dimis7 Posted September 2, 2016 Share Posted September 2, 2016 Hi! I'm trying to implement a OTG USB ethernet interface on a Orange pi one... I'm not an advanced Linux user and the information that I found on the Internet is very confused... The instructions on the first post of this topic i think is the most easy to follow... But the link for the kernel (http://kaiser-edv.de..._kernel.tar.bz2) is not working anymore... Can someone reupload it somewhere? Thanks in advance, Dimitris Link to comment Share on other sites More sharing options...
tkaiser Posted September 2, 2016 Author Share Posted September 2, 2016 Can someone reupload it somewhere? Why don't you upgrade your Armbian installation instead? It's September now and stuff from June might've become obsolete in the meantime Link to comment Share on other sites More sharing options...
dimis7 Posted September 2, 2016 Share Posted September 2, 2016 tkaiser thanks for the really fast reply!! I have done the installation yesterday followed by a apt-get update, apt-get upgrade so I must have the latest release for this board... When I run the commands from first post: echo -n 0 > /sys/bus/platform/devices/sunxi_usb_udc/otg_role modprobe g_ether echo -n 2 > /sys/bus/platform/devices/sunxi_usb_udc/otg_role Nothing happens... the pc didn't find any new device and the orange pi don't show any error... Link to comment Share on other sites More sharing options...
tkaiser Posted September 2, 2016 Author Share Posted September 2, 2016 the pc didn't find any new device and the orange pi don't show any error... If the PC is running Windows then I'm out of ideas (deal only sometimes with this and then it's Windows Server and I can use SSH). At least checking dmesg and lsmod output before and after should help (maybe the module is already loaded?) Link to comment Share on other sites More sharing options...
dimis7 Posted September 2, 2016 Share Posted September 2, 2016 The pc is indeed a windows machine but the goal is to use it on a synology nas box that is running a custom Linux... The wired thing is that Windows not seen any new hardware... I will post later the output of dmesg and lsmod because I don't have the board with me now... Thanks for your help! Link to comment Share on other sites More sharing options...
dimis7 Posted September 2, 2016 Share Posted September 2, 2016 tkaiser than you so much for your help! after checking with dmesg and lsmod i found that the modules is loaded fine... so i connected the board with a rooted android phone and from terminal emulator i tried the command lsusb and guess what: the phone detect the usb device as RNDIS/Ethernet Gadget!!! after that i found three problems with my pc: 1st: for some reason if i have connected on the 2 front usb ports of my pc the orange pi board and my FTDI usb to serial adaper, only the second show up on device manager of windows... 2nd: on the /etc/network/interfaces file i must add the line allow-hotplug usb0. if not the device is not detected by windows... 3rd: the windows don't load the drivers automatically. i flowed the instructions from this page and everything is working fine now... So after all its very easy: 1) Add the g_ether module to /etc/modules 2) Add the following config to /etc/network/interfaces : allow-hotplug usb0iface usb0 inet staticaddress 169.254.1.1netmask 255.255.0.0pre-up /bin/sh -c 'echo 2 > /sys/bus/platform/devices/sunxi_usb_udc/otg_role' 3) Manual install the drivers for windows. Now you can use putty or any other SSH client to connect to orange pi IP (in the above example 169.254.1.1) Once again thanks for your help!! 1 Link to comment Share on other sites More sharing options...
Jim Tibbets Posted September 21, 2016 Share Posted September 21, 2016 tkaiser: I'm a noob when it comes to compiling things. The link to download from your site is not working. I have the latest Armbian installed, but as you know, no g_ether module. I also got Igor2's "lib" off of github, but it doesn't have g_ether installed (I thought it might). Could you post an up to date link, or teach me the magic so I don't have to keep asking everybody for help? I really don't understand what I'm doing, but I learn fast and will spread the knowledge! Link to comment Share on other sites More sharing options...
tkaiser Posted September 22, 2016 Author Share Posted September 22, 2016 tkaiser Starting personal conversations like this or even worse via PM is really no good idea. I'm not a paid supporter here and this is a community forum where users help users. Using g_ether is possible with every recent Armbian image built or updated within the last months, everything is included now and everything is explained here in detail. In case you need someone to walk you through the steps simply ask and it will happen (but not by me, will spend my time on different things) Link to comment Share on other sites More sharing options...
