That would be interesting indeed.
... somewhere (perhaps here) I heard about a recent mali driver code tarball:
TX011-SW-99002-r16p0-00rel0.tgz
https://armkeil.blob.core.windows.net/developer/Files/downloads/mali-drivers/kernel/mali-midgard-gpu/TX011-SW-99002-r16p0-00rel0.tgz
but I don't think it has a driver for S912 (but then I am not familiar with all terms)
balbes150 also mentioned Mali T830 GPU (s912) is not licensed.
Hi everyone !
I have seen that some of you have done an amazing job here, providing support for a proper packaged linux system targeting S912 boards out there.
I may be interested in setuping a H96 pro box (32GB hard drive + 3GB RAM) for my Gitlab runners, and some occasional benchmark related to a software I am developing, that make use of NEON intrisics.
I have two questions :
-Is the H96 pro a good choice for what I am trying to achieve and/or to have fun doing embedded linux (I have no TV) ?
-What linux image would you advise me to use ?
I am not yet interested in doing openCL computations on the mali GPU by the way, and probably won't until openCL will offer a compatibility with C++14 (variadic templates, lamda, etc...)
  On 3/26/2017 at 11:39 PM, gnthibault said:
Is someone able to follow the instructions given at http://openlinux.amlogic.com/wiki/index.php/Arm/Buildroot/buildroot-3.14/buildroot-2017-03-10 ?
The ssh command ask me for a password, so I am stuck right now.
I would like to see if I can build my own mini distribution from scratch with a recent kernel, and all driver support from AmLogic through the builroot project they provide.
Expand
It seems transition to repo correctly is imminent,  but for now one can still download from
http://openlinux.amlogic.com:8000/download/ARM/filesystem/buildroot-openlinux-20170310.tar.gz
Then one can go from step:
% source buildroot/build/setenv.sh
no password needed.
I am doing this right now...
Thank you @Nofan Tasi I did not understood that this was what you posted earlier. Unfortunately the bandwidth looks extremely limited to download the 1.8GB file, I won't probably be able to get it today.
I'll try to build an image to qemu first, and maybe if I can get my software to compile and run om qemu, I'll buy a S912 TV box.
I just started to understand. Inside there is such a folder:
buildroot-openlinux-20170310/hardware/aml-3.14/arm/gpu/t83x/kernel/drivers/gpu/arm/midgard
Unzip buildroot-openlinux-20170310.tar.gz to /home
A folder is created: /buildroot-openlinux-20170310
$ cd ~/buildroot-openlinux-20170310
$ source buildroot/build/setenv.sh
You're building on Linux
Lunch menu...pick a combo:
1. mesongxl_p212_32_kernel49_release
2. mesongxl_p212_kernel49_release
3. mesongxm_q200_32_kernel49_release
4. mesongxm_q200_kernel49_release
5. mesongxb_p200_release
6. mesongxb_p200_32_release
7. mesongxb_p201_release
8. mesongxb_p201_32_release
9. mesongxl_p212_release
10. mesongxl_p212_32_release
11. mesongxl_p230_release
12. mesongxl_p230_32_release
13. mesongxm_q200_release
14. mesongxm_q200_32_release
15. meson8_k200_release
16. meson8_k200b_release
17. meson8b_m200_release
18. meson8b_m201_release
19. meson8m2_n200_release
Which would you like? [5] 13
(Note: mesongxm_q200 is board on Amlogic S912
Q200:
•   Amlogic S912 CPU
•   2GB DDR3
•   HDMI out x 1
•   TF Card x 1
•   Ethernet 100M x 1, 1000M x 1
•   SDIO WIFI/BT (AP6356S) x 1
•   SPDIF x 1
•   USB hub x 2
•   USB otg x 1
•   EMMC x 1
end Note)
#TARGET_BOARD=q200
#BUILD_TYPE=64
#OUTPUT_DIR=output/mesongxm_q200
#CONFIG=mesongxm_q200_release_defconfig
# configuration written to /home/buildroot-openlinux-20170310/output/mesongxm_q200/.config
$ make menuconfig
The buildroot window opens
In the bookmark KERNEL there is such an item
[*] amlogic gpu driver git repo │ │
│ │ (r6p1) amlogic gpu branch
[*] amlogic gpu driver local
│$(TOPDIR)/../hardware/aml-3.14/arm/gpu
I chose package gstreamer1
Started the assembly..
