Rolf Bakker Posted May 4, 2020 Posted May 4, 2020 Armbianmonitor: http://ix.io/2kIJ I've got a Sony RX100VA camera that I want to connect to the NanoPi Neo2 running Armbian Buster. On the Camera I can select the type of USB connection: -Auto -Mass Storage -MTP -PC Remote My intention is to use the PC Remote connection for use with gphoto2, this works fine on a PC with Ubuntu 18.04, but when I connect the camera to the Nano Pi Neo2 with Armbian, the camera display shows connecting (but doesn't connect). I suspect a bug in the OS, but I am unsure how to find it. lsusb gives the following report with an error: can't get debug descriptor: Resource temporarily unavailable root@nanopineo2:~# lsusb -d 054c:0cb2 -v Bus 003 Device 019: ID 054c:0cb2 Sony Corp. Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0x054c Sony Corp. idProduct 0x0cb2 bcdDevice 2.00 iManufacturer 1 Sony iProduct 2 DSC-RX100M5A iSerial 3 C7A5602C40B2 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x0027 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xc0 Self Powered MaxPower 100mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 3 bInterfaceClass 6 Imaging bInterfaceSubClass 1 Still Image Capture bInterfaceProtocol 1 Picture Transfer Protocol (PIMA 15470) iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 7 Device Qualifier (for other device speed): bLength 10 bDescriptorType 6 bcdUSB 2.00 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 bNumConfigurations 1 can't get debug descriptor: Resource temporarily unavailable Device Status: 0x0000 (Bus Powered) Mounting as a mass storage device works fine, but then I can't use it with gphoto2. How do I find the bug?
Werner Posted May 4, 2020 Posted May 4, 2020 Could you grab the dmesg output when connection the camera to your PC? Maybe there is a kernel module missing in the Armbian kernel config.
Rolf Bakker Posted May 4, 2020 Author Posted May 4, 2020 dmesg output Connect Sony via USB [ 6581.158357] usb 3-1: new high-speed USB device number 14 using ehci-platform [ 6581.187896] usb 3-1: New USB device found, idVendor=054c, idProduct=0cb2, bcdDevice= 2.00 [ 6581.187915] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 6581.187926] usb 3-1: Product: DSC-RX100M5A [ 6581.187937] usb 3-1: Manufacturer: Sony [ 6581.187947] usb 3-1: SerialNumber: C7A5602C40B2 Disconnect Sony from USB [ 6637.583714] usb 3-1: USB disconnect, device number 14 The dmesg output is also part of the Armbianmonitor, of which the output can be found here: http://ix.io/2kIJ I just found out that despite the camera shows the connecting message, I am able to send gphoto2 commands to the camera. However, normally the connecting message would disappear and a live view is visible on the camera lcd screen. So although it appears to work, there is something odd in the USB connection. The behaviour is very similar for Armbian Buster and Armbian Bionic.
Igor Posted May 4, 2020 Posted May 4, 2020 13 minutes ago, Rolf Bakker said: The behaviour is very similar for Armbian Buster and Armbian Bionic. Armbian is the hardware interface, "Buster" or "Bionic" are only userland which you choose upon your software need. You need drivers for this card (probably it just need to be enabled in the config). Try nightly images - we recently enable lots of drivers ... Storage mode works because that is very basic and generic feature. Perhaps it is just a power problem - with mUSB powered devices this is the first thing you check - put powered USB hub in between.
Rolf Bakker Posted May 4, 2020 Author Posted May 4, 2020 ok, thanks for the explanation and the driver suggestion. The device is not powered via mUSB, it has its own power supply. It's great to receive the feedback and suggestions in such a short time after posting the question.
Werner Posted May 5, 2020 Posted May 5, 2020 From what I have seen so far is that the output is identical. Which is good...and bad because it does not bring us any further If you want to continue debugging kernelside you can compare the loaded kernel modules on both PC and SBC.
