Armbianmonitor:
But only when the connection is initiated by the remote host.
iperf3 -s
Server listening on 5201
Accepted connection from nanopcT4, port 51356
[  5] local nanopiNeo4 port 5201 connected to nanopcT4 port 51358
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec  2.34 MBytes  19.7 Mbits/sec  108   1.41 KBytes
[  5]   1.00-2.00   sec  2.05 MBytes  17.2 Mbits/sec  100   2.83 KBytes
[  5]   2.00-3.00   sec  4.68 MBytes  39.3 Mbits/sec  220   5.66 KBytes
[  5]   3.00-4.00   sec   199 KBytes  1.63 Mbits/sec   24   1.41 KBytes
[  5]   4.00-5.00   sec  3.25 MBytes  27.3 Mbits/sec  179   15.6 KBytes
[  5]   5.00-6.00   sec  4.53 MBytes  38.0 Mbits/sec  217   1.41 KBytes
[  5]   6.00-7.00   sec  1.10 MBytes  9.19 Mbits/sec   56   4.24 KBytes
[  5]   7.00-8.00   sec   860 KBytes  7.04 Mbits/sec   38   2.83 KBytes
[  5]   8.00-9.00   sec  5.75 MBytes  48.3 Mbits/sec  291   1.41 KBytes
[  5]   9.00-10.00  sec  4.00 MBytes  33.6 Mbits/sec  209   1.41 KBytes
[  5]   0.00-10.00  sec  28.7 MBytes  24.1 Mbits/sec  1442             sender
iperf3 -c nanopcT4 -R
Connecting to host nanopcT4, port 5201
Reverse mode, remote host nanopcT4 is sending
[  5] local nanopiNeo4 port 55042 connected to nanopcT4 port 5201
[  5]   0.00-1.00   sec   108 MBytes   905 Mbits/sec
[  5]   1.00-2.00   sec   112 MBytes   942 Mbits/sec
[  5]   2.00-3.00   sec   112 MBytes   942 Mbits/sec
[  5]   3.00-4.00   sec   112 MBytes   942 Mbits/sec
[  5]   4.00-5.00   sec   112 MBytes   942 Mbits/sec
[  5]   5.00-6.00   sec   112 MBytes   942 Mbits/sec
[  5]   6.00-7.00   sec   112 MBytes   942 Mbits/sec
[  5]   7.00-8.00   sec   112 MBytes   942 Mbits/sec
[  5]   8.00-9.00   sec   112 MBytes   942 Mbits/sec
[  5]   9.00-10.00  sec   112 MBytes   941 Mbits/sec
[  5]   0.00-10.00  sec  1.09 GBytes   940 Mbits/sec    0             sender
[  5]   0.00-10.00  sec  1.09 GBytes   938 Mbits/sec                  receiver
There was also some less significant packet loss and slower performance running Bionic. and asymmetric as well, but in the opposite direction - when neo4 is initiating connection:
[  4] local nanopiNeo4 port 60366 connected to nanopcT4 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec  73.5 MBytes   617 Mbits/sec
[  4]   1.00-2.00   sec  78.2 MBytes   656 Mbits/sec
[  4]   2.00-3.00   sec  78.2 MBytes   656 Mbits/sec
[  4]   3.00-4.00   sec  78.4 MBytes   658 Mbits/sec
[  4]   4.00-5.00   sec  77.7 MBytes   652 Mbits/sec
[  4]   5.00-6.00   sec  77.6 MBytes   651 Mbits/sec
[  4]   6.00-7.00   sec  77.8 MBytes   653 Mbits/sec
[  4]   7.00-8.00   sec  77.7 MBytes   652 Mbits/sec
[  4]   8.00-9.00   sec  76.8 MBytes   644 Mbits/sec
[  4]   9.00-10.00  sec  79.1 MBytes   663 Mbits/sec
[ ID] Interval           Transfer     Bandwidth       Retr
[  4]   0.00-10.00  sec   778 MBytes   653 Mbits/sec  152             sender
[  4]   0.00-10.00  sec   775 MBytes   650 Mbits/sec                  receiver
iperf Done.
