register vad
[    3.840381] EARC ff660000.audiobus:earc: Check whether support eARC TX
[    3.840385] EARC ff660000.audiobus:earc: Check whether support eARC TX
[    3.840389] EARC ff660000.audiobus:earc: Check whether support eARC TX
[    3.840392] EARC ff660000.audiobus:earc: Check whether support eARC TX
[    3.840419] EARC ff660000.audiobus:earc: platform get irq tx_cmdc failed, Check whether support eARC TX
[    3.840422] EARC ff660000.audiobus:earc: platform get irq tx_dmac failed, Check whether support eARC TX
[    3.840432] earc_platform_probe, register soc platform
[    3.949237] meson-aml-mmc ffe07000.emmc: divider requested rate 200000000 != actual rate 199999997: ret=0
[    3.949243] meson-mmc: actual_clock :199999997, HHI_nand: 0x80
[    3.949245] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x10000245
[    3.949250] meson-mmc: Data 1 aligned delay is 0
[    3.949254] meson-mmc: emmc: clk 199999997 tuning start
[    3.954844] meson-mmc: emmc: rx_tuning_result[0] = 40
[    3.957417] meson-mmc: emmc: rx_tuning_result[1] = 40
[    3.960008] meson-mmc: emmc: rx_tuning_result[2] = 40
[    3.962660] meson-mmc: emmc: rx_tuning_result[3] = 40
[    3.965241] meson-mmc: emmc: rx_tuning_result[4] = 40
[    3.965247] meson-mmc: _aml_sd_emmc_execute_tuning() d1_dly 0, window start 0, size 5
[    3.965250] meson-mmc: emmc: clk 199999997 tuning start
[    3.970415] meson-mmc: emmc: rx_tuning_result[0] = 40
[    3.973041] meson-mmc: emmc: rx_tuning_result[1] = 40
[    3.975648] meson-mmc: emmc: rx_tuning_result[2] = 40
[    3.978223] meson-mmc: emmc: rx_tuning_result[3] = 40
[    3.980827] meson-mmc: emmc: rx_tuning_result[4] = 40
[    3.980829] meson-mmc: _aml_sd_emmc_execute_tuning() d1_dly 1, window start 0, size 5
[    3.980832] meson-mmc: emmc: clk 199999997 tuning start
[    3.984214] meson-mmc: Tuning transfer error: nmatch=11 tuning_err:0xffffffac
[    3.986805] meson-mmc: emmc: rx_tuning_result[1] = 40
[    3.989407] meson-mmc: emmc: rx_tuning_result[2] = 40
[    3.991989] meson-mmc: emmc: rx_tuning_result[3] = 40
[    3.994595] meson-mmc: emmc: rx_tuning_result[4] = 40
[    3.994598] meson-mmc: emmc: best_win_start =1, best_win_size =4
[    3.994603] meson-mmc: emmc: sd_emmc_regs->gclock=0x10000245,sd_emmc_regs->gadjust=0x32000
[    3.995289] emmc: new HS200 MMC card at address 0001
[    3.995869] emmc: clock 199999997, 8-bit-bus-width\x0a
[    3.995869] mmcblk0: emmc:0001 DF4064 58.2 GiB
[    3.997004] mmcblk0boot0: emmc:0001 DF4064 partition 1 4.00 MiB
[    4.001210] mmcblk0boot1: emmc:0001 DF4064 partition 2 4.00 MiB
[    4.005414] mmcblk0rpmb: emmc:0001 DF4064 partition 3 4.00 MiB
[    4.006583] meson-mmc: Enter aml_emmc_partition_ops
[    4.007645] meson-mmc: [mmc_read_partition_tbl] mmc read partition OK!
[    4.007646] meson-mmc: add_emmc_partition
[    4.007816] meson-mmc: [mmcblk0p01]           bootloader  offset 0x000000000000, size 0x000000400000
[    4.007957] meson-mmc: [mmcblk0p02]             reserved  offset 0x000002400000, size 0x000004000000
[    4.008098] meson-mmc: [mmcblk0p03]                cache  offset 0x000006c00000, size 0x000046000000
[    4.008216] meson-mmc: [mmcblk0p04]                  env  offset 0x00004d400000, size 0x000000800000
[    4.008350] meson-mmc: [mmcblk0p05]                 logo  offset 0x00004e400000, size 0x000000800000
[    4.008486] meson-mmc: [mmcblk0p06]             recovery  offset 0x00004f400000, size 0x000001800000
[    4.008610] meson-mmc: [mmcblk0p07]                 misc  offset 0x000051400000, size 0x000000800000
[    4.008744] meson-mmc: [mmcblk0p08]                 dtbo  offset 0x000052400000, size 0x000000800000
[    4.008870] meson-mmc: [mmcblk0p09]             cri_data  offset 0x000053400000, size 0x000000800000
[    4.009003] meson-mmc: [mmcblk0p10]                param  offset 0x000054400000, size 0x000001000000
[    4.009138] meson-mmc: [mmcblk0p11]                 boot  offset 0x000055c00000, size 0x000001000000
[    4.009254] meson-mmc: [mmcblk0p12]                  rsv  offset 0x000057400000, size 0x000001000000
[    4.009388] meson-mmc: [mmcblk0p13]             metadata  offset 0x000058c00000, size 0x000001000000
[    4.009527] meson-mmc: [mmcblk0p14]               vbmeta  offset 0x00005a400000, size 0x000000200000
[    4.009660] meson-mmc: [mmcblk0p15]                  tee  offset 0x00005ae00000, size 0x000002000000
[    4.009784] meson-mmc: [mmcblk0p16]               vendor  offset 0x00005d600000, size 0x000046000000
[    4.009919] meson-mmc: [mmcblk0p17]                  odm  offset 0x0000a3e00000, size 0x000008000000
[    4.010053] meson-mmc: [mmcblk0p18]               system  offset 0x0000ac600000, size 0x000050000000
[    4.010173] meson-mmc: [mmcblk0p19]              product  offset 0x0000fce00000, size 0x000008000000
[    4.010304] meson-mmc: [mmcblk0p20]                 data  offset 0x000105600000, size 0x000d8a200000
[    4.010319] card key: card_blk_probe.
[    4.010323] emmc_key_init:183 emmc key lba_start:0x12020,lba_end:0x12220
[    4.010326] emmc key: emmc_key_init:205 ok.
[    4.012525] meson-mmc: amlmmc_dtb_init: register dtb chardev
[    4.012525] meson-mmc: calc ed53d474, store ed53d474
[    4.015241] meson-mmc: calc ed53d474, store ed53d474
[    4.015243] meson-mmc: total valid 2
[    4.015485] meson-mmc: amlmmc_dtb_init: register dtb chardev OK
[    4.015485] meson-mmc: Exit aml_emmc_partition_ops OK.
[    4.049852] asoc-aml-card auge_sound: control 2:0:0:I2SIn CLK:0 is already present
[    4.049857] snd_tdm ff660000.audiobus:tdm@1: ASoC: Failed to add I2SIn CLK: -16
[    4.049859] aml_dai_tdm_probe, failed add snd tdm controls
[    4.049867] asoc-aml-card auge_sound: control 2:0:0:I2SIn CLK:0 is already present
[    4.049871] snd_tdm ff660000.audiobus:tdm@2: ASoC: Failed to add I2SIn CLK: -16
[    4.049874] aml_dai_tdm_probe, failed add snd tdm controls
[    4.049876] aml_dai_spdif_probe
[    4.049891] aml_dai_spdif_probe
[    4.049894] asoc debug: earc_dai_probe-342
[    4.049899] aml_dai_set_tdm_slot(), txmask(0xff), rxmask(0xff)
[    4.049900] \x09lanes_out_cnt(0), lanes_in_cnt(1)
[    4.049902] \x09lanes_lb_cnt(0)
[    4.049904] \x09slots(8), slot_width(32)
[    4.049905] \x09lanes_oe_out_cnt(0), lanes_oe_in_cnt(0)
[    4.049919] asoc aml_dai_set_tdm_fmt, 0x4004, ed56d410, id(0), clksel(0)
[    4.049925] master_mode(1), binv(1), finv(0) out_skew(2), in_skew(3)
[    4.050549] asoc-aml-card auge_sound: multicodec <-> TDM-A mapping ok
[    4.050555] aml_dai_set_tdm_slot(), txmask(0x3), rxmask(0x3)
[    4.050557] \x09lanes_out_cnt(1), lanes_in_cnt(1)
[    4.050558] \x09lanes_lb_cnt(0)
[    4.050560] \x09slots(2), slot_width(32)
[    4.050564] \x09lanes_oe_out_cnt(0), lanes_oe_in_cnt(0)
[    4.050575] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[    4.050582] master_mode(1), binv(1), finv(1) out_skew(2), in_skew(3)
[    4.051084] asoc-aml-card auge_sound: multicodec <-> TDM-B mapping ok
[    4.051090] aml_dai_set_tdm_slot(), txmask(0x3), rxmask(0x3)
[    4.051092] \x09lanes_out_cnt(0), lanes_in_cnt(1)
[    4.051093] \x09lanes_lb_cnt(0)
[    4.051096] \x09slots(2), slot_width(32)
[    4.051097] \x09lanes_oe_out_cnt(0), lanes_oe_in_cnt(0)
[    4.051101] asoc aml_dai_set_tdm_fmt, 0x4001, ed7f7210, id(2), clksel(2)
[    4.051104] master_mode(1), binv(1), finv(1) out_skew(2), in_skew(3)
[    4.051640] asoc-aml-card auge_sound: dummy <-> TDM-C mapping ok
[    4.052092] asoc-aml-card auge_sound: dummy <-> ff660000.audiobus:pdm mapping ok
[    4.052098] aml_dai_set_spdif_fmt , fmt 0x4000
[    4.052204] aml_spdif_new spdif_a, clk continuous:1
[    4.052206] spdifout_play_with_zerodata_free, spdif id:0
[    4.052666] asoc-aml-card auge_sound: dummy <-> SPDIF mapping ok
[    4.052669] set normal 512 fs /4 fs
[    4.052722] \x09 set spdifout clk:6144000, mpll:24576000
[    4.052724] \x09 get spdifout clk:6143997, mpll:24575987
[    4.052726] aml_dai_set_spdif_fmt , fmt 0x4010
[    4.052801] aml_spdif_new spdif_b, clk continuous:1
[    4.052803] spdifout_play_with_zerodata_free, spdif id:1
[    4.053007] asoc-aml-card auge_sound: dummy <-> SPDIF-B mapping ok
[    4.053012] asoc earc_dai_set_fmt, 0x4000, ed5ca910
[    4.053532] asoc-aml-card auge_sound: dummy <-> ff660000.audiobus:earc mapping ok
[    4.055660] snd_card_add_kcontrols card:ed129c10
[    4.055735] eq/drc v1 function enable
[    4.055741] no node audio_effect for eq/drc info!
[    4.055742] Failed to add audio effects v1 controls
[    4.055956] GACT probability NOT on
[    4.055966] Mirror/redirect action on
[    4.055973] u32 classifier
[    4.055974] Actions configured
[    4.055978] Netfilter messages via NETLINK v0.30.
[    4.056178] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    4.056417] ctnetlink v0.93: registering with nfnetlink.
[    4.056940] xt_time: kernel timezone is -0000
[    4.057028] ipip: IPv4 and MPLS over IPv4 tunneling driver
[    4.057414] IPv4 over IPsec tunneling driver
[    4.065902] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.066052] arp_tables: arp_tables: (C) 2002 David S. Miller
[    4.074890] Initializing XFRM netlink socket
[    4.075279] NET: Registered protocol family 10
[    4.076148] mip6: Mobile IPv6
[    4.076168] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    4.090012] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    4.090857] NET: Registered protocol family 17
[    4.090879] NET: Registered protocol family 15
[    4.090904] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.090991] Bluetooth: RFCOMM TTY layer initialized
[    4.090999] Bluetooth: RFCOMM socket layer initialized
[    4.091019] Bluetooth: RFCOMM ver 1.11
[    4.091026] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.091027] Bluetooth: BNEP filters: protocol multicast
[    4.091040] Bluetooth: BNEP socket layer initialized
[    4.091042] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.091046] Bluetooth: HIDP socket layer initialized
[    4.091065] l2tp_core: L2TP core driver, V2.0
[    4.091075] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    4.091076] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[    4.091091] l2tp_netlink: L2TP netlink interface
[    4.091116] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[    4.091133] l2tp_debugfs: L2TP debugfs support
[    4.091135] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[    4.091168] NET: Registered protocol family 35
[    4.091212] Key type dns_resolver registered
[    4.092942] Registering SWP/SWPB emulation handler
[    4.093569] registered taskstats version 1
[    4.103664] dwc3 ff500000.dwc3: Configuration mismatch. dr_mode forced to host
[    4.106410] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.106428] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.106766] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x20010010
[    4.106808] xhci-hcd xhci-hcd.0.auto: irq 29, io mem 0xff500000
[    4.107494] hub 1-0:1.0: USB hub found
[    4.107522] hub 1-0:1.0: 2 ports detected
[    4.107882] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.107891] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.107956] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.108499] hub 2-0:1.0: USB hub found
[    4.108523] hub 2-0:1.0: 1 port detected
[    4.110319] aml_vrtc rtc: setting system clock to 2015-01-01 00:00:13 UTC (1420070413)
[    4.110613] dwc_otg ff400000.dwc2_a: dwc_otg_driver_probe(ed684a00)
[    4.110642] dwc_otg: usb0: type: 2 speed: 0, config: 0, dma: 0, id: 0, phy: ffe09000, ctrl: 0
[    4.110644] dwc_otg_driver_probe host only, not probe usb_otg!!!
[    4.111154] lcd extern: key_valid: 0
[    4.111157] lcd extern: lcd_extern_get_config from dts
[    4.111166] lcd extern: error: failed to get extern_5
[    4.111201] lcd extern: aml_lcd_extern_probe ok
[    4.111639] bl: chip type/name: (8-sm1)
[    4.111642] bl: key_valid: 0
[    4.111643] bl: aml_bl_config_load from dts
[    4.111647] bl: load: backlight_0
[    4.111654] bl error: failed to get bl_power_attr
[    4.111659] bl: bl pwm_port: PWM_F(5)
[    4.111665] bl: name              = backlight_pwm
[    4.111666] bl: method            = pwm(1)
[    4.111733] bl: register pwm_ch(5) 0xed01fc30
[    4.111735] bl: aml_bl_pwm_channel_register ok
[    4.112005] bl: probe OK
[    4.112779] meson_cdev probe
[    4.112789] thermal: read gpupp failed
[    4.112886] meson_cdev index: 0
[    4.113021] thermal: read gpupp failed
[    4.113072] meson_cdev index: 1
[    4.113078] cpucore_cooling_register, max_cpu_core_num:4
[    4.113204] meson_cdev index: 2
[    4.113207] thermal: read gpupp failed
[    4.113237] meson_cdev index: 3
[    4.113288] find tzd id: 0
[    4.113394] find tzd id: 0
[    4.113425] meson_cdev probe done
[    4.113590] gxbb_pm: enter meson_pm_probe!
[    4.113618] gxbb_pm: meson_pm_probe done
[    4.114001] ALSA device list:
[    4.114004] #0: AML-AUGESOUND
[    4.318782] hdmitx: system: ###plugin!
[    4.318784] ###hdmi turn on!
[    4.456181] hdmitx: edid: EDID Parser:
[    4.456184] hdmitx: hdmitx: reach vesa idx MAX
[    4.456186] hdmitx: hdmitx: reach vesa idx MAX
[    4.456187] hdmitx: hdmitx: reach vesa idx MAX
[    4.456194] hdmitx: hdmitx: reach vesa idx MAX
[    4.456197] hdmitx: hdmitx: reach vesa idx MAX
[    4.456200] hdmitx: hdmitx: reach vesa idx MAX
[    4.456212] hdmitx: edid: get dtd0 vic: 16
[    4.456216] hdmitx: hdmitx: get PMT vic: 97
[    4.456219] hdmitx: edid: find IEEEOUT
[    4.456241] hdmitx: edid: check sum valid
[    4.456242] hdmitx: edid: check sum valid
[    4.456248] hdmitx: edid: check sum valid
[    4.456250] hdmitx: edid: check sum valid
[    4.456254] hdmitx: edid: blk0 raw data
[    4.456277] hdmitx: edid: \x0a00ffffffffffff001e6d085bcff40100021b0103803c2278ea3035a7554ea326\x0a0f50542108007140818081c0a9c0d1c081000101010108e80030f2705a80b058\x0a8a0058542100001e04740030f2705a80b0588a0058542100001a000000fd0038\x0a3d1e873c000a202020202020000000fc004c4720556c7472612048440a20014c\x0a\x0a
[    4.456280] hdmitx: edid: blk1 raw data
[    4.456301] hdmitx: edid: \x0a020330714d902220050403020161605d5e5f230907076d030c002000b83c2000\x0a6001020367d85dc401788003e30f0006023a801871382d40582c450058542100\x0a001a565e00a0a0a029503020350058542100001a000000000000000000000000\x0a000000000000000000000000000000000000000000000000000000000000009a\x0a\x0a
[    4.456304] hdmitx: system: cann't get valid mode
[    4.572184] av out status: high
[    4.697545] vout: refresh_tvout_mode: mode chang to 1080p60hz
[    4.697548] vout: vmode set to 1080p60hz
[    4.697590] fb: current vmode=576cvbs, cmd: 0x10000
[    4.697599] \x0avdac_enable: on:0,module_sel:8
[    4.697621] hdmitx: hdmitx_set_current_vmode[3693]
[    4.697625] hdmitx: system: recalc before 1080p60hz 60 1
[    4.697628] hdmitx: system: recalc after 1080p60hz 2997 50
[    4.697634] hdmitx: system: get current mode: 1080p60hz
[    4.697636] hdmitx: system: update rx hdr info 0
[    4.697638] hdmitx: system: update physcial size: 600 340
[    4.697668] hdmitx: video: already init VIC = 0  Now VIC = 16
[    4.697673] hdmitx: hw: div40: 0
[    4.731534] hdmitx: frac_rate = 1
[    4.731541] hdmitx: config HPLL = 5940000 frac_rate = 1
[    4.731598] hdmitx: HPLLv1: 0xdb3a04f7
[    4.731601] hdmitx: config HPLL done
[    4.731611] hdmitx: set_hpll_od3_clk_div[610] div = 6
[    4.731617] hdmitx: j = 4  vid_clk_div = 1
[    4.731623] hdmitx: set enc for VIC: 16
[    4.849539] hdmitx: hw:  config hdmitx IP vic = 16 cd:4 cs: 2
[    4.859647] hdmitx: video: Sink is HDMI device
[    4.859717] hdmitx: hw: set audio
[    4.859724] hdmitx: hw: hdmitx tx_aud_src = 0
[    4.859738] hdmitx: fs = 3, cd = 4, tmds_clk = 148352
[    4.859741] hdmitx: hw: aud_n_para = 5824
[    4.859749] hdmitx: hw: set channel status
[    4.859781] hdmitx: audio: Audio Type: PCM
[    4.859784] vout: new mode 1080p60hz set ok
[    4.859788] fb: current vmode=1080p60hz, cmd: 0x20000
[    4.859796] fb: outputmode changed to 1080p60hz, reset osd0, (0, 0, 719, 287) -> (0, 0, 1919, 1079)
[    4.893077] fb: osd[0] enable: 1 (kworker/0:0)
[    6.211283] meson_uart ff803000.serial: ttyS0 use xtal(24M) 24000000 change 115200 to 115200
[    6.317527] prepare_namespace() wait 79
[    6.317598] md: Waiting for all devices to be available before autodetect
[    6.322876] md: If you don't use raid, use raid=noautodetect
[    6.330055] md: Autodetecting RAID arrays.
[    6.332911] md: Scanned 0 and added 0 devices.
[    6.337496] md: autorun ...
[    6.340448] md: ... autorun DONE.
[    6.347112] EXT4-fs (mmcblk0p18): couldn't mount as ext3 due to feature incompatibilities
[    6.352639] EXT4-fs (mmcblk0p18): couldn't mount as ext2 due to feature incompatibilities
[    6.366437] EXT4-fs (mmcblk0p18): mounted filesystem without journal. Opts: (null)
[    6.368561] VFS: Mounted root (ext4 filesystem) readonly on device 179:18.
[    6.377099] devtmpfs: mounted
[    6.379514] Freeing unused kernel memory: 1024K
[    6.405694] init: init first stage started!
[    6.406958] init: Using Android DT directory /proc/device-tree/firmware/android/
[    6.416361] init: [libfs_mgr]fs_mgr_read_fstab_default(): failed to find device default fstab
[    6.472813] EXT4-fs (mmcblk0p17): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[    6.477337] init: [libfs_mgr]__mount(source=/dev/block/odm,target=/odm,type=ext4)=0: Success
[    6.488417] EXT4-fs (mmcblk0p19): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[    6.495949] init: [libfs_mgr]__mount(source=/dev/block/product,target=/product,type=ext4)=0: Success
[    6.509466] EXT4-fs (mmcblk0p16): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[    6.515192] init: [libfs_mgr]__mount(source=/dev/block/vendor,target=/vendor,type=ext4)=0: Success
[    6.524389] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[    6.531444] init: Loading SELinux policy
[    6.551362] SELinux: 8192 avtab hash slots, 19689 rules.
[    6.562623] SELinux: 8192 avtab hash slots, 19689 rules.
[    6.562637] SELinux:  1 users, 4 roles, 1433 types, 0 bools, 1 sens, 1024 cats
[    6.562646] SELinux:  93 classes, 19689 rules
[    6.565228] SELinux:  Completing initialization.
[    6.565233] SELinux:  Setting up existing superblocks.
[    6.713073] audit: type=1403 audit(1420070416.100:2): policy loaded auid=4294967295 ses=4294967295
[    6.716771] selinux: SELinux: Loaded policy from /odm/etc/selinux/precompiled_sepolicy\x0a
[    6.737464] selinux: SELinux: Loaded file_contexts\x0a
[    6.743048] init: init second stage started!
[    6.768061] init: Using Android DT directory /proc/device-tree/firmware/android/
[    6.775302] selinux: SELinux: Loaded file_contexts\x0a
[    6.776595] init: Running restorecon...
[    6.787900] init: waitid failed: No child processes
[    6.795263] init: Couldn't load property file '/odm/default.prop': open() failed: No such file or directory: No such file or directory
[    6.804843] init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
[    6.811151] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2500
[    6.818228] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2501
[    6.824598] init: Parsing file /init.rc...
[    6.928578] ueventd: ueventd started!
[    6.934246] selinux: SELinux: Loaded file_contexts\x0a
[    6.935707] mali_kbase: loading out-of-tree module taints kernel.
[    6.940241] mali ffe40000.bifrost: Continuing without Mali regulator control
[    6.940330] mali ffe40000.bifrost: max pp is 2
[    6.940335] mali ffe40000.bifrost: set min pp to default 1
[    6.940338] mali ffe40000.bifrost: min pp is 1
[    6.940340] mali ffe40000.bifrost: set min clk default to 0
[    6.940344] mali ffe40000.bifrost: min clk  is 0
[    6.940360] mali ffe40000.bifrost: hiu io source  0xf1797000
[    6.940368] mali ffe40000.bifrost: hiu io source  0xf1799000
[    6.940372] mali ffe40000.bifrost: num of pp used most of time 1
[    6.940375] mali ffe40000.bifrost: clock dvfs cfg table size is 6
[    6.940447] mali ffe40000.bifrost: max clk set 4
[    6.940450] mali ffe40000.bifrost: max clk  is 4
[    6.940454] mali ffe40000.bifrost: turbo clk set to 5
[    6.940457] mali ffe40000.bifrost: turbo clk  is 5
[    6.940460] mali ffe40000.bifrost: default clk set to 4
[    6.940463] mali ffe40000.bifrost: default clk  is 4
[    6.940469] mali ffe40000.bifrost: ====================0====================\x0aclk_freq= 285714285, clk_parent=fclk_div7, voltage=1150, keep_count=5, threshod=<100 190>, clk_sample=285
[    6.940473] mali ffe40000.bifrost: ====================1====================\x0aclk_freq= 400000000, clk_parent=fclk_div5, voltage=1150, keep_count=5, threshod=<152 207>, clk_sample=400
[    6.940478] mali ffe40000.bifrost: ====================2====================\x0aclk_freq= 500000000, clk_parent=fclk_div4, voltage=1150, keep_count=5, threshod=<180 220>, clk_sample=500
[    6.940482] mali ffe40000.bifrost: ====================3====================\x0aclk_freq= 666666666, clk_parent=fclk_div3, voltage=1150, keep_count=5, threshod=<210 236>, clk_sample=666
[    6.940489] mali ffe40000.bifrost: ====================4====================\x0aclk_freq= 846000000, clk_parent=  gp0_pll, voltage=1150, keep_count=5, threshod=<230 255>, clk_sample=846
[    6.940493] mali ffe40000.bifrost: ====================5====================\x0aclk_freq= 846000000, clk_parent=  gp0_pll, voltage=1150, keep_count=5, threshod=<230 255>, clk_sample=846
[    6.940496] mali ffe40000.bifrost: clock dvfs table size is 6
[    6.940733] mali_plat=bf05e2d8
[    6.941098] find tzd id: 0
[    6.941122] gpu cooling register okay with err=0
[    6.941345] find tzd id: 0
[    6.941354] gpu core cooling register okay with err=0
[    6.941380] shader_present=1, tiler_present=1, l2_present=1
[    6.941460] Mali_pwr_on:gpu_irq : 200
[    6.949602] hrtimer: interrupt took 16792 ns
[    6.950165] mali ffe40000.bifrost: GPU identified as 0x3 arch 7.0.9 r0p0 status 0
[    6.954925] mali ffe40000.bifrost: Probed as mali0
[    6.965077] PPMGRVPP: info: RegisterTB_Function: gfunc   (null), func: bf08f000, ver:TB detect: v2016.11.15a *** [ Tue Mar 19 19:21:39 CST 2019]-[ renjiang.han]-[* master]-[67f03d41e0612a58d1edd96db9bc8b92de1a59b1]-[Date: Wed Jul 4 00:44:57 2018 +0800]-[2]
[    7.210976] ueventd: Parsing file /ueventd.rc...