Rolf Bakker Posted May 6, 2020 Author Posted May 6, 2020 Hi Werner, Thank you for your support. Yesterday I was tied up and couldn't respond. I would like to help getting to the bottom of this, so I got behind the Ubuntu PC and did some tests. In the meantime I have updated the gpphoto2 to the latest version on the Ubuntu PC. The Ubuntu PC has a fresh Ubuntu 18.04 install. gphoto2 2.5.23 Copyright (c) 2000-2019 Marcus Meissner and others gphoto2 comes with NO WARRANTY, to the extent permitted by law. You may redistribute copies of gphoto2 under the terms of the GNU General Public License. For more information about these matters, see the files named COPYING. This version of gphoto2 is using the following software versions and options: gphoto2 2.5.23 gcc, popt(m), exif, no cdk, no aa, no jpeg, no readline libgphoto2 2.5.24 standard camlibs (SKIPPING lumix), gcc, ltdl, EXIF libgphoto2_port 0.12.0 iolibs: disk ptpip serial usb usbdiskdirect usbscsi, gcc, ltdl, EXIF, USB, serial without locking But now the gphoto2 software stopped working on the Ubuntu PC The last working version on the Ubuntu is based on libgphoto2 2.5.22 instead of libgphoto2 2.5.24 gphoto2 2.5.23 Copyright (c) 2000-2019 Marcus Meissner and others gphoto2 comes with NO WARRANTY, to the extent permitted by law. You may redistribute copies of gphoto2 under the terms of the GNU General Public License. For more information about these matters, see the files named COPYING. This version of gphoto2 is using the following software versions and options: gphoto2 2.5.23 gcc, popt(m), exif, no cdk, no aa, no jpeg, no readline libgphoto2 2.5.22 all camlibs, gcc, ltdl, EXIF libgphoto2_port 0.12.0 iolibs: disk ptpip serial usb usbdiskdirect usbscsi, gcc, ltdl, USB, serial without locking So, maybe its wise to have the libgphoto2 bug fix first which appeared in libgphoto2 2.5.23 Anyway the lsmod on the Ubuntu pc shows the following: root@ubuntu-test-pc:~# lsmod Module Size Used by rfcomm 81920 4 ccm 20480 9 cmac 16384 1 intel_rapl_msr 20480 0 intel_rapl_common 24576 1 intel_rapl_msr x86_pkg_temp_thermal 20480 0 intel_powerclamp 20480 0 coretemp 20480 0 kvm_intel 245760 0 kvm 655360 1 kvm_intel irqbypass 16384 1 kvm bnep 24576 2 crct10dif_pclmul 16384 1 crc32_pclmul 16384 0 mei_hdcp 24576 0 snd_hda_codec_hdmi 57344 1 ghash_clmulni_intel 16384 0 rtl8821ae 233472 0 snd_soc_rt5640 143360 0 btcoexist 147456 1 rtl8821ae snd_soc_rl6231 20480 1 snd_soc_rt5640 rtl_pci 28672 1 rtl8821ae aesni_intel 372736 8 aes_x86_64 20480 1 aesni_intel crypto_simd 16384 1 aesni_intel rtlwifi 90112 3 rtl_pci,rtl8821ae,btcoexist cryptd 24576 2 crypto_simd,ghash_clmulni_intel glue_helper 16384 1 aesni_intel snd_hda_codec_realtek 118784 1 intel_cstate 20480 0 snd_hda_codec_generic 81920 1 snd_hda_codec_realtek mac80211 847872 3 rtl_pci,rtl8821ae,rtlwifi intel_rapl_perf 20480 0 ledtrig_audio 16384 2 snd_hda_codec_generic,snd_hda_codec_realtek snd_soc_core 237568 1 snd_soc_rt5640 snd_compress 24576 1 snd_soc_core ac97_bus 16384 1 snd_soc_core snd_pcm_dmaengine 16384 1 snd_soc_core i915 1937408 28 snd_seq_midi 20480 0 input_leds 16384 0 snd_hda_intel 53248 10 snd_seq_midi_event 16384 1 snd_seq_midi snd_intel_nhlt 20480 1 snd_hda_intel snd_hda_codec 131072 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek cfg80211 704512 2 rtlwifi,mac80211 drm_kms_helper 180224 1 i915 btusb 57344 0 btrtl 20480 1 btusb snd_hda_core 90112 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek snd_hwdep 20480 1 snd_hda_codec btbcm 16384 1 btusb btintel 24576 1 btusb lpc_ich 24576 0 drm 491520 18 drm_kms_helper,i915 libarc4 16384 1 mac80211 bluetooth 573440 33 btrtl,btintel,btbcm,bnep,btusb,rfcomm snd_rawmidi 36864 1 snd_seq_midi snd_pcm 102400 7 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_soc_rt5640,snd_soc_core,snd_hda_core,snd_pcm_dmaengine i2c_algo_bit 