Marcus Nguyen Posted March 17, 2020 Share Posted March 17, 2020 Hi all, I want to set my Pi with specified hostname. I checked successful when cat /etc/hostname. Howerver, when I am using a Advanced IP Scanner to scan all the network, it just show the IP without the hostname while others raspberry boards have displayed as my attached image below. Thanks! Link to comment Share on other sites More sharing options...
martinayotte Posted March 17, 2020 Share Posted March 17, 2020 4 hours ago, Marcus Nguyen said: it just show the IP without the hostname Most probably because you don't have "avahi-daemon" installed or its configs in /etc/avahi/avahi-daemon.conf doesn't have "publish-workstation" set to "yes" ... Link to comment Share on other sites More sharing options...
Igor Posted March 17, 2020 Share Posted March 17, 2020 @Marcus Nguyen armbian-config -> system Link to comment Share on other sites More sharing options...
