Orange Pi Zero boot corruption
Aleksey Vasenev
Armbian_20.05.3_Orangepizero_buster_current_5.4.45.img
apt install cryptsetup lvm2 thin-provisioning-tools
All ok if install any two, size problem?
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    13697769 Bytes = 13.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... Bad Data CRC
Ramdisk image is corrupt or invalid
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
28 minutes ago, Werner said:
20.05.3
Known issue. Either start over with the most recent image or fix it by changing the compression algorythm of you ramdisk to gzip.
Some notes:
1. You only discuss focal problem, but i reproduce with buster, no newer images yet.
2. What real reason of problem? Only some update-initramfs failed, in my case only when i add 3 packages to it.
Edited by Aleksey Vasenev
Link to comment
But it could be related. What if those packages changes compression and this is failing on (ARM? only)
Check what those packages do and check support terms before getting to exicted who has to fix problems https://github.com/armbian/build#support
Link to comment