16384 1 i915 fb_sys_fops 16384 1 drm_kms_helper syscopyarea 16384 1 drm_kms_helper mei_me 40960 1 sysfillrect 16384 1 drm_kms_helper ecdh_generic 16384 2 bluetooth mei 102400 3 mei_hdcp,mei_me ecc 32768 1 ecdh_generic sysimgblt 16384 1 drm_kms_helper snd_seq 69632 2 snd_seq_midi,snd_seq_midi_event snd_seq_device 16384 3 snd_seq,snd_seq_midi,snd_rawmidi snd_timer 36864 2 snd_seq,snd_pcm snd 86016 33 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm,snd_rawmidi soundcore 16384 1 snd intel_smartconnect 16384 0 acpi_pad 184320 0 mac_hid 16384 0 sch_fq_codel 20480 9 parport_pc 40960 0 ppdev 24576 0 lp 20480 0 parport 53248 3 parport_pc,lp,ppdev ip_tables 32768 0 x_tables 40960 1 ip_tables autofs4 45056 2 hid_generic 16384 0 usbhid 53248 0 hid 126976 2 usbhid,hid_generic ahci 40960 1 libahci 32768 1 ahci alx 49152 0 mdio 16384 1 alx video 49152 1 i915 The lsmod on the NanoPi Neo2 with Armbian shows this: root@nanopineo2:~# lsmod Module Size Used by rfkill 28672 1 zstd 16384 4 snd_soc_simple_card 16384 0 sun8i_codec_analog 32768 0 snd_soc_simple_card_utils 16384 1 snd_soc_simple_card sun4i_i2s 24576 0 sun8i_adda_pr_regmap 16384 1 sun8i_codec_analog zram 32768 2 snd_soc_core 151552 4 sun4i_i2s,sun8i_codec_analog,snd_soc_simple_card_utils,snd_soc_simple_card snd_pcm_dmaengine 16384 1 snd_soc_core sunxi_cedrus 40960 0 lima 45056 0 snd_pcm 106496 3 sun4i_i2s,snd_soc_core,snd_pcm_dmaengine gpu_sched 28672 1 lima sun4i_gpadc_iio 24576 0 snd_timer 36864 1 snd_pcm v4l2_mem2mem 28672 1 sunxi_cedrus snd 73728 3 snd_timer,snd_soc_core,snd_pcm industrialio 69632 1 sun4i_gpadc_iio videobuf2_dma_contig 20480 1 sunxi_cedrus soundcore 16384 1 snd videobuf2_memops 16384 1 videobuf2_dma_contig videobuf2_v4l2 28672 2 sunxi_cedrus,v4l2_mem2mem videobuf2_common 40960 3 sunxi_cedrus,videobuf2_v4l2,v4l2_mem2mem videodev 225280 4 sunxi_cedrus,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem mc 45056 5 sunxi_cedrus,videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem cpufreq_dt 16384 0 usb_f_acm 16384 1 u_serial 28672 1 usb_f_acm g_serial 16384 0 libcomposite 53248 2 g_serial,usb_f_acm realtek 20480 1 dwmac_sun8i 24576 0 mdio_mux 16384 1 dwmac_sun8i But the NanoPi Neo is on a different version, not sure why. gphoto2 2.5.20 Copyright (c) 2000-2018 Lutz Mueller and others gphoto2 comes with NO WARRANTY, to the extent permitted by law. You may redistribute copies of gphoto2 under the terms of the GNU General Public License. For more information about these matters, see the files named COPYING. This version of gphoto2 is using the following software versions and options: gphoto2 2.5.20 gcc, popt(m), exif, cdk, aa, jpeg, readline libgphoto2 2.5.22 all camlibs, gcc, ltdl, EXIF libgphoto2_port 0.12.0 iolibs: disk ptpip serial usb1 usbdiskdirect usbscsi, gcc, ltdl, USB, serial without locking But I am not sure whether that has an impact on how the Camera connects. That issue remains.Ubuntu 18.04 behaviour: Camera display shows live view --> plug in USB to camera --> display shows brief message "Connecting" --> camera display shows live view again.Armbian behaviour: Camera display shows live view --> plug in USB to camera --> display shows message "Connecting" --> camera display continuous to show "Connecting message". Only when a new command gphoto2 command is issued the live view returns. If there is anything else I can do to help solve this, please let me know.
Igor Posted May 6, 2020 Posted May 6, 2020 7 hours ago, Rolf Bakker said: If there is anything else I can do to help solve this, please let me know. I assume that modules list above is with a connected camera and on most recent Armbian beta kernel? armbian-config -> system -> nightly builds 7 hours ago, Rolf Bakker said: But the NanoPi Neo is on a different version, not sure why. Did you update packages after you started?
