technik007_cz Posted July 9, 2020 Posted July 9, 2020 I found root of my card not resized to maximum space available. Unfortunately when I run out of space. Consider adding missing package btrfs-progs to minimal image or warn user when building of such system image is complete so user can resize root manually before the sd card is inserted.
Igor Posted July 9, 2020 Posted July 9, 2020 3 hours ago, technik007_cz said: Consider adding missing package btrfs-progs to minimal image Somewhere here:https://github.com/armbian/build/blob/master/lib/configuration.sh https://docs.armbian.com/Process_Contribute/ 3 hours ago, technik007_cz said: or warn user when building of such system image is complete so user can resize root manually before the sd card is inserted. Also about other bugs yet to be discovered? And who has to do that?
Technicavolous Posted July 9, 2020 Posted July 9, 2020 Yeah the minimal image is missing a few things. See also https://forum.armbian.com/topic/14455-error-verifying-gcc-linaro-2013/?do=findComment&comment=104091 Also instructions tell you to log in as root, but default ubuntu has no root password, so you have to sudo passwd root or sudo everything you do.
