Shoka Posted March 20, 2020 Share Posted March 20, 2020 Looks like an expired key on http://repo.aptly.info/dists/nightly/InRelease EXPKEYSIG ED75B5A4483DA07C Andrey Smirnov <me@smira.ru> Harry Link to comment Share on other sites More sharing options...
Igor Posted March 20, 2020 Share Posted March 20, 2020 Rename / delete userpatches directory and run the script again. https://github.com/armbian/build/issues/1847 Link to comment Share on other sites More sharing options...
guidol Posted March 20, 2020 Share Posted March 20, 2020 new key is available since 4 days ( see https://github.com/aptly-dev/aptly/issues/911 ) at https://www.aptly.info/pubkey.txt Now how to get it into the build-system? @Igor the right way wouldnt be?: wget https://www.aptly.info/pubkey.txt gpg --import ./pubkey.txt gpg: /root/.gnupg/trustdb.gpg: trustdb created gpg: key ED75B5A4483DA07C: public key "Andrey Smirnov <me@smira.ru>" imported gpg: Total number processed: 1 gpg: imported: 1 Link to comment Share on other sites More sharing options...
Igor Posted March 20, 2020 Share Posted March 20, 2020 1 minute ago, guidol said: Now how to get it into the build-system? It will get automatically when key servers are synced - key has same ID. I think this error bumps out only when building docker image since we had only one keyserver there. Link to comment Share on other sites More sharing options...
guidol Posted March 20, 2020 Share Posted March 20, 2020 Just now, Igor said: I think this error bumps out only when building docker image since we had only one keyserver there. I also got this message today while building a image - without docker - Its was a dev bullseye image for the NPi Neo with the option CREATE_PATCHES Link to comment Share on other sites More sharing options...
Igor Posted March 20, 2020 Share Posted March 20, 2020 3 minutes ago, guidol said: I also got this message today while building a image - without docker - Its was a dev bullseye image for the NPi Neo with the option CREATE_PATCHES But you were able to build image? Link to comment Share on other sites More sharing options...
guidol Posted March 20, 2020 Share Posted March 20, 2020 23 minutes ago, Igor said: But you were able to build image? yes - it did built Link to comment Share on other sites More sharing options...
Shoka Posted March 22, 2020 Author Share Posted March 22, 2020 I encountered this running apt-get update, not during a build. Tried several fixes without success. Eventually fixed it using info from the bug report for the last time it occurred in 2018. here sudo apt-key adv --keyserver pool.sks-keyservers.net --recv-keys ED75B5A4483DA07C Harry 1 Link to comment Share on other sites More sharing options...
