I am successfully using Armbian Current on my Banana Pi.
I have a 120GB usb SSD drive.
I'd like to boot from it - my other Banana Pi with the same system boots from SATA connected HDD no problem.
When I boot the device, I can see the drive using sudo fdisk -l as /dev/sda1
I can also get the UUID and everything.
I've modified the /boot/armbianEnv.txt file and changed the UUID, but I can't get the machine to boot.
I tried also to change the UUID to /dev/sda1.
Didn't help either.
When I boot with HDMI connected, I can see the kernel iterating through USB bus and the result is "no USB storage device found" and that's it.
Even when I modify the armbianEnv.txt back and boot with HDMI, I can see the same message - however, when the system boots, I can see the drive and the corresponding device, too.
Any idea what I do wrong?
Thanks for any guidance.
Just a small note - the USB drive has sufficient power as it has "dual" cable - one for power, one for data. It even works when plugged to the USB OTG connector thanks to the external power supply.
Board: Not on the list
- do you have rootfs on that drive?
- why don't you use supplied tools? (nand-sata-install)
- logs logs logs
I tried not to use the tool as it gives a big warning about erasing whole drive.
I wanted to keep the data, so I did manual rsync of the rootfs onto the drive and modified the steps accordingly.
However, now I did erase the drive and used the script, but the result is exactly the same.
Not sure how can I obtain the logs as the network is not connected and I cannot copy&paste from the device. Don't have serial adapter at hand right now :(
At least I've made a screen snapshot, not sure if it helps, though...
When changing ROOTFS, you need to change BOTH places in /boot/armbianEnv.txt as well as /etc/fstab, otherwise you get this "ALERT! UUID=... doesn't exist" ...
