@lanefu, @TonyMac32  I am looking for support of native english speakers.
I just wanted to install RPi-Monitor, listed all options to find it: armbianmonitor --help  and saw this :
armbianmonitor -M provides simple CLI monitoring - fixed-line output
armbianmonitor -N provides simple CLI network monitoring - fixed-line output
So, I thought what has been repaired  (fixed) ?
So, I tested the two options -m & -M   and I saw,
    -m is with history, not scrolling rather new-line feed
    -M is dynamically refreshing in line (static), (fix,  but not fixed)
In short, I think the wording is a bit bumpy.  My suggestion to change wording, as below:
armbianmonitor -m provides simple CLI monitoring - new-line feed output
armbianmonitor -M provides simple CLI monitoring - automatic refreshing in line output
armbianmonitor -n provides simple CLI network monitoring - new-line feed output
armbianmonitor -N provides simple CLI network monitoring - automatic refreshing in line output
What do you think?
The word "automatic" could imply that the other outputs are not automatically refreshing.
  • Tido changed the title to armbianmonitor - service description
Hi Werner, not only that, while thinking about it I realized that the title of my posting is wrong - it is the service description not the naming conventions :)
Expand
I agree with you, as a Swiss (non native speaker). Does it explain itself better like this:
armbianmonitor -m provides simple CLI monitoring - automatic new-line feed output
armbianmonitor -n provides simple CLI network monitoring - automatic new-line feed output
By the way, everybody is welcome to chime in !
