g_ether module not loading - "udc-core: couldn't find an available UDC"
djjerdog
Using Armbian_20.02.1 with 5.4 kernel on NEO2 board, I'm running into an issue trying to get the USB OTG working with the g_ether module. When I run modprobe g_ether I see the following in dmesg:
[  490.490582] udc-core: couldn't find an available UDC - added [g_ether] to list of pending drivers
I've also tried compiling my own img using the Armbian builder but it looks like all the correct OTG options are already selected by default.
Any ideas what I'm doing wrong?
Link to comment
Share on other sites
Ok, I narrowed it down a bit, it appears this is specific to the NEO2 Black Armbian image, works fine if I use the NEO2 Armbian image (even on a NEO2 Black board).
Using Armbian_20.02.1_Nanopineo2_buster_current_5.4.20 g_ether loads just fine
[  190.883225] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[  190.883234] g_ether gadget: g_ether ready
[  191.258813] g_ether gadget: high-speed config #1: CDC Ethernet (EEM)
However, using Armbian_20.02.1_Nanopineo2black_buster_current_5.4.20 I see the following when I try to modprobe g_ether
Any ideas why g_ether works fine when using the Nanopineo2 image but not when using the Nanopineo2black image?
Link to comment
hi, I encounter the same error message at boot time on my tritium H5 running armbian buster
Linux tritium 5.4.43-sunxi64 #20.05.2 SMP Tue Jun 2 17:20:17 CEST 2020 aarch64 GNU/Linux
@Igor, is my problem  similar to OP's ?
tks
Link to comment
1 hour ago, ravelo said:
which maintainer could give us an advice, if not try to investigate this misbehaviour please ?
The one which you are supporting?
“Supported” is not a guarantee.
https://docs.armbian.com/#what-is-supported
Support terms:
https://github.com/armbian/build#support
Forum ruiles:
https://forum.armbian.com/terms
"Do not bump topics or create duplicate messages for the purpose of bringing attention to your issue. If bumping an old topic to resume conversation or provide new information, update the beginning post if possible."
Link to comment
sorry, I do not understand if this question is an aswer or not..
Ok, I tend to understand that there is no such thing as a maintainer for ambian buster on tritium h5. So be it.
I am willing to investigate and fix if I know how to, then publish the solution to the community. But to get started, I would need a small amout of info to know here to look at first.
Link to comment
Any for that you have to spam forums? Who will clean after you?
You are welcome to solve any problem for and with the help of community, but so far I haven't notice anyone asking for this https://forum.armbian.com/forum/38-feature-requests/
Link to comment
