jcheriton Posted May 11, 2020 Posted May 11, 2020 It been a while since I have made custom images for the OrangePi PC Plus so things have changed a bit in the intervening period. First I made the development environment change to Ubuntu Focal, then changes to a couple of patch files to bring them into line with the new u-boot and kernel versions however I have simply lost the ability to display an Armbian splash screen during boot. In the past I had patched general-armbian-boot-logo-on-screen-center.patch and general-armbian-boot-logo-on-screen-center copy.patch to show the splash screen I required however now these patches are this patch is no longer even referenced during the build process. Now, after the build, even with logo=enabled in armbianEnv.txt (this is also probably been superseded during the last year) I have no splash screen during kernel boot. So just in case it was my build, I downloaded the latest Buster server build (Linux 5.4.20-sunxi) and edited armbvianEnv.txt to enable the logo. No joy, still no splash screen. Is there something I've missed? Trawling through the forums has not found any information that I can find. Has the splash screen been lost during the process of updating the kernel, or am I just being dense?
Igor Posted May 11, 2020 Posted May 11, 2020 On 5/11/2020 at 1:08 PM, jcheriton said: Is there something I've missed? Expand "Disable DE2 in u-boot to improve EDID detection" https://github.com/armbian/build/commit/5e8cbd8e6aaa87ee03d08c761d5e765e81c4c686#diff-380d179e59cc86f471a51c3aa7c21299 Waiting someone to implement plymouth https://github.com/armbian/build/commit/b41834796294709644a4e503086bfbdd27b87785#diff-380d179e59cc86f471a51c3aa7c21299
jcheriton Posted May 12, 2020 Author Posted May 12, 2020 Thanks Igor. I already have u-boot working with a splash screen and no text. It's the kernel boot that is the problem. I found the Plymouth forum topic and tried to implement it on my OrangPi PC Plus but it failed to boot once I had installed it, along with the themes, and had run init-ramfs. Perhaps more investigation required to make Plymouth work. When I get some time I'll have a look at it.
DevShanky Posted May 30, 2020 Posted May 30, 2020 @jcheriton The patch Igor has mentioned is already included in the latest build as of today. I was able to locate one of the patch files you have mentioned: 1. general-armbian-boot-logo-on-screen-center.patch (https://github.com/FireflyTeam/armbian-build/blob/master/patch/kernel/odroidn2-default/general-armbian-boot-logo-on-screen-center.patch) The other patch that has 'copy' in its name is not traceable general-armbian-boot-logo-on-screen-center copy.patch. Will it be possible for you to point me to this another file. My device is orangepiplus2e so I hope this would work. I am unable to get the logo displayed with just '"Disable DE2 in u-boot to improve EDID detection""' Any help is highly appreciated! Thanks & Regards -R
jcheriton Posted June 1, 2020 Author Posted June 1, 2020 Rajesh Sorry that was my bad. The .copy file is simply that, a saved copy of the original general-armbian-boot-logo-on-screen-center.patch and should never have been mentioned above. Please ignore any reference to it!
DevShanky Posted June 1, 2020 Posted June 1, 2020 On 6/1/2020 at 7:04 AM, jcheriton said: Rajesh Sorry that was my bad. The .copy file is simply that, a saved copy of the original general-armbian-boot-logo-on-screen-center.patch and should never have been mentioned above. Please ignore any reference to it! Expand This patch fails on the latest 20.08 build. Looks like some of the newer patches supersedes this one. I think I am going to throw in the towel on the u-boot splash image. Tried everything I could. If you want a bootspalsh as kernel loads, you may want to try https://www.tanzolab.it/CM3-Panel-boot-process Nothing fancy. Running fim as systemd service. The earlier it loads, the better the user experience. Thank you for your response and help. Regards -Rajesh
usual user Posted June 1, 2020 Posted June 1, 2020 The proper way to implement a bootsplash is to use the framework in the kernel as referenced here. Quote Bootsplash ========== There is support in place now for writing internal DRM clients making it possible to pick up the bootsplash work that was rejected because it was written for fbdev. - [v6,8/8] drm/client: Hack: Add bootsplash example https://patchwork.freedesktop.org/patch/306579/ - [RFC PATCH v2 00/13] Kernel based bootsplash https://lkml.org/lkml/2017/12/13/764 Contact: Sam Ravnborg Level: Advanced Expand Max Staudt promised in one of his last posts to implement his work as soon as a framework will be available but he never showed up again. The referenced example hack shows that the framework works, only someone needs to implement the bells and whistles.
DevShanky Posted June 4, 2020 Posted June 4, 2020 I finally managed to get the plymouth working on Orange Pi Plus 2e. 1. Enabled the patch remove-boot-messages-from-hdmi.patch removed .disable. I get this warning during the build 'Cannot update. patch has changed. Options exit, ignore and continue. I chose ignore and continue) 2. Install plymouth as per instructions in I had to remove these two lines from armbianEnv.txt console=custom consoleargs="console=ttyS0,115200 console=tty7" and replace with console=serial The custom image I am building excluded Ethernet drivers and with these line above u-boot keeps on looking for ethernet device. Not sure if these two are related but removing these lines did help. The plymouth theme comes into action when kernel loads however I still do not see boot logo. I am wondering if removing this patch 'xxx-disable-de2-to-improve-edid-detection.patch' would help. Thanks & Regards Rajesh
DevShanky Posted June 4, 2020 Posted June 4, 2020 Update: I disabled patch xxx-disable-de2-to-improve-edid-detection.patch.disable so the boot logo now works. But this breaks plymouth. It takes longer than usual to load the kernel and ends up booting in initramfs prompt. It appears the patch 'remove-boot-messages-from-hdmi.patch' does not go too well with plymouth. -Rajesh
DevShanky Posted June 4, 2020 Posted June 4, 2020 All issues resolved. I was copying a preset armbianEnv.txt (to save time to type in the details each time). Obviously the UUID of rootfs was different. In Summary To enable boot logo: 1. disable patch xxx-disable-de2-to-improve-edid-detection.patch 2. enable patch remove-boot-messages-from-hdmi.patch Follow instructions in link below to install plymouth -Rajesh 1