$ make
Let's look :-)
Ouch, during buildroot build, it looks like one has also to download http://openlinux.amlogic.com:8000/deploy/arc-4.8-amlogic-20130904-r2.tar.gz, which can take some time.
Edit : looks like someone had a spare ;)https://gitlab.com/ember-dev/deploy/blob/master/deploy_ubuntu_14.04.sh :
wget https://www.dropbox.com/s/tkvnj4n6klrb3pw/CodeSourcery.tar.gz
wget  https://www.dropbox.com/s/rvved2rwjptibfb/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.gz
gunzip  gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.gz
wget https://www.dropbox.com/s/5pn69t7gcthuqf0/arc-4.8-amlogic-20130904-r2.tar.gz
Also had to download (and bypass sha256)
wget http://sources.buildroot.net/DirectFB-1.7.7.tar.gz
I can share the various buildroot utilities (including buildroot-openlinux-20170310.tar.gz) on amazon if someone is interested.
Looks promising anyway, but I have seen that default kernel is 3.14, although 4.9 seems to be included. I'll report my build results when I will be done
Yes, in order to build without any problems (the fact is that the download from openlinux.amlogic.com is constantly broken), you need to use any tool with the ability to download the following packages of large sizes:
http://openlinux.amlogic.com:8000/deploy/CodeSourcery.tar.gz
http://openlinux.amlogic.com:8000/deploy/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar
And put them in the folder:
~/buildroot-openlinux-20170310/buildroot/dl
I was finally not able to build:
RuntimeError: Bad magic number in .pyc file
/home/tnotargi/projects/S912/buildroot/buildroot-openlinux-20170310/output/mesongxm_q200/build/uboot-next-2015-dev/Makefile:927: recipe for target 'boot.bin' failed
How can I debug this, and eventually remove the package that generated the error  ?
Expand
 I get similar error when I build in gentoo.
But when I build same way inside a minimal ubuntu chroot all goes fine.
Not sure how to troubleshoot this. Perhaps python 2.7 is required.
If I google "RuntimeError: Bad magic number in .pyc file", I do get a lot of hits.
 Which linux distribution do you use? And which python version?
My gentoo has python 3.6 selected active. The ubuntu chroot has python 2.7 selected active
 PS: I built mesongxl_p212_kernel49.
During the compilation, was built a file: mali.ko, Which is placed in the file system /output/target  In folder /lib/modules/3.14.29/kernel/amlogic/gpu
gpu r6p1 Installing to target
In folder buildroot-openlinux-20170310/output/mesongxm_q200/build created folder /gpu-r6p1
Expand
That's nice. It seems 4.9.4 does not provide this module (yet).
Expand
Run the command "make menuconfig" and remove from the configuration Assembly u-boot. This set of files not needed for normal use for TV boxes. To replace the stock u-boot in the TV box for this option is risky. It probably not support all the features of the TV box (buttons on the remote control and the inclusion of a number of other features of this particular iron TV box).
Unfortunately, everything is very simple.
The library libmali.so is in the folders at: buildroot/package/opengl/src/lib/arm64/r6p1
There are folders:
m450
m450-x
And there are no folder for T8xx
And assembly buildroot with opengl for S912 is interrupted with the inscription:
cp: cannot stat '/home/buildroot-openlinux-20170310/output/mesongxm_q200/build/opengl/lib/arm64/r6p1//*.so*': No such file or directory
For the active use of Linux, the acquisition of S912 seems so far too early ... IMHO
S905x at the moment is the most ..
@diaamant
If you want to use it as a proper desktop, but what about a headless server ?
I still have many things to learn about embedded linux, but I think I should be able to run at least some scripts, and some of my applications.