[    7.219266] ueventd: Parsing file /vendor/ueventd.rc...
[    7.222038] ueventd: /vendor/ueventd.rc: 110: /sys/ lines must have 5 entries
[    7.228310] ueventd: Parsing file /odm/ueventd.rc...
[    7.233419] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[    7.243310] ueventd: Parsing file /ueventd.amlogic.rc...
[    7.248727] ueventd: Unable to read config file '/ueventd.amlogic.rc': open() failed: No such file or directory
[    7.716024] ueventd: Coldboot took 0.451 seconds
[    7.732198] audit: type=1400 audit(1420070417.120:3): avc:  denied  { write } for  pid=1 comm="init" name="alignment" dev="proc" ino=4026531966 scontext=u:r:init:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[    7.746060] audit: type=1400 audit(1420070417.136:4): avc:  denied  { open } for  pid=1 comm="init" path="/proc/cpu/alignment" dev="proc" ino=4026531966 scontext=u:r:init:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[    7.788410] audit: type=1400 audit(1420070417.176:5): avc:  denied  { write } for  pid=2500 comm="init" name="watermark_scale_factor" dev="proc" ino=666 scontext=u:r:vendor_init:s0 tcontext=u:object_r:proc_vm_writable:s0 tclass=file permissive=1
[    7.828585] EXT4-fs (mmcblk0p20): Ignoring removed nomblk_io_submit option
[    7.849472] EXT4-fs (mmcblk0p20): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    8.005239] e2fsck: e2fsck 1.43.3 (04-Sep-2016)\x0a
[    8.006038] e2fsck: /dev/block/data: clean, 18023/3555328 files, 602481/14197248 blocks\x0a
[    8.018594] EXT4-fs (mmcblk0p20): Ignoring removed nomblk_io_submit option
[    8.034491] EXT4-fs (mmcblk0p20): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submit,errors=panic
[    8.043851] EXT4-fs (mmcblk0p3): Ignoring removed nomblk_io_submit option
[    8.052618] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    8.118016] e2fsck: e2fsck 1.43.3 (04-Sep-2016)\x0a
[    8.118814] e2fsck: /dev/block/cache: clean, 20/71712 files, 13092/286720 blocks\x0a
[    8.129469] EXT4-fs (mmcblk0p3): Ignoring removed nomblk_io_submit option
[    8.140127] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submit,errors=panic
[    8.148211] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[    8.157854] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    8.213868] e2fsck: e2fsck 1.43.3 (04-Sep-2016)\x0a
[    8.214629] e2fsck: /dev/block/metadata: clean, 12/4096 files, 1166/4096 blocks\x0a
[    8.224813] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[    8.233803] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submit,errors=panic
[    8.285465] e2fsck: e2fsck 1.43.3 (04-Sep-2016)\x0a
[    8.286266] e2fsck: Superblock last mount time is in the future.\x0a
[    8.294048] e2fsck: \x09(by less than a day, probably due to the hardware clock being incorrectly set)\x0a
[    8.304998] e2fsck: Superblock last write time (Fri Jul 31 08:27:25 2020,\x0a
[    8.314731] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[    8.323242] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submit,errors=panic
[    8.376439] EXT4-fs (mmcblk0p15): Ignoring removed nomblk_io_submit option
[    8.380069] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submit,errors=panic
[    8.389937] init: 22 output lines suppressed due to ratelimiting
[    8.404864] register clk_set_setting cpu[43]
[    8.410279] Registered firmware driver success.
[    8.411759] Try to load video/h264_enc.bin  ...
[    8.415969] load firmware size : 76288, Name : video/h264_enc.bin.
[    8.420457] the fw pack ver v0.0 is too lower.
[    8.424993] it may work abnormally so need to be update in time.
[    8.431889] Try to load video/video_ucode.bin  ...
[    8.451069] load firmware size : 1706240, Name : video/video_ucode.bin.
[    8.452463] the fw pack ver v0.2 is too lower.
[    8.456860] it may work abnormally so need to be update in time.
[    8.522421] Amlogic A/V streaming port init
[    8.524764] get gate demux control ok cb175880
[    8.525795] get gate parser_top control ok cb175c00
[    8.530956] get gate vdec control ok cb1758c0
[    8.531921] audit: type=1400 audit(1420070417.920:6): avc:  denied  { read } for  pid=3047 comm="imageserver" name="vndbinder" dev="tmpfs" ino=12581 scontext=u:r:imageserver:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_file permissive=1
[    8.531958] audit: type=1400 audit(1420070417.920:7): avc:  denied  { write } for  pid=3047 comm="imageserver" name="vndbinder" dev="tmpfs" ino=12581 scontext=u:r:imageserver:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_file permissive=1
[    8.531980] audit: type=1400 audit(1420070417.920:8): avc:  denied  { open } for  pid=3047 comm="imageserver" path="/dev/vndbinder" dev="tmpfs" ino=12581 scontext=u:r:imageserver:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_file permissive=1
[    8.532103] audit: type=1400 audit(1420070417.920:9): avc:  denied  { ioctl } for  pid=3047 comm="imageserver" path="/dev/vndbinder" dev="tmpfs" ino=12581 ioctlcmd=0x6209 scontext=u:r:imageserver:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_file permissive=1
[    8.625154] get gate clk_81 control ok cb175400
[    8.629788] get gate clk_vdec_mux control ok cb1752c0
[    8.634984] get gate clk_hcodec_mux control ok cb175e00
[    8.640370] get gate clk_hevc_mux control ok cb175140
[    8.645571] get gate clk_hevcb_mux control ok cb1750c0
[    8.650837] get gate ahbarb0 control ok cb175f80
[    8.655582] get gate asyncfifo control failed   (null)
[    8.672403] amvdec_avs module init
[    8.678399] amvdec_h264 module init
[    8.688173] ammvdec_h264 module init
[    8.701447] amvdec_h265 module init
[    8.719447] ammvdec_mpeg12 module init
[    8.728285] ammvdec_mpeg4_driver_init_module
[    8.736068] amvdec_vc1 module init
[    8.743445] amvdec_vp9 module init
[    8.757324] amvenc_avc_probe -- reserved memory config fail.
[    8.757540] amvenc_avc - cma memory pool size: 60 MB
[    8.762706] encode_wq_init.
[    8.765597] encode start monitor.
[    8.769138] encode workqueue monitor start.
[    8.778529] vpu_init
[    8.778803] vpu_probe
[    8.778819] HevcEnc reserved memory config fail.
[    8.782934] HevcEnc - cma memory pool size: 64 MB
[    8.787796] HevcEnc - wave420l_irq: 65
[    8.791731] vpu base address get from platform driver physical base addr=0xff610000, virtual base=0xf25d0000
[    8.801945] success to probe vpu device with video memory from cma
[    8.845175] audit: type=1400 audit(1420070418.232:10): avc:  denied  { setattr } for  pid=1 comm="init" name="slabinfo" dev="proc" ino=4026532013 scontext=u:r:init:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[    8.911209] logd.auditd: start
[    9.013025] vdc: Waited 0ms for vold
[    9.096435] type=1400 audit(1420070418.484:11): avc: denied { setattr } for pid=2500 comm="init" name="droidota" dev="mmcblk0p20" ino=786434 scontext=u:r:vendor_init:s0 tcontext=u:object_r:update_data_file:s0 tclass=dir permissive=1
[    9.111609] atbm8881_fe: disagrees about version of symbol i2c_transfer
[    9.119324] ATBM: register atbm8881 demod driver
[    9.125619] type=1400 audit(1420070418.484:11): avc: denied { setattr } for pid=2500 comm="init" name="droidota" dev="mmcblk0p20" ino=786434 scontext=u:r:vendor_init:s0 tcontext=u:object_r:update_data_file:s0 tclass=dir permissive=1
[    9.133779] aml dvb init
[    9.146542] type=1400 audit(1420070418.484:12): avc: denied { setattr } for pid=2500 comm="init" name="log" dev="mmcblk0p20" ino=2228226 scontext=u:r:vendor_init:s0 tcontext=u:object_r:log_file:s0 tclass=dir permissive=1
[    9.166314] type=1400 audit(1420070418.484:12): avc: denied { setattr } for pid=2500 comm="init" name="log" dev="mmcblk0p20" ino=2228226 scontext=u:r:vendor_init:s0 tcontext=u:object_r:log_file:s0 tclass=dir permissive=1
[    9.176907] nn is disable,should not do probe continue
[    9.191215] type=1400 audit(1420070418.488:13): avc: denied { setattr } for pid=2500 comm="init" name="media" dev="mmcblk0p20" ino=3276802 scontext=u:r:vendor_init:s0 tcontext=u:object_r:media_rw_data_file:s0 tclass=dir permissive=1
[    9.214572] logd.daemon: reinit
[    9.222090] type=1400 audit(1420070418.488:13): avc: denied { setattr } for pid=2500 comm="init" name="media" dev="mmcblk0p20" ino=3276802 scontext=u:r:vendor_init:s0 tcontext=u:object_r:media_rw_data_file:s0 tclass=dir permissive=1
[    9.237473] type=1400 audit(1420070418.612:14): avc: denied { setattr } for pid=1 comm="init" name="export" dev="sysfs" ino=4019 scontext=u:r:init:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[    9.529495] healthd: BatteryTemperaturePath not found
[    9.529564] healthd: BatteryCycleCountPath not found
[    9.594087] android.hardware.health@2.0-impl: wakealarm_init: timerfd_create failed
[    9.597662] healthd: battery l=42 v=4 t=42.4 h=2 st=2 c=1 fc=10000000 chg=u
[    9.721221] fb: osd_open, 1497, fb_index=0,fb_rmem_size=26738688
[    9.721977] fb: osd_open, 1497, fb_index=1,fb_rmem_size=1048576
[    9.727980] fb: osd_open, 1497, fb_index=2,fb_rmem_size=1048576
[    9.728151] fb: vpu clkc clock is 199 MHZ
[    9.728160] vpu: switch_vpu_mem_pd: unsupport vpu mod: 18
[    9.728162] vpu: switch_vpu_mem_pd: unsupport vpu mod: 22
[    9.728163] vpu: switch_vpu_mem_pd: unsupport vpu mod: 53
[    9.728168] fb: osd_open, 1497, fb_index=3,fb_rmem_size=8388608
[    9.730518] fb: osd[0] enable: 0 (systemcontrol)
[    9.746145] unifykey: amlkey_init_gen() enter!
[    9.755912] emmc_key_read:114, read ok
[    9.755927] unifykey: amlkey_init_gen() storagekey_info.buffer=c5080000, storagekey_info.size = 40000!
[    9.766229] vfm_map_store:rm default
[    9.766489] vfm_map_store:add default decoder ppmgr deinterlace amvideo
[    9.779761] file system registered
[    9.786677] assign_ffs_buffer FFS_BUFFER_MAX=100!!!
[    9.811968] fb: osd[1] enable: 0 (systemcontrol)
[    9.818605] hdmitx: system: set hdcp_pwr 1
[    9.864476] hdmitx: system: restore hdcp_pwr 0
[    9.870361] hdmitx: system: sname = 2160p60hz
[    9.870393] hdmitx: system: char_clk = 594000
[    9.896507] read descriptors
[    9.896517] read strings
[    9.907565] hdmitx: system: cd = 6
[    9.918141] hdmitx: system: cs = 3
[    9.918169] hdmitx: RX tmds clk: 600   Calc clk: 445
[    9.931057] vout: vmode set to null
[    9.931201] fb: current vmode=1080p60hz, cmd: 0x10000
[    9.935679] vout: new mode null set ok
[    9.938756] fb: current vmode=null, cmd: 0x20000
[    9.977303] vout: vmode set to 2160p60hz
[    9.979076] fb: current vmode=null, cmd: 0x10000
[    9.981898] hdmitx: hdmitx_set_current_vmode[3693]
[    9.985669] hdmitx: system: recalc before 2160p60hz 60 1
[   10.018023] hdmitx: system: recalc after 2160p60hz 2997 50
[   10.018065] hdmitx: system: get current mode: 2160p60hz
[   10.024675] type=1400 audit(1420070418.612:14): avc: denied { setattr } for pid=1 comm="init" name="export" dev="sysfs" ino=4019 scontext=u:r:init:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   10.076236] capability: warning: `su' uses 32-bit capabilities (legacy support in use)
[   10.133820] hdmitx: system: update rx hdr info 0
[   10.133852] hdmitx: system: update physcial size: 600 340
[   10.162849] hdmitx: video: already init VIC = 0  Now VIC = 353
[   10.164332] hdmitx: hw: div40: 1
[   10.203626] hdmitx: frac_rate = 1
[   10.203658] hdmitx: config HPLL = 4455000 frac_rate = 1
[   10.218891] hdmitx: HPLL: 0xdb0004b9
[   10.218917] hdmitx: config HPLL done
[   10.220809] hdmitx: set_hpll_od3_clk_div[610] div = 15
[   10.239943] hdmitx: j = 8  vid_clk_div = 1
[   10.239976] hdmitx: set enc for VIC: 353
[   10.250722] hdmitx: system: irq 80000001 0
[   10.373917] hdmitx: [0x10000104]: 0x00000001
[   10.373952] hdmitx: [0x10000180]: 0x000000ff
[   10.377210] hdmitx: [0x10000181]: 0x000000ff
[   10.379268] hdmitx: hw:  config hdmitx IP vic = 353 cd:6 cs: 3
[   10.381624] hdmitx: system: irq 80000001 0
[   10.391926] hdmitx: [0x10000182]: 0x00000003
[   10.396287] hdmitx: [0x10000183]: 0x00000007
[   10.400707] hdmitx: [0x10000184]: 0x0000003f
[   10.405138] hdmitx: video: Sink is HDMI device
[   10.409799] hdmitx: [0x10000185]: 0x00000002
[   10.413614] hdmitx: hw: set audio
[   10.413622] hdmitx: hw: hdmitx tx_aud_src = 0
[   10.413635] hdmitx: fs = 3, cd = 6, tmds_clk = 593407
[   10.413637] hdmitx: hw: aud_n_para = 6144
[   10.413645] hdmitx: hw: set channel status
[   10.413675] hdmitx: audio: Audio Type: PCM
[   10.413679] vout: new mode 2160p60hz set ok
[   10.413684] fb: current vmode=2160p60hz, cmd: 0x20000
[   10.413691] fb: outputmode changed to 2160p60hz, reset osd0, (0, 0, 1919, 1079) -> (0, 0, 3839, 2159)
[   10.431643] EXT4-fs (mmcblk0p18): re-mounted. Opts: (null)
[   10.440005] fb: osd[0] enable: 1 (systemcontrol)
[   10.462227] audit: audit_lost=1 audit_rate_limit=5 audit_backlog_limit=64
[   10.476314] hdmitx: [0x10000187]: 0x000000ff
[   10.476321] hdmitx: [0x10000188]: 0x00000003
[   10.485604] hdmitx: [0x10000104]: 0x00000001
[   10.485609] hdmitx: [0x10000180]: 0x000000ff
[   10.485611] hdmitx: [0x10000181]: 0x000000ff
[   10.485612] hdmitx: [0x10000182]: 0x00000003
[   10.485614] hdmitx: [0x10000183]: 0x00000007
[   10.485616] hdmitx: [0x10000184]: 0x0000003f
[   10.485617] hdmitx: [0x10000185]: 0x00000002
[   10.485619] hdmitx: [0x10000187]: 0x000000ff
[   10.485621] hdmitx: [0x10000188]: 0x00000003
[   10.536477] vout: aml_tvout_mode_work: monitor stop
[   10.625828] vout: vout_io_open
[   10.797671] [DI] load 0x3e00 pq table len 424 later.
[   10.852245] avc open
[   10.852273] amvenc_avc  check CMA pool success, max instance: 3.
[   10.856697] allocating phys 0x64c00000, size 20480k, wq:eaac4c00.
[   10.861532] amvenc_avc  memory config success, buff start:0x64c00000, size is 0x1400000, wq:eaac4c00.
[   10.870975] avc release, wq:eaac4c00
[   10.874559] remove  encode_work_queue eaac4c00 success, _destroy_encode_work_queue line 3513.
[   10.883557] [+] vpu_open
[   10.888366] allocating phys 0x64c00000, virt addr 0x0, size 65536k
[   10.892466] the vdec            clock on, ref cnt: 1
[   10.892502] [-] vpu_open, ret: 0
[   10.895585] vpu_release
[   10.898189] vpu_free_buffers
[   10.901210] vpu_free_instances
[   10.904434] vpu_release, s_video_memory 0x64c00000
[   10.909936] the vdec            clock off, ref cnt: 0
[   10.962048] EXT4-fs (mmcblk0p18): re-mounted. Opts: (null)
[   11.190126] aml_tdm_open
[   11.190331] audio_ddr_mngr: toddrs[0] registered by device ff660000.audiobus:tdm@2
[   11.190873] tdm capture mute: 1
[   11.190966] audio_ddr_mngr: toddrs[0] released by device ff660000.audiobus:tdm@2
[   11.191350] asoc debug: earc_open-138
[   11.191556] audio_ddr_mngr: toddrs[0] registered by device ff660000.audiobus:earc
[   11.191829] asoc debug: earc_close-209
[   11.192425] audio locker is not init
[   11.195328] audio_ddr_mngr: toddrs[0] released by device ff660000.audiobus:earc
[   11.195817] aml_tdm_open
[   11.197802] audio_ddr_mngr: toddrs[0] registered by device ff660000.audiobus:tdm@1
[   11.198079] tdm capture mute: 1
[   11.198156] audio_ddr_mngr: toddrs[0] released by device ff660000.audiobus:tdm@1
[   11.198535] aml_spdif_open
[   11.200670] audio_ddr_mngr: toddrs[0] registered by device ff660000.audiobus:spdif@0
[   11.200992] aml_spdif_close
[   11.205852] audio_ddr_mngr: toddrs[0] released by device ff660000.audiobus:spdif@0
[   11.206657] audio_ddr_mngr: toddrs[0] registered by device ff660000.audiobus:pdm
[   11.207541] audio_ddr_mngr: toddrs[0] released by device ff660000.audiobus:pdm
[   11.207666] vout: vout_io_open
[   11.207695] vout: vout_ioctl: cmd_dir = 0x2, cmd_nr = 0x0
[   11.212234] vout: vout_io_release
[   11.216741] aml_tdm_open
[   11.218584] vout: vout_io_open
[   11.221609] vout: vout_ioctl: cmd_dir = 0x2, cmd_nr = 0x0
[   11.228222] vout: vout_io_release
[   11.228258] audio_ddr_mngr: toddrs[0] registered by device ff660000.audiobus:tdm@0
[   11.228631] tdm capture mute: 1
[   11.230634] audio_ddr_mngr: toddrs[0] released by device ff660000.audiobus:tdm@0
[   11.243326] vout: vout_io_open
[   11.243360] vout: vout_ioctl: cmd_dir = 0x2, cmd_nr = 0x0
[   11.246572] vout: vout_io_release
[   11.313840] cectx ff80023c.aocec: init_cec_port_info phy_addr:2000, port num:1
[   11.315596] cectx ff80023c.aocec: port_seq=0x0
[   11.320326] cectx ff80023c.aocec: portinfo id:0 arc:0 phy:2100,type:0
[   14.449697] early_suspend_state=0
[   15.686186] healthd: battery l=42 v=4 t=42.4 h=2 st=2 c=1 fc=10000000 chg=u
[   15.689093] healthd: battery l=42 v=4 t=42.4 h=2 st=2 c=1 fc=10000000 chg=u
[   15.696980] healthd: battery l=42 v=4 t=42.4 h=2 st=2 c=1 fc=10000000 chg=u
[   15.972872] type=1400 audit(1420070420.612:46): avc: denied { bind } for pid=3239 comm="HwBinder:3239_1" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=netlink_kobject_uevent_socket permissive=1
[   15.987580] type=1400 audit(1420070425.360:47): avc: denied { read } for pid=3512 comm="android.ui" name="state" dev="sysfs" ino=9888 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs_amhdmitx:s0 tclass=file permissive=1
[   16.008065] type=1400 audit(1420070425.360:47): avc: denied { read } for pid=3512 comm="android.ui" name="state" dev="sysfs" ino=9888 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs_amhdmitx:s0 tclass=file permissive=1
[   16.027676] type=1400 audit(1420070425.360:48): avc: denied { open } for pid=3512 comm="android.ui" path="/sys/devices/virtual/amhdmitx/amhdmitx0/hdmi/state" dev="sysfs" ino=9888 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs_amhdmitx:s0 tclass=file permissive=1
[   16.051866] type=1400 audit(1420070425.360:48): avc: denied { open } for pid=3512 comm="android.ui" path="/sys/devices/virtual/amhdmitx/amhdmitx0/hdmi/state" dev="sysfs" ino=9888 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs_amhdmitx:s0 tclass=file permissive=1
[   16.072051] the demux           clock on, ref cnt: 1
[   16.072058] the parser_top      clock on, ref cnt: 1
[   16.072061] the vdec            clock on, ref cnt: 1
[   16.072083] the clk_hevc_mux    clock on, ref cnt: 1
[   16.072088] the clk_hevcb_mux   clock on, ref cnt: 1
[   16.072191] hevc mux clock is 499999992 Hz
[   16.072225] hevc back mux clock is 499999992 Hz
[   16.072344] vdec_create instance f5ba1000, total 1
[   16.072372] vdec_disable_DMC input->target= 0x0
[   16.072375] vdec_release instance f5ba1000, total 1
[   16.072396] the clk_hevc_mux    clock off, ref cnt: 0
[   16.072399] the clk_hevcb_mux   clock off, ref cnt: 0
[   16.072405] the vdec            clock off, ref cnt: 0
[   16.072409] the parser_top      clock off, ref cnt: 0
[   16.072412] the demux           clock off, ref cnt: 0
[   16.072519] the demux           clock on, ref cnt: 1
[   16.072522] the parser_top      clock on, ref cnt: 1
[   16.072525] the vdec            clock on, ref cnt: 1
[   16.072542] the clk_vdec_mux    clock on, ref cnt: 1
[   16.072603] vdec mux clock is 799999987 Hz
[   16.072681] vdec_create instance f5bb4000, total 1
[   16.072695] vdec_disable_DMC input->target= 0x0
[   16.072697] vdec_release instance f5bb4000, total 1
[   16.072724] the clk_vdec_mux    clock off, ref cnt: 0
[   16.072728] the vdec            clock off, ref cnt: 0
[   16.072731] the parser_top      clock off, ref cnt: 0
[   16.072733] the demux           clock off, ref cnt: 0
[   16.072853] ionvid: dbg: ionvideo open
[   16.072861] ionvid: dbg: vidioc_close!!!!
[   16.072872] ionvid: dbg: vidioc_close
[   16.076105] type=1400 audit(1420070425.360:49): avc: denied { getattr } for pid=3512 comm="android.ui" path="/sys/devices/virtual/amhdmitx/amhdmitx0/hdmi/state" dev="sysfs" ino=9888 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs_amhdmitx:s0 tclass=file permissive=1
[   16.116308] the demux           clock on, ref cnt: 1
[   16.116317] the parser_top      clock on, ref cnt: 1
[   16.116321] the vdec            clock on, ref cnt: 1
[   16.116342] the clk_hevc_mux    clock on, ref cnt: 1
[   16.116345] the clk_hevcb_mux   clock on, ref cnt: 1
[   16.116452] hevc mux clock is 499999992 Hz
[   16.116487] hevc back mux clock is 499999992 Hz
[   16.116593] vdec_create instance f5bc7000, total 1
[   16.116619] vdec_disable_DMC input->target= 0x0
[   16.116624] vdec_release instance f5bc7000, total 1
[   16.116649] the clk_hevc_mux    clock off, ref cnt: 0
[   16.116653] the clk_hevcb_mux   clock off, ref cnt: 0
[   16.116658] the vdec            clock off, ref cnt: 0
[   16.116663] the parser_top      clock off, ref cnt: 0
[   16.116666] the demux           clock off, ref cnt: 0
[   16.116744] the demux           clock on, ref cnt: 1
[   16.116749] the parser_top      clock on, ref cnt: 1
[   16.116753] the vdec            clock on, ref cnt: 1
[   16.116768] the clk_vdec_mux    clock on, ref cnt: 1
[   16.116825] vdec mux clock is 799999987 Hz
[   16.116911] vdec_create instance f5bda000, total 1
[   16.116932] vdec_disable_DMC input->target= 0x0
[   16.116935] vdec_release instance f5bda000, total 1
[   16.116967] the clk_vdec_mux    clock off, ref cnt: 0
[   16.116973] the vdec            clock off, ref cnt: 0
[   16.116976] the parser_top      clock off, ref cnt: 0
[   16.116980] the demux           clock off, ref cnt: 0
[   16.117063] ionvid: dbg: ionvideo open
[   16.117073] ionvid: dbg: vidioc_close!!!!
