pkfox 8 Posted June 28, 2020 Share Posted June 28, 2020 Hi all, is it possible to boot a Nanopi M4 V2 from a NVME M2 ? 0 Quote Link to post Share on other sites
Werner 366 Posted June 28, 2020 Share Posted June 28, 2020 If this is a generic question: I don't know. If you actually have this board then use the nand-sata-install script and it should do the trick 0 Quote Link to post Share on other sites
NicoD 405 Posted June 28, 2020 Share Posted June 28, 2020 You can't boot it directly from NVMe. You need either an sd-card or eMMC to start the boot process. Then it goes further to NVMe. Use "sudo armbian-config" to install it from sd-card/eMMC to NVMe. 0 Quote Link to post Share on other sites
pkfox 8 Posted June 28, 2020 Author Share Posted June 28, 2020 Ok thanks guys 0 Quote Link to post Share on other sites
