yaa314 Posted June 3, 2020 Posted June 3, 2020 Hi Everyone, I am having trouble installing kernel headers in order to build and install the neccessary wifi drivers for my rtl8188eu dongle. I have tried installing the headers from armbian-config as suggested elsewhere in the forum but nothing seems to happen. For reference, i am running armbian on an amlogic s912 box. Release: Ubuntu 18.04.4 LTS uname -r: 5.5.0-rc6-aml-s9xxx Error Message: make ARCH=aarch64 CROSS_COMPILE= -C /lib/modules/5.5.0-rc6-aml-s9xxx/build M=/home/***/Downloads/rtlquick/rtl8188eus modules make[1]: *** /lib/modules/5.5.0-rc6-aml-s9xxx/build: No such file or directory. Stop. Makefile:1911: recipe for target 'modules' failed make: *** [modules] Error 2 Any and all help with solving this problem will be much appreciated
guidol Posted June 3, 2020 Posted June 3, 2020 1 hour ago, yaa314 said: I am having trouble installing kernel headers in order to build and install the neccessary wifi drivers for my rtl8188eu dongle. Any and all help with solving this problem will be much appreciated are you sure that a actual armbian doenst has that already included?: root@npi-neo2-24(192.168.6.24):~# find / -name rtl8188eu* /lib/modules/5.6.13-sunxi64/kernel/drivers/net/wireless/rtl8188eu /lib/firmware/rtlwifi/rtl8188eufw.bin root@npi-neo2-24(192.168.6.24):~# uname -a Linux npi-neo2-24 5.6.13-sunxi64 #20.05.1 SMP Sat May 30 11:29:49 CEST 2020 aarch64 GNU/Linux
yaa314 Posted June 5, 2020 Author Posted June 5, 2020 Hi, it seemed i had to wait a day to reply Oddly yes, i get the same result when i run find / -name rtl8188eu* thus showing it as already installed but the dongle still does not work. I am using another dongle for now that worked out of the box. However, i do wish to resolve the headers issue since any program i need to build runs into the same issue. Any ideas? Thanks in advance 1
Werner Posted June 5, 2020 Posted June 5, 2020 4 hours ago, yaa314 said: Hi, it seemed i had to wait a day to reply Spam encounter measure. The limit should be gone now for you.
eduamld1 Posted October 2, 2020 Posted October 2, 2020 hi i have arm board which was a tanix tv box S905, it comes with rtl8189etv wifi built in, it have booted smoothly now i need to install the wifi module but i need to install the kernel header, i did the same as @yaa314 and got the same nothing result. could i get a little help
eduamld1 Posted October 6, 2020 Posted October 6, 2020 Im using arm s905 by inphic which worked smoothly with buster current 20200205 using meson-gxl-s905w-tx3-mini.dtb Im trying to install kernal headers that is suitable with 5.5.0-rc6-aml-s9xxx, in order for me to install wifi rtl8189etv drivers. Based on what i have found, the following driver could be suitable for my wifi built in chipset https://linux-sunxi.org/Wifi#RTL8189ES_.2F_RTL8189ETV , however i haven’t reached this point to test it yet. So i have tried the armbian-config method to install the headers but it did not have any effect, should i download and install headers found in this url https://github.com/armbian/upload/find/apt.armbian.com ? The other challenge is that am not able to copy sd to emmc through nand-sata-install, i guess nand-sata-install.sh is not available to me in the current build that im using, is it exclusively availablefor to specific kernal as mentioned by@igor in this doc https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb ? I apologize for the lengthy questions Sent from my iPhone using Tapatalk
Igor Posted October 6, 2020 Posted October 6, 2020 Armbian provides limited support for certain boards https://www.armbian.com/download/?device_support=Supported and no support for unofficial builds or any TV box hardware, but you are welcome to use software as is and help each other via this community. Check general support term: https://github.com/armbian/build#support How do you know which build is official? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity
eduamld1 Posted October 7, 2020 Posted October 7, 2020 Hi@igor my inquiry can be treated as general question if possible, i hope my questions were in the right place to get any useful hints. Much appreciated Sent from my iPhone using Tapatalk
Igor Posted October 7, 2020 Posted October 7, 2020 6 hours ago, eduamld1 said: Hi@igor my inquiry can be treated as general question if possible, i hope my questions were in the right place to get any useful hints. Much appreciated Sent from my iPhone using Tapatalk It is in right place. Just don't know what this problem has to do with me personally?
Werner Posted October 8, 2020 Posted October 8, 2020 11 hours ago, Igor said: It is in right place. Just don't know what this problem has to do with me personally? Maybe becasue this founder label sticking to your back Joking apart: There are many contributors to the Armbian project as well as to it's documentation so Igor does not necessarily know about at specific topic. To cut a long story short: it is not Igor's documentation, it is the Armbian's documentation which consists of many different people, not a specific one
eduamld1 Posted October 10, 2020 Posted October 10, 2020 Oh thank you @Warner for making things clear! truly appreciated.@igor please forgive me! As i thought that the referred article was another great contribution of yours.Sent from my iPhone using Tapatalk