Jim Tibbets Posted September 22, 2016 Share Posted September 22, 2016 I try again then. I just want it to work. If I don't have to compile, that is a plus. Link to comment Share on other sites More sharing options...
tkaiser Posted September 22, 2016 Author Share Posted September 22, 2016 If I don't have to compile, that is a plus. Checked it in the meantime on a host where the g_ether connection is used to act as some sort of a heartbeat connection (to test whether the other SBC is still reachable when all network routes aren't available any more). It's really just definition of an 'usb0' interface with legacy kernel in the following way (more details in post #4 of this thread): tk@bananapim2plus:~$ grep -A5 'allow-hotplug usb0' /etc/network/interfaces allow-hotplug usb0 iface usb0 inet static address 169.254.2.1 netmask 255.255.0.0 pre-up /bin/sh -c 'echo 2 > /sys/bus/platform/devices/sunxi_usb_udc/otg_role' tk@bananapim2plus:~$ /sbin/ifconfig usb0 usb0 Link encap:Ethernet HWaddr ea:10:28:46:e5:7a inet addr:169.254.2.1 Bcast:169.254.255.255 Mask:255.255.0.0 inet6 addr: fe80::e810:28ff:fe46:e57a/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:150 errors:0 dropped:0 overruns:0 frame:0 TX packets:169 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:17569 (17.5 KB) TX bytes:15497 (15.4 KB) tk@bananapim2plus:~$ ping 169.254.2.2 PING 169.254.2.2 (169.254.2.2) 56(84) bytes of data. 64 bytes from 169.254.2.2: icmp_seq=1 ttl=64 time=1.09 ms 64 bytes from 169.254.2.2: icmp_seq=2 ttl=64 time=0.539 ms ^C --- 169.254.2.2 ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 1001ms rtt min/avg/max/mdev = 0.539/0.819/1.099/0.280 ms tk@bananapim2plus:~$ iperf3 -c 169.254.2.2 Connecting to host 169.254.2.2, port 5201 [ 4] local 169.254.2.1 port 52106 connected to 169.254.2.2 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 15.3 MBytes 128 Mbits/sec 0 800 KBytes [ 4] 1.00-2.02 sec 15.9 MBytes 131 Mbits/sec 0 1004 KBytes [ 4] 2.02-3.00 sec 13.5 MBytes 115 Mbits/sec 0 1.10 MBytes [ 4] 3.00-4.01 sec 15.1 MBytes 126 Mbits/sec 0 1.20 MBytes [ 4] 4.01-5.00 sec 14.4 MBytes 121 Mbits/sec 0 1.27 MBytes [ 4] 5.00-6.00 sec 14.4 MBytes 120 Mbits/sec 0 1.32 MBytes [ 4] 6.00-7.01 sec 14.5 MBytes 121 Mbits/sec 0 1.36 MBytes [ 4] 7.01-8.00 sec 13.9 MBytes 118 Mbits/sec 0 1.38 MBytes [ 4] 8.00-9.00 sec 14.9 MBytes 125 Mbits/sec 0 1.39 MBytes [ 4] 9.00-10.01 sec 14.8 MBytes 122 Mbits/sec 0 1.01 MBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.01 sec 147 MBytes 123 Mbits/sec 0 sender [ 4] 0.00-10.01 sec 145 MBytes 122 Mbits/sec receiver iperf Done. Link to comment Share on other sites More sharing options...
