gecko42 Posted July 6, 2020 Posted July 6, 2020 Hello there, I am trying to (first) boot an Orange Pi Zero (H2+, 512MB ram, v1.5) that I received a long time ago but can't get it to start. There are no LEDs turned on, not on the ethernet port nor on the other side (but afaik the latter is software controlled so this does not worry me). Here is what I tried: multiple attempts with Armbian Buster (Armbian_20.05.3_Orangepizero_buster_current_5.4.45.img) burnt with BalenaEtcher, multiple microSD cards, different power supplies (via microUSB and GPIO). Unfortunately, nothing shows up on the serial connection, and 0 amps are drained when 5V is sent to the board. I have little experience with Orange Pis and I have usually found my way around, the microSD cards and PSUs were also tested working on an Orange Pi PC and another Orange Pi Zero (H2+, 256MB ram, v1.4)... Can someone help me? Is my board dead? Thank you for your help! Board: Orangepi Zero
Werner Posted July 6, 2020 Posted July 6, 2020 (edited) Quote , and 0 amps are drained Expand That is not good. The board might be dead.... I'll try the same image with my Zero v1.1 Edit: As expected the Armbian image is perfectly fine. http://ix.io/2r2n Edited July 6, 2020 by Werner Add result
gecko42 Posted July 6, 2020 Author Posted July 6, 2020 On 7/6/2020 at 4:56 PM, Werner said: That is not good. The board might be dead.... I'll try the same image with my Zero v1.1 Edit: As expected the Armbian image is perfectly fine. http://ix.io/2r2n Expand This image also works with my Zero v1.4 :(( Well thank you, do you think of anything else I could try?
Werner Posted July 6, 2020 Posted July 6, 2020 If you have some knowledge in electronics you can check the board schematics and try to follow the circuit to the point where its broken.
gecko42 Posted July 6, 2020 Author Posted July 6, 2020 On 7/6/2020 at 5:24 PM, Werner said: If you have some knowledge in electronics you can check the board schematics and try to follow the circuit to the point where its broken. Expand Unfortunately no, not on my own
Technicavolous Posted July 6, 2020 Posted July 6, 2020 Do you have a 12v power supply that you may have accidentally plugged into it? Seems to be a common mistake. If so, your board is probably toast :[
martinayotte Posted July 7, 2020 Posted July 7, 2020 On 7/6/2020 at 10:33 PM, Technicavolous said: Do you have a 12v power supply that you may have accidentally plugged into it? Seems to be a common mistake. If so, your board is probably toast :[ Expand I doubt he did since OPiZero doesn't have any barrel connector ...
Technicavolous Posted July 8, 2020 Posted July 8, 2020 Yes I should have thought of that ... but you'd be surprised at what comes in to my student labs!! 1
martinayotte Posted July 8, 2020 Posted July 8, 2020 On 7/8/2020 at 2:09 AM, Technicavolous said: but you'd be surprised at what comes in to my student labs!! Expand