[   16.117086] ionvid: dbg: vidioc_close
[   16.125788] the demux           clock on, ref cnt: 1
[   16.125798] the parser_top      clock on, ref cnt: 1
[   16.125802] the vdec            clock on, ref cnt: 1
[   16.125823] the clk_hevc_mux    clock on, ref cnt: 1
[   16.125827] the clk_hevcb_mux   clock on, ref cnt: 1
[   16.125856] hevc mux clock is 499999992 Hz
[   16.125869] hevc back mux clock is 499999992 Hz
[   16.125970] vdec_create instance f5bed000, total 1
[   16.125991] vdec_disable_DMC input->target= 0x0
[   16.125994] vdec_release instance f5bed000, total 1
[   16.126019] the clk_hevc_mux    clock off, ref cnt: 0
[   16.126023] the clk_hevcb_mux   clock off, ref cnt: 0
[   16.126028] the vdec            clock off, ref cnt: 0
[   16.126032] the parser_top      clock off, ref cnt: 0
[   16.126035] the demux           clock off, ref cnt: 0
[   16.126106] the demux           clock on, ref cnt: 1
[   16.126111] the parser_top      clock on, ref cnt: 1
[   16.126115] the vdec            clock on, ref cnt: 1
[   16.126131] the clk_vdec_mux    clock on, ref cnt: 1
[   16.126152] vdec mux clock is 799999987 Hz
[   16.126240] vdec_create instance f5c00000, total 1
[   16.126258] vdec_disable_DMC input->target= 0x0
[   16.126261] vdec_release instance f5c00000, total 1
[   16.126293] the clk_vdec_mux    clock off, ref cnt: 0
[   16.126298] the vdec            clock off, ref cnt: 0
[   16.126302] the parser_top      clock off, ref cnt: 0
[   16.126305] the demux           clock off, ref cnt: 0
[   16.126397] ionvid: dbg: ionvideo open
[   16.126406] ionvid: dbg: vidioc_close!!!!
[   16.126418] ionvid: dbg: vidioc_close
[   16.136006] the demux           clock on, ref cnt: 1
[   16.136015] the parser_top      clock on, ref cnt: 1
[   16.136019] the vdec            clock on, ref cnt: 1
[   16.136040] the clk_hevc_mux    clock on, ref cnt: 1
[   16.136044] the clk_hevcb_mux   clock on, ref cnt: 1
[   16.136072] hevc mux clock is 499999992 Hz
[   16.136084] hevc back mux clock is 499999992 Hz
[   16.136185] vdec_create instance f5c13000, total 1
[   16.136204] vdec_disable_DMC input->target= 0x0
[   16.136207] vdec_release instance f5c13000, total 1
[   16.136232] the clk_hevc_mux    clock off, ref cnt: 0
[   16.136236] the clk_hevcb_mux   clock off, ref cnt: 0
[   16.136241] the vdec            clock off, ref cnt: 0
[   16.136245] the parser_top      clock off, ref cnt: 0
[   16.136248] the demux           clock off, ref cnt: 0
[   16.136324] the demux           clock on, ref cnt: 1
[   16.136329] the parser_top      clock on, ref cnt: 1
[   16.136332] the vdec            clock on, ref cnt: 1
[   16.136348] the clk_vdec_mux    clock on, ref cnt: 1
[   16.136368] vdec mux clock is 799999987 Hz
[   16.136456] vdec_create instance f5c26000, total 1
[   16.136476] vdec_disable_DMC input->target= 0x0
[   16.136479] vdec_release instance f5c26000, total 1
[   16.136508] the clk_vdec_mux    clock off, ref cnt: 0
[   16.136513] the vdec            clock off, ref cnt: 0
[   16.136517] the parser_top      clock off, ref cnt: 0
[   16.136521] the demux           clock off, ref cnt: 0
[   16.136601] ionvid: dbg: ionvideo open
[   16.136610] ionvid: dbg: vidioc_close!!!!
[   16.136622] ionvid: dbg: vidioc_close
[   16.281879] the demux           clock on, ref cnt: 1
[   16.281888] the parser_top      clock on, ref cnt: 1
[   16.281892] the vdec            clock on, ref cnt: 1
[   16.281912] the clk_hevc_mux    clock on, ref cnt: 1
[   16.281916] the clk_hevcb_mux   clock on, ref cnt: 1
[   16.281943] hevc mux clock is 499999992 Hz
[   16.281955] hevc back mux clock is 499999992 Hz
[   16.282053] vdec_create instance f5c39000, total 1
[   16.282068] vdec_disable_DMC input->target= 0x0
[   16.282072] vdec_release instance f5c39000, total 1
[   16.282091] the clk_hevc_mux    clock off, ref cnt: 0
[   16.282095] the clk_hevcb_mux   clock off, ref cnt: 0
[   16.282099] the vdec            clock off, ref cnt: 0
[   16.282102] the parser_top      clock off, ref cnt: 0
[   16.282106] the demux           clock off, ref cnt: 0
[   16.282154] the demux           clock on, ref cnt: 1
[   16.282158] the parser_top      clock on, ref cnt: 1
[   16.282162] the vdec            clock on, ref cnt: 1
[   16.282176] the clk_vdec_mux    clock on, ref cnt: 1
[   16.282191] vdec mux clock is 799999987 Hz
[   16.282267] vdec_create instance f5c4c000, total 1
[   16.282277] vdec_disable_DMC input->target= 0x0
[   16.282280] vdec_release instance f5c4c000, total 1
[   16.282303] the clk_vdec_mux    clock off, ref cnt: 0
[   16.282307] the vdec            clock off, ref cnt: 0
[   16.282311] the parser_top      clock off, ref cnt: 0
[   16.282314] the demux           clock off, ref cnt: 0
[   16.282400] ionvid: dbg: ionvideo open
[   16.282409] ionvid: dbg: vidioc_close!!!!
[   16.282421] ionvid: dbg: vidioc_close
[   16.330441] the demux           clock on, ref cnt: 1
[   16.330449] the parser_top      clock on, ref cnt: 1
[   16.330453] the vdec            clock on, ref cnt: 1
[   16.330475] the clk_hevc_mux    clock on, ref cnt: 1
[   16.330478] the clk_hevcb_mux   clock on, ref cnt: 1
[   16.330506] hevc mux clock is 499999992 Hz
[   16.330517] hevc back mux clock is 499999992 Hz
[   16.330619] vdec_create instance f5c5f000, total 1
[   16.330639] vdec_disable_DMC input->target= 0x0
[   16.330642] vdec_release instance f5c5f000, total 1
[   16.330665] the clk_hevc_mux    clock off, ref cnt: 0
[   16.330668] the clk_hevcb_mux   clock off, ref cnt: 0
[   16.330673] the vdec            clock off, ref cnt: 0
[   16.330677] the parser_top      clock off, ref cnt: 0
[   16.330680] the demux           clock off, ref cnt: 0
[   16.330744] the demux           clock on, ref cnt: 1
[   16.330749] the parser_top      clock on, ref cnt: 1
[   16.330752] the vdec            clock on, ref cnt: 1
[   16.330769] the clk_vdec_mux    clock on, ref cnt: 1
[   16.330786] vdec mux clock is 799999987 Hz
[   16.330862] vdec_create instance f5c72000, total 1
[   16.330874] vdec_disable_DMC input->target= 0x0
[   16.330877] vdec_release instance f5c72000, total 1
[   16.330905] the clk_vdec_mux    clock off, ref cnt: 0
[   16.330909] the vdec            clock off, ref cnt: 0
[   16.330913] the parser_top      clock off, ref cnt: 0
[   16.330916] the demux           clock off, ref cnt: 0
[   16.330981] ionvid: dbg: ionvideo open
[   16.330989] ionvid: dbg: vidioc_close!!!!
[   16.330999] ionvid: dbg: vidioc_close
[   16.355967] the demux           clock on, ref cnt: 1
[   16.355976] the parser_top      clock on, ref cnt: 1
[   16.355981] the vdec            clock on, ref cnt: 1
[   16.356002] the clk_hevc_mux    clock on, ref cnt: 1
[   16.356007] the clk_hevcb_mux   clock on, ref cnt: 1
[   16.356033] hevc mux clock is 499999992 Hz
[   16.356046] hevc back mux clock is 499999992 Hz
[   16.356159] vdec_create instance f5c85000, total 1
[   16.356183] vdec_disable_DMC input->target= 0x0
[   16.356186] vdec_release instance f5c85000, total 1
[   16.356209] the clk_hevc_mux    clock off, ref cnt: 0
[   16.356214] the clk_hevcb_mux   clock off, ref cnt: 0
[   16.356220] the vdec            clock off, ref cnt: 0
[   16.356223] the parser_top      clock off, ref cnt: 0
[   16.356227] the demux           clock off, ref cnt: 0
[   16.356320] the demux           clock on, ref cnt: 1
[   16.356325] the parser_top      clock on, ref cnt: 1
[   16.356328] the vdec            clock on, ref cnt: 1
[   16.356344] the clk_vdec_mux    clock on, ref cnt: 1
[   16.356364] vdec mux clock is 799999987 Hz
[   16.356448] vdec_create instance f5c98000, total 1
[   16.356464] vdec_disable_DMC input->target= 0x0
[   16.356467] vdec_release instance f5c98000, total 1
[   16.356495] the clk_vdec_mux    clock off, ref cnt: 0
[   16.356500] the vdec            clock off, ref cnt: 0
[   16.356503] the parser_top      clock off, ref cnt: 0
[   16.356507] the demux           clock off, ref cnt: 0
[   16.356947] ionvid: dbg: ionvideo open
[   16.356963] ionvid: dbg: vidioc_close!!!!
[   16.356974] ionvid: dbg: vidioc_close
[   16.364164] the demux           clock on, ref cnt: 1
[   16.364173] the parser_top      clock on, ref cnt: 1
[   16.364177] the vdec            clock on, ref cnt: 1
[   16.364197] the clk_hevc_mux    clock on, ref cnt: 1
[   16.364201] the clk_hevcb_mux   clock on, ref cnt: 1
[   16.364228] hevc mux clock is 499999992 Hz
[   16.364240] hevc back mux clock is 499999992 Hz
[   16.364344] vdec_create instance f5cab000, total 1
[   16.364367] vdec_disable_DMC input->target= 0x0
[   16.364370] vdec_release instance f5cab000, total 1
[   16.364392] the clk_hevc_mux    clock off, ref cnt: 0
[   16.364396] the clk_hevcb_mux   clock off, ref cnt: 0
[   16.364400] the vdec            clock off, ref cnt: 0
[   16.364404] the parser_top      clock off, ref cnt: 0
[   16.364408] the demux           clock off, ref cnt: 0
[   16.364488] the demux           clock on, ref cnt: 1
[   16.364493] the parser_top      clock on, ref cnt: 1
[   16.364496] the vdec            clock on, ref cnt: 1
[   16.364512] the clk_vdec_mux    clock on, ref cnt: 1
[   16.364531] vdec mux clock is 799999987 Hz
[   16.364606] vdec_create instance f5cbe000, total 1
[   16.364620] vdec_disable_DMC input->target= 0x0
[   16.364624] vdec_release instance f5cbe000, total 1
[   16.364650] the clk_vdec_mux    clock off, ref cnt: 0
[   16.364655] the vdec            clock off, ref cnt: 0
[   16.364660] the parser_top      clock off, ref cnt: 0
[   16.364665] the demux           clock off, ref cnt: 0
[   16.364752] ionvid: dbg: ionvideo open
[   16.364762] ionvid: dbg: vidioc_close!!!!
[   16.364774] ionvid: dbg: vidioc_close
[   16.512109] video_inuse return 0,set 1
[   16.512264] the demux           clock on, ref cnt: 1
[   16.512272] the parser_top      clock on, ref cnt: 1
[   16.512276] the vdec            clock on, ref cnt: 1
[   16.512295] the clk_vdec_mux    clock on, ref cnt: 1
[   16.512324] vdec mux clock is 799999987 Hz
[   16.512426] vdec_create instance f5cd1000, total 1
[   16.512534] no drmmode
[   16.512571] is_reset=0
[   16.512917] The fw has been loaded.
[   16.516631] vdec_init, dev_name:ammvdec_h264, vdec_type=VDEC_TYPE_FRAME_BLOCK
[   16.526317] ammvdec_h264_mmu_init tvp = 0x0 mmu_enable 0
[   16.526324] decoder_bmmu_box_alloc_box, tvp_flags = 0
[   16.526339] 0: ammvdec_h264_probe mmu_enable 0 double_write_mode 0x0
[   16.528432] 0: ammvdec_h264 mem-addr=0,buff_offset=63c10000,buf_start=64c00000
[   16.528468] vdec mux clock is 799999987 Hz
[   16.528472] vdec1 video changed to 3840 x 2160 60 fps clk->800MHZ
[   16.528476] H264 sysinfo: 1920x1080 duration=3200, pts_outside=1
[   16.530028] sync_outside=0, use_idr_framerate=0, is_used_v4l: 0
[   16.530104] [LOCAL], the fw (h264_multi) will be loaded.
[   16.536388] vh264_init, vaddr=ebef8000 phy_addr=2bef8000
[   16.536452] vfm map vdec-map-0 created
[   16.536478] di_receiver_event_fun: vframe provider reg ppmgr
[   16.542423] DI: reg f
[   16.544000] vdec_init, vf_provider_name = vdec.h264.00
[   16.559153] 0: AV_SCRATCH_1 = 831fe078, AV_SCRATCH_2 8042\x0d
[   16.559195] 0: frame_mbs_only_flag 1, crop_bottom 4,  frame_height 1080,
[   16.559199] 0: mb_height 68,crop_right 0, frame_width 1920, mb_width 120
[   16.559203] 0: mb height/widht/total: 44/78/1fe0 level_idc 29 max_ref_num 3
[   16.559207] 0: restriction_flag=0, max_dec_frame_buffering=0, reorder_pic_num=5
[   16.559210] 0: vh264_set_params active_buf_spec_num 11 reorder_pic_num 5 collocate_buf_num 7\x0d
[   16.585759] 0: num_ref_frames change from 0 to 3\x0d
[   16.591985] PPMGRVPP: info: tb first frame type: 0
[   16.592379] PPMGRVPP: info: tb cma memory 64e80000, size 18000, item 8
[   16.598175] DI: di_wr_cue_int:finish
[   16.601753] di: di_init_buf -S
[   16.604941] DI: di_init_buf:cma alloc req time: 4294683844 ms
[   16.604968] di: di_init_buf -E
[   16.608330] di_patch_post_update_mc_sw:0x0->0x2
[   16.609553] DI: DI: tasklet schedule cost 12ms.
[   16.616654] aml_tdm_open
[   16.618660] di_cma_alloc:alloc 10 buffer use 16 ms(4294683844~4294683860)
[   16.618956] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[   16.619052] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[   16.619054] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[   16.619059] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[   16.619062] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[   16.619063] aml_dai_set_tdm_fmt(), fmt not change
[   16.619068] dump_pcm_setting(ed56df10)
[   16.619068] \x09pcm_mode(1)
[   16.619069] \x09sysclk(12288000)
[   16.619070] \x09sysclk_bclk_ratio(4)
[   16.619072] \x09bclk(3072000)
[   16.619073] \x09bclk_lrclk_ratio(64)
[   16.619074] \x09lrclk(48000)
[   16.619075] \x09tx_mask(0x3)
[   16.619076] \x09rx_mask(0x3)
[   16.619077] \x09slots(2)
[   16.619078] \x09slot_width(32)
[   16.619079] \x09lane_mask_in(0x2)
[   16.619080] \x09lane_mask_out(0x1)
[   16.619081] \x09lane_oe_mask_in(0x0)
[   16.619082] \x09lane_oe_mask_out(0x0)
[   16.619083] \x09lane_lb_mask_in(0x0)
[   16.619084] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[   16.619085] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[   16.619088] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[   16.619090] aml_dai_set_clkdiv, div 4, clksel(1)
[   16.619097] aml_dai_set_bclk_ratio, select I2S mode
[   16.619107] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[   16.619146] aml_tdm_prepare(), reset fddr
[   16.619160] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[   16.619166] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[   16.619175] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[   16.620217] tdm playback mute: 0, lane_cnt = 8
[   16.623908] asoc-aml-card auge_sound: tdm playback enable
[   16.626803] pre_de_buf_config:4294683868ms 1th source change: 0x0/0/0/0=>0x9000/1920/1080/0
[   16.626823] videosync_open
[   16.626861] omx_need_drop_frame_num 0
[   16.641654] spdif_a is set to enable
[   16.645124] detect vout mode change!!!!!!!!!!!!
[   16.646080] video first pts = bba
[   16.650441] videosync_open
[   16.653072] fb: osd[0] enable: 1 scale:0x10001 (composer@2.2-se)
[   16.658660] fb: osd[0] enable: 1 scale:0x10001 (composer@2.2-se)
[   16.661896] first picture {1920,1080} pts:bba,
[   16.661946] \x0a[amvideo..] saturation_pre:0 hue_pre:0 mab:1000000
[   16.678626] VsyncEnableVideoLayer
[   16.680506] fb: free_scale_switch to fb0, mode: 0x10001
[   16.686639] fb: set logo loaded
[   16.695233] first picture {1920,1080} pts:1775,
[   16.711976] VsyncEnableVideoLayer
[   17.023132] cectx ff80023c.aocec: init_cec_port_info phy_addr:2000, port num:1
[   17.024988] cectx ff80023c.aocec: port_seq=0x0
[   17.030169] cectx ff80023c.aocec: portinfo id:0 arc:0 phy:2100,type:0
[   17.237650] eth0: device MAC address 90:0e:b3:1d:20:fe
[   17.294308] healthd: battery l=42 v=4 t=42.4 h=2 st=2 c=1 fc=10000000 chg=u
[   17.328041] meson6-dwmac ff3f0000.ethernet eth0: fail to init PTP.
[   17.330554] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   17.650280] sdcardfs version 2.0
[   17.650312] sdcardfs: dev_name -> /data/media
[   17.654674] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,mask=6,userid=0,gid=1015
[   17.663569] sdcardfs: mnt -> eaa28410
[   17.685107] sdcardfs: mounted on top of /data/media type ext4
[   17.694878] Remount options were mask=23,gid=9997 for vfsmnt eaa28a10.
[   17.696028] sdcardfs : options - debug:1
[   17.700332] sdcardfs : options - gid:9997
[   17.705265] sdcardfs : options - mask:23
[   17.709310] Remount options were mask=7,gid=9997 for vfsmnt eb282710.
[   17.715986] sdcardfs : options - debug:1
[   17.724285] sdcardfs : options - gid:9997
[   17.725204] sdcardfs : options - mask:7
[   17.818852] aml_wifi wifi: [usb_power_control] Set WiFi power down
[   18.024972] aml_wifi wifi: [usb_power_control] Set WiFi power on !
[   18.027029] meson-mmc: sdio: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[   18.032281] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8
[   18.039739] meson-mmc: sdio: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[   18.045280] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8
[   18.056618] meson-mmc: sdio: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[   18.058282] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8
[   18.065371] meson-aml-mmc ffe03000.sdio: card claims to support voltages below defined range
[   18.076450] meson-mmc: actual_clock :0, HHI_nand: 0x80
[   18.078661] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x1000033c
[   18.105756] meson-mmc: actual_clock :400000, HHI_nand: 0x80
[   18.105868] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x1000033c
[   18.149939] meson-aml-mmc ffe03000.sdio: divider requested rate 170000000 != actual rate 166666664: ret=0
[   18.154151] meson-mmc: actual_clock :166666664, HHI_nand: 0x80
[   18.160820] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x10000246
[   18.167412] meson-mmc: Data 1 aligned delay is 0
[   18.171985] meson-mmc: sdio: clk 166666664 tuning start
[   18.179657] meson-mmc: sdio: rx_tuning_result[0] = 40
[   18.184801] meson-mmc: sdio: rx_tuning_result[1] = 40
[   18.189474] meson-mmc: sdio: rx_tuning_result[2] = 40
[   18.192951] meson-mmc: Tuning transfer error: nmatch=0 tuning_err:0xffffffac
[   18.203607] meson-mmc: Tuning transfer error: nmatch=0 tuning_err:0xffffffac
[   18.218613] meson-mmc: sdio: rx_tuning_result[5] = 40
[   18.218662] meson-mmc: sdio: best_win_start =5, best_win_size =4
[   18.224561] meson-mmc: sdio: sd_emmc_regs->gclock=0x10000246,sd_emmc_regs->gadjust=0x12000
[   18.237419] sdio: new ultra high speed SDR104 SDIO card at address 0001
[   18.239601] sdio: clock 166666664, 4-bit-bus-width\x0a
[   18.250215] meson-mmc: [sdio_reinit] finish
[   18.250299] aml_wifi wifi: [usb_power_control] Set WiFi power on !
[   18.506675] aml_wifi wifi: [pci_reinit] pci wifi reinit!
[   18.506744] aml_wifi wifi: [wifi_power_ioctl] Set sdio wifi power up!
[   18.513478] aml_wifi wifi: [wifi_power_ioctl] wifi interface dev type: sdio, length = 4
[   18.682233] RTW: module init start
[   18.682290] RTW: rtl88x2cs v5.7.3_33726.20190522_COEX20190403-0c0c
[   18.687392] RTW: build time: Jun 19 2020 21:03:04
[   18.691898] RTW: rtl88x2cs BT-Coex version = COEX20190403-0c0c
[   18.699377] RTW: == SDIO Card Info ==
[   18.701284] RTW:   card: eb208800
[   18.705581] RTW:   clock: 170000000 Hz
[   18.708641] RTW:   timing spec: sd uhs SDR104
[   18.713033] RTW:   sd3_bus_mode: TRUE
[   18.717262] RTW:   func num: 1
[   18.720295] RTW:   func1: eb74ac00 (*)
[   18.724336] RTW: ================
[   18.728852] RTW: [HALMAC]11692M\x0aHALMAC_MAJOR_VER = 1\x0aHALMAC_PROTOTYPE_VER = 5\x0aHALMAC_MINOR_VER = 14\x0aHALMAC_PATCH_VER = 27
[   18.751155] BT_RADIO going: off
[   18.751199] AML_BT: going OFF
[   18.751834] type=1400 audit(1420070425.360:49): avc: denied { getattr } for pid=3512 comm="android.ui" path="/sys/devices/virtual/amhdmitx/amhdmitx0/hdmi/state" dev="sysfs" ino=9888 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs_amhdmitx:s0 tclass=file permissive=1
[   18.751876] type=1400 audit(1420070428.140:50): avc: denied { create } for pid=3240 comm="bluetooth@1.0-s" scontext=u:r:hal_bluetooth_default:s0 tcontext=u:r:hal_bluetooth_default:s0 tclass=udp_socket permissive=1
[   18.890425] RTW: HW EFUSE
[   18.890478] RTW: 0x000: 29 81 00 8F  FF 20 28 00  9A 04 ED 75  10 0F F1 EB
[   18.894790] RTW: 0x010: 4D 4D 51 53  53 53 48 48  4A 4C 4C 02  00 00 FF FF
[   18.901985] RTW: 0x020: FF FF 54 54  54 54 4E 4E  4E 4E 4E 4E  42 42 42 42
[   18.909176] RTW: 0x030: 02 00 FF FF  00 FF 00 00  FF FF 56 56  5A 5B 5B 5B
[   18.916398] RTW: 0x040: 50 50 51 53  53 02 00 00  FF FF FF FF  54 54 54 54
[   18.923564] RTW: 0x050: 4A 4A 4A 4A  4A 4A 44 44  44 44 02 00  FF FF 00 FF
[   18.930763] RTW: 0x060: 00 00 FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   18.937951] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   18.945144] RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   18.952336] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   18.959534] RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   18.966755] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  7F 45 FF 00  FF FF FF FF
[   18.973918] RTW: 0x0C0: FF 21 00 10  00 00 FF FF  00 33 04 FF  FF FF FF FF
[   18.981112] RTW: 0x0D0: 20 20 FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   18.988309] RTW: 0x0E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   18.995496] RTW: 0x0F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.002697] RTW: 0x100: F0 94 65 D3  58 C5 FF FF  CD F0 FF FF  FF FF FF FF
[   19.009885] RTW: 0x110: 45 45 FC A0  D8 D8 FD FF  35 8C FF FF  FF FF FF FF
[   19.017079] RTW: 0x120: FE DF 01 23  34 FF FF FF  FF FF
[   19.022279] BT_RADIO going: on
[   19.022280] AML_BT: going ON
[   19.028692] 4C
[   19.030393] 02  22 C8 FF FF
[   19.031983] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.039176] RTW: 0x140: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.046369] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.053580] RTW: 0x160: FF FF FF FF  FF FF FF FF  FF FF 80 9F  9B 90 19 74
[   19.060756] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.068858] RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.075184] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.082680] RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.089617] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.096723] RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.103916] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.111109] RTW: 0x1E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.118303] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.125495] RTW: 0x200: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.132689] RTW: 0x210: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.139882] RTW: 0x220: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.147076] RTW: 0x230: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.154269] RTW: 0x240: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.161462] RTW: 0x250: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.168656] RTW: 0x260: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.175849] RTW: 0x270: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.183042] RTW: 0x280: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.190236] RTW: 0x290: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.197429] RTW: 0x2A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.204622] RTW: 0x2B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.211816] RTW: 0x2C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.219010] RTW: 0x2D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.227796] RTW: 0x2E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.233979] RTW: 0x2F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   19.241203] RTW: hal_com_config_channel_plan chplan:0x7F
[   19.310985] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
[   19.437998] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 0 to 9600
[   19.438123] RTW: rtw_ndev_init(wlan0) if1 mac_addr=80:9f:9b:90:19:74
[   19.439962] RTW: rtw_ndev_init(p2p0) if2 mac_addr=82:9f:9b:90:19:74
[   19.442491] RTW: module init ret=0
[   19.457098] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 9600 to 9600
[   19.465433] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 9600 to 115200
[   19.528443] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 115200 to 1500000
[   19.531739] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 1500000 to 1500000
[   20.405850] meson6-dwmac ff3f0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   20.574058] RTW: wlan0- hw port(0) mac_addr =80:9f:9b:90:19:74
[   20.574549] RTW: p2p0- hw port(1) mac_addr =82:9f:9b:90:19:74
[   20.595937] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
[   20.596653] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   20.671320] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   23.769659] DI: DI: tasklet schedule cost 12ms.