hyphop Posted January 13, 2017 Share Posted January 13, 2017 hi g_ether work fine but only for kernel 3.4 i try to do same on last kernel 4.9.0-sun8i but without success lsmod libcomposite 34616 1 usb_f_rndis u_ether 9963 1 usb_f_rndis usb_f_rndis 12443 0 insmod g_ether failed to insert /lib/modules/4.9.0-sun8i/g_ether.ko dmesg -c [ 2404.192826] g_ether musb-hdrc.1.auto: failed to start g_ether: -2 some recommendation for me ? insmod g_ether Link to comment Share on other sites More sharing options...
zador.blood.stained Posted January 13, 2017 Share Posted January 13, 2017 g_ether work fine but only for kernel 3.4 i try to do same on last kernel 4.9.0-sun8i but without success lsmod libcomposite 34616 1 usb_f_rndis u_ether 9963 1 usb_f_rndis usb_f_rndis 12443 0 insmod g_ether failed to insert /lib/modules/4.9.0-sun8i/g_ether.ko dmesg -c [ 2404.192826] g_ether musb-hdrc.1.auto: failed to start g_ether: -2 some recommendation for me ? What board exactly? Not all boards enable OTG in DT by default, and OTG driver is still WIP/experimental so it may not work perfectly. And you should probably grab the latest nightly image or kernel which should have version 4.9.2 4.9.3. Link to comment Share on other sites More sharing options...
hyphop Posted January 14, 2017 Share Posted January 14, 2017 What board exactly? Not all boards enable OTG in DT by default, and OTG driver is still WIP/experimental so it may not work perfectly. And you should probably grab the latest nightly image or kernel which should have version 4.9.2 4.9.3. Hi i check last kernel 4.9.3 its same have error [ 1241.108446] g_ether musb-hdrc.1.auto: failed to start g_ether: -2 my device Orange Pi Zero - g_ether work fine with 3.4.113 Link to comment Share on other sites More sharing options...
zador.blood.stained Posted January 14, 2017 Share Posted January 14, 2017 Hi i check last kernel 4.9.3 its same have error [ 1241.108446] g_ether musb-hdrc.1.auto: failed to start g_ether: -2 my device Orange Pi Zero - g_ether work fine with 3.4.113 Because why do you use insmod? It doesn't check for module dependencies. You should use modprobe instead root@orangepizero:~# uname -r 4.9.3-sun8i root@orangepizero:~# modprobe sunxi root@orangepizero:~# modprobe g_ether root@orangepizero:~# ifconfig usb0 up root@orangepizero:~# ifconfig usb0 usb0 Link encap:Ethernet HWaddr be:99:65:70:8b:8a UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:0 (0.0 root@orangepizero:~# Link to comment Share on other sites More sharing options...
hyphop Posted January 15, 2017 Share Posted January 15, 2017 Because why do you use insmod? It doesn't check for module dependencies. You should use modprobe instead root@orangepizero:~# uname -r 4.9.3-sun8i root@orangepizero:~# modprobe sunxi root@orangepizero:~# modprobe g_ether root@orangepizero:~# ifconfig usb0 up root@orangepizero:~# ifconfig usb0 usb0 Link encap:Ethernet HWaddr be:99:65:70:8b:8a UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:0 (0.0 root@orangepizero:~# hi what is it modprobe sunxi ? i cant find this module sunxi.ko can u provide your lsmod output i use insmod, because i try test 4.3.9 kernel in openwrt env ))) yes its lil ugly but sure i have check dep kernel/drivers/usb/gadget/legacy/g_ether.ko: kernel/drivers/usb/gadget/function/usb_f_rndis.ko kernel/drivers/usb/gadget/function/u_ether.ko kernel/drivers/usb/gadget/libcomposite.ko Link to comment Share on other sites More sharing options...
