olivluca Posted May 11, 2020 Posted May 11, 2020 Armbianmonitor: http://ix.io/2lCo Today unattended-upgrades warned me that hostapd was on hold: Unattended upgrade returned: True Packages that were upgraded: Packages with upgradable origin but kept back: Armbian xenial: hostapd I checked and it's because it depends on libssl1.1 >= 1.1.1 which isn't available The following packages have unmet dependencies: hostapd : Depends: libssl1.1 (>= 1.1.1) but it is not installable E: Unable to correct problems, you have held broken packages. The package comes from armbian's repository (ubuntu has an older version) $ apt-cache policy hostapd hostapd: Installed: 3:2.7-99~armbian5.73+1 Candidate: 3:2.9-100~armbian20.05.0-trunk+1 Version table: 3:2.9-100~armbian20.05.0-trunk+1 500 500 http://apt.armbian.com xenial/main armhf Packages *** 3:2.7-99~armbian5.73+1 100 100 /var/lib/dpkg/status 1:2.4-0ubuntu6.6 500 500 http://ports.ubuntu.com xenial-security/universe armhf Packages 500 http://ports.ubuntu.com xenial-updates/universe armhf Packages 1:2.4-0ubuntu6 500 500 http://ports.ubuntu.com xenial/universe armhf Packages I don't use or need it (I suppose it was installed by default in the original image) but I thought to report it anyway.
Igor Posted May 11, 2020 Posted May 11, 2020 It should be fixed yesterday - the same problem was with Bionic. Can you try (apt update + upgrade) once again? https://apt.armbian.com/pool/main/w/wpa/ https://apt.armbian.com/pool/main/w/wpa/hostapd_2.9-100~armbian20.05.0-trunk%2B1_armhf.deb
Cucaracha Posted May 11, 2020 Posted May 11, 2020 Hi folks, I'm using a NanoPi Neo 2 with Armbian Buster but I think my problem does not relate to this specific hardware. I wanted to update my Pi today, so I ran: > sudo apt update Hit:1 [... and so on] Reading package lists... Done Building dependency tree Reading state information... Done 1 package can be upgraded. Run 'apt list --upgradable' to see it. and > sudo apt list --upgradable Listing... Done hostapd/buster 3:2.9-101~armbian20.05.0-trunk+1 arm64 [upgradable from: 3:2.7-99~armbian5.86+1] N: There are 4 additional versions. Please use the '-a' switch to see them. But I could not upgrade. It says there are no packages available. So I ran: > sudo apt install hostapd Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: hostapd : Depends: libssl1.0.0 (>= 1.0.2~beta3) but it is not installable E: Unable to correct problems, you have held broken packages. Today I updated Pi-Hole and yesterday I activated unintended-upgrades (security updates) by editing /etc/apt/apt.conf.d/02-armbian-periodic. I also executed the following command: sudo dpkg-divert --no-rename --add /etc/apt/apt.conf.d/02-armbian-periodic So there is something broken but I don't know what and how I can fix it. I hope you can help me. Thanks in advance.