[   28.785901] is_reset=1
[   28.787754] PPMGRVPP: info: tb cma free addr is 64e80000, size is 18000
[   28.789796] DI: di_receiver_event_fun , is_bypass() 0 trick_mode 0 bypass_all 0
[   28.789807] DI: di_receiver_event_fun: unreg
[   28.795222] DI: provider name:(null)
[   28.798319] DI: di_unreg_process unreg start 1.
[   28.798347] di:no w
[   28.798377] keep exit is di
[   28.798383] video first pts = 0
[   28.798393] VD1 AFBC 0x0.
[   28.798427] pattern detected = 1, pts_enter_pattern_cnt =2, pts_exit_pattern_cnt =1
[   28.798427] DI: di_unreg_process vf unreg cost 0 ms.
[   28.798430] DI: di_unreg_process unreg stop 1.
[   28.798467] DI: di_uninit_buf keep cur di_buf 7 (
[   28.798469] DI: 8\x09
[   28.798471] DI: 9\x09
[   28.798471] DI: )
[   28.798498] di_patch_post_update_mc_sw:0x2->0x0
[   28.798502] DI: di_unreg_process_irq:cma release req time: -271256 ms
[   28.799018] DI: di_cma_release skip buf[8].\x0a
[   28.799021] DI: di_cma_release skip buf[9].\x0a
[   28.799027] di_cma_release:release 8 buffer use 0 ms(4294696040~4294696040)
[   28.825351] DI: unreg f
[   28.826570] vdec_disable_DMC input->target= 0x0
[   28.826710] 0: vh264_stop
[   28.827994] vdec_release instance f5cd1000, total 1
[   28.834270] the clk_vdec_mux    clock off, ref cnt: 0
[   28.834280] the vdec            clock off, ref cnt: 0
[   28.834288] the parser_top      clock off, ref cnt: 0
[   28.834296] the demux           clock off, ref cnt: 0
[   28.834369] the demux           clock on, ref cnt: 1
[   28.834376] the parser_top      clock on, ref cnt: 1
[   28.834383] the vdec            clock on, ref cnt: 1
[   28.834402] the clk_vdec_mux    clock on, ref cnt: 1
[   28.834431] vdec mux clock is 799999987 Hz
[   28.834562] vdec_create instance f0cc9000, total 1
[   28.834599] no drmmode
[   28.834645] is_reset=1
[   28.834677] The fw has been loaded.
[   28.835184] vdec_init, dev_name:ammvdec_h264, vdec_type=VDEC_TYPE_FRAME_BLOCK
[   28.844338] ammvdec_h264_mmu_init tvp = 0x0 mmu_enable 0
[   28.844346] decoder_bmmu_box_alloc_box, tvp_flags = 0
[   28.844364] 0: ammvdec_h264_probe mmu_enable 0 double_write_mode 0x0
[   28.847919] 0: ammvdec_h264 mem-addr=0,buff_offset=63c10000,buf_start=64c00000
[   28.847945] vdec mux clock is 799999987 Hz
[   28.847950] vdec1 video changed to 3840 x 2160 60 fps clk->800MHZ
[   28.847955] H264 sysinfo: 1920x1080 duration=3200, pts_outside=1
[   28.848616] sync_outside=0, use_idr_framerate=0, is_used_v4l: 0
[   28.848699] [LOCAL], the fw (h264_multi) will be loaded.
[   28.854593] vh264_init, vaddr=ebef8000 phy_addr=2bef8000
[   28.854660] vfm map vdec-map-0 created
[   28.854688] di_receiver_event_fun: vframe provider reg ppmgr
[   28.860966] DI: reg f
[   28.862528] vdec_init, vf_provider_name = vdec.h264.00
[   28.873625] is_reset=0
[   28.875268] is_reset=1
[   28.877215] DI: di_receiver_event_fun , is_bypass() 0 trick_mode 0 bypass_all 0
[   28.877218] DI: di_receiver_event_fun: unreg
[   28.877457] DI: provider name:(null)
[   28.881243] DI: di_unreg_process unreg start 1.
[   28.881250] di:no w
[   28.881258] keep exit is di
[   28.881261] VD1 AFBC 0x0.
[   28.881267] DI: di_unreg_process vf unreg cost 0 ms.
[   28.881269] DI: di_unreg_process unreg stop 1.
[   28.881296] DI: di_uninit_buf keep cur di_buf 7 (
[   28.881298] DI: 8\x09
[   28.881300] DI: 9\x09
[   28.881300] DI: )
[   28.881320] DI: di_unreg_process_irq:cma release req time: -271176 ms
[   28.881338] DI: di_cma_release skip buf[8].\x0a
[   28.881341] DI: di_cma_release skip buf[9].\x0a
[   28.881344] di_cma_release:release 0 buffer use 0 ms(4294696120~4294696120)
[   28.896312] DI: unreg f
[   28.898913] vdec_disable_DMC input->target= 0x0
[   28.899024] 0: vh264_stop
[   28.899279] vdec_release instance f0cc9000, total 1
[   28.899355] the clk_vdec_mux    clock off, ref cnt: 0
[   28.899363] the vdec            clock off, ref cnt: 0
[   28.899367] the parser_top      clock off, ref cnt: 0
[   28.899372] the demux           clock off, ref cnt: 0
[   28.899425] the demux           clock on, ref cnt: 1
[   28.899430] the parser_top      clock on, ref cnt: 1
[   28.899434] the vdec            clock on, ref cnt: 1
[   28.899450] the clk_vdec_mux    clock on, ref cnt: 1
[   28.899477] vdec mux clock is 799999987 Hz
[   28.899591] vdec_create instance f0e01000, total 1
[   28.899625] no drmmode
[   28.899650] is_reset=1
[   28.901387] The fw has been loaded.
[   28.905053] vdec_init, dev_name:ammvdec_h264, vdec_type=VDEC_TYPE_FRAME_BLOCK
[   28.913054] ammvdec_h264_mmu_init tvp = 0x0 mmu_enable 0
[   28.913060] decoder_bmmu_box_alloc_box, tvp_flags = 0
[   28.913103] 0: ammvdec_h264_probe mmu_enable 0 double_write_mode 0x0
[   28.914385] 0: ammvdec_h264 mem-addr=0,buff_offset=63c10000,buf_start=64c00000
[   28.914420] vdec mux clock is 799999987 Hz
[   28.914425] vdec1 video changed to 3840 x 2160 60 fps clk->800MHZ
[   28.914428] H264 sysinfo: 1920x1080 duration=3200, pts_outside=1
[   28.918500] sync_outside=0, use_idr_framerate=0, is_used_v4l: 0
[   28.918585] [LOCAL], the fw (h264_multi) will be loaded.
[   28.924115] vh264_init, vaddr=eb016000 phy_addr=2b016000
[   28.924177] vfm map vdec-map-0 created
[   28.924199] di_receiver_event_fun: vframe provider reg ppmgr
[   28.929861] DI: reg f
[   28.932371] vdec_init, vf_provider_name = vdec.h264.00
[   28.932681] is_reset=0
[   28.937219] DI: di_receiver_event_fun , is_bypass() 0 trick_mode 0 bypass_all 0
[   28.937224] DI: di_receiver_event_fun: unreg
[   28.939114] DI: provider name:(null)
[   28.942854] DI: di_unreg_process unreg start 1.
[   28.942858] di:no w
[   28.942867] keep exit is di
[   28.942870] VD1 AFBC 0x0.
[   28.942877] DI: di_unreg_process vf unreg cost 0 ms.
[   28.942879] DI: di_unreg_process unreg stop 1.
[   28.942907] DI: di_uninit_buf keep cur di_buf 7 (
[   28.942910] DI: 8\x09
[   28.942911] DI: 9\x09
[   28.942911] DI: )
[   28.942932] DI: di_unreg_process_irq:cma release req time: -271112 ms
[   28.942950] DI: di_cma_release skip buf[8].\x0a
[   28.942951] DI: di_cma_release skip buf[9].\x0a
[   28.942957] di_cma_release:release 0 buffer use 0 ms(4294696184~4294696184)
[   28.957937] DI: unreg f
[   28.960503] vdec_disable_DMC input->target= 0x0
[   28.960618] 0: vh264_stop
[   28.960890] vdec_release instance f0e01000, total 1
[   28.960968] the clk_vdec_mux    clock off, ref cnt: 0
[   28.960975] the vdec            clock off, ref cnt: 0
[   28.960980] the parser_top      clock off, ref cnt: 0
[   28.960985] the demux           clock off, ref cnt: 0
[   28.962597] set video_inuse val:0
[   28.985447] DisableVideoLayer()
[   28.990884] VsyncDisableVideoLayer
[   28.990912] AFBC off now.
[   29.344314] zram0: detected capacity change from 0 to 268435456
[   29.383869] mkswap: Swapspace size: 262140k, UUID=69e3056d-8c89-45a3-b477-5198b8e8a85c
[   29.388157] Adding 262140k swap on /dev/block/zram0.  Priority:-1 extents:1 across:262140k SS
[   29.415520] selinux: SELinux: Skipping restorecon_recursive(/data/system_ce/0)\x0a
[   29.447197] logd: logdr: UID=1000 GID=1007 PID=4149 n tail=0 logMask=80 pid=0 start=0ns timeout=0ns
[   29.550701] selinux: SELinux: Skipping restorecon_recursive(/data/misc_ce/0)\x0a
[   29.581716] type=1400 audit(1420070428.140:50): avc: denied { create } for pid=3240 comm="bluetooth@1.0-s" scontext=u:r:hal_bluetooth_default:s0 tcontext=u:r:hal_bluetooth_default:s0 tclass=udp_socket permissive=1
[   29.595402] type=1400 audit(1596265697.913:51): avc: denied { read execute } for pid=4157 comm="preinstall.sh" path="/system/bin/sh" dev="mmcblk0p18" ino=788 scontext=u:r:preinstall:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   29.617273] type=1400 audit(1596265697.913:51): avc: denied { read execute } for pid=4157 comm="preinstall.sh" path="/system/bin/sh" dev="mmcblk0p18" ino=788 scontext=u:r:preinstall:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   29.638677] type=1400 audit(1596265697.917:52): avc: denied { getattr } for pid=4157 comm="preinstall.sh" path="/system/bin/sh" dev="mmcblk0p18" ino=788 scontext=u:r:preinstall:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   29.660205] type=1400 audit(1596265697.917:52): avc: denied { getattr } for pid=4157 comm="preinstall.sh" path="/system/bin/sh" dev="mmcblk0p18" ino=788 scontext=u:r:preinstall:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[   29.681125] type=1400 audit(1596265697.933:53): avc: denied { getattr } for pid=4157 comm="preinstall.sh" path="/data/local/symbol_thirdpart_apks_installed" dev="mmcblk0p20" ino=1048581 scontext=u:r:preinstall:s0 tcontext=u:object_r:system_data_file:s0 tclass=file permissive=1
[   30.042972] audit_log_lost: 1 callbacks suppressed
[   30.042977] audit: audit_lost=23 audit_rate_limit=5 audit_backlog_limit=64
[   30.043432] type=1400 audit(1596265697.933:53): avc: denied { getattr } for pid=4157 comm="preinstall.sh" path="/data/local/symbol_thirdpart_apks_installed" dev="mmcblk0p20" ino=1048581 scontext=u:r:preinstall:s0 tcontext=u:object_r:system_data_file:s0 tclass=file permissive=1
[   30.047890] type=1400 audit(1596265698.377:54): avc: denied { read } for pid=4150 comm="screencontrol" name="vndbinder" dev="tmpfs" ino=12581 scontext=u:r:screen_control:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_file permissive=1
[   30.048339] type=1400 audit(1596265698.377:54): avc: denied { read } for pid=4150 comm="screencontrol" name="vndbinder" dev="tmpfs" ino=12581 scontext=u:r:screen_control:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_file permissive=1
[   30.118397] audit: rate limit exceeded
[   31.691932] asoc-aml-card auge_sound: tdm playback stop
[   31.691981] spdif_a is set to disable
[   32.634954] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[   32.634962] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[   32.634996] tdm playback mute: 1, lane_cnt = 8
[   32.635087] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[   33.789452] input: Bluetooth Laser Travel Mouse as /devices/virtual/misc/uhid/0005:046D:B008.0001/input/input4
[   33.799663] hid-generic 0005:046D:B008.0001: input,hidraw0: BLUETOOTH HID v0.18 Mouse [Bluetooth Laser Travel Mouse] on
[   34.831695] input: Bluetooth 3.0 Keyboard as /devices/virtual/misc/uhid/0005:05AC:023C.0002/input/input5
[   34.852548] hid-generic 0005:05AC:023C.0002: input,hidraw1: BLUETOOTH HID v0.02 Keyboard [Bluetooth 3.0 Keyboard] on
[   40.281294] type=1400 audit(1596265700.553:59): avc: denied { open } for pid=4393 comm="sh" path="/sys/devices/platform/meson-vfd/attr/usbled" dev="sysfs" ino=10166 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   40.298011] type=1400 audit(1596265708.613:60): avc: denied { search } for pid=3254 comm="memtrack@1.0-se" name="3238" dev="proc" ino=14574 scontext=u:r:hal_memtrack_default:s0 tcontext=u:r:hal_allocator_default:s0 tclass=dir permissive=1
[   40.319882] type=1400 audit(1596265708.613:60): avc: denied { search } for pid=3254 comm="memtrack@1.0-se" name="3238" dev="proc" ino=14574 scontext=u:r:hal_memtrack_default:s0 tcontext=u:r:hal_allocator_default:s0 tclass=dir permissive=1
[   40.340662] type=1400 audit(1596265708.613:61): avc: denied { read } for pid=3254 comm="memtrack@1.0-se" name="status" dev="proc" ino=23248 scontext=u:r:hal_memtrack_default:s0 tcontext=u:r:hal_allocator_default:s0 tclass=file permissive=1
[   40.361637] type=1400 audit(1596265708.613:61): avc: denied { read } for pid=3254 comm="memtrack@1.0-se" name="status" dev="proc" ino=23248 scontext=u:r:hal_memtrack_default:s0 tcontext=u:r:hal_allocator_default:s0 tclass=file permissive=1
[   40.382824] type=1400 audit(1596265708.613:62): avc: denied { open } for pid=3254 comm="memtrack@1.0-se" path="/proc/3238/status" dev="proc" ino=23248 scontext=u:r:hal_memtrack_default:s0 tcontext=u:r:hal_allocator_default:s0 tclass=file permissive=1
[   40.405225] type=1400 audit(1596265708.613:62): avc: denied { open } for pid=3254 comm="memtrack@1.0-se" path="/proc/3238/status" dev="proc" ino=23248 scontext=u:r:hal_memtrack_default:s0 tcontext=u:r:hal_allocator_default:s0 tclass=file permissive=1
[   40.427317] type=1400 audit(1596265708.613:63): avc: denied { getattr } for pid=3254 comm="memtrack@1.0-se" path="/proc/3238/status" dev="proc" ino=23248 scontext=u:r:hal_memtrack_default:s0 tcontext=u:r:hal_allocator_default:s0 tclass=file permissive=1
[   40.451026] type=1400 audit(1596265708.613:63): avc: denied { getattr } for pid=3254 comm="memtrack@1.0-se" path="/proc/3238/status" dev="proc" ino=23248 scontext=u:r:hal_memtrack_default:s0 tcontext=u:r:hal_allocator_default:s0 tclass=file permissive=1
[   40.472360] type=1400 audit(1596265708.741:64): avc: denied { search } for pid=3254 comm="memtrack@1.0-se" name="3252" dev="proc" ino=12828 scontext=u:r:hal_memtrack_default:s0 tcontext=u:r:hal_ir_default:s0 tclass=dir permissive=1
[   40.621057] audit: audit_lost=24 audit_rate_limit=5 audit_backlog_limit=64
[   40.622490] audit: rate limit exceeded
[   41.115807] audio_dsp: dts_dec_control/0x0
[   41.174945] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[   41.175664] audio_dsp: last mode 0,now 0
[   41.528656] audio_dsp: drc high cut scale set to 100%
[   41.534490] audio_dsp: drc low boost scale set to 100%
[   41.535630] audio_dsp: drc mode set to LINE
[   42.559992] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[   42.560618] audio_dsp: last mode 0,now 0
[   42.636746] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[   42.637369] audio_dsp: last mode 0,now 0
[   47.142787] aml_tdm_open
[   47.143164] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[   47.143258] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[   47.143262] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[   47.143268] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[   47.143274] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[   47.143276] aml_dai_set_tdm_fmt(), fmt not change
[   47.143282] dump_pcm_setting(ed56df10)
[   47.143284] \x09pcm_mode(1)
[   47.143287] \x09sysclk(12288000)
[   47.143289] \x09sysclk_bclk_ratio(4)
[   47.143291] \x09bclk(3072000)
[   47.143293] \x09bclk_lrclk_ratio(64)
[   47.143295] \x09lrclk(48000)
[   47.143298] \x09tx_mask(0x3)
[   47.143300] \x09rx_mask(0x3)
[   47.143302] \x09slots(2)
[   47.143305] \x09slot_width(32)
[   47.143307] \x09lane_mask_in(0x2)
[   47.143309] \x09lane_mask_out(0x1)
[   47.143311] \x09lane_oe_mask_in(0x0)
[   47.143314] \x09lane_oe_mask_out(0x0)
[   47.143316] \x09lane_lb_mask_in(0x0)
[   47.143318] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[   47.143321] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[   47.143324] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[   47.143328] aml_dai_set_clkdiv, div 4, clksel(1)
[   47.143336] aml_dai_set_bclk_ratio, select I2S mode
[   47.143347] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[   47.143392] aml_tdm_prepare(), reset fddr
[   47.143410] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[   47.143416] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[   47.143428] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[   47.143670] tdm playback mute: 0, lane_cnt = 8
[   47.153024] asoc-aml-card auge_sound: tdm playback enable
[   47.153076] spdif_a is set to enable
[   47.727869] type=1400 audit(1596265708.741:67): avc: denied { getattr } for pid=3254 comm="memtrack@1.0-se" path="/proc/3252/status" dev="proc" ino=32890 scontext=u:r:hal_memtrack_default:s0 tcontext=u:r:hal_ir_default:s0 tclass=file permissive=1
[   47.744470] type=1400 audit(1596265716.061:80): avc: denied { write } for pid=4687 comm="sh" name="appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   47.763263] type=1400 audit(1596265716.061:80): avc: denied { write } for pid=4687 comm="sh" name="appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   47.781821] type=1400 audit(1596265716.061:81): avc: denied { open } for pid=4687 comm="sh" path="/sys/devices/platform/meson-vfd/attr/appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   50.982031] asoc-aml-card auge_sound: tdm playback stop
[   50.982111] spdif_a is set to disable
[   51.922266] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[   51.922276] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[   51.922315] tdm playback mute: 1, lane_cnt = 8
[   51.922547] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[   56.489689] aml_tdm_open
[   56.490043] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[   56.490137] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[   56.490140] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[   56.490147] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[   56.490153] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[   56.490156] aml_dai_set_tdm_fmt(), fmt not change
[   56.490162] dump_pcm_setting(ed56df10)
[   56.490165] \x09pcm_mode(1)
[   56.490167] \x09sysclk(12288000)
[   56.490170] \x09sysclk_bclk_ratio(4)
[   56.490173] \x09bclk(3072000)
[   56.490175] \x09bclk_lrclk_ratio(64)
[   56.490178] \x09lrclk(48000)
[   56.490181] \x09tx_mask(0x3)
[   56.490183] \x09rx_mask(0x3)
[   56.490186] \x09slots(2)
[   56.490188] \x09slot_width(32)
[   56.490191] \x09lane_mask_in(0x2)
[   56.490194] \x09lane_mask_out(0x1)
[   56.490196] \x09lane_oe_mask_in(0x0)
[   56.490199] \x09lane_oe_mask_out(0x0)
[   56.490201] \x09lane_lb_mask_in(0x0)
[   56.490204] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[   56.490207] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[   56.490211] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[   56.490215] aml_dai_set_clkdiv, div 4, clksel(1)
[   56.490223] aml_dai_set_bclk_ratio, select I2S mode
[   56.490236] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[   56.490281] aml_tdm_prepare(), reset fddr
[   56.490299] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[   56.490306] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[   56.490317] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[   56.490554] tdm playback mute: 0, lane_cnt = 8
[   56.494832] asoc-aml-card auge_sound: tdm playback enable
[   56.494885] spdif_a is set to enable
[   59.801257] asoc-aml-card auge_sound: tdm playback stop
[   59.801315] spdif_a is set to disable
[   60.739933] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[   60.739944] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[   60.739987] tdm playback mute: 1, lane_cnt = 8
[   60.740263] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[   62.489548] fb: mem_free_work, free memory: addr:800000
[   65.789077] aml_tdm_open
[   65.790993] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[   65.791099] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[   65.791104] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[   65.791112] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[   65.791118] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[   65.791122] aml_dai_set_tdm_fmt(), fmt not change
[   65.791130] dump_pcm_setting(ed56df10)
[   65.791133] \x09pcm_mode(1)
[   65.791136] \x09sysclk(12288000)
[   65.791139] \x09sysclk_bclk_ratio(4)
[   65.791141] \x09bclk(3072000)
[   65.791144] \x09bclk_lrclk_ratio(64)
[   65.791147] \x09lrclk(48000)
[   65.791150] \x09tx_mask(0x3)
[   65.791154] \x09rx_mask(0x3)
[   65.791156] \x09slots(2)
[   65.791159] \x09slot_width(32)
[   65.791161] \x09lane_mask_in(0x2)
[   65.791164] \x09lane_mask_out(0x1)
[   65.791166] \x09lane_oe_mask_in(0x0)
[   65.791169] \x09lane_oe_mask_out(0x0)
[   65.791172] \x09lane_lb_mask_in(0x0)
[   65.791175] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[   65.791177] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[   65.791182] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[   65.791186] aml_dai_set_clkdiv, div 4, clksel(1)
[   65.791195] aml_dai_set_bclk_ratio, select I2S mode
[   65.791207] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[   65.791259] aml_tdm_prepare(), reset fddr
[   65.791281] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[   65.791291] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[   65.791304] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[   65.791574] tdm playback mute: 0, lane_cnt = 8
[   65.794442] asoc-aml-card auge_sound: tdm playback enable
[   65.794496] spdif_a is set to enable
[   68.919841] asoc-aml-card auge_sound: tdm playback stop
[   68.919942] spdif_a is set to disable
[   69.867247] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[   69.867272] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[   69.867345] tdm playback mute: 1, lane_cnt = 8
[   69.867842] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[   92.253578] type=1400 audit(1596265716.061:81): avc: denied { open } for pid=4687 comm="sh" path="/sys/devices/platform/meson-vfd/attr/appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   92.270148] type=1400 audit(1596265760.585:82): avc: denied { read } for pid=5076 comm="find" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[   92.290620] type=1400 audit(1596265760.585:82): avc: denied { read } for pid=5076 comm="find" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[   92.311049] type=1400 audit(1596265760.589:83): avc: denied { open } for pid=5076 comm="find" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  103.440317] type=1400 audit(1596265760.589:83): avc: denied { open } for pid=5076 comm="find" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  103.550184] type=1400 audit(1596265771.773:84): avc: denied { open } for pid=5005 comm="Binder:5005_1" path="/sys/devices/virtual/android_usb/android0/state" dev="sysfs" ino=24439 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs_android_usb:s0 tclass=file permissive=1
[  108.697943] binder_alloc: 4094: binder_alloc_buf size 1056768 failed, no address space
[  108.700399] binder_alloc: allocated: 568 (num: 11 largest: 172), free: 1039816 (num: 7 largest: 1028176)
[  108.710288] binder: 4158:5619 transaction failed 29201/-28, size 1056768-0 line 3258
[  109.267848] logd: logdr: UID=10003 GID=10003 PID=4158 n tail=0 logMask=4 pid=0 start=0ns timeout=0ns
[  109.960520] type=1400 audit(1596265771.773:84): avc: denied { open } for pid=5005 comm="Binder:5005_1" path="/sys/devices/virtual/android_usb/android0/state" dev="sysfs" ino=24439 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs_android_usb:s0 tclass=file permissive=1
[  109.988998] type=1400 audit(1596265778.293:85): avc: denied { open } for pid=5005 comm="IntentService[D" path="/sys/fs/ext4" dev="sysfs" ino=13296 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[  110.308781] type=1400 audit(1596265778.293:85): avc: denied { open } for pid=5005 comm="IntentService[D" path="/sys/fs/ext4" dev="sysfs" ino=13296 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[  110.378457] type=1400 audit(1596265778.641:86): avc: denied { open } for pid=5005 comm="IntentService[D" path="/proc/bus/pci/devices" dev="proc" ino=4026532025 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[  110.400701] type=1400 audit(1596265778.641:86): avc: denied { open } for pid=5005 comm="IntentService[D" path="/proc/bus/pci/devices" dev="proc" ino=4026532025 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[  110.417489] type=1400 audit(1596265778.649:87): avc: denied { read } for pid=5005 comm="IntentService[D" name="type" dev="sysfs" ino=21525 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  110.438274] type=1400 audit(1596265778.649:87): avc: denied { read } for pid=5005 comm="IntentService[D" name="type" dev="sysfs" ino=21525 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  110.462245] type=1400 audit(1596265778.649:88): avc: denied { open } for pid=5005 comm="IntentService[D" path="/sys/devices/virtual/net/sit0/type" dev="sysfs" ino=21525 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  110.678548] audit: audit_lost=36 audit_rate_limit=5 audit_backlog_limit=64
[  110.679961] audit: rate limit exceeded
[  110.680850] type=1400 audit(1596265778.649:88): avc: denied { open } for pid=5005 comm="IntentService[D" path="/sys/devices/virtual/net/sit0/type" dev="sysfs" ino=21525 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  114.382632] type=1400 audit(1596265782.253:193): avc: denied { open } for pid=5005 comm="Binder:5005_2" path="/sys/devices/virtual/android_usb/android0/state" dev="sysfs" ino=24439 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs_android_usb:s0 tclass=file permissive=1
[  114.444892] type=1400 audit(1596265782.717:194): avc: denied { read } for pid=5005 comm="Binder:5005_1" name="stat" dev="proc" ino=16841 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:r:zygote:s0 tclass=file permissive=1
[  114.474139] type=1400 audit(1596265782.717:194): avc: denied { read } for pid=5005 comm="Binder:5005_1" name="stat" dev="proc" ino=16841 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:r:zygote:s0 tclass=file permissive=1
[  114.488803] type=1400 audit(1596265782.717:195): avc: denied { open } for pid=5005 comm="Binder:5005_1" path="/proc/3232/stat" dev="proc" ino=16841 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:r:zygote:s0 tclass=file permissive=1
[  114.556581] type=1400 audit(1596265782.717:195): avc: denied { open } for pid=5005 comm="Binder:5005_1" path="/proc/3232/stat" dev="proc" ino=16841 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:r:zygote:s0 tclass=file permissive=1
[  114.585449] type=1400 audit(1596265782.889:196): avc: denied { open } for pid=5005 comm="Binder:5005_1" path="/proc/bus/pci/devices" dev="proc" ino=4026532025 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[  117.635998] logd: logdr: UID=10003 GID=10003 PID=4094 n tail=0 logMask=4 pid=0 start=0ns timeout=0ns
[  117.939370] logd: logdr: UID=10003 GID=10003 PID=4094 n tail=0 logMask=4 pid=0 start=1596265785538000000ns timeout=1596272986262183379ns
[  118.654981] logd: logdr: UID=10003 GID=10003 PID=4094 n tail=0 logMask=4 pid=0 start=0ns timeout=0ns
[  119.286411] aml_tdm_open
[  119.297151] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[  119.297239] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  119.297241] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  119.297246] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  119.297250] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[  119.297253] aml_dai_set_tdm_fmt(), fmt not change
[  119.297257] dump_pcm_setting(ed56df10)
[  119.297259] \x09pcm_mode(1)
[  119.297260] \x09sysclk(12288000)
[  119.297262] \x09sysclk_bclk_ratio(4)
[  119.297264] \x09bclk(3072000)
[  119.297265] \x09bclk_lrclk_ratio(64)
[  119.297267] \x09lrclk(48000)
[  119.297269] \x09tx_mask(0x3)
[  119.297270] \x09rx_mask(0x3)
[  119.297272] \x09slots(2)
[  119.297274] \x09slot_width(32)
[  119.297275] \x09lane_mask_in(0x2)
[  119.297277] \x09lane_mask_out(0x1)
[  119.297278] \x09lane_oe_mask_in(0x0)
[  119.297280] \x09lane_oe_mask_out(0x0)
[  119.297282] \x09lane_lb_mask_in(0x0)
[  119.297284] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  119.297285] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  119.297288] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  119.297291] aml_dai_set_clkdiv, div 4, clksel(1)
[  119.297298] aml_dai_set_bclk_ratio, select I2S mode
[  119.297307] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[  119.297347] aml_tdm_prepare(), reset fddr
[  119.297361] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[  119.297367] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[  119.297376] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  119.304048] tdm playback mute: 0, lane_cnt = 8
[  119.307664] asoc-aml-card auge_sound: tdm playback enable
[  119.307711] spdif_a is set to enable
[  122.443320] asoc-aml-card auge_sound: tdm playback stop
[  122.443368] spdif_a is set to disable
[  123.386645] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  123.386655] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[  123.386691] tdm playback mute: 1, lane_cnt = 8
[  123.386962] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[  123.929007] logd: logdr: UID=10003 GID=10003 PID=4094 n tail=0 logMask=4 pid=0 start=0ns timeout=0ns
[  129.467936] aml_tdm_open
[  129.471785] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[  129.471881] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  129.471884] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  129.471890] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  129.471894] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[  129.471896] aml_dai_set_tdm_fmt(), fmt not change