I ordered my H96 pro + (3GB RAM /32GB RON / S912) today, just to run ssh, and some continuous integration tests.
There are folders:
m450
m450-x
Expand
You could perhaps attempt to continue assembly by linking, say
ln -s m450/libMali.so /home/buildroot-openlinux-20170310/output/mesongxm_q200/build/opengl/lib/arm64/r6p1
I recall I did something similar for S905x.
Hi, I want to thank balbes150 and armbian for the opportunity to install linux on s912 devices.
I've installed armbian 5.27, and run it as a complete webserver, with Nextcloud
I've put it on internal memory with an external HDD that serves as Home partition and no issue so far, except I cannot change settings to static ip, right now I'm on dhcp with ip reserved in router.
All and all, you did a great job!
Expand
In Networkmanager edit does not work. I opened in the editor (as root) the file /etc/network/interfaces, changed the settings from DHCP to static, restarted. Now a static address. If you need a graphical system settings, You can use WebMin.
@kingul Just out of curiosity, what device are you using, 2 or 3GB of RAM ?
I was also interested in installing armbian directly on the emmc memory (32GB on the H96 pro+ I should receive in a few days) have you used the builtin tool from ubuntu to do that ?
Thank you in advance for your help.
Posted (edited)
@gnthibault I have 2GB of ram with 32GB rom. (Yoka TV KB2)
First time I tried with nand-sata-install, but it was a bad move, because bootloader was rewritten, I had to restore official image of my device.
After a little search I found /root/install.sh script and it worked perfectly.
@balbes150
I've tried all possibilities but none worked. Every change that I've made in /etc/network/interfaces for static ip was resulting in no ip at all, eth0 didn't wanna start.
Also tried in webmin, same situation, so I figured that may be a bug related to my hardware. I can live with that though.
I didn't try wifi settings because I use only cable.
P.S. I'm using Armbian_5.27_S9xxx_Ubuntu_xenial_3.14.29_server_20170323 image
Edited by kingul
P.S.
Show your configuration file /etc/network/interfaces
Here is an option that works for me with a static address.
# Wired adapter #1
auto eth0
iface eth0 inet static
#dhcp
address 192.168.1.155
netmask 255.255.255.0
gateway 192.168.1.1
dns-nameservers 192.168.1.1
#    hwaddress ether # if you want to set MAC manually
#    pre-up /sbin/ifconfig eth0 mtu 3838 # setting MTU for DHCP, static just: mtu 3838
# Wireless adapter #1
# Armbian ships with network-manager installed by default. To save you time
# and hassles consider using 'sudo nmtui' instead of configuring Wi-Fi settings
# manually. The below lines are only meant as an example how configuration could
# be done in an anachronistic way:
#allow-hotplug wlan0
#iface wlan0 inet dhcp
#address 192.168.0.100
#netmask 255.255.255.0
#gateway 192.168.0.1
#dns-nameservers 8.8.8.8 8.8.4.4
#   wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
# Disable power saving on compatible chipsets (prevents SSH/connection dropouts over WiFi)
#wireless-mode Managed
#wireless-power off
# Local loopback
auto lo
iface lo inet loopback
That's my configuration that works. I did some testing again, just to be sure that it wasn't a one time thing.