hyphop Posted January 15, 2017 Share Posted January 15, 2017 hi what is it modprobe sunxi ? i cant find this module sunxi.ko can u provide your lsmod output i use insmod, because i try test 4.3.9 kernel in openwrt env ))) yes its lil ugly but sure i have check dep kernel/drivers/usb/gadget/legacy/g_ether.ko: kernel/drivers/usb/gadget/function/usb_f_rndis.ko kernel/drivers/usb/gadget/function/u_ether.ko kernel/drivers/usb/gadget/libcomposite.ko i have find it but only on build in modules modules.builtin kernel/drivers/usb/musb/sunxi.ko i will try test again Link to comment Share on other sites More sharing options...
zador.blood.stained Posted January 15, 2017 Share Posted January 15, 2017 what is it modprobe sunxi ? i cant find this module sunxi.ko OK, "sunxi" is built-in here, so you don't need to modprobe it. This is the OTG driver for sunxi devices and it was built as a module previously. can u provide your lsmod output root@orangepizero:~# lsmod Module Size Used by usb_f_eem 4914 1 g_ether 4851 0 usb_f_rndis 12519 2 g_ether u_ether 9963 3 g_ether,usb_f_rndis,usb_f_eem libcomposite 34756 3 g_ether,usb_f_rndis,usb_f_eem sunxi_cir 3825 0 evdev 10043 0 xradio_wlan 92375 1 mac80211 322651 1 xradio_wlan sun8i_ths 3284 0 cfg80211 191902 2 mac80211,xradio_wlan rfkill 10928 1 cfg80211 gpio_keys 8453 0 cpufreq_dt 3586 0 uio_pdrv_genirq 3354 0 uio 8012 1 uio_pdrv_genirq thermal_sys 42239 2 cpufreq_dt,sun8i_ths fuse 70616 1 uas 11678 0 root@orangepizero:~# You can use modinfo with absolute path to the module file to check module dependencies (should work on OpenWRT too) Link to comment Share on other sites More sharing options...
zador.blood.stained Posted January 15, 2017 Share Posted January 15, 2017 sure i have check dep kernel/drivers/usb/gadget/legacy/g_ether.ko: kernel/drivers/usb/gadget/function/usb_f_rndis.ko kernel/drivers/usb/gadget/function/u_ether.ko kernel/drivers/usb/gadget/libcomposite.ko Each module may have some dependencies too, and you need to load them in the right order You may try to move all .ko files in /lib/modules/`uname -r` in OpenWRT because at least on my router it is organized in that way (without subdirectories) and modprobe may work after that. Link to comment Share on other sites More sharing options...
hyphop Posted January 15, 2017 Share Posted January 15, 2017 Each module may have some dependencies too, and you need to load them in the right order You may try to move all .ko files in /lib/modules/`uname -r` in OpenWRT because at least on my router it is organized in that way (without subdirectories) and modprobe may work after that. tnx for help after 1 hour i have success, ( modprobe u_ether not work without modprobe usb_f_eem before ) i have troubles becouse openwrt have another kernel module loading system ( without some automate ) my script for startup g_ether modprobe usb_f_eem modprobe usb_f_ecm modprobe usb_f_ncm modprobe usb_f_rndis modprobe libcomposite modprobe u_ether insmod g_ether iProduct=opizero \ iManufacturer=hyphop \ dev_addr=62:ef:11:22:11:22 \ host_addr=ea:c9:35:d4:66:87 \ use_eem=0 ifconfig usb0 10.1.1.1 netmask 255.255.255.0 TNX u again Link to comment Share on other sites More sharing options...
Masoud Posted January 31, 2017 Share Posted January 31, 2017 Hello, I've used your method for nanopi air, every thing goes well but it completely destroyed WiFi connection and wlan0 not listed on /sys/class/net ... Please help me on this issue, I need both connection, how can i configured nanopi air to have usb0 as Ethernet dongle and WiFi .. BR, Masoud. Link to comment Share on other sites More sharing options...