[  129.471900] dump_pcm_setting(ed56df10)
[  129.471902] \x09pcm_mode(1)
[  129.471904] \x09sysclk(12288000)
[  129.471905] \x09sysclk_bclk_ratio(4)
[  129.471907] \x09bclk(3072000)
[  129.471909] \x09bclk_lrclk_ratio(64)
[  129.471910] \x09lrclk(48000)
[  129.471912] \x09tx_mask(0x3)
[  129.471914] \x09rx_mask(0x3)
[  129.471915] \x09slots(2)
[  129.471917] \x09slot_width(32)
[  129.471919] \x09lane_mask_in(0x2)
[  129.471920] \x09lane_mask_out(0x1)
[  129.471922] \x09lane_oe_mask_in(0x0)
[  129.471924] \x09lane_oe_mask_out(0x0)
[  129.471926] \x09lane_lb_mask_in(0x0)
[  129.471927] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  129.471929] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  129.471932] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  129.471935] aml_dai_set_clkdiv, div 4, clksel(1)
[  129.471942] aml_dai_set_bclk_ratio, select I2S mode
[  129.471952] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[  129.471996] aml_tdm_prepare(), reset fddr
[  129.472011] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[  129.472017] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[  129.472026] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  129.472899] tdm playback mute: 0, lane_cnt = 8
[  129.478228] asoc-aml-card auge_sound: tdm playback enable
[  129.478274] spdif_a is set to enable
[  132.592570] asoc-aml-card auge_sound: tdm playback stop
[  132.592620] spdif_a is set to disable
[  133.529362] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  133.529370] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[  133.529405] tdm playback mute: 1, lane_cnt = 8
[  133.530033] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[  134.886448] logd: logdr: UID=10003 GID=10003 PID=4158 n tail=0 logMask=4 pid=0 start=0ns timeout=0ns
[  135.798372] type=1400 audit(1596265782.889:196): avc: denied { open } for pid=5005 comm="Binder:5005_1" path="/proc/bus/pci/devices" dev="proc" ino=4026532025 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[  135.833485] type=1400 audit(1596265804.133:197): avc: denied { read } for pid=5005 comm="Binder:5005_2" name="type" dev="sysfs" ino=21525 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  135.848672] type=1400 audit(1596265804.133:197): avc: denied { read } for pid=5005 comm="Binder:5005_2" name="type" dev="sysfs" ino=21525 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  135.868602] type=1400 audit(1596265804.133:198): avc: denied { open } for pid=5005 comm="Binder:5005_2" path="/sys/devices/virtual/net/sit0/type" dev="sysfs" ino=21525 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  135.996258] type=1400 audit(1596265804.133:198): avc: denied { open } for pid=5005 comm="Binder:5005_2" path="/sys/devices/virtual/net/sit0/type" dev="sysfs" ino=21525 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  136.013754] type=1400 audit(1596265804.329:199): avc: denied { read } for pid=5005 comm="Binder:5005_2" name="stat" dev="proc" ino=16841 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:r:zygote:s0 tclass=file permissive=1
[  136.033743] type=1400 audit(1596265804.329:199): avc: denied { read } for pid=5005 comm="Binder:5005_2" name="stat" dev="proc" ino=16841 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:r:zygote:s0 tclass=file permissive=1
[  136.053710] type=1400 audit(1596265804.329:200): avc: denied { open } for pid=5005 comm="Binder:5005_2" path="/proc/3232/stat" dev="proc" ino=16841 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:r:zygote:s0 tclass=file permissive=1
[  136.104857] type=1400 audit(1596265804.329:200): avc: denied { open } for pid=5005 comm="Binder:5005_2" path="/proc/3232/stat" dev="proc" ino=16841 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:r:zygote:s0 tclass=file permissive=1
[  214.038330] type=1400 audit(1596265804.493:203): avc: denied { open } for pid=5005 comm="Binder:5005_2" path="/proc/bus/pci/devices" dev="proc" ino=4026532025 scontext=u:r:priv_app:s0:c512,c768 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[  214.054755] type=1400 audit(1596265882.373:204): avc: denied { write } for pid=6411 comm="sh" name="appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  214.073912] type=1400 audit(1596265882.373:204): avc: denied { write } for pid=6411 comm="sh" name="appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  214.092418] type=1400 audit(1596265882.373:205): avc: denied { open } for pid=6411 comm="sh" path="/sys/devices/platform/meson-vfd/attr/appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  217.414131] aml_tdm_open
[  217.414526] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[  217.414631] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  217.414636] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  217.414644] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  217.414650] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[  217.414655] aml_dai_set_tdm_fmt(), fmt not change
[  217.414662] dump_pcm_setting(ed56df10)
[  217.414665] \x09pcm_mode(1)
[  217.414668] \x09sysclk(12288000)
[  217.414671] \x09sysclk_bclk_ratio(4)
[  217.414674] \x09bclk(3072000)
[  217.414678] \x09bclk_lrclk_ratio(64)
[  217.414681] \x09lrclk(48000)
[  217.414684] \x09tx_mask(0x3)
[  217.414687] \x09rx_mask(0x3)
[  217.414690] \x09slots(2)
[  217.414693] \x09slot_width(32)
[  217.414696] \x09lane_mask_in(0x2)
[  217.414699] \x09lane_mask_out(0x1)
[  217.414702] \x09lane_oe_mask_in(0x0)
[  217.414705] \x09lane_oe_mask_out(0x0)
[  217.414708] \x09lane_lb_mask_in(0x0)
[  217.414712] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  217.414715] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  217.414720] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  217.414725] aml_dai_set_clkdiv, div 4, clksel(1)
[  217.414734] aml_dai_set_bclk_ratio, select I2S mode
[  217.414748] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[  217.414800] aml_tdm_prepare(), reset fddr
[  217.414820] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[  217.414829] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[  217.414842] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  217.417020] tdm playback mute: 0, lane_cnt = 8
[  217.419351] asoc-aml-card auge_sound: tdm playback enable
[  217.419409] spdif_a is set to enable
[  221.077680] asoc-aml-card auge_sound: tdm playback stop
[  221.077741] spdif_a is set to disable
[  222.019785] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  222.019796] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[  222.019840] tdm playback mute: 1, lane_cnt = 8
[  222.019958] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[  222.050255] aml_tdm_open
[  222.050719] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[  222.050825] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  222.050830] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  222.050838] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  222.050844] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[  222.050848] aml_dai_set_tdm_fmt(), fmt not change
[  222.050856] dump_pcm_setting(ed56df10)
[  222.050859] \x09pcm_mode(1)
[  222.050862] \x09sysclk(12288000)
[  222.050865] \x09sysclk_bclk_ratio(4)
[  222.050868] \x09bclk(3072000)
[  222.050871] \x09bclk_lrclk_ratio(64)
[  222.050874] \x09lrclk(48000)
[  222.050877] \x09tx_mask(0x3)
[  222.050880] \x09rx_mask(0x3)
[  222.050883] \x09slots(2)
[  222.050886] \x09slot_width(32)
[  222.050889] \x09lane_mask_in(0x2)
[  222.050892] \x09lane_mask_out(0x1)
[  222.050896] \x09lane_oe_mask_in(0x0)
[  222.050899] \x09lane_oe_mask_out(0x0)
[  222.050902] \x09lane_lb_mask_in(0x0)
[  222.050905] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  222.050909] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  222.050914] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  222.050919] aml_dai_set_clkdiv, div 4, clksel(1)
[  222.050929] aml_dai_set_bclk_ratio, select I2S mode
[  222.050943] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[  222.050997] aml_tdm_prepare(), reset fddr
[  222.051017] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[  222.051026] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[  222.051039] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  222.051440] tdm playback mute: 0, lane_cnt = 8
[  222.062670] asoc-aml-card auge_sound: tdm playback enable
[  222.062783] spdif_a is set to enable
[  225.347731] asoc-aml-card auge_sound: tdm playback stop
[  225.347792] spdif_a is set to disable
[  226.286779] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  226.286790] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[  226.286835] tdm playback mute: 1, lane_cnt = 8
[  226.287131] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[  226.705017] aml_tdm_open
[  226.720837] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[  226.720935] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  226.720939] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  226.720945] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  226.720952] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[  226.720957] aml_dai_set_tdm_fmt(), fmt not change
[  226.720963] dump_pcm_setting(ed56df10)
[  226.720966] \x09pcm_mode(1)
[  226.720968] \x09sysclk(12288000)
[  226.720971] \x09sysclk_bclk_ratio(4)
[  226.720973] \x09bclk(3072000)
[  226.720976] \x09bclk_lrclk_ratio(64)
[  226.720978] \x09lrclk(48000)
[  226.720980] \x09tx_mask(0x3)
[  226.720983] \x09rx_mask(0x3)
[  226.720985] \x09slots(2)
[  226.720987] \x09slot_width(32)
[  226.720989] \x09lane_mask_in(0x2)
[  226.720991] \x09lane_mask_out(0x1)
[  226.720993] \x09lane_oe_mask_in(0x0)
[  226.720995] \x09lane_oe_mask_out(0x0)
[  226.720997] \x09lane_lb_mask_in(0x0)
[  226.720999] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  226.721002] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  226.721005] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  226.721008] aml_dai_set_clkdiv, div 4, clksel(1)
[  226.721016] aml_dai_set_bclk_ratio, select I2S mode
[  226.721030] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[  226.721078] aml_tdm_prepare(), reset fddr
[  226.721098] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[  226.721107] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[  226.721120] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  226.723725] tdm playback mute: 0, lane_cnt = 8
[  226.725252] asoc-aml-card auge_sound: tdm playback enable
[  226.725300] spdif_a is set to enable
[  229.850287] asoc-aml-card auge_sound: tdm playback stop
[  229.850385] spdif_a is set to disable
[  230.796823] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  230.796864] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[  230.796989] tdm playback mute: 1, lane_cnt = 8
[  230.797810] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[  278.806690] type=1400 audit(1596265882.373:205): avc: denied { open } for pid=6411 comm="sh" path="/sys/devices/platform/meson-vfd/attr/appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  278.823334] type=1400 audit(1596265947.141:206): avc: denied { read } for pid=6457 comm="ls" name="base" dev="sysfs" ino=61 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[  278.843602] type=1400 audit(1596265947.141:206): avc: denied { read } for pid=6457 comm="ls" name="base" dev="sysfs" ino=61 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[  278.863424] type=1400 audit(1596265947.141:207): avc: denied { open } for pid=6457 comm="ls" path="/sys/firmware/devicetree/base" dev="sysfs" ino=61 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[  278.885878] type=1400 audit(1596265947.141:207): avc: denied { open } for pid=6457 comm="ls" path="/sys/firmware/devicetree/base" dev="sysfs" ino=61 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[  278.907958] type=1400 audit(1596265947.141:208): avc: denied { getattr } for pid=6457 comm="ls" path="/sys/firmware/devicetree/base/compatible" dev="sysfs" ino=64 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  287.111278] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
[  328.571625] type=1400 audit(1596265947.141:208): avc: denied { getattr } for pid=6457 comm="ls" path="/sys/firmware/devicetree/base/compatible" dev="sysfs" ino=64 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  328.589811] type=1400 audit(1596265996.905:209): avc: denied { read } for pid=6458 comm="dtc" name="compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  328.612298] type=1400 audit(1596265996.905:209): avc: denied { read } for pid=6458 comm="dtc" name="compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  328.632330] type=1400 audit(1596265996.905:210): avc: denied { open } for pid=6458 comm="dtc" path="/sys/firmware/devicetree/base/codec_mm/compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  328.770514] type=1400 audit(1596265996.905:210): avc: denied { open } for pid=6458 comm="dtc" path="/sys/firmware/devicetree/base/codec_mm/compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  328.770621] audit: audit_lost=137 audit_rate_limit=5 audit_backlog_limit=64
[  328.770622] audit: rate limit exceeded
[  328.800340] type=1400 audit(1596265997.105:211): avc: denied { read } for pid=6458 comm="dtc" name="android" dev="sysfs" ino=2382 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=dir permissive=1
[  328.822885] type=1400 audit(1596265997.105:211): avc: denied { read } for pid=6458 comm="dtc" name="android" dev="sysfs" ino=2382 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=dir permissive=1
[  328.845086] type=1400 audit(1596265997.105:212): avc: denied { open } for pid=6458 comm="dtc" path="/sys/firmware/devicetree/base/firmware/android" dev="sysfs" ino=2382 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=dir permissive=1
[  328.870996] type=1400 audit(1596265997.105:212): avc: denied { open } for pid=6458 comm="dtc" path="/sys/firmware/devicetree/base/firmware/android" dev="sysfs" ino=2382 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=dir permissive=1
[  328.896632] type=1400 audit(1596265997.105:213): avc: denied { search } for pid=6458 comm="dtc" name="android" dev="sysfs" ino=2382 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=dir permissive=1
[  353.261488] type=1400 audit(1596265997.105:215): avc: denied { read } for pid=6458 comm="dtc" name="compatible" dev="sysfs" ino=2383 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=file permissive=1
[  353.279723] type=1400 audit(1596266021.593:217): avc: denied { read } for pid=6460 comm="dtc" name="base" dev="sysfs" ino=61 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[  353.302247] type=1400 audit(1596266021.593:217): avc: denied { read } for pid=6460 comm="dtc" name="base" dev="sysfs" ino=61 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[  353.319211] type=1400 audit(1596266021.613:218): avc: denied { open } for pid=6460 comm="dtc" path="/sys/firmware/devicetree/base" dev="sysfs" ino=61 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[  353.342165] type=1400 audit(1596266021.613:218): avc: denied { open } for pid=6460 comm="dtc" path="/sys/firmware/devicetree/base" dev="sysfs" ino=61 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[  353.342197] type=1400 audit(1596266021.613:219): avc: denied { getattr } for pid=6460 comm="dtc" path="/sys/firmware/devicetree/base/codec_mm/compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  353.342302] type=1400 audit(1596266021.613:219): avc: denied { getattr } for pid=6460 comm="dtc" path="/sys/firmware/devicetree/base/codec_mm/compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  353.343155] type=1400 audit(1596266021.613:220): avc: denied { read } for pid=6460 comm="dtc" name="compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  353.343301] type=1400 audit(1596266021.613:220): avc: denied { read } for pid=6460 comm="dtc" name="compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  353.343326] type=1400 audit(1596266021.613:221): avc: denied { open } for pid=6460 comm="dtc" path="/sys/firmware/devicetree/base/codec_mm/compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  452.446185] meson-mmc: card IN
[  452.557779] meson-mmc: normal card in
[  452.681710] meson-mmc: actual_clock :400000, HHI_nand: 0x80
[  452.681832] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x1000033c
[  452.810271] meson-mmc: actual_clock :50000000, HHI_nand: 0x80
[  452.810565] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x10000354
[  452.817795] sd: new high speed SDHC card at address 1234
[  452.823434] sd: clock 50000000, 4-bit-bus-width\x0a
[  452.830860] mmcblk1: sd:1234 SA08G 7.21 GiB
[  452.834593] type=1400 audit(1596266021.613:221): avc: denied { open } for pid=6460 comm="dtc" path="/sys/firmware/devicetree/base/codec_mm/compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  452.857708] type=1400 audit(1596266121.169:222): avc: denied { create } for pid=32 comm="kdevtmpfs" name="mmcblk1" scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[  452.874635] mmcblk1: p1 p2
[  452.874860] type=1400 audit(1596266121.169:222): avc: denied { create } for pid=32 comm="kdevtmpfs" name="mmcblk1" scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[  452.874901] type=1400 audit(1596266121.169:223): avc: denied { setattr } for pid=32 comm="kdevtmpfs" name="mmcblk1" dev="devtmpfs" ino=59903 scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[  452.923345] meson-mmc: Enter aml_emmc_partition_ops
[  453.158039] sdcardfs version 2.0
[  453.158067] sdcardfs: dev_name -> /mnt/media_rw/1106-2008
[  453.161356] sdcardfs: options -> fsuid=1023,fsgid=1023,mask=6,userid=0,gid=1015
[  453.168863] sdcardfs: mnt -> e9bdd510
[  453.172872] sdcardfs: mounted on top of /mnt/media_rw/1106-2008 type vfat
[  453.180668] Remount options were mask=18,gid=9997 for vfsmnt ebf08410.
[  453.186271] sdcardfs : options - debug:1
[  453.190335] sdcardfs : options - gid:9997
[  453.194481] sdcardfs : options - mask:18
[  453.199348] Remount options were mask=18,gid=9997 for vfsmnt eb2f3b10.
[  453.205255] sdcardfs : options - debug:1
[  453.209304] sdcardfs : options - gid:9997
[  453.213468] sdcardfs : options - mask:18
[  458.838131] type=1400 audit(1596266121.169:223): avc: denied { setattr } for pid=32 comm="kdevtmpfs" name="mmcblk1" dev="devtmpfs" ino=59903 scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[  458.852575] type=1400 audit(1596266127.173:224): avc: denied { getattr } for pid=6553 comm="ls" path="/mnt/media_rw" dev="tmpfs" ino=1260 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=1
[  458.875063] type=1400 audit(1596266127.173:224): avc: denied { getattr } for pid=6553 comm="ls" path="/mnt/media_rw" dev="tmpfs" ino=1260 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=1
[  458.897328] type=1400 audit(1596266127.185:225): avc: denied { getattr } for pid=6553 comm="ls" path="/mnt/vendor" dev="tmpfs" ino=456 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  495.139210] type=1400 audit(1596266127.185:225): avc: denied { getattr } for pid=6553 comm="ls" path="/mnt/vendor" dev="tmpfs" ino=456 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  495.155666] type=1400 audit(1596266163.473:226): avc: denied { read } for pid=6601 comm="find" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  495.176167] type=1400 audit(1596266163.473:226): avc: denied { read } for pid=6601 comm="find" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  495.196400] type=1400 audit(1596266163.473:227): avc: denied { open } for pid=6601 comm="find" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  505.405762] type=1400 audit(1596266163.473:227): avc: denied { open } for pid=6601 comm="find" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  505.421041] type=1400 audit(1596266173.737:228): avc: denied { ioctl } for pid=6719 comm="mc" path="/dev/pts/0" dev="devpts" ino=3 ioctlcmd=0x541c scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  522.827146] type=1400 audit(1596266173.737:228): avc: denied { ioctl } for pid=6719 comm="mc" path="/dev/pts/0" dev="devpts" ino=3 ioctlcmd=0x541c scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  522.848207] type=1400 audit(1596266191.161:229): avc: denied { write } for pid=6727 comm="sh" name="appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  522.866591] type=1400 audit(1596266191.161:229): avc: denied { write } for pid=6727 comm="sh" name="appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  522.885235] type=1400 audit(1596266191.161:230): avc: denied { open } for pid=6727 comm="sh" path="/sys/devices/platform/meson-vfd/attr/appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  535.702338] aml_tdm_open
[  535.704186] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[  535.704291] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  535.704295] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  535.704301] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  535.704307] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[  535.704311] aml_dai_set_tdm_fmt(), fmt not change
[  535.704317] dump_pcm_setting(ed56df10)
[  535.704320] \x09pcm_mode(1)
[  535.704322] \x09sysclk(12288000)
[  535.704325] \x09sysclk_bclk_ratio(4)
[  535.704328] \x09bclk(3072000)
[  535.704330] \x09bclk_lrclk_ratio(64)
[  535.704333] \x09lrclk(48000)
[  535.704336] \x09tx_mask(0x3)
[  535.704340] \x09rx_mask(0x3)
[  535.704343] \x09slots(2)
[  535.704346] \x09slot_width(32)
[  535.704349] \x09lane_mask_in(0x2)
[  535.704351] \x09lane_mask_out(0x1)
[  535.704354] \x09lane_oe_mask_in(0x0)
[  535.704358] \x09lane_oe_mask_out(0x0)
[  535.704360] \x09lane_lb_mask_in(0x0)
[  535.704363] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  535.704366] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  535.704370] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  535.704375] aml_dai_set_clkdiv, div 4, clksel(1)
[  535.704384] aml_dai_set_bclk_ratio, select I2S mode
[  535.704396] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[  535.704443] aml_tdm_prepare(), reset fddr
[  535.704461] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[  535.704469] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[  535.704481] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  535.705867] tdm playback mute: 0, lane_cnt = 8
[  535.707544] asoc-aml-card auge_sound: tdm playback enable
[  535.707595] spdif_a is set to enable
[  538.832547] asoc-aml-card auge_sound: tdm playback stop
[  538.832629] spdif_a is set to disable
[  539.178709] aml_tdm_prepare(), reset fddr
[  539.178749] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[  539.178756] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[  539.178769] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  539.179651] tdm playback mute: 0, lane_cnt = 8
[  539.189647] asoc-aml-card auge_sound: tdm playback enable
[  539.189693] spdif_a is set to enable
[  542.314686] asoc-aml-card auge_sound: tdm playback stop
[  542.314787] spdif_a is set to disable
[  543.256218] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  543.256226] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[  543.256260] tdm playback mute: 1, lane_cnt = 8
[  543.256419] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[  549.839731] aml_tdm_open
[  549.841609] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[  549.841693] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  549.841696] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  549.841702] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  549.841706] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[  549.841709] aml_dai_set_tdm_fmt(), fmt not change
[  549.841713] dump_pcm_setting(ed56df10)
[  549.841715] \x09pcm_mode(1)
[  549.841717] \x09sysclk(12288000)
[  549.841718] \x09sysclk_bclk_ratio(4)
[  549.841720] \x09bclk(3072000)
[  549.841722] \x09bclk_lrclk_ratio(64)
[  549.841723] \x09lrclk(48000)
[  549.841725] \x09tx_mask(0x3)
[  549.841727] \x09rx_mask(0x3)
[  549.841728] \x09slots(2)
[  549.841730] \x09slot_width(32)
[  549.841731] \x09lane_mask_in(0x2)
[  549.841733] \x09lane_mask_out(0x1)
[  549.841735] \x09lane_oe_mask_in(0x0)
[  549.841737] \x09lane_oe_mask_out(0x0)
[  549.841738] \x09lane_lb_mask_in(0x0)
[  549.841740] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  549.841742] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  549.841745] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  549.841747] aml_dai_set_clkdiv, div 4, clksel(1)
[  549.841754] aml_dai_set_bclk_ratio, select I2S mode
[  549.841764] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[  549.841806] aml_tdm_prepare(), reset fddr
[  549.841821] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[  549.841826] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[  549.842627] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  549.843463] tdm playback mute: 0, lane_cnt = 8
[  549.845355] asoc-aml-card auge_sound: tdm playback enable
[  549.845399] spdif_a is set to enable
[  552.970354] asoc-aml-card auge_sound: tdm playback stop
[  552.970415] spdif_a is set to disable
[  553.333347] aml_tdm_prepare(), reset fddr
[  553.333379] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[  553.333494] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[  553.333551] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  553.334243] tdm playback mute: 0, lane_cnt = 8
[  553.341187] asoc-aml-card auge_sound: tdm playback enable
[  553.341237] spdif_a is set to enable
[  555.787787] type=1400 audit(1596266191.161:230): avc: denied { open } for pid=6727 comm="sh" path="/sys/devices/platform/meson-vfd/attr/appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  555.804354] type=1400 audit(1596266224.121:231): avc: denied { ioctl } for pid=6719 comm="mc" path="/dev/pts/0" dev="devpts" ino=3 ioctlcmd=0x541c scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  556.024368] type=1400 audit(1596266224.121:231): avc: denied { ioctl } for pid=6719 comm="mc" path="/dev/pts/0" dev="devpts" ino=3 ioctlcmd=0x541c scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  556.025840] audit: audit_lost=138 audit_rate_limit=5 audit_backlog_limit=64
[  556.025842] audit: rate limit exceeded
[  556.055709] type=1400 audit(1596266224.357:232): avc: denied { read } for pid=6719 comm="mc" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  556.076825] type=1400 audit(1596266224.357:232): avc: denied { read } for pid=6719 comm="mc" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  556.096341] type=1400 audit(1596266224.357:233): avc: denied { open } for pid=6719 comm="mc" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  556.116689] type=1400 audit(1596266224.357:233): avc: denied { open } for pid=6719 comm="mc" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  556.136887] type=1400 audit(1596266224.357:234): avc: denied { getattr } for pid=6719 comm="mc" path="/init.usb.configfs.rc" dev="mmcblk0p18" ino=2612 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[  556.159729] type=1400 audit(1596266224.357:234): avc: denied { getattr } for pid=6719 comm="mc" path="/init.usb.configfs.rc" dev="mmcblk0p18" ino=2612 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[  556.182075] type=1400 audit(1596266224.357:235): avc: denied { getattr } for pid=6719 comm="mc" path="/init" dev="mmcblk0p18" ino=2623 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:init_exec:s0 tclass=file permissive=1
[  556.466179] asoc-aml-card auge_sound: tdm playback stop
[  556.466239] spdif_a is set to disable
[  557.405074] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  557.405087] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[  557.405132] tdm playback mute: 1, lane_cnt = 8
[  557.405351] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[  595.684923] type=1400 audit(1596266224.357:236): avc: denied { getattr } for pid=6719 comm="mc" path="/metadata" dev="mmcblk0p13" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[  595.701257] type=1400 audit(1596266264.017:238): avc: denied { getattr } for pid=6854 comm="dboxed_process0" path="/data/data/com.android.chrome" dev="mmcblk0p20" ino=786664 scontext=u:r:isolated_app:s0:c0,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1
[  595.834314] binder: undelivered transaction 266641, process died.
