teknoid 0 Posted May 3, 2020 Share Posted May 3, 2020 I've just installed latest minimal image (https://dl.armbian.com/bananapipro/Buster_current_minimal) and found some issues: Doing apt-get update results in: 30 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/49.8 MB of archives. After this operation, 618 kB disk space will be freed. Do you want to continue? [Y/n] Preconfiguring packages ... dpkg-deb: error while loading shared libraries: dpkg-deb: unsupported version 0 of Verneed record dpkg: error processing archive /var/cache/apt/archives/base-files_10.3+deb10u3_armhf.deb (--unpack): dpkg-deb --control subprocess returned error exit status 127 I fixed this by using an old dpkg-deb that i copied over /usr/bin/dpkg-deb. After doing that upgrade went fine. At each login I get message Warning: a reboot is needed to finish resizing the filesystem Please reboot the system as soon as possible So it looks like armbian-firstrun did not properly work. I check system log and found: May 3 13:52:36 localhost armbian-firstrun[1029]: /usr/lib/armbian/armbian-firstrun: line 39: iozone: command not found I installed iozone3 and manually run "/usr/lib/armbian/armbian-firstrun start". Reboot, but message still there. So I deleted rm /var/run/resize2fs-reboot. Reboot, still there. Hmmm. I deleted /etc/systemd/system/multi-user.target.wants/armbian-firstrun-config.service. Still there. It was finally gone after doing systemctl disable armbian-resize-filesystem.service Greetings Heiko 0 Quote Link to post Share on other sites More sharing options...
Igor 2301 Posted May 3, 2020 Share Posted May 3, 2020 Bug ... was fixed for the future https://github.com/armbian/build/commit/bbaddc8aaa2cc3d3ffa6324c4472eab812f84781 0 Quote Link to post Share on other sites More sharing options...