# Wired adapter #1
#auto eth0
iface eth0 inet dhcp
	allow-hotplug eth0
	no-auto-down eth0
#    address 192.168.10.115
#    netmask 255.255.255.0
#    gateway 192.168.10.1
#wireless-power off
# Local loopback
auto lo
So, after I make changes for static ip, the box starts in almost 3 minutes, but only after I disconnect and reconnect ethernet cable. That's my dmesg output:
[   28.958652] aml_audio_i2s_mute_flag: flag=0
[   28.958674] aml_audio_set_spdif_mute: flag=0
[   28.958687] aml_snd_card: aml_m8_set_spk: aml_m8_spk_enabled=0
[   32.802936] libphy: stmmac-0:00 - Link is Up - 1000/Full
[   64.801664] libphy: stmmac-0:00 - Link is Down
[   66.801605] libphy: stmmac-0:00 - Link is Up - 1000/Full
[   86.421880] brcmfmac: brcmf_sdio_get_fw: fail to request firmware brcm/brcmfmac4335-sdio.txt (-2)
[   86.477075] brcmfmac: brcmf_bus_start: brcmf_sdbrcm_bus_init failed -2
[   86.484371] brcmfmac: brcmf_sdio_probe: dongle is not responding
[   86.507041] sdio: queuing unknown CIS tuple 0x80 (2 bytes)
[   86.512346] sdio: queuing unknown CIS tuple 0x80 (7 bytes)
[   86.515179] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[   86.619785] sdio: clk 200000000 SDR mode tuning start
[   86.620536] sdio: rx_tuning_result[0] = 10
[   86.621354] sdio: rx_tuning_result[1] = 10
[   86.622086] sdio: rx_tuning_result[2] = 10
[   86.622805] sdio: rx_tuning_result[3] = 10
[   86.622899] sdio: best_win_start =0, best_win_size =4
[   86.622924] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x22000
[   86.622961] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x22000
[   86.622992] [sdio_reinit] finish
[   87.631238] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x00
[   88.681218] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x00
[  142.006841] brcmfmac: brcmf_ops_sdio_probe: F2 error, probe failed -19...
[  142.064678] usbcore: registered new interface driver brcmfmac
[  142.082690] bcmsdh_register: register client driver
[  142.083365] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[  142.083430] bus num (host idx)=0, slot num (rca)=1
[  142.083478] found adapter info 'DHD generic adapter'
[  142.083855] sdioh_attach: set sd_f2_blocksize 128
[  142.093954] bcmsdh_sdmmc: Failed to enable F1 Err: 0xffffffc2dhdsdio_probe : no mutex held. set lock
[  144.801212] libphy: stmmac-0:00 - Link is Down
[  146.188723] F1 signature read @0x18000000=0x   5
[  146.188803] dhdsdio_probe: ChipClkCSR access: err 0 wrote 0x28 read 0x00
[  146.188810] dhdsdio_probe: dhdsdio_probe_attach failed
[  146.188819] dhdsdio_probe : the lock is released.
[  146.188824] bcmsdh_probe: device attach failed
[  146.188831] sdioh_probe: bcmsdh_probe failed
[  146.188953] bcmsdh_sdmmc: probe of sdio:0001:2 failed with error -12
[  146.189033] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[  146.801248] libphy: stmmac-0:00 - Link is Up - 1000/Full
[  149.452227] vout_serve: vmode set to 720p60hz
You can see where I disconnect the ethernet cable. Also, don't know how to disable completely the wifi module, maybe it has something to do with it.
Here are the contents of the file, which will allow you to have a static address. Change the highlighted value to the desired ip.
# Wired adapter #1
auto eth0
gateway 192.168.1.1
# Local loopback
auto lo
I really know how to do this, you will see in my config that static settings are commented out. :)
Don't worry about that, I'm just a particularly case, I can live with that.
Dmesg output is taken after changing to static ip, but man...it takes long to boot.
So, I'll stay with dhcp settings until I'll find out how to completely disable wifi modules without breaking the server.
Thank you again for your work!
Open the file /etc/module and remove from the run list module Wi-Fi (wifi_dumy). If does not help, additionally insert in the blocking list all the modules that are in the output of the lsmod command is responsible for Wi-Fi.
Yes, removing wifi_dumy from /etc/modules worked like a charm, now there is no problem and all is ok, with static ip. :beer:
@gnthibault I see you're waiting for an H96+ Pro - mind trying a memory benchmark on it? (previous comment)
I've managed to get my hands on this device without having to buy it and I'm about to do some testing, having successfully booted with the following dtb file (q912_otg.dtb):
https://mega.nz/#!4VVxiaxL!GpIoviN2diegsmlfovIV2zElfv_eQ6EPXBukSRd58y0
I'll be posting benchmark results including memory performance soon.