Eridani Posted March 8, 2017 Share Posted March 8, 2017 Guys, doesn't matter what I do, it loads as a serial device on Win10. (g_ether module is loaded, all usb0 interface configs are OK) I don't have modules usb_f_rndis, libcomposite or usb_f_* loaded. Do I need them? If yes, how to have them (new kernel, patches...what?) (Running Jessie on an Orange Pi Zero) Modules Loaded: Module Size Used by ir_lirc_codec 3650 0 lirc_dev 7834 1 ir_lirc_codec ir_mce_kbd_decoder 2885 0 ir_sanyo_decoder 1480 0 ir_sony_decoder 1422 0 ir_jvc_decoder 1452 0 ir_rc6_decoder 1941 0 ir_rc5_decoder 1412 0 ir_nec_decoder 1556 0 sunxi_cir 1601 0 rc_core 12727 10 ir_lirc_codec,ir_rc5_decoder,ir_nec_decoder,ir_sony_decoder,sunxi_cir,ir_mce_kbd_decoder,ir_jvc_decoder,ir_rc6_decoder,ir_sanyo_decoder pcf8591 3363 0 bmp085 3487 0 g_ether 38566 0 xradio_wlan 210530 0 mac80211 358445 1 xradio_wlan btrfs 712409 0 Link to comment Share on other sites More sharing options...
dhlii Posted March 9, 2017 Share Posted March 9, 2017 I am also working to get g_ether up. I have succeeded but I have some first boot issues. I need the usb ethernet working the first time the unit boots. I have modified Armbian_5.27_Orangepilite_Debian_jessie_dev_4.10.1.img as follows: I have added g_ether to /etc/modules I have create /etc/modprobe.d/g_ether.conf with the contents options g_ether host_addr=12:a5:cf:42:92:fd dev_addr=5e:bc:ca:27:92:b1 idVendor=1317 idProduct=42146 This gets me a usb0 when the system boots. But it has no IP and is otherwise not useful. I added /etc/network/interfaces.d/usb0 auto usb0 iface usb0 inet static hwaddress ether 82:bc:09:47:28:a9 address 169.254.7.2 netmask 255.255.0.0 network 169.168.7.0 gateway 169.168.7.1 but the armbian setup does not source interfaces.d I appended source /etc/network/interfaces.d/* to /etc/network/interfaces.network-manager but still no joy. I added /etc/NetworkManager/systemconnections/USB Network [ethernet] mac-address=5E:BC:CA:27:92:B1 [connection] id=USB Network uuid=fbffa806-7cd2-4234-b406-ea7e6423a45a type=ethernet timestamp=1488840639 [ipv6] method=ignore [ipv4] method=link-local Still No joy. HOWEVER If I boot the SDcard, log in via Serial get through the firstrun stuff including creating a new user and reboot the system comes up with fully working usb0 But I need it to work the first time. I need to be able to bring the system up without a serial connection. Link to comment Share on other sites More sharing options...
MegaLoL Posted June 22, 2017 Share Posted June 22, 2017 Hello, I have all the settings reset after reboot and I have to register again: 1) echo -n 0> / sys / bus / platform / devices / sunxi_usb_udc / otg_role Modprobe g_ether Echo -n 2> / sys / bus / platform / devices / sunxi_usb_udc / otg_roll 2) lsmod | Grep -q g_ether && echo -n 2> / sys / bus / platform / devices / sunxi_usb_udc / otg_role \ || (Sleep 10 && echo -n 2> / sys / bus / platform / devices / sunxi_usb_udc / otg_role) 3) nano / etc / network / interfaces Auto lo Iface lo inet loopback # Wired adapter # 1 Auto eth0 Iface eth0 inet dhcp Allow-hotplug usb0 Iface usb0 inet static Hwaddress ether 82: bc: 09: 47: 28: a9 Address 192.168.172.2 Netmask 255.255.255.0 Pre-up / bin / sh -c 'echo 2> / sys / bus / platform / devices / sunxi_usb_udc / otg_role' Did I miss something? After 1 point, I prescribe the command lsmod and see g_ether, but after the reboot there is no this module and use ifconfig-a i dont see usb0 Link to comment Share on other sites More sharing options...