iperf3 -s
Accepted connection from nanopcT4, port 51336
[  5] local nanopiNeo4 port 5201 connected to nanopcT4 port 51338
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  5]   0.00-1.00   sec   106 MBytes   889 Mbits/sec    0    404 KBytes
[  5]   1.00-2.00   sec   113 MBytes   946 Mbits/sec    0    404 KBytes
[  5]   2.00-3.00   sec   112 MBytes   936 Mbits/sec    0    404 KBytes
[  5]   3.00-4.00   sec   113 MBytes   947 Mbits/sec    0    445 KBytes
[  5]   4.00-5.00   sec   112 MBytes   943 Mbits/sec    1    328 KBytes
[  5]   5.00-6.00   sec   112 MBytes   940 Mbits/sec    0    369 KBytes
[  5]   6.00-7.00   sec   112 MBytes   939 Mbits/sec    0    392 KBytes
[  5]   7.00-8.00   sec   112 MBytes   942 Mbits/sec    0    428 KBytes
[  5]   8.00-9.00   sec   113 MBytes   945 Mbits/sec    0    428 KBytes
[  5]   9.00-10.00  sec   112 MBytes   941 Mbits/sec    0    443 KBytes
[  5]  10.00-10.02  sec  2.86 MBytes  1.06 Gbits/sec    0    443 KBytes
[  5]   0.00-10.02  sec  1.09 GBytes   937 Mbits/sec    1             sender
[  5]   0.00-10.02  sec  0.00 Bytes  0.00 bits/sec                  receiver
Just wanted to make sure...
Anyway. Both Buster and Bionic (if you did not switch branches) share the very same kernel. Therefore the issue must be searched on OS side and there is very little Armbian can do since the OS itself is barely touched.
Or 3rd party hardware related. Such as cabling, switches, ...
@ottawan When https://github.com/armbian/autotests will receive more love, things could be cleared out at once. But now, someone needs to find some time and try to recreate ...
Edited by Igor
wording
Great observation, thank you Werner!
Before the upgrade from Stretch (was not Bionic, sorry, my mistake) I was indeed running kernel v.5.x because back then I also saw some slow performance but blamed it on a new USB enclosure without proper testing, then just upgraded the kernel and that solved the problem. In fact I bet it was the very same thing.
Now after switching to 5.4.20 theres still some insignificant packet loss but guess I can live with it.
3 hours ago, ottawan said:
I'll definitely look into it now,
I made some major changes today, but running low on time. Check this entire thread:
seems neo4 is not quite popular out there
We are mainly and well stock with bigger brother, M4 and T4. They are very similar.
That's kinda obvious, as all 3 share the very same on chip ethernet port.  But I'm still struggling to understand how come my T4 is running 4.4.192 just fine, but neo4 is experiencing a massive packet loss running 4.4.208 and one of the earlier 4.4.x versions but 5.4.20 and 5.3.x before - all good.
So now on that automated testing script topic: is it to be run as root or a regular user? Is it safe to run on a live system? Does it send anything automatically like armbianmonitor does? (To be honest - I was unpleasantly surprized seeing the data collected sent somewhere without review or even asking).
That is correct but experiences shows that things like PCB line length matters. Not necessarily this is the case ... just speculating.
- in this very early stage it runs as root. Working under normal user should be added under "to do" and rework accordingly.
- it should be safe to run it on a live system but testing might provoke your system to break. We actually want to move the system to the borders, which might result in bricking ... wireless speed test reconfigure your wireless devices and doesn't put them back, we will add more tests which I don't know what they will do ATM. This is not a end user application.
- it doesn't send any data anywhere. This test is meant for us, for people that will attach their devices to common testing facility. We will collect data. I will sent my test results, you will sent your test results and we will display some results. They will tell us if this and that hardware feature is not working as expected or if its failed.
Nobody cares who is the person that made the test, so that data will not be collected at all.
armbianmonitor sends out strictly anonymised data on your command and that data is stored on public servers. We take privacy and security seriously.
Yes I figured that out once I examined the data. But ony after it was uploaded.
When I ran armbianmonitor though I did not expect it to do automatic upload and my immediate reaction was WTF :blink:
