ILI9488 display patch for SKU: MSP3520, MSP3521, MSP4020, MSP4021
I am releasing this patch in the hope of you may find it useful. I have also included a sample dts file.  It seems to work in 48mhz quite well with very few SPI errors. (Note that the pieces of the driver has been around for some time but I have never seen it put together without further work. Hopefully this patch would make it readily usable. I have tested it on 5.5.18 and quite happy with it.)
0001-fbtft-fb_ili9488.patch 1_ili9488.dts
Sample file is for nanopi neo.
Driver also works with 4 inch LCD, MSP4020, MSP4021
The colors seem a bit off, I tried fixing it with the following changes. Its a better approximation/mapping and also makes screen brighter but the colors still a bit off. Any ideas?
for (i = 0; i < to_copy; i++) {
+            u16 pixel = vmem16;
+            u16 b = pixel & 0x1f;
+            u16 g = (pixel & (0x3f << 5)) >> 5;
+            u16 r = (pixel & (0x1f << 11)) >> 11;
+            u8 r8 = ((r & 0x1F)*4*63)/31 + 3;
+            u8 g8 = (g & 0x3F)*4 + 3;
+            u8 b8 = ((b & 0x1F)*4*63)/31 + 3;
+            txbuf[i * 3 + 0] = r8;
+            txbuf[i * 3 + 1] = g8;
+            txbuf[i * 3 + 2] = b8;
Thank a lot for your ILI9488 driver. Indeed the colors seem not as they should be.  But this part of code do not work for me at all:
I'm getting these lines regardless of whether what is located in framebuffer:
Edited by enclis
On another note, kernel 5.7 or later is somehow automatically switched to use DRM driver for ili9486 displays - this driver is not working. To work around this I made a copy of the fb ili9486 driver with a different name:
0001-fbtft-fb_ili9486o.patch
update: DRM driver is working (slowly) on 5.9, so may be you don't need this patch any more... fbdev drivers seem to take precedence over DRM drivers, so if you leave this in it would still use the fbdev driver -- for drmfb the initialization string seemed not being honored may be the reason why it's so slow
hi
could you please explain how to apply this patch?
all im getting is:
$patch < 0001-fbtft-fb_ili9488.patch
can't find file to patch at input line 5
Perhaps you should have used the -p or --strip option?
The text leading up to this was:
|diff --git a/drivers/staging/fbtft/Kconfig b/drivers/staging/fbtft/Kconfig
|index dad1ddcd7..fd27a2dea 100644
|--- a/drivers/staging/fbtft/Kconfig
|+++ b/drivers/staging/fbtft/Kconfig
thanks!!
