Now I have connected this display using fbtft
This is done as folows:
sudo modprobe fbtft_device name=flexpfb rotate=180 gpios=dc:110,reset:21,wr:1,cs:6,db00:3,db01:68,db02:71,db03:64,db04:2,db05:65,db06:66,db07:67
sudo modprobe flexfb width=320 height=480 buswidth=8 init=-1,0x11,-2,200,-1,0x36,-1,0x3A,0x05,-1,0x36,0x48,-1,0x13,-1,0x29,-1,0x2C,-3
and test picture:
sudo fbi -d /dev/fb8 -T 1 -noverbose -a example.jpg
Video:
sudo apt-get install -y mplayer
sudo SDL_VIDEODRIVER=fbcon SDL_FBDEV=/dev/fb8 mplayer -vo sdl -framedrop example.mpg
Why it is extremaly slow ?  ( 1 frame pre second)
Some hint?
First thank you very much. This is what I was looking for , for like a few months.
But why the output is in portrait mode ? I tried both by playing wih rotate , width , hieght in modprobe but I could not change it to landscape mode. I also tried to change X11/xorg.conf with no luck.
Can you tell me how to change display orientation from portrait to landscape?
Thanks.
Did You try manipulate of 0x36 register ? (now is value 0x48)
Ps.
you have to be careful with fbi, remains in memory - how many times You call to as many copies
use eg.
 pkill -9 fbi
Thank you for your input on the pins/ init sequence. I was trying a different set of pins/init sequence thinking the controller was a different one. There doesnt seem to be much information in aliexpress. Is there any documentation somewhere that I can use to understand on how this init sequence needs to be formatted and significance of the values? I know what -1, -2 and -3 mean, but not sure about the hex and int values in sequence.
BTW, I would also like to know how to manipulate 0x36 register. :)
Thanks a lot. I kinda figured out how to change 0x36 register.
it seems I can see it in the init params, like 0x36 followed by another hex value.
The hex value can be one of the below ones based on an issue discussion in fbtft support. (I'm yet to even try these ones to see how it works.)
 hexvalue rotatevalue result
0x28 0 Horizontal
0xF8 0 Horizontal
0x48 90 Vertical
0x84 90 Vertical
They seem to work in conjuction with rotate values passed to fbtft_device modprobe. I once again thank Mariuszb for your help :) :) :) :) :) :)
hi i have a similar buts its for ardunio and got every pin in accept
lcd_rd
lcd_wr
lcd_rs
and how can
dc:110 < what layout of the pin is that?  i also do not  understand this
my english is not good
can you help me a little?
Your display is not with a SPI interface, all transfers are done with parallel GPIOs.
So, don't expect been able to run it using frame buffer.
You can use GPIO library to drive it, but you are on your own displaying something from your own application.
