Armbianmonitor:
I have one FriendlyARM NanoPi R2S. It should have 1G DDR4 memory. Everything works fine with latest Armbian 20.02.08 except only 512M memory shows up. Both Buster and Bionic have the same issue:
Armbian_20.02.8_Nanopi-r2s_buster_current_5.4.28
Armbian_20.02.8_Nanopi-r2s_bionic_current_5.4.28
I tried FriendlyARM official FriendlyCore. I can see all 1G memory, /proc/meminfo on FriendlyCore is as follows:
MemTotal:         971052 kB
MemFree:          842880 kB
MemAvailable:     844352 kB
Buffers:            8012 kB
Cached:            48272 kB
SwapCached:            0 kB
Active:            45904 kB
Inactive:          31580 kB
Active(anon):      21408 kB
Inactive(anon):     4768 kB
Active(file):      24496 kB
Inactive(file):    26812 kB
Unevictable:           4 kB
Mlocked:               0 kB
SwapTotal:             0 kB
SwapFree:              0 kB
Dirty:              1392 kB
Writeback:             0 kB
AnonPages:         21116 kB
Mapped:            24300 kB
Shmem:              4976 kB
KReclaimable:      19212 kB
Slab:              36376 kB
SReclaimable:      19212 kB
SUnreclaim:        17164 kB
KernelStack:        1824 kB
PageTables:          780 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:      485524 kB
Committed_AS:     114152 kB
VmallocTotal:   262930368 kB
VmallocUsed:        2664 kB
VmallocChunk:          0 kB
Percpu:              656 kB
AnonHugePages:         0 kB
ShmemHugePages:        0 kB
ShmemPmdMapped:        0 kB
FileHugePages:         0 kB
FilePmdMapped:         0 kB
CmaTotal:          16384 kB
CmaFree:           15344 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
Hugetlb:               0 kB
I don't have UART to USB at home, so i get these information through ssh. How can i use the other half of the memory?
  On 5/8/2020 at 8:47 AM, Igor said:
Expand
The first one Armbian_20.02.14.129_Nanopi-r2s_focal_current_5.4.39_minimal works fine. I can see all 1G RAM now.
The second one Armbian_20.02.14.129_Nanopi-r2s_focal_dev_5.6.11_minimal doesn't startup. LEDs onboard don't blink and no devices on DHCP. I'm ordering a USL-TTL adapter to see if there is anything on serial.
Expand
This is the reason:
  Reveal hidden contents
Expand
Until yesterday evening NanoPi R2S was only supported in current. That's why dev build is not working.
Next builds (@Igor will this happen automatically if I added dev target to targets.conf) will work properly.
Expand
If some target does not build, nightly builds stops and waits for manual intervention ... I restarted it this morning and its not finished yet. In last https://dl.armbian.com/nanopi-r2s/nightly/ those changes are not included yet.
In a few hours.
