Darknight Posted March 18, 2020 Posted March 18, 2020 Hello, I use the amlogic S905W (TX3mini) When I would like to start my PPP connection my Kernel says missing Module: Couldn't open the /dev/ppp device: No such file or directory modprobe: FATAL: Module ppp_generic not found in directory /lib/modules/5.5.1-arm-64 pppd: You need to create the /dev/ppp device node by executing the following command as root: mknod /dev/ppp c 108 0 Please check kernel 5.5.1-arm-64 Many Thanks
Werner Posted March 18, 2020 Posted March 18, 2020 PPP module is present in all meson64 kernel configs. Belongs here btw:https://forum.armbian.com/forum/16-amlogic-s905x/
Igor Posted March 18, 2020 Posted March 18, 2020 5 hours ago, Darknight said: Please check kernel 5.5.1-arm-64 Not official kernel build. 4 hours ago, Werner said: PPP module is present in all meson64 kernel configs.
Darknight Posted April 2, 2020 Author Posted April 2, 2020 On 3/18/2020 at 11:56 PM, Igor said: Not official kernel build. Why its not supported? Tks!
Werner Posted April 2, 2020 Posted April 2, 2020 Because nobody knows what in your 3rd party kernel config might be altered. Quite obviously they removed PPP support. So blame them.
