Hi
I would like to know whether I can use orange pi lite 2 image on orange pi one plus.  I tried it but eth0 is not visible. Is there a way to tweak it? The reason is I want to create an image with various packages installed. So that i do not need to maintain 2 sd images since both are H6. Tq
Is there any reason for that ? Because there are images dedicated for OPiOne+ ...
@Wener thanks for the guidance. It seems that fdtfile= in armbianEnv.txt doesn't work. Incidentally, i saw both lite2 and one+ dtb in /boot/dtb/allwinner folder and i just need to switch dtb name because apparently the image file is hardcoded to load the respective board name.
It should work !
But be aware that variable doesn't include /boot/dtb path, but you still need to provide allwinner/ subpath, so it should be "fdtfile=allwinner/sun50i-h6-orangepi-lite2.dtb" ...