[  595.834973] binder: undelivered transaction 266642, process died.
[  595.841549] binder: undelivered transaction 266643, process died.
[  599.882432] type=1400 audit(1596266264.017:238): avc: denied { getattr } for pid=6854 comm="dboxed_process0" path="/data/data/com.android.chrome" dev="mmcblk0p20" ino=786664 scontext=u:r:isolated_app:s0:c0,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1
[  599.903376] type=1400 audit(1596266268.217:239): avc: denied { ioctl } for pid=6719 comm="mc" path="/dev/pts/0" dev="devpts" ino=3 ioctlcmd=0x541c scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  599.947497] type=1400 audit(1596266268.217:239): avc: denied { ioctl } for pid=6719 comm="mc" path="/dev/pts/0" dev="devpts" ino=3 ioctlcmd=0x541c scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  599.968113] type=1400 audit(1596266268.281:240): avc: denied { ioctl } for pid=6721 comm="bash" path=2F6465762F7074732F31202864656C6574656429 dev="devpts" ino=4 ioctlcmd=0x540a scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  602.291456] type=1400 audit(1596266268.281:240): avc: denied { ioctl } for pid=6721 comm="bash" path=2F6465762F7074732F31202864656C6574656429 dev="devpts" ino=4 ioctlcmd=0x540a scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  602.292671] audit: audit_lost=139 audit_rate_limit=5 audit_backlog_limit=64
[  602.292673] audit: rate limit exceeded
[  602.325545] type=1400 audit(1596266270.625:241): avc: denied { getattr } for pid=6877 comm="df" path="/mnt/vendor/param" dev="mmcblk0p10" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  602.349098] type=1400 audit(1596266270.625:241): avc: denied { getattr } for pid=6877 comm="df" path="/mnt/vendor/param" dev="mmcblk0p10" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  602.371197] type=1400 audit(1596266270.625:242): avc: denied { getattr } for pid=6877 comm="df" path="/mnt/vendor/tee" dev="mmcblk0p15" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[  602.393328] type=1400 audit(1596266270.625:242): avc: denied { getattr } for pid=6877 comm="df" path="/mnt/vendor/tee" dev="mmcblk0p15" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[  602.415061] type=1400 audit(1596266270.625:243): avc: denied { getattr } for pid=6877 comm="df" path="/metadata" dev="mmcblk0p13" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[  602.437108] type=1400 audit(1596266270.625:243): avc: denied { getattr } for pid=6877 comm="df" path="/metadata" dev="mmcblk0p13" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[  602.458154] type=1400 audit(1596266270.625:244): avc: denied { getattr } for pid=6877 comm="df" path="/dev/block" dev="tmpfs" ino=458 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:block_device:s0 tclass=dir permissive=1
[  602.479957] type=1400 audit(1596266270.625:244): avc: denied { getattr } for pid=6877 comm="df" path="/dev/block" dev="tmpfs" ino=458 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:block_device:s0 tclass=dir permissive=1
[  602.501307] type=1400 audit(1596266270.625:245): avc: denied { getattr } for pid=6877 comm="df" path="/dev/block/param" dev="tmpfs" ino=14337 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:param_block_device:s0 tclass=blk_file permissive=1
[  611.688285] type=1400 audit(1596266270.625:247): avc: denied { getattr } for pid=6877 comm="df" path="/dev/block/odm" dev="tmpfs" ino=468 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:odm_block_device:s0 tclass=blk_file permissive=1
[  611.712089] type=1400 audit(1596266280.021:254): avc: denied { read } for pid=4762 comm="bash" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  611.727807] type=1400 audit(1596266280.021:254): avc: denied { read } for pid=4762 comm="bash" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  611.747579] type=1400 audit(1596266280.021:255): avc: denied { open } for pid=4762 comm="bash" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  611.767853] logd: logdr: UID=10003 GID=10003 PID=4094 n tail=0 logMask=4 pid=0 start=1596266221675000000ns timeout=1596273480100662906ns
[  619.593865] type=1400 audit(1596266280.021:255): avc: denied { open } for pid=4762 comm="bash" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  619.609449] type=1400 audit(1596266287.929:256): avc: denied { read } for pid=6899 comm="su" name="/" dev="selinuxfs" ino=1 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=dir permissive=1
[  619.629647] type=1400 audit(1596266287.929:256): avc: denied { read } for pid=6899 comm="su" name="/" dev="selinuxfs" ino=1 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=dir permissive=1
[  619.649685] type=1400 audit(1596266287.929:257): avc: denied { read } for pid=6899 comm="su" name="enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[  619.671033] type=1400 audit(1596266287.929:257): avc: denied { read } for pid=6899 comm="su" name="enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[  619.691887] type=1400 audit(1596266287.929:258): avc: denied { open } for pid=6899 comm="su" path="/sys/fs/selinux/enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[  619.699609] audit: audit_lost=145 audit_rate_limit=5 audit_backlog_limit=64
[  619.699611] audit: rate limit exceeded
[  619.725485] type=1400 audit(1596266287.929:258): avc: denied { open } for pid=6899 comm="su" path="/sys/fs/selinux/enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[  619.747807] type=1400 audit(1596266287.929:259): avc: denied { connectto } for pid=6899 comm="su" path=0065752E636861696E666972652E73757065727375 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:init:s0 tclass=unix_stream_socket permissive=1
[  619.770530] type=1400 audit(1596266287.929:259): avc: denied { connectto } for pid=6899 comm="su" path=0065752E636861696E666972652E73757065727375 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:init:s0 tclass=unix_stream_socket permissive=1
[  619.792962] type=1400 audit(1596266287.929:260): avc: denied { sys_ptrace } for pid=3359 comm="su" capability=19 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=1
[  627.676757] type=1400 audit(1596266292.505:270): avc: denied { ioctl } for pid=6910 comm="tmp-mksh" path="/dev/pts/2" dev="devpts" ino=5 ioctlcmd=0x5401 scontext=u:r:init:s0 tcontext=u:object_r:devpts:s0 tclass=chr_file permissive=1
[  627.692488] type=1400 audit(1596266296.009:271): avc: denied { read } for pid=6910 comm="tmp-mksh" name="home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[  629.631672] type=1400 audit(1596266296.009:271): avc: denied { read } for pid=6910 comm="tmp-mksh" name="home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[  629.647745] type=1400 audit(1596266297.965:272): avc: denied { read write } for pid=6911 comm="ls" path="/dev/pts/1" dev="devpts" ino=4 scontext=u:r:toolbox:s0 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  629.673004] type=1400 audit(1596266297.965:272): avc: denied { read write } for pid=6911 comm="ls" path="/dev/pts/1" dev="devpts" ino=4 scontext=u:r:toolbox:s0 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  629.693041] type=1400 audit(1596266298.005:273): avc: denied { dac_override } for pid=6911 comm="ls" capability=1 scontext=u:r:toolbox:s0 tcontext=u:r:toolbox:s0 tclass=capability permissive=1
[  629.710413] type=1400 audit(1596266298.005:273): avc: denied { dac_override } for pid=6911 comm="ls" capability=1 scontext=u:r:toolbox:s0 tcontext=u:r:toolbox:s0 tclass=capability permissive=1
[  629.727797] type=1400 audit(1596266298.005:274): avc: denied { getattr } for pid=6911 comm="ls" path="/data/data/com.termux/files/home" dev="mmcblk0p20" ino=1053540 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[  629.751751] type=1400 audit(1596266298.005:274): avc: denied { getattr } for pid=6911 comm="ls" path="/data/data/com.termux/files/home" dev="mmcblk0p20" ino=1053540 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[  629.775511] type=1400 audit(1596266298.005:275): avc: denied { read } for pid=6911 comm="ls" name="home" dev="mmcblk0p20" ino=1053540 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[  642.440981] type=1400 audit(1596266298.005:277): avc: denied { getattr } for pid=6911 comm="ls" path="/data/data/com.termux/files/home/.bash_history" dev="mmcblk0p20" ino=1053913 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[  642.460750] type=1400 audit(1596266310.773:278): avc: denied { getattr } for pid=6913 comm="ls" path="/storage" dev="tmpfs" ino=1266 scontext=u:r:toolbox:s0 tcontext=u:object_r:storage_file:s0 tclass=dir permissive=1
[  642.480210] type=1400 audit(1596266310.773:278): avc: denied { getattr } for pid=6913 comm="ls" path="/storage" dev="tmpfs" ino=1266 scontext=u:r:toolbox:s0 tcontext=u:object_r:storage_file:s0 tclass=dir permissive=1
[  642.499370] type=1400 audit(1596266310.773:279): avc: denied { read } for pid=6913 comm="ls" name="default" dev="tmpfs" ino=1266 scontext=u:r:toolbox:s0 tcontext=u:object_r:storage_file:s0 tclass=dir permissive=1
[  642.524483] type=1400 audit(1596266310.773:279): avc: denied { read } for pid=6913 comm="ls" name="default" dev="tmpfs" ino=1266 scontext=u:r:toolbox:s0 tcontext=u:object_r:storage_file:s0 tclass=dir permissive=1
[  642.537978] type=1400 audit(1596266310.773:280): avc: denied { open } for pid=6913 comm="ls" path="/storage" dev="tmpfs" ino=1266 scontext=u:r:toolbox:s0 tcontext=u:object_r:storage_file:s0 tclass=dir permissive=1
[  642.557164] type=1400 audit(1596266310.773:280): avc: denied { open } for pid=6913 comm="ls" path="/storage" dev="tmpfs" ino=1266 scontext=u:r:toolbox:s0 tcontext=u:object_r:storage_file:s0 tclass=dir permissive=1
[  642.576047] type=1400 audit(1596266310.773:281): avc: denied { getattr } for pid=6913 comm="ls" path="/data/media" dev="mmcblk0p20" ino=3276802 scontext=u:r:toolbox:s0 tcontext=u:object_r:media_rw_data_file:s0 tclass=dir permissive=1
[  646.970966] type=1400 audit(1596266310.773:281): avc: denied { getattr } for pid=6913 comm="ls" path="/data/media" dev="mmcblk0p20" ino=3276802 scontext=u:r:toolbox:s0 tcontext=u:object_r:media_rw_data_file:s0 tclass=dir permissive=1
[  646.986741] type=1400 audit(1596266315.305:282): avc: denied { read } for pid=6914 comm="ls" name="/" dev="sdcardfs" ino=3276802 scontext=u:r:toolbox:s0 tcontext=u:object_r:sdcardfs:s0 tclass=dir permissive=1
[  648.829145] type=1400 audit(1596266315.305:286): avc: denied { setattr } for pid=6914 comm="ls" name="obb" dev="mmcblk0p20" ino=3276803 scontext=u:r:toolbox:s0 tcontext=u:object_r:media_rw_data_file:s0 tclass=dir permissive=1
[  648.832676] audit: audit_lost=147 audit_rate_limit=5 audit_backlog_limit=64
[  648.832679] audit: rate limit exceeded
[  648.854740] type=1400 audit(1596266317.161:287): avc: denied { getattr } for pid=6915 comm="df" path="/mnt/vendor/param" dev="mmcblk0p10" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  648.875429] type=1400 audit(1596266317.161:287): avc: denied { getattr } for pid=6915 comm="df" path="/mnt/vendor/param" dev="mmcblk0p10" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  648.895593] type=1400 audit(1596266317.165:288): avc: denied { getattr } for pid=6915 comm="df" path="/cache" dev="mmcblk0p3" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=1
[  648.914726] type=1400 audit(1596266317.165:288): avc: denied { getattr } for pid=6915 comm="df" path="/cache" dev="mmcblk0p3" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=1
[  648.933659] type=1400 audit(1596266317.165:289): avc: denied { getattr } for pid=6915 comm="df" path="/metadata" dev="mmcblk0p13" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[  648.953386] type=1400 audit(1596266317.165:289): avc: denied { getattr } for pid=6915 comm="df" path="/metadata" dev="mmcblk0p13" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[  648.972999] type=1400 audit(1596266317.165:290): avc: denied { getattr } for pid=6915 comm="df" path="/dev/block" dev="tmpfs" ino=458 scontext=u:r:toolbox:s0 tcontext=u:object_r:block_device:s0 tclass=dir permissive=1
[  648.992583] type=1400 audit(1596266317.165:290): avc: denied { getattr } for pid=6915 comm="df" path="/dev/block" dev="tmpfs" ino=458 scontext=u:r:toolbox:s0 tcontext=u:object_r:block_device:s0 tclass=dir permissive=1
[  649.011851] type=1400 audit(1596266317.165:291): avc: denied { getattr } for pid=6915 comm="df" path="/dev/block/param" dev="tmpfs" ino=14337 scontext=u:r:toolbox:s0 tcontext=u:object_r:param_block_device:s0 tclass=blk_file permissive=1
[  655.512375] type=1400 audit(1596266317.165:295): avc: denied { getattr } for pid=6915 comm="df" path="/dev/block/odm" dev="tmpfs" ino=468 scontext=u:r:toolbox:s0 tcontext=u:object_r:odm_block_device:s0 tclass=blk_file permissive=1
[  655.527621] type=1400 audit(1596266323.845:301): avc: denied { getattr } for pid=6916 comm="dboxed_process1" path="/data/data/com.android.chrome" dev="mmcblk0p20" ino=786664 scontext=u:r:isolated_app:s0:c1,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1
[  655.609029] type=1400 audit(1596266323.845:301): avc: denied { getattr } for pid=6916 comm="dboxed_process1" path="/data/data/com.android.chrome" dev="mmcblk0p20" ino=786664 scontext=u:r:isolated_app:s0:c1,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1
[  655.630239] type=1400 audit(1596266323.941:302): avc: denied { setattr } for pid=6916 comm="CrUtilityMain" name="commands.json" dev="mmcblk0p20" ino=787979 scontext=u:r:isolated_app:s0:c1,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=file permissive=1
[  655.703043] type=1400 audit(1596266323.941:302): avc: denied { setattr } for pid=6916 comm="CrUtilityMain" name="commands.json" dev="mmcblk0p20" ino=787979 scontext=u:r:isolated_app:s0:c1,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=file permissive=1
[  655.722022] type=1400 audit(1596266324.037:303): avc: denied { getattr } for pid=6938 comm="dboxed_process2" path="/data/data/com.android.chrome" dev="mmcblk0p20" ino=786664 scontext=u:r:isolated_app:s0:c2,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1
[  655.830992] binder: undelivered transaction 277318, process died.
[  655.831625] binder: undelivered transaction 277319, process died.
[  655.840681] binder: undelivered transaction 277317, process died.
[  655.879154] type=1400 audit(1596266324.037:303): avc: denied { getattr } for pid=6938 comm="dboxed_process2" path="/data/data/com.android.chrome" dev="mmcblk0p20" ino=786664 scontext=u:r:isolated_app:s0:c2,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1
[  655.899597] type=1400 audit(1596266324.213:304): avc: denied { getattr } for pid=6957 comm="dboxed_process3" path="/data/data/com.android.chrome" dev="mmcblk0p20" ino=786664 scontext=u:r:isolated_app:s0:c3,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1
[  655.993128] binder: undelivered transaction 277424, process died.
[  655.993777] binder: undelivered transaction 277425, process died.
[  656.005611] binder: undelivered transaction 277423, process died.
[  656.555745] type=1400 audit(1596266324.213:304): avc: denied { getattr } for pid=6957 comm="dboxed_process3" path="/data/data/com.android.chrome" dev="mmcblk0p20" ino=786664 scontext=u:r:isolated_app:s0:c3,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1
[  656.576362] type=1400 audit(1596266324.889:305): avc: denied { getattr } for pid=6977 comm="dboxed_process4" path="/data/data/com.android.chrome" dev="mmcblk0p20" ino=786664 scontext=u:r:isolated_app:s0:c4,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1
[  656.674201] binder: undelivered transaction 277602, process died.
[  656.674828] binder: undelivered transaction 277603, process died.
[  656.681477] binder: undelivered transaction 277601, process died.
[  657.727907] binder: undelivered transaction 277831, process died.
