Martin W. Posted May 25, 2020 Share Posted May 25, 2020 Hello, compiling Kernel 5.4.40 (setting in lib.config with KERNELBRANCH=tag:'5.4.40') under Vagrand with RT-Patch "patch-5.4.40-rt24.patch" putting in " ~/build/userpatches/kernel/rockchip64-current/ "for RockPro64 fails. ........ [ o.k. ] * [l][c] general-rt5651-add-mclk.patch [ o.k. ] * [l][c] mp8859-kbuild-makefile.patch [ o.k. ] * [c] patch-5.4.40-rt24.patch [ o.k. ] * [l][c] rk3328-add-dmc-driver.patch [ o.k. ] * [l][c] rk3328-audio-and-renegade-supplies.patch [ o.k. ] * [l][c] rk3328-clean-up-codec-gpio-SD.patch [ o.k. ] * [l][c] rk3328-fix-wrong-mmc-shift.patch [ o.k. ] * [l][c] rk3399-add-sclk-i2sout-src-clock.patch [ o.k. ] * [l][c] rk3399-adjust-txpbl-for-mtu-1500.patch [ o.k. ] * [l][c] rk3399-sd-drive-level-8ma.patch [ o.k. ] * [l][c] rockpi4-0005-arm64-dts-enable-es8316-audio.patch [ o.k. ] * [l][c] timekeeping32-tweaks-for-5.0.y.patch [ o.k. ] * [l][c] unlock-temperature.patch [ .... ] Compressing sources for the linux-source package ..... The following compiling process stopped with: ...... CC security/inode.o CC security/lsm_audit.o CC security/device_cgroup.o CC kernel/configs.o AR security/built-in.a AR kernel/built-in.a CC [M] kernel/kheaders.o[ error ] ERROR in function compile_kernel [ compilation.sh:378 ][ error ] Kernel was not built [ @host ][ o.k. ] Process terminated Any idea what goes wrong ? Martin Link to comment Share on other sites More sharing options...
Igor Posted May 25, 2020 Share Posted May 25, 2020 nano output/debug/compilation.log ... and see what went wrong. Link to comment Share on other sites More sharing options...
Martin W. Posted May 25, 2020 Author Share Posted May 25, 2020 1 hour ago, Igor said: nano output/debug/compilation.log ... and see what went wrong. These are the last lines of compilation.log: ...... == kernel == arch/arm64/boot/dts/rockchip/overlay/rockchip-spi-spidev.dts:22.11-27.6: Warning (spi_bus_reg): /fragment@1/__overlay__/spidev: SPI bus unit address format error, expected "0" arch/arm64/boot/dts/rockchip/overlay/rockchip-spi-spidev.dts:36.11-41.6: Warning (spi_bus_reg): /fragment@2/__overlay__/spidev: SPI bus unit address format error, expected "0" arch/arm64/boot/dts/rockchip/overlay/rockchip-spi-spidev.dts:50.11-55.6: Warning (spi_bus_reg): /fragment@3/__overlay__/spidev: SPI bus unit address format error, expected "0" arch/arm64/boot/dts/rockchip/overlay/rockchip-spi-spidev.dts:64.11-69.6: Warning (spi_bus_reg): /fragment@4/__overlay__/spidev: SPI bus unit address format error, expected "0" arch/arm64/boot/dts/rockchip/rk3328.dtsi:344.5-15: Warning (reg_format): /syscon@ff100000/pd_gpu@1:reg: property has invalid length (4 bytes) (#address-cells == 1, #size-cells == 1) arch/arm64/boot/dts/rockchip/rk3328-evb.dtb: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328-evb.dtb: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328-evb.dtb: Warning (spi_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328.dtsi:344.5-15: Warning (reg_format): /syscon@ff100000/pd_gpu@1:reg: property has invalid length (4 bytes) (#address-cells == 1, #size-cells == 1) arch/arm64/boot/dts/rockchip/rk3328-nanopi-r2-rev00.dtb: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328-nanopi-r2-rev00.dtb: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328-nanopi-r2-rev00.dtb: Warning (spi_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328.dtsi:344.5-15: Warning (reg_format): /syscon@ff100000/pd_gpu@1:reg: property has invalid length (4 bytes) (#address-cells == 1, #size-cells == 1) arch/arm64/boot/dts/rockchip/rk3328-nanopi-r2-rev20.dtb: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328-nanopi-r2-rev20.dtb: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328-nanopi-r2-rev20.dtb: Warning (spi_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328.dtsi:344.5-15: Warning (reg_format): /syscon@ff100000/pd_gpu@1:reg: property has invalid length (4 bytes) (#address-cells == 1, #size-cells == 1) arch/arm64/boot/dts/rockchip/rk3328-rock64.dtb: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328-rock64.dtb: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328-rock64.dtb: Warning (spi_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328.dtsi:344.5-15: Warning (reg_format): /syscon@ff100000/pd_gpu@1:reg: property has invalid length (4 bytes) (#address-cells == 1, #size-cells == 1) arch/arm64/boot/dts/rockchip/rk3328-roc-cc.dtb: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328-roc-cc.dtb: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3328-roc-cc.dtb: Warning (spi_bus_reg): Failed prerequisite 'reg_format' fs/aufs/i_op.c: In function ‘au_pin_hdir_set_owner’: fs/aufs/i_op.c:636:45: error: ‘struct rw_semaphore’ has no member named ‘owner’ atomic_long_set(&p->hdir->hi_inode->i_rwsem.owner, (long)task); ^ make[2]: *** [fs/aufs/i_op.o] Error 1 make[1]: *** [fs/aufs] Error 2 make: *** [fs] Error 2 make: *** Waiting for unfinished jobs.... Link to comment Share on other sites More sharing options...
Igor Posted May 25, 2020 Share Posted May 25, 2020 42 minutes ago, Martin W. said: These are the last lines of compilation.log This log is for you, not for me. Link to comment Share on other sites More sharing options...
martinayotte Posted May 25, 2020 Share Posted May 25, 2020 2 hours ago, Martin W. said: fs/aufs/i_op.c: In function ‘au_pin_hdir_set_owner’: fs/aufs/i_op.c:636:45: error: ‘struct rw_semaphore’ has no member named ‘owner’ You can try to compile with "AUFS=no" ... Link to comment Share on other sites More sharing options...
Martin W. Posted May 26, 2020 Author Share Posted May 26, 2020 (edited) Okay, I disabled aufs, and now it compiles. Thank you for the support. Very strange, what has aufs filesystem with RT to do 🤔. Edited May 26, 2020 by Martin W. Link to comment Share on other sites More sharing options...
martinayotte Posted May 27, 2020 Share Posted May 27, 2020 22 hours ago, Martin W. said: Very strange, what has aufs filesystem with RT to do Nothing special, but maybe ‘struct rw_semaphore’ has changed across kernel versions and ‘owner’ has been removed. To get AUFS working, maybe it require a fix to RT patches to match that change. Link to comment Share on other sites More sharing options...
