Armbianmonitor:
I'm getting logspam from RTL871X running buster on my OrangePi Plus 2e.
I'm not using wifi on this so I guess I could just disable/blacklist rtl871x to stop this?
But is there a better/cleaner way to stop all these log entries?
Or does it indicate something is broken/mis-configured?
syslog is showing many many log entries from RTL871X; each minute I get the following sequence:
May 23 16:52:06 orangepiplus2e kernel: RTL871X: cfg80211_rtw_scan(wlan0)
May 23 16:52:06 orangepiplus2e kernel: RTL871X: _rtw_pwr_wakeup call ips_leave....
May 23 16:52:06 orangepiplus2e kernel: RTL871X: ==>ips_leave cnts:112
May 23 16:52:06 orangepiplus2e kernel: RTL871X: ===>  rtw_ips_pwr_up..............
May 23 16:52:06 orangepiplus2e kernel: RTL871X: ===> ips_netdrv_open.........
May 23 16:52:06 orangepiplus2e kernel: RTL871X: FW does not exist before power on!!
May 23 16:52:06 orangepiplus2e kernel: RTL871X: SetHwReg8188F: hci_sus_state=1
May 23 16:52:06 orangepiplus2e kernel: RTL871X: SetHwReg8188F: bMacPwrCtrlOn=1
May 23 16:52:06 orangepiplus2e kernel: RTL871X: SetHwReg8188F: hci_sus_state=2
May 23 16:52:06 orangepiplus2e kernel: RTL871X: PowerOnCheck: val_mix:0x0000063f, res:0x0000063f
May 23 16:52:06 orangepiplus2e kernel: RTL871X: PowerOnCheck: 0x100 the result of cmd52 and cmd53 is the same.
May 23 16:52:06 orangepiplus2e kernel: RTL871X: PowerOnCheck: 0x1B8 test Pass.
May 23 16:52:06 orangepiplus2e kernel: RTL871X: Power on ok!
May 23 16:52:06 orangepiplus2e kernel: RTL871X: rtl8188f_FirmwareDownload(wlan0) tmp_ps=3
May 23 16:52:06 orangepiplus2e kernel: RTL871X: rtl8188f_FirmwareDownload fw: FW_NIC, size: 21020
May 23 16:52:06 orangepiplus2e kernel: RTL871X: rtl8188f_FirmwareDownload: fw_ver=4 fw_subver=0000 sig=0x88f1, Month=08, Date=22, Hour=17, Minute=36
May 23 16:52:06 orangepiplus2e kernel: RTL871X: rtl8188f_FirmwareDownload(): Shift for fw header!
May 23 16:52:06 orangepiplus2e kernel: RTL871X: rtl8188f_FirmwareDownload by IO write!
May 23 16:52:06 orangepiplus2e kernel: RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00050505
May 23 16:52:06 orangepiplus2e kernel: RTL871X: _8051Reset8188: Finish
May 23 16:52:06 orangepiplus2e kernel: RTL871X: _FWFreeToGo: Polling FW ready OK! (237, 16ms), REG_MCUFWDL:0x000505c6
May 23 16:52:06 orangepiplus2e kernel: RTL871X: rtl8188f_FirmwareDownload: DLFW OK !
May 23 16:52:06 orangepiplus2e kernel: RTL871X: rtl8188f_FirmwareDownload success. write_fw:1, 236ms
May 23 16:52:06 orangepiplus2e kernel: RTL871X:  <=== rtl8188f_FirmwareDownload()
May 23 16:52:06 orangepiplus2e kernel: RTL871X: HalDetectPwrDownMode(): PDN=0
May 23 16:52:06 orangepiplus2e kernel: RTL871X: Set RF Chip ID to RF_6052 and RF type to 3.
May 23 16:52:06 orangepiplus2e kernel: RTL871X: #### hw_var_set_opmode() -4815 iface_type(0) mode = 2 ####
May 23 16:52:06 orangepiplus2e kernel: RTL871X: rtw_rf_get_kfree_tx_gain_offset path:0, ch:6, bb_gain_sel:0, kfree_offset:0
May 23 16:52:06 orangepiplus2e kernel: RTL871X: kfree gain_offset 0x55:0x82060
May 23 16:52:06 orangepiplus2e kernel: RTL871X:  after :0x2060
May 23 16:52:06 orangepiplus2e kernel: RTL871X: <===  rtw_ips_pwr_up.............. in 728ms
May 23 16:52:06 orangepiplus2e kernel: RTL871X: nolinked power save leave
May 23 16:52:06 orangepiplus2e kernel: RTL871X: ==> ips_leave.....LED(0x01028282)...
May 23 16:52:08 orangepiplus2e kernel: RTL871X: survey done event(35) band:0 for wlan0
May 23 16:52:08 orangepiplus2e kernel: RTL871X: rtw_indicate_scan_done(wlan0)
May 23 16:52:08 orangepiplus2e kernel: RTL871X: ==>rtw_ps_processor .fw_state(8)
May 23 16:52:08 orangepiplus2e kernel: RTL871X: ==>ips_enter cnts:113
May 23 16:52:08 orangepiplus2e kernel: RTL871X: nolinked power save enter
May 23 16:52:08 orangepiplus2e kernel: RTL871X: ===> rtw_ips_pwr_down...................
May 23 16:52:08 orangepiplus2e kernel: RTL871X: ====> rtw_ips_dev_unload...
May 23 16:52:08 orangepiplus2e kernel: RTL871X: SetHwReg8188F: bMacPwrCtrlOn=0
May 23 16:52:08 orangepiplus2e kernel: RTL871X: SetHwReg8188F: hci_sus_state=3
May 23 16:52:08 orangepiplus2e kernel: RTL871X: SetHwReg8188F: hci_sus_state=0
May 23 16:52:08 orangepiplus2e kernel: RTL871X: <=== rtw_ips_pwr_down..................... in 8ms
This look like there are debug flags enabled in this driver for some reason.
Not sure from which WiFi driver this comes.
Fun fact: Found a small bug in the system information collector:
[ 10.279598] RTL871X: rtl8189fs vXXX.XXX.24.8_22657.20170607
Expand
Probably has been detected as IP address and therefore anonymized.