[  704.767410] type=1400 audit(1596266326.301:310): avc: denied { getattr } for pid=7036 comm="dboxed_process7" path="/data/data/com.android.chrome" dev="mmcblk0p20" ino=786664 scontext=u:r:isolated_app:s0:c7,c256,c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1
[  704.787983] type=1400 audit(1596266373.101:311): avc: denied { read write } for pid=7057 comm="ls" path="/dev/pts/1" dev="devpts" ino=4 scontext=u:r:toolbox:s0 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  704.800717] audit: audit_lost=152 audit_rate_limit=5 audit_backlog_limit=64
[  704.800721] audit: rate limit exceeded
[  704.821626] type=1400 audit(1596266373.101:311): avc: denied { read write } for pid=7057 comm="ls" path="/dev/pts/1" dev="devpts" ino=4 scontext=u:r:toolbox:s0 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  704.844255] type=1400 audit(1596266373.133:312): avc: denied { dac_override } for pid=7057 comm="ls" capability=1 scontext=u:r:toolbox:s0 tcontext=u:r:toolbox:s0 tclass=capability permissive=1
[  704.861665] type=1400 audit(1596266373.133:312): avc: denied { dac_override } for pid=7057 comm="ls" capability=1 scontext=u:r:toolbox:s0 tcontext=u:r:toolbox:s0 tclass=capability permissive=1
[  704.878719] type=1400 audit(1596266373.133:313): avc: denied { read } for pid=7057 comm="ls" name="/" dev="mmcblk1p1" ino=1 scontext=u:r:toolbox:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[  704.896691] type=1400 audit(1596266373.133:313): avc: denied { read } for pid=7057 comm="ls" name="/" dev="mmcblk1p1" ino=1 scontext=u:r:toolbox:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[  704.914354] type=1400 audit(1596266373.133:314): avc: denied { open } for pid=7057 comm="ls" path="/mnt/media_rw/1106-2008" dev="mmcblk1p1" ino=1 scontext=u:r:toolbox:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[  704.934227] type=1400 audit(1596266373.133:314): avc: denied { open } for pid=7057 comm="ls" path="/mnt/media_rw/1106-2008" dev="mmcblk1p1" ino=1 scontext=u:r:toolbox:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[  704.953844] type=1400 audit(1596266373.133:315): avc: denied { getattr } for pid=7057 comm="ls" path="/mnt/media_rw" dev="tmpfs" ino=1260 scontext=u:r:toolbox:s0 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=1
[  735.276618] type=1400 audit(1596266373.133:315): avc: denied { getattr } for pid=7057 comm="ls" path="/mnt/media_rw" dev="tmpfs" ino=1260 scontext=u:r:toolbox:s0 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=1
[  735.291590] type=1400 audit(1596266403.609:317): avc: denied { read } for pid=6910 comm="tmp-mksh" name="home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[  735.312214] audit: audit_lost=153 audit_rate_limit=5 audit_backlog_limit=64
[  735.312217] audit: rate limit exceeded
[  735.323892] type=1400 audit(1596266403.609:317): avc: denied { read } for pid=6910 comm="tmp-mksh" name="home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[  735.345197] type=1400 audit(1596266403.609:318): avc: denied { open } for pid=6910 comm="tmp-mksh" path="/data/data/com.termux/files/home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[  735.369168] type=1400 audit(1596266403.609:318): avc: denied { open } for pid=6910 comm="tmp-mksh" path="/data/data/com.termux/files/home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[  735.392929] type=1400 audit(1596266403.645:319): avc: denied { getattr } for pid=7058 comm="cp" path="/data/data/com.termux/files/home/a" dev="mmcblk0p20" ino=1052963 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[  735.417224] type=1400 audit(1596266403.645:319): avc: denied { getattr } for pid=7058 comm="cp" path="/data/data/com.termux/files/home/a" dev="mmcblk0p20" ino=1052963 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[  735.440981] type=1400 audit(1596266403.645:320): avc: denied { read } for pid=7058 comm="cp" name="a" dev="mmcblk0p20" ino=1052963 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[  735.462115] type=1400 audit(1596266403.645:320): avc: denied { read } for pid=7058 comm="cp" name="a" dev="mmcblk0p20" ino=1052963 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[  735.482894] type=1400 audit(1596266403.645:321): avc: denied { open } for pid=7058 comm="cp" path="/data/data/com.termux/files/home/a" dev="mmcblk0p20" ino=1052963 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[  770.358347] type=1400 audit(1596266403.645:321): avc: denied { open } for pid=7058 comm="cp" path="/data/data/com.termux/files/home/a" dev="mmcblk0p20" ino=1052963 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[  770.376798] type=1400 audit(1596266438.693:326): avc: denied { write } for pid=6910 comm="tmp-mksh" name="/" dev="mmcblk1p1" ino=1 scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[  770.395309] type=1400 audit(1596266438.693:326): avc: denied { write } for pid=6910 comm="tmp-mksh" name="/" dev="mmcblk1p1" ino=1 scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[  770.413188] type=1400 audit(1596266438.693:327): avc: denied { add_name } for pid=6910 comm="tmp-mksh" name="uname.txt" scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[  770.430528] type=1400 audit(1596266438.693:327): avc: denied { add_name } for pid=6910 comm="tmp-mksh" name="uname.txt" scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[  770.447662] type=1400 audit(1596266438.693:328): avc: denied { create } for pid=6910 comm="tmp-mksh" name="uname.txt" scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=file permissive=1
[  770.464860] type=1400 audit(1596266438.693:328): avc: denied { create } for pid=6910 comm="tmp-mksh" name="uname.txt" scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=file permissive=1
[  770.481910] type=1400 audit(1596266438.709:329): avc: denied { write open } for pid=6910 comm="tmp-mksh" path="/mnt/media_rw/1106-2008/uname.txt" dev="mmcblk1p1" ino=489 scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=file permissive=1
[  800.622505] type=1400 audit(1596266438.709:329): avc: denied { write open } for pid=6910 comm="tmp-mksh" path="/mnt/media_rw/1106-2008/uname.txt" dev="mmcblk1p1" ino=489 scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=file permissive=1
[  800.638943] type=1400 audit(1596266468.957:330): avc: denied { ioctl } for pid=7062 comm="mc" path="/dev/pts/0" dev="devpts" ino=3 ioctlcmd=0x541c scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  812.708197] type=1400 audit(1596266468.957:330): avc: denied { ioctl } for pid=7062 comm="mc" path="/dev/pts/0" dev="devpts" ino=3 ioctlcmd=0x541c scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[  812.729032] type=1400 audit(1596266481.041:331): avc: denied { write } for pid=7068 comm="sh" name="appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  812.748165] type=1400 audit(1596266481.041:331): avc: denied { write } for pid=7068 comm="sh" name="appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  812.767344] type=1400 audit(1596266481.041:332): avc: denied { open } for pid=7068 comm="sh" path="/sys/devices/platform/meson-vfd/attr/appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  823.260745] type=1400 audit(1596266481.041:332): avc: denied { open } for pid=7068 comm="sh" path="/sys/devices/platform/meson-vfd/attr/appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  823.277225] type=1400 audit(1596266491.593:333): avc: denied { write } for pid=7106 comm="sh" name="appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  823.297381] type=1400 audit(1596266491.593:333): avc: denied { write } for pid=7106 comm="sh" name="appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  823.314808] type=1400 audit(1596266491.593:334): avc: denied { open } for pid=7106 comm="sh" path="/sys/devices/platform/meson-vfd/attr/appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  837.554942] aml_tdm_open
[  837.556157] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[  837.556281] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  837.556286] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  837.556294] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  837.556301] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[  837.556305] aml_dai_set_tdm_fmt(), fmt not change
[  837.556312] dump_pcm_setting(ed56df10)
[  837.556315] \x09pcm_mode(1)
[  837.556318] \x09sysclk(12288000)
[  837.556321] \x09sysclk_bclk_ratio(4)
[  837.556325] \x09bclk(3072000)
[  837.556328] \x09bclk_lrclk_ratio(64)
[  837.556331] \x09lrclk(48000)
[  837.556334] \x09tx_mask(0x3)
[  837.556337] \x09rx_mask(0x3)
[  837.556340] \x09slots(2)
[  837.556343] \x09slot_width(32)
[  837.556346] \x09lane_mask_in(0x2)
[  837.556350] \x09lane_mask_out(0x1)
[  837.556353] \x09lane_oe_mask_in(0x0)
[  837.556356] \x09lane_oe_mask_out(0x0)
[  837.556359] \x09lane_lb_mask_in(0x0)
[  837.556362] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[  837.556366] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[  837.556371] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[  837.556375] aml_dai_set_clkdiv, div 4, clksel(1)
[  837.556386] aml_dai_set_bclk_ratio, select I2S mode
[  837.556400] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[  837.556456] aml_tdm_prepare(), reset fddr
[  837.556477] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[  837.556486] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[  837.556498] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  837.556873] tdm playback mute: 0, lane_cnt = 8
[  837.560881] asoc-aml-card auge_sound: tdm playback enable
[  837.560968] spdif_a is set to enable
[  840.696575] asoc-aml-card auge_sound: tdm playback stop
[  840.696633] spdif_a is set to disable
[  841.634647] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[  841.634658] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[  841.634704] tdm playback mute: 1, lane_cnt = 8
[  841.634916] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[  845.714065] type=1400 audit(1596266491.593:334): avc: denied { open } for pid=7106 comm="sh" path="/sys/devices/platform/meson-vfd/attr/appled" dev="sysfs" ino=10168 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  845.731227] type=1400 audit(1596266514.049:335): avc: denied { read } for pid=7157 comm="ls" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  845.751076] type=1400 audit(1596266514.049:335): avc: denied { read } for pid=7157 comm="ls" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  845.771977] type=1400 audit(1596266514.049:336): avc: denied { open } for pid=7157 comm="ls" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  845.791823] type=1400 audit(1596266514.049:336): avc: denied { open } for pid=7157 comm="ls" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[  845.811943] type=1400 audit(1596266514.049:337): avc: denied { getattr } for pid=7157 comm="ls" path="/init.usb.configfs.rc" dev="mmcblk0p18" ino=2612 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[  845.834704] type=1400 audit(1596266514.049:337): avc: denied { getattr } for pid=7157 comm="ls" path="/init.usb.configfs.rc" dev="mmcblk0p18" ino=2612 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[  845.857087] type=1400 audit(1596266514.049:338): avc: denied { getattr } for pid=7157 comm="ls" path="/init" dev="mmcblk0p18" ino=2623 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:init_exec:s0 tclass=file permissive=1
[  845.878490] type=1400 audit(1596266514.049:338): avc: denied { getattr } for pid=7157 comm="ls" path="/init" dev="mmcblk0p18" ino=2623 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:init_exec:s0 tclass=file permissive=1
[  845.899787] type=1400 audit(1596266514.049:339): avc: denied { getattr } for pid=7157 comm="ls" path="/metadata" dev="mmcblk0p13" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[  850.593147] audit: audit_lost=157 audit_rate_limit=5 audit_backlog_limit=64
[  850.594678] audit: rate limit exceeded
[  865.641066] type=1400 audit(1596266518.925:345): avc: denied { getattr } for pid=7158 comm="ls" path="/dev/snd" dev="tmpfs" ino=12569 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:audio_device:s0 tclass=dir permissive=1
[  865.646709] audit: audit_lost=160 audit_rate_limit=5 audit_backlog_limit=64
[  865.646712] audit: rate limit exceeded
[  865.668148] type=1400 audit(1596266533.973:349): avc: denied { getattr } for pid=7159 comm="find" path="/mnt/media_rw" dev="tmpfs" ino=1260 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=1
[  865.692041] type=1400 audit(1596266533.973:349): avc: denied { getattr } for pid=7159 comm="find" path="/mnt/media_rw" dev="tmpfs" ino=1260 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=1
[  865.713326] type=1400 audit(1596266533.981:350): avc: denied { getattr } for pid=7159 comm="find" path="/mnt/vendor" dev="tmpfs" ino=456 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  865.735315] type=1400 audit(1596266533.981:350): avc: denied { getattr } for pid=7159 comm="find" path="/mnt/vendor" dev="tmpfs" ino=456 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  865.757210] type=1400 audit(1596266533.981:351): avc: denied { read } for pid=7159 comm="find" name="vendor" dev="tmpfs" ino=456 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  865.778515] type=1400 audit(1596266533.981:351): avc: denied { read } for pid=7159 comm="find" name="vendor" dev="tmpfs" ino=456 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  865.799587] type=1400 audit(1596266533.981:352): avc: denied { open } for pid=7159 comm="find" path="/mnt/vendor" dev="tmpfs" ino=456 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  865.821427] type=1400 audit(1596266533.981:352): avc: denied { open } for pid=7159 comm="find" path="/mnt/vendor" dev="tmpfs" ino=456 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:param_tv_file:s0 tclass=dir permissive=1
[  865.842944] type=1400 audit(1596266533.981:353): avc: denied { getattr } for pid=7159 comm="find" path="/mnt/vendor/tee" dev="mmcblk0p15" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[  866.733379] audit: audit_lost=183 audit_rate_limit=5 audit_backlog_limit=64
[  866.735196] audit: rate limit exceeded
[  867.807584] audit: audit_lost=295 audit_rate_limit=5 audit_backlog_limit=64
[  867.809159] audit: rate limit exceeded
[  869.005429] audit: audit_lost=356 audit_rate_limit=5 audit_backlog_limit=64
[  869.007350] audit: rate limit exceeded
[  870.324730] audit: audit_lost=372 audit_rate_limit=5 audit_backlog_limit=64
[  870.326659] audit: rate limit exceeded
[  871.675065] type=1400 audit(1596266538.657:585): avc: denied { read } for pid=7159 comm="find" name="4271" dev="proc" ino=32466 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:mediaprovider:s0:c512,c768 tclass=dir permissive=1
[  871.691556] type=1400 audit(1596266540.009:587): avc: denied { getattr } for pid=7159 comm="find" path="/proc/5929" dev="proc" ino=48202 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c65,c256,c512,c768 tclass=dir permissive=1
[  871.714270] type=1400 audit(1596266540.009:587): avc: denied { getattr } for pid=7159 comm="find" path="/proc/5929" dev="proc" ino=48202 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c65,c256,c512,c768 tclass=dir permissive=1
[  871.736943] type=1400 audit(1596266540.009:588): avc: denied { read } for pid=7159 comm="find" name="5929" dev="proc" ino=48202 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c65,c256,c512,c768 tclass=dir permissive=1
[  872.646345] type=1400 audit(1596266540.009:588): avc: denied { read } for pid=7159 comm="find" name="5929" dev="proc" ino=48202 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c65,c256,c512,c768 tclass=dir permissive=1
[  872.663378] type=1400 audit(1596266540.981:589): avc: denied { getattr } for pid=7159 comm="find" path="/metadata" dev="mmcblk0p13" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[  872.667910] audit: audit_lost=373 audit_rate_limit=5 audit_backlog_limit=64
[  872.667913] audit: rate limit exceeded
[  872.696932] type=1400 audit(1596266540.981:589): avc: denied { getattr } for pid=7159 comm="find" path="/metadata" dev="mmcblk0p13" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[  872.718160] type=1400 audit(1596266540.981:590): avc: denied { read } for pid=7159 comm="find" name="/" dev="mmcblk0p13" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[  872.739587] type=1400 audit(1596266540.981:590): avc: denied { read } for pid=7159 comm="find" name="/" dev="mmcblk0p13" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[  872.760513] type=1400 audit(1596266540.981:591): avc: denied { open } for pid=7159 comm="find" path="/metadata" dev="mmcblk0p13" ino=2 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[  881.206444] type=1400 audit(1596266541.101:613): avc: denied { read } for pid=7159 comm="find" name="wakeup_reasons" dev="sysfs" ino=21725 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_wakeup_reasons:s0 tclass=dir permissive=1
[  881.225733] type=1400 audit(1596266549.541:686): avc: denied { getattr } for pid=7166 comm="ls" path="/sys/firmware/fdt" dev="sysfs" ino=22045 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  977.112198] type=1400 audit(1596266549.541:686): avc: denied { getattr } for pid=7166 comm="ls" path="/sys/firmware/fdt" dev="sysfs" ino=22045 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  977.130522] type=1400 audit(1596266645.445:687): avc: denied { read } for pid=7169 comm="dtc" name="compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  977.150445] type=1400 audit(1596266645.445:687): avc: denied { read } for pid=7169 comm="dtc" name="compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  977.171018] type=1400 audit(1596266645.445:688): avc: denied { open } for pid=7169 comm="dtc" path="/sys/firmware/devicetree/base/codec_mm/compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  977.242527] type=1400 audit(1596266645.445:688): avc: denied { open } for pid=7169 comm="dtc" path="/sys/firmware/devicetree/base/codec_mm/compatible" dev="sysfs" ino=2876 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[  977.261485] type=1400 audit(1596266645.577:689): avc: denied { getattr } for pid=7169 comm="dtc" path="/sys/firmware/devicetree/base/firmware/android/compatible" dev="sysfs" ino=2383 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=file permissive=1
[  977.294536] type=1400 audit(1596266645.577:689): avc: denied { getattr } for pid=7169 comm="dtc" path="/sys/firmware/devicetree/base/firmware/android/compatible" dev="sysfs" ino=2383 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=file permissive=1
[  977.316076] type=1400 audit(1596266645.577:690): avc: denied { read } for pid=7169 comm="dtc" name="compatible" dev="sysfs" ino=2383 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=file permissive=1
[  977.338905] type=1400 audit(1596266645.577:690): avc: denied { read } for pid=7169 comm="dtc" name="compatible" dev="sysfs" ino=2383 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=file permissive=1
[  977.361623] type=1400 audit(1596266645.577:691): avc: denied { open } for pid=7169 comm="dtc" path="/sys/firmware/devicetree/base/firmware/android/compatible" dev="sysfs" ino=2383 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=file permissive=1
[ 1072.920494] type=1400 audit(1596266645.577:691): avc: denied { open } for pid=7169 comm="dtc" path="/sys/firmware/devicetree/base/firmware/android/compatible" dev="sysfs" ino=2383 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:sysfs_dt_firmware_android:s0 tclass=file permissive=1
[ 1072.941793] type=1400 audit(1596266741.253:692): avc: denied { read } for pid=7181 comm="su" name="enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[ 1072.945787] audit: audit_lost=462 audit_rate_limit=5 audit_backlog_limit=64
[ 1072.945790] audit: rate limit exceeded
[ 1072.974045] type=1400 audit(1596266741.253:692): avc: denied { read } for pid=7181 comm="su" name="enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[ 1072.994945] type=1400 audit(1596266741.253:693): avc: denied { open } for pid=7181 comm="su" path="/sys/fs/selinux/enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[ 1073.017668] type=1400 audit(1596266741.253:693): avc: denied { open } for pid=7181 comm="su" path="/sys/fs/selinux/enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[ 1073.039842] type=1400 audit(1596266741.253:694): avc: denied { connectto } for pid=7181 comm="su" path=0065752E636861696E666972652E73757065727375 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:init:s0 tclass=unix_stream_socket permissive=1
[ 1073.068566] type=1400 audit(1596266741.253:694): avc: denied { connectto } for pid=7181 comm="su" path=0065752E636861696E666972652E73757065727375 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:init:s0 tclass=unix_stream_socket permissive=1
[ 1073.085684] type=1400 audit(1596266741.257:695): avc: denied { sys_ptrace } for pid=3359 comm="su" capability=19 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=1
[ 1073.102422] type=1400 audit(1596266741.257:695): avc: denied { sys_ptrace } for pid=3359 comm="su" capability=19 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=1
[ 1073.118969] type=1400 audit(1596266741.257:696): avc: denied { read write } for pid=6902 comm="su" name="1" dev="devpts" ino=4 scontext=u:r:init:s0 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[ 1081.169478] type=1400 audit(1596266741.269:700): avc: denied { execute_no_trans } for pid=7189 comm="su" path="/tmp-mksh/tmp-mksh" dev="mmcblk0p18" ino=2627 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 1081.184827] type=1400 audit(1596266749.501:705): avc: denied { ioctl } for pid=7199 comm="tmp-mksh" path="/dev/pts/2" dev="devpts" ino=5 ioctlcmd=0x5401 scontext=u:r:init:s0 tcontext=u:object_r:devpts:s0 tclass=chr_file permissive=1
[ 1084.922088] type=1400 audit(1596266749.501:705): avc: denied { ioctl } for pid=7199 comm="tmp-mksh" path="/dev/pts/2" dev="devpts" ino=5 ioctlcmd=0x5401 scontext=u:r:init:s0 tcontext=u:object_r:devpts:s0 tclass=chr_file permissive=1
[ 1084.937842] type=1400 audit(1596266753.257:706): avc: denied { read } for pid=7199 comm="tmp-mksh" name="home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[ 1084.959273] type=1400 audit(1596266753.257:706): avc: denied { read } for pid=7199 comm="tmp-mksh" name="home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[ 1084.980588] type=1400 audit(1596266753.257:707): avc: denied { open } for pid=7199 comm="tmp-mksh" path="/data/data/com.termux/files/home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[ 1085.004431] type=1400 audit(1596266753.257:707): avc: denied { open } for pid=7199 comm="tmp-mksh" path="/data/data/com.termux/files/home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[ 1085.028569] type=1400 audit(1596266753.257:708): avc: denied { getattr } for pid=7199 comm="tmp-mksh" path="/data/data/com.termux/files/home/x96maxp2.dtb" dev="mmcblk0p20" ino=1052969 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1 b/77873135
[ 1092.023998] type=1400 audit(1596266753.257:708): avc: denied { getattr } for pid=7199 comm="tmp-mksh" path="/data/data/com.termux/files/home/x96maxp2.dtb" dev="mmcblk0p20" ino=1052969 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1 b/77873135
[ 1092.045095] type=1400 audit(1596266760.357:709): avc: denied { getattr } for pid=7200 comm="cp" path="/data/data/com.termux/files/home/x96maxp2.dtb" dev="mmcblk0p20" ino=1052969 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[ 1092.070109] audit: audit_lost=466 audit_rate_limit=5 audit_backlog_limit=64
[ 1092.070596] type=1400 audit(1596266760.357:709): avc: denied { getattr } for pid=7200 comm="cp" path="/data/data/com.termux/files/home/x96maxp2.dtb" dev="mmcblk0p20" ino=1052969 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[ 1092.070624] type=1400 audit(1596266760.357:710): avc: denied { read } for pid=7200 comm="cp" name="x96maxp2.dtb" dev="mmcblk0p20" ino=1052969 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[ 1092.070748] type=1400 audit(1596266760.357:710): avc: denied { read } for pid=7200 comm="cp" name="x96maxp2.dtb" dev="mmcblk0p20" ino=1052969 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[ 1092.070768] type=1400 audit(1596266760.357:711): avc: denied { open } for pid=7200 comm="cp" path="/data/data/com.termux/files/home/x96maxp2.dtb" dev="mmcblk0p20" ino=1052969 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[ 1092.070840] type=1400 audit(1596266760.357:711): avc: denied { open } for pid=7200 comm="cp" path="/data/data/com.termux/files/home/x96maxp2.dtb" dev="mmcblk0p20" ino=1052969 scontext=u:r:toolbox:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=file permissive=1
[ 1092.070856] type=1400 audit(1596266760.357:712): avc: denied { write } for pid=7200 comm="cp" name="/" dev="mmcblk1p1" ino=1 scontext=u:r:toolbox:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[ 1092.071040] type=1400 audit(1596266760.357:712): avc: denied { write } for pid=7200 comm="cp" name="/" dev="mmcblk1p1" ino=1 scontext=u:r:toolbox:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[ 1092.071059] type=1400 audit(1596266760.357:713): avc: denied { add_name } for pid=7200 comm="cp" name="x96maxp2.dtb" scontext=u:r:toolbox:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[ 1092.248442] audit: rate limit exceeded
[ 1097.687634] type=1400 audit(1596266760.357:714): avc: denied { create } for pid=7200 comm="cp" name="x96maxp2.dtb" scontext=u:r:toolbox:s0 tcontext=u:object_r:vfat:s0 tclass=file permissive=1
[ 1097.699315] type=1400 audit(1596266766.021:716): avc: denied { read } for pid=7199 comm="tmp-mksh" name="primary" dev="tmpfs" ino=1273 scontext=u:r:init:s0 tcontext=u:object_r:storage_file:s0 tclass=lnk_file permissive=1
[ 1097.719450] type=1400 audit(1596266766.021:716): avc: denied { read } for pid=7199 comm="tmp-mksh" name="primary" dev="tmpfs" ino=1273 scontext=u:r:init:s0 tcontext=u:object_r:storage_file:s0 tclass=lnk_file permissive=1
[ 1097.738724] type=1400 audit(1596266766.021:717): avc: denied { read } for pid=7199 comm="tmp-mksh" name="primary" dev="tmpfs" ino=32312 scontext=u:r:init:s0 tcontext=u:object_r:mnt_user_file:s0 tclass=lnk_file permissive=1
[ 1097.758688] type=1400 audit(1596266766.021:717): avc: denied { read } for pid=7199 comm="tmp-mksh" name="primary" dev="tmpfs" ino=32312 scontext=u:r:init:s0 tcontext=u:object_r:mnt_user_file:s0 tclass=lnk_file permissive=1
[ 1097.778405] type=1400 audit(1596266766.021:718): avc: denied { search } for pid=7199 comm="tmp-mksh" name="/" dev="sdcardfs" ino=3276802 scontext=u:r:init:s0 tcontext=u:object_r:sdcardfs:s0 tclass=dir permissive=1
[ 1107.494934] logd: logdr: UID=10003 GID=10003 PID=4094 n tail=0 logMask=4 pid=0 start=1596266775724000000ns timeout=1596273975826089309ns
[ 1114.487558] aml_tdm_open
[ 1114.487908] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[ 1114.488003] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[ 1114.488005] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[ 1114.488010] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[ 1114.488014] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[ 1114.488017] aml_dai_set_tdm_fmt(), fmt not change
[ 1114.488022] dump_pcm_setting(ed56df10)
[ 1114.488024] \x09pcm_mode(1)
[ 1114.488025] \x09sysclk(12288000)
[ 1114.488027] \x09sysclk_bclk_ratio(4)
[ 1114.488030] \x09bclk(3072000)
[ 1114.488031] \x09bclk_lrclk_ratio(64)
[ 1114.488033] \x09lrclk(48000)
[ 1114.488035] \x09tx_mask(0x3)
[ 1114.488036] \x09rx_mask(0x3)
[ 1114.488038] \x09slots(2)
[ 1114.488040] \x09slot_width(32)
[ 1114.488041] \x09lane_mask_in(0x2)
[ 1114.488043] \x09lane_mask_out(0x1)
[ 1114.488045] \x09lane_oe_mask_in(0x0)
[ 1114.488046] \x09lane_oe_mask_out(0x0)
[ 1114.488048] \x09lane_lb_mask_in(0x0)
[ 1114.488050] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[ 1114.488052] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[ 1114.488054] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[ 1114.488057] aml_dai_set_clkdiv, div 4, clksel(1)
[ 1114.488064] aml_dai_set_bclk_ratio, select I2S mode
[ 1114.488074] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[ 1114.488113] aml_tdm_prepare(), reset fddr
[ 1114.488127] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[ 1114.488132] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[ 1114.488142] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[ 1114.488346] tdm playback mute: 0, lane_cnt = 8
[ 1114.499139] asoc-aml-card auge_sound: tdm playback enable
[ 1114.499186] spdif_a is set to enable
[ 1117.634889] asoc-aml-card auge_sound: tdm playback stop
[ 1117.635056] spdif_a is set to disable
[ 1118.575198] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[ 1118.575241] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[ 1118.575367] tdm playback mute: 1, lane_cnt = 8
[ 1118.576453] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[ 1130.932864] aml_tdm_open
[ 1130.933267] audio_ddr_mngr: frddrs[0] registered by device ff660000.audiobus:tdm@1
[ 1130.933372] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[ 1130.933377] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[ 1130.933385] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[ 1130.933392] asoc aml_dai_set_tdm_fmt, 0x4001, ed56df10, id(1), clksel(1)
[ 1130.933396] aml_dai_set_tdm_fmt(), fmt not change
[ 1130.933403] dump_pcm_setting(ed56df10)
[ 1130.933406] \x09pcm_mode(1)
[ 1130.933409] \x09sysclk(12288000)
[ 1130.933413] \x09sysclk_bclk_ratio(4)
[ 1130.933416] \x09bclk(3072000)
[ 1130.933419] \x09bclk_lrclk_ratio(64)
[ 1130.933422] \x09lrclk(48000)
[ 1130.933425] \x09tx_mask(0x3)
[ 1130.933428] \x09rx_mask(0x3)
[ 1130.933431] \x09slots(2)
[ 1130.933434] \x09slot_width(32)
[ 1130.933438] \x09lane_mask_in(0x2)
[ 1130.933441] \x09lane_mask_out(0x1)
[ 1130.933444] \x09lane_oe_mask_in(0x0)
[ 1130.933447] \x09lane_oe_mask_out(0x0)
[ 1130.933450] \x09lane_lb_mask_in(0x0)
[ 1130.933453] aml_dai_set_tdm_sysclk(), mpll no change, keep clk
[ 1130.933456] aml_dai_set_tdm_sysclk(), mclk no change, keep clk
[ 1130.933462] set mclk:12288000, mpll:24576000, get mclk:12287994, mpll:24575987
[ 1130.933466] aml_dai_set_clkdiv, div 4, clksel(1)
[ 1130.933476] aml_dai_set_bclk_ratio, select I2S mode
[ 1130.933489] aml_dai_tdm_hw_params(), enable mclk for TDM-B
[ 1130.933599] aml_tdm_prepare(), reset fddr
[ 1130.933621] spdif_a fifo ctrl, frddr:0 type:1, 16 bits, chmask 0x3, swap 0x10
[ 1130.933630] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[ 1130.933643] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[ 1130.934681] tdm playback mute: 0, lane_cnt = 8
[ 1130.938091] asoc-aml-card auge_sound: tdm playback enable
[ 1130.938149] spdif_a is set to enable
[ 1134.063113] asoc-aml-card auge_sound: tdm playback stop
[ 1134.063175] spdif_a is set to disable
[ 1135.006592] audio_ddr_mngr: frddr_set_sharebuffer_enable sel:1, dst_src:3
[ 1135.006603] aml_dai_tdm_hw_free(), disable mclk for TDM-B
[ 1135.006641] tdm playback mute: 1, lane_cnt = 8
[ 1135.006739] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:tdm@1
[ 1139.966097] type=1400 audit(1596266766.021:718): avc: denied { search } for pid=7199 comm="tmp-mksh" name="/" dev="sdcardfs" ino=3276802 scontext=u:r:init:s0 tcontext=u:object_r:sdcardfs:s0 tclass=dir permissive=1
[ 1139.979901] type=1400 audit(1596266808.301:719): avc: denied { read } for pid=7281 comm="ls" name="firmware" dev="sysfs" ino=11 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 1139.998152] type=1400 audit(1596266808.301:719): avc: denied { read } for pid=7281 comm="ls" name="firmware" dev="sysfs" ino=11 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 1140.016303] type=1400 audit(1596266808.313:720): avc: denied { open } for pid=7281 comm="ls" path="/sys/firmware" dev="sysfs" ino=11 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 1140.035204] type=1400 audit(1596266808.313:720): avc: denied { open } for pid=7281 comm="ls" path="/sys/firmware" dev="sysfs" ino=11 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 1140.053753] type=1400 audit(1596266808.313:721): avc: denied { getattr } for pid=7281 comm="ls" path="/sys/firmware/fdt" dev="sysfs" ino=22045 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 1163.372223] type=1400 audit(1596266808.313:721): avc: denied { getattr } for pid=7281 comm="ls" path="/sys/firmware/fdt" dev="sysfs" ino=22045 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 1163.388117] type=1400 audit(1596266831.705:722): avc: denied { ioctl } for pid=7198 comm="su" path="/dev/pts/1" dev="devpts" ino=4 ioctlcmd=0x5413 scontext=u:r:init:s0 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[ 1181.661194] type=1400 audit(1596266831.705:722): avc: denied { ioctl } for pid=7198 comm="su" path="/dev/pts/1" dev="devpts" ino=4 ioctlcmd=0x5413 scontext=u:r:init:s0 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[ 1181.679114] type=1400 audit(1596266849.993:723): avc: denied { read } for pid=7313 comm="ls" name="firmware" dev="sysfs" ino=22700 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 1181.697852] type=1400 audit(1596266849.993:723): avc: denied { read } for pid=7313 comm="ls" name="firmware" dev="sysfs" ino=22700 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 1181.716232] type=1400 audit(1596266850.013:724): avc: denied { open } for pid=7313 comm="ls" path="/sys/module/firmware" dev="sysfs" ino=22700 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 1215.319837] type=1400 audit(1596266850.013:724): avc: denied { open } for pid=7313 comm="ls" path="/sys/module/firmware" dev="sysfs" ino=22700 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 1215.334001] DI: DI: tasklet schedule cost 12ms.
[ 1215.334646] type=1400 audit(1596266883.653:725): avc: denied { read } for pid=7315 comm="find" name="wakeup_reasons" dev="sysfs" ino=21725 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs_wakeup_reasons:s0 tclass=dir permissive=1
[ 1215.335330] audit: audit_lost=467 audit_rate_limit=5 audit_backlog_limit=64
[ 1215.335332] audit: rate limit exceeded
[ 1215.365847] type=1400 audit(1596266883.653:725): avc: denied { read } for pid=7315 comm="find" name="wakeup_reasons" dev="sysfs" ino=21725 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs_wakeup_reasons:s0 tclass=dir permissive=1
[ 1215.386061] type=1400 audit(1596266883.669:726): avc: denied { open } for pid=7315 comm="find" path="/sys/kernel/wakeup_reasons" dev="sysfs" ino=21725 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs_wakeup_reasons:s0 tclass=dir permissive=1
[ 1215.407685] type=1400 audit(1596266883.669:726): avc: denied { open } for pid=7315 comm="find" path="/sys/kernel/wakeup_reasons" dev="sysfs" ino=21725 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs_wakeup_reasons:s0 tclass=dir permissive=1
[ 1215.429355] type=1400 audit(1596266883.669:727): avc: denied { search } for pid=7315 comm="find" name="wakeup_reasons" dev="sysfs" ino=21725 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs_wakeup_reasons:s0 tclass=dir permissive=1
[ 1215.450110] type=1400 audit(1596266883.669:727): avc: denied { search } for pid=7315 comm="find" name="wakeup_reasons" dev="sysfs" ino=21725 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs_wakeup_reasons:s0 tclass=dir permissive=1
[ 1215.470574] type=1400 audit(1596266883.669:728): avc: denied { getattr } for pid=7315 comm="find" path="/sys/kernel/wakeup_reasons/last_suspend_time" dev="sysfs" ino=21727 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs_wakeup_reasons:s0 tclass=file permissive=1
[ 1215.494187] type=1400 audit(1596266883.669:728): avc: denied { getattr } for pid=7315 comm="find" path="/sys/kernel/wakeup_reasons/last_suspend_time" dev="sysfs" ino=21727 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs_wakeup_reasons:s0 tclass=file permissive=1
[ 1215.517564] type=1400 audit(1596266883.669:729): avc: denied { getattr } for pid=7315 comm="find" path="/sys/kernel/notes" dev="sysfs" ino=3771 scontext=u:r:toolbox:s0 tcontext=u:object_r:sysfs_kernel_notes:s0 tclass=file permissive=1
[ 1216.356396] audit: audit_lost=590 audit_rate_limit=5 audit_backlog_limit=64
[ 1216.358069] audit: rate limit exceeded
[ 1256.435989] type=1400 audit(1596266884.689:858): avc: denied { getattr } for pid=7315 comm="find" path="/sys/fs/bpf/xt_bpf_egress_prog" dev="bpf" ino=15947 scontext=u:r:toolbox:s0 tcontext=u:object_r:fs_bpf:s0 tclass=file permissive=1
[ 1256.436398] audit: audit_lost=614 audit_rate_limit=5 audit_backlog_limit=64
[ 1256.436402] audit: rate limit exceeded
[ 1256.462451] type=1400 audit(1596266924.769:883): avc: denied { read } for pid=7319 comm="ls" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[ 1256.482879] type=1400 audit(1596266924.769:883): avc: denied { read } for pid=7319 comm="ls" name="/" dev="mmcblk0p18" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[ 1256.498614] type=1400 audit(1596266924.769:884): avc: denied { open } for pid=7319 comm="ls" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[ 1256.516882] type=1400 audit(1596266924.769:884): avc: denied { open } for pid=7319 comm="ls" path="/" dev="mmcblk0p18" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[ 1256.534820] type=1400 audit(1596266924.769:885): avc: denied { getattr } for pid=7319 comm="ls" path="/init.usb.configfs.rc" dev="mmcblk0p18" ino=2612 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 1256.555482] type=1400 audit(1596266924.769:885): avc: denied { getattr } for pid=7319 comm="ls" path="/init.usb.configfs.rc" dev="mmcblk0p18" ino=2612 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 1256.575716] type=1400 audit(1596266924.769:886): avc: denied { getattr } for pid=7319 comm="ls" path="/init" dev="mmcblk0p18" ino=2623 scontext=u:r:toolbox:s0 tcontext=u:object_r:init_exec:s0 tclass=file permissive=1
[ 1256.595317] type=1400 audit(1596266924.769:886): avc: denied { getattr } for pid=7319 comm="ls" path="/init" dev="mmcblk0p18" ino=2623 scontext=u:r:toolbox:s0 tcontext=u:object_r:init_exec:s0 tclass=file permissive=1
[ 1256.614405] type=1400 audit(1596266924.769:887): avc: denied { getattr } for pid=7319 comm="ls" path="/metadata" dev="mmcblk0p13" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[ 1270.278769] type=1400 audit(1596266924.769:887): avc: denied { getattr } for pid=7319 comm="ls" path="/metadata" dev="mmcblk0p13" ino=2 scontext=u:r:toolbox:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[ 1270.293085] type=1400 audit(1596266938.613:891): avc: denied { read } for pid=7199 comm="tmp-mksh" name="primary" dev="tmpfs" ino=1273 scontext=u:r:init:s0 tcontext=u:object_r:storage_file:s0 tclass=lnk_file permissive=1
[ 1270.313898] type=1400 audit(1596266938.613:891): avc: denied { read } for pid=7199 comm="tmp-mksh" name="primary" dev="tmpfs" ino=1273 scontext=u:r:init:s0 tcontext=u:object_r:storage_file:s0 tclass=lnk_file permissive=1
[ 1270.332367] type=1400 audit(1596266938.613:892): avc: denied { read } for pid=7199 comm="tmp-mksh" name="primary" dev="tmpfs" ino=32312 scontext=u:r:init:s0 tcontext=u:object_r:mnt_user_file:s0 tclass=lnk_file permissive=1
[ 1270.801650] type=1400 audit(1596266938.613:892): avc: denied { read } for pid=7199 comm="tmp-mksh" name="primary" dev="tmpfs" ino=32312 scontext=u:r:init:s0 tcontext=u:object_r:mnt_user_file:s0 tclass=lnk_file permissive=1
[ 1270.801727] audit: audit_lost=617 audit_rate_limit=5 audit_backlog_limit=64
[ 1270.801729] audit: rate limit exceeded
[ 1270.827018] type=1400 audit(1596266939.133:893): avc: denied { read } for pid=7320 comm="ls" name="primary" dev="tmpfs" ino=1273 scontext=u:r:toolbox:s0 tcontext=u:object_r:storage_file:s0 tclass=lnk_file permissive=1
[ 1270.846644] type=1400 audit(1596266939.133:893): avc: denied { read } for pid=7320 comm="ls" name="primary" dev="tmpfs" ino=1273 scontext=u:r:toolbox:s0 tcontext=u:object_r:storage_file:s0 tclass=lnk_file permissive=1
[ 1270.865883] type=1400 audit(1596266939.137:894): avc: denied { search } for pid=7320 comm="ls" name="user" dev="tmpfs" ino=1261 scontext=u:r:toolbox:s0 tcontext=u:object_r:mnt_user_file:s0 tclass=dir permissive=1
[ 1270.884979] type=1400 audit(1596266939.137:894): avc: denied { search } for pid=7320 comm="ls" name="user" dev="tmpfs" ino=1261 scontext=u:r:toolbox:s0 tcontext=u:object_r:mnt_user_file:s0 tclass=dir permissive=1
[ 1270.903762] type=1400 audit(1596266939.137:895): avc: denied { read } for pid=7320 comm="ls" name="primary" dev="tmpfs" ino=32312 scontext=u:r:toolbox:s0 tcontext=u:object_r:mnt_user_file:s0 tclass=lnk_file permissive=1
[ 1282.673764] type=1400 audit(1596266939.137:895): avc: denied { read } for pid=7320 comm="ls" name="primary" dev="tmpfs" ino=32312 scontext=u:r:toolbox:s0 tcontext=u:object_r:mnt_user_file:s0 tclass=lnk_file permissive=1
[ 1282.688351] type=1400 audit(1596266951.009:902): avc: denied { read } for pid=7321 comm="ls" name="system" dev="mmcblk0p18" ino=34 scontext=u:r:toolbox:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1
[ 1282.707371] type=1400 audit(1596266951.009:902): avc: denied { read } for pid=7321 comm="ls" name="system" dev="mmcblk0p18" ino=34 scontext=u:r:toolbox:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1
[ 1282.726393] type=1400 audit(1596266951.009:903): avc: denied { open } for pid=7321 comm="ls" path="/system" dev="mmcblk0p18" ino=34 scontext=u:r:toolbox:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1
[ 1297.512434] type=1400 audit(1596266951.009:903): avc: denied { open } for pid=7321 comm="ls" path="/system" dev="mmcblk0p18" ino=34 scontext=u:r:toolbox:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1
[ 1297.526593] type=1400 audit(1596266965.845:904): avc: denied { getattr } for pid=7322 comm="find" path="/system/etc/selinux/plat_service_contexts" dev="mmcblk0p18" ino=2304 scontext=u:r:toolbox:s0 tcontext=u:object_r:service_contexts_file:s0 tclass=file permissive=1
[ 1297.530414] audit: audit_lost=623 audit_rate_limit=5 audit_backlog_limit=64
[ 1297.530416] audit: rate limit exceeded
[ 1297.561249] type=1400 audit(1596266965.845:904): avc: denied { getattr } for pid=7322 comm="find" path="/system/etc/selinux/plat_service_contexts" dev="mmcblk0p18" ino=2304 scontext=u:r:toolbox:s0 tcontext=u:object_r:service_contexts_file:s0 tclass=file permissive=1
[ 1297.584742] type=1400 audit(1596266965.845:905): avc: denied { getattr } for pid=7322 comm="find" path="/system/etc/selinux/plat_seapp_contexts" dev="mmcblk0p18" ino=2297 scontext=u:r:toolbox:s0 tcontext=u:object_r:seapp_contexts_file:s0 tclass=file permissive=1
[ 1297.608029] type=1400 audit(1596266965.845:905): avc: denied { getattr } for pid=7322 comm="find" path="/system/etc/selinux/plat_seapp_contexts" dev="mmcblk0p18" ino=2297 scontext=u:r:toolbox:s0 tcontext=u:object_r:seapp_contexts_file:s0 tclass=file permissive=1
[ 1297.631509] type=1400 audit(1596266965.845:906): avc: denied { getattr } for pid=7322 comm="find" path="/system/etc/selinux/plat_sepolicy.cil" dev="mmcblk0p18" ino=2298 scontext=u:r:toolbox:s0 tcontext=u:object_r:sepolicy_file:s0 tclass=file permissive=1
[ 1297.654085] type=1400 audit(1596266965.845:906): avc: denied { getattr } for pid=7322 comm="find" path="/system/etc/selinux/plat_sepolicy.cil" dev="mmcblk0p18" ino=2298 scontext=u:r:toolbox:s0 tcontext=u:object_r:sepolicy_file:s0 tclass=file permissive=1
[ 1297.676613] type=1400 audit(1596266965.845:907): avc: denied { getattr } for pid=7322 comm="find" path="/system/etc/selinux/plat_mac_permissions.xml" dev="mmcblk0p18" ino=2305 scontext=u:r:toolbox:s0 tcontext=u:object_r:mac_perms_file:s0 tclass=file permissive=1
[ 1297.700585] type=1400 audit(1596266965.845:907): avc: denied { getattr } for pid=7322 comm="find" path="/system/etc/selinux/plat_mac_permissions.xml" dev="mmcblk0p18" ino=2305 scontext=u:r:toolbox:s0 tcontext=u:object_r:mac_perms_file:s0 tclass=file permissive=1
[ 1297.723611] type=1400 audit(1596266965.845:908): avc: denied { getattr } for pid=7322 comm="find" path="/system/etc/selinux/plat_hwservice_contexts" dev="mmcblk0p18" ino=2306 scontext=u:r:toolbox:s0 tcontext=u:object_r:hwservice_contexts_file:s0 tclass=file permissive=1
[ 1316.553974] type=1400 audit(1596266965.865:911): avc: denied { getattr } for pid=7322 comm="find" path="/system/bin/mtpd" dev="mmcblk0p18" ino=499 scontext=u:r:toolbox:s0 tcontext=u:object_r:mtp_exec:s0 tclass=file permissive=1
[ 1316.568867] type=1400 audit(1596266984.885:975): avc: denied { ioctl } for pid=7323 comm="mc" path="/dev/pts/0" dev="devpts" ino=3 ioctlcmd=0x541c scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[ 1437.159426] type=1400 audit(1596266984.885:975): avc: denied { ioctl } for pid=7323 comm="mc" path="/dev/pts/0" dev="devpts" ino=3 ioctlcmd=0x541c scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[ 1437.179880] type=1400 audit(1596267105.493:976): avc: denied { ioctl } for pid=7325 comm="bash" path=2F6465762F7074732F31202864656C6574656429 dev="devpts" ino=4 ioctlcmd=0x540a scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[ 1441.720722] type=1400 audit(1596267105.493:976): avc: denied { ioctl } for pid=7325 comm="bash" path=2F6465762F7074732F31202864656C6574656429 dev="devpts" ino=4 ioctlcmd=0x540a scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[ 1441.744413] type=1400 audit(1596267110.053:977): avc: denied { read } for pid=7336 comm="su" name="/" dev="selinuxfs" ino=1 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=dir permissive=1
[ 1441.764934] type=1400 audit(1596267110.053:977): avc: denied { read } for pid=7336 comm="su" name="/" dev="selinuxfs" ino=1 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=dir permissive=1
[ 1441.784789] type=1400 audit(1596267110.053:978): avc: denied { read } for pid=7336 comm="su" name="enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[ 1441.806887] type=1400 audit(1596267110.053:978): avc: denied { read } for pid=7336 comm="su" name="enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[ 1441.826845] type=1400 audit(1596267110.053:979): avc: denied { open } for pid=7336 comm="su" path="/sys/fs/selinux/enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[ 1441.850243] type=1400 audit(1596267110.053:979): avc: denied { open } for pid=7336 comm="su" path="/sys/fs/selinux/enforce" dev="selinuxfs" ino=4 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=1
[ 1441.872223] type=1400 audit(1596267110.053:980): avc: denied { connectto } for pid=7336 comm="su" path=0065752E636861696E666972652E73757065727375 scontext=u:r:untrusted_app:s0:c55,c256,c512,c768 tcontext=u:r:init:s0 tclass=unix_stream_socket permissive=1
[ 1443.360629] type=1400 audit(1596267110.077:984): avc: denied { getattr } for pid=7339 comm="su" path="/dev/pts/1" dev="devpts" ino=4 scontext=u:r:init:s0 tcontext=u:object_r:untrusted_app_all_devpts:s0:c55,c256,c512,c768 tclass=chr_file permissive=1
[ 1443.377494] type=1400 audit(1596267111.693:985): avc: denied { execute_no_trans } for pid=7344 comm="su" path="/tmp-mksh/tmp-mksh" dev="mmcblk0p18" ino=2627 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 1443.398555] type=1400 audit(1596267111.693:985): avc: denied { execute_no_trans } for pid=7344 comm="su" path="/tmp-mksh/tmp-mksh" dev="mmcblk0p18" ino=2627 scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 1443.418822] type=1400 audit(1596267111.693:986): avc: denied { getattr } for pid=7344 comm="tmp-mksh" path="/data/data/com.termux/files/home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[ 1443.443073] type=1400 audit(1596267111.693:986): avc: denied { getattr } for pid=7344 comm="tmp-mksh" path="/data/data/com.termux/files/home" dev="mmcblk0p20" ino=1053540 scontext=u:r:init:s0 tcontext=u:object_r:app_data_file:s0:c55,c256,c512,c768 tclass=dir permissive=1
[ 1443.466952] type=1400 audit(1596267111.693:987): avc: denied { getattr } for pid=7344 comm="tmp-mksh" path="/dev/pts/2" dev="devpts" ino=5 scontext=u:r:init:s0 tcontext=u:object_r:devpts:s0 tclass=chr_file permissive=1
[ 1443.486518] type=1400 audit(1596267111.693:987): avc: denied { getattr } for pid=7344 comm="tmp-mksh" path="/dev/pts/2" dev="devpts" ino=5 scontext=u:r:init:s0 tcontext=u:object_r:devpts:s0 tclass=chr_file permissive=1
[ 1443.505971] type=1400 audit(1596267111.693:988): avc: denied { ioctl } for pid=7344 comm="tmp-mksh" path="/dev/pts/2" dev="devpts" ino=5 ioctlcmd=0x5401 scontext=u:r:init:s0 tcontext=u:object_r:devpts:s0 tclass=chr_file permissive=1
[ 1481.828228] type=1400 audit(1596267111.693:988): avc: denied { ioctl } for pid=7344 comm="tmp-mksh" path="/dev/pts/2" dev="devpts" ino=5 ioctlcmd=0x5401 scontext=u:r:init:s0 tcontext=u:object_r:devpts:s0 tclass=chr_file permissive=1
[ 1481.843520] type=1400 audit(1596267150.161:989): avc: denied { read } for pid=7347 comm="ls" name="etc" dev="mmcblk0p18" ino=2093 scontext=u:r:toolbox:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1
[ 1481.862664] type=1400 audit(1596267150.161:989): avc: denied { read } for pid=7347 comm="ls" name="etc" dev="mmcblk0p18" ino=2093 scontext=u:r:toolbox:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1
[ 1481.881593] type=1400 audit(1596267150.161:990): avc: denied { open } for pid=7347 comm="ls" path="/system/etc" dev="mmcblk0p18" ino=2093 scontext=u:r:toolbox:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1
[ 1534.472822] type=1400 audit(1596267150.161:990): avc: denied { open } for pid=7347 comm="ls" path="/system/etc" dev="mmcblk0p18" ino=2093 scontext=u:r:toolbox:s0 tcontext=u:object_r:system_file:s0 tclass=dir permissive=1
[ 1534.487262] type=1400 audit(1596267202.805:991): avc: denied { getattr } for pid=7344 comm="tmp-mksh" path="/proc/sysrq-trigger" dev="proc" ino=4026532026 scontext=u:r:init:s0 tcontext=u:object_r:proc_sysrq:s0 tclass=file permissive=1
[ 1544.534494] type=1400 audit(1596267202.805:991): avc: denied { getattr } for pid=7344 comm="tmp-mksh" path="/proc/sysrq-trigger" dev="proc" ino=4026532026 scontext=u:r:init:s0 tcontext=u:object_r:proc_sysrq:s0 tclass=file permissive=1
[ 1544.549936] type=1400 audit(1596267212.869:992): avc: denied { read } for pid=7350 comm="cat" name="hotplug" dev="proc" ino=65660 scontext=u:r:toolbox:s0 tcontext=u:object_r:usermodehelper:s0 tclass=file permissive=1
[ 1544.569474] type=1400 audit(1596267212.869:992): avc: denied { read } for pid=7350 comm="cat" name="hotplug" dev="proc" ino=65660 scontext=u:r:toolbox:s0 tcontext=u:object_r:usermodehelper:s0 tclass=file permissive=1
[ 1544.588622] type=1400 audit(1596267212.869:993): avc: denied { open } for pid=7350 comm="cat" path="/proc/sys/kernel/hotplug" dev="proc" ino=65660 scontext=u:r:toolbox:s0 tcontext=u:object_r:usermodehelper:s0 tclass=file permissive=1
[ 1564.516058] type=1400 audit(1596267212.869:993): avc: denied { open } for pid=7350 comm="cat" path="/proc/sys/kernel/hotplug" dev="proc" ino=65660 scontext=u:r:toolbox:s0 tcontext=u:object_r:usermodehelper:s0 tclass=file permissive=1
[ 1564.531437] type=1400 audit(1596267232.849:994): avc: denied { read } for pid=7352 comm="ls" name="sbin" dev="mmcblk0p18" ino=2605 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[ 1564.550246] type=1400 audit(1596267232.849:994): avc: denied { read } for pid=7352 comm="ls" name="sbin" dev="mmcblk0p18" ino=2605 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[ 1564.568675] type=1400 audit(1596267232.849:995): avc: denied { open } for pid=7352 comm="ls" path="/sbin" dev="mmcblk0p18" ino=2605 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[ 1564.587531] type=1400 audit(1596267232.849:995): avc: denied { open } for pid=7352 comm="ls" path="/sbin" dev="mmcblk0p18" ino=2605 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=1
[ 1564.612315] type=1400 audit(1596267232.849:996): avc: denied { getattr } for pid=7352 comm="ls" path="/sbin/charger" dev="mmcblk0p18" ino=2606 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 1605.558527] type=1400 audit(1596267232.849:996): avc: denied { getattr } for pid=7352 comm="ls" path="/sbin/charger" dev="mmcblk0p18" ino=2606 scontext=u:r:toolbox:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 1605.572818] type=1400 audit(1596267273.893:997): avc: denied { read } for pid=7354 comm="dmesg" name="kmsg" dev="tmpfs" ino=451 scontext=u:r:toolbox:s0 tcontext=u:object_r:kmsg_device:s0 tclass=chr_file permissive=1
[ 1605.592840] type=1400 audit(1596267273.893:997): avc: denied { read } for pid=7354 comm="dmesg" name="kmsg" dev="tmpfs" ino=451 scontext=u:r:toolbox:s0 tcontext=u:object_r:kmsg_device:s0 tclass=chr_file permissive=1
[ 1605.611368] type=1400 audit(1596267273.893:998): avc: denied { open } for pid=7354 comm="dmesg" path="/dev/kmsg" dev="tmpfs" ino=451 scontext=u:r:toolbox:s0 tcontext=u:object_r:kmsg_device:s0 tclass=chr_file permissive=1
[ 1605.637102] type=1400 audit(1596267273.893:998): avc: denied { open } for pid=7354 comm="dmesg" path="/dev/kmsg" dev="tmpfs" ino=451 scontext=u:r:toolbox:s0 tcontext=u:object_r:kmsg_device:s0 tclass=chr_file permissive=1
[ 1605.651317] type=1400 audit(1596267273.893:999): avc: denied { syslog_read } for pid=7354 comm="dmesg" scontext=u:r:toolbox:s0 tcontext=u:r:kernel:s0 tclass=system permissive=1
[ 1625.632618] type=1400 audit(1596267273.893:999): avc: denied { syslog_read } for pid=7354 comm="dmesg" scontext=u:r:toolbox:s0 tcontext=u:r:kernel:s0 tclass=system permissive=1
[ 1625.643129] type=1400 audit(1596267293.965:1000): avc: denied { write } for pid=7344 comm="tmp-mksh" name="/" dev="mmcblk1p1" ino=1 scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[ 1625.662684] type=1400 audit(1596267293.965:1000): avc: denied { write } for pid=7344 comm="tmp-mksh" name="/" dev="mmcblk1p1" ino=1 scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[ 1625.666220] audit: audit_lost=686 audit_rate_limit=5 audit_backlog_limit=64
[ 1625.666223] audit: rate limit exceeded
[ 1625.690530] type=1400 audit(1596267293.965:1001): avc: denied { add_name } for pid=7344 comm="tmp-mksh" name="dmesg.txt" scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
[ 1625.708039] type=1400 audit(1596267293.965:1001): avc: denied { add_name } for pid=7344 comm="tmp-mksh" name="dmesg.txt" scontext=u:r:init:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=1
Edited by Werner
Added spoiler for long message
On 9/15/2020 at 2:14 AM, rforcen said:
i'm working on it, both dtb & firmware,
i've just tried with 88x2ce, compiled & installed, dbt to compatible="realtek, rtl88x2ce";
but no luck yet.:wacko:
I take it you couldn't get this to work? What about the bcm4329-fmac module?
not really worth it spending much time with this as it can be solved with a cheap wifi dongle & bt,
also solved sound issues with dlna,
broadcom is the original dtb posting, (don't ask me why)
15 minutes ago, sgrayban said:
Any recommendations ? Or a dongle you already use?
i've got 5 wifi dongles and all work, the latest is a ac600 "free driver" working with the rtl8821CU driver ,
Bus 003 Device 008: ID 0bda:c811 Realtek Semiconductor Corp. 802.11ac NIC
others:
Bus 003 Device 005: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 003 Device 006: ID 2001:3319 D-Link Corp. Wireless N Nano USB Adapter
better to install realtek drivers
sudo apt search realtek
Drivers are in the kernel, I assume you mean the matching firmware?
7 minutes ago, sgrayban said:
please read the product Q&A or google it before posting here:
Question:
Does anyone know if this works with ubuntu 14.04?
Answer:
No! The "real" TP-WN725N will, but these (thought advertised as a WN725N) are "NOT" the WN725N, but are made by Archer, and they don't work with LINUX, Ubuntu or LINUX Mint. If you get a real TP-WN725N and plug it in, it will work right out of the box!!
never mind... I guess there is no list of dongles that work and the links to get them at? Like mazon maybe?
  • Werner locked this topic
