a.rodionov Posted July 14, 2020 Posted July 14, 2020 Armbianmonitor: https://drive.google.com/file/d/1ik7BWZdcjR7WsVOnyZB7M9mV0Qu0JQtY/view?usp=sharing Hi all. I have a board nanopi neo air with armbian linux on it. We with my colleague try to setting up ffmpeg with cedrus264 for hardware accelerated capturing video from ov5640-like camera device. There is my armbianmonitor. There are my v4l2-ctl -d /dev/videox -D out: Spoiler Driver Info: Driver name : cedrus Card type : cedrus Bus info : platform:cedrus Driver version : 5.4.51 Capabilities : 0x84208000 Video Memory-to-Memory Streaming Extended Pix Format Device Capabilities Device Caps : 0x04208000 Video Memory-to-Memory Streaming Extended Pix Format Media Driver Info: Driver name : cedrus Model : cedrus Serial : Bus info : platform:cedrus Media version : 5.4.51 Hardware revision: 0x00000000 (0) Driver version : 5.4.51 Interface Info: ID : 0x0300000c Type : V4L Video Entity Info: ID : 0x00000001 (1) Name : cedrus-source Function : V4L2 I/O Pad 0x01000002 : 0: Source Link 0x02000008: to remote pad 0x1000004 of entity 'cedrus-proc': Data, Enabled, Immutable Spoiler Driver Info: Driver name : sun6i-video Card type : sun6i-csi Bus info : platform:camera Driver version : 5.4.51 Capabilities : 0x84200001 Video Capture Streaming Extended Pix Format Device Capabilities Device Caps : 0x04200001 Video Capture Streaming Extended Pix Format Media Driver Info: Driver name : sun6i-csi Model : Allwinner Video Capture Device Serial : Bus info : Media version : 5.4.51 Hardware revision: 0x00000000 (0) Driver version : 5.4.51 Interface Info: ID : 0x03000003 Type : V4L Video Entity Info: ID : 0x00000001 (1) Name : sun6i-csi Function : V4L2 I/O Pad 0x01000002 : 0: Sink, Must Connect Link 0x02000007: from remote pad 0x1000006 of entity 'Borei_VideoDriver 0-003c': Data, Enabled, Immutable After some reconfiguration of dts, we can successfully capture video in low fps with ffmpeg -f v4l2 -framerate 25 -video_size 960x720 -i /dev/video1 output.mkv but with ffmpeg -f v4l2 -channel 0 -video_size 960x720 -i /dev/video1 -pix_fmt nv12 -r 30 -b:v 64k -c:v cedrus264 test.mp4 ffmpeg failed: Spoiler root@nanopiair:/home/pi# ffmpeg -f v4l2 -channel 0 -video_size 960x720 -i /dev/video1 -pix_fmt nv12 -r 30 -b:v 64k -c:v cedrus264 test.mp4 > ffmpeg_error.txt ffmpeg version git-2015-01-22-f86a076 Copyright (c) 2000-2014 the FFmpeg developers built on Jul 14 2020 09:02:41 with gcc 8 (Debian 8.3.0-6) configuration: --prefix=/usr --enable-nonfree --enable-gpl --enable-vdpau --enable-libx264 --enable-libv4l2 libavutil 54. 6.100 / 54. 6.100 libavcodec 56. 0.101 / 56. 0.101 libavformat 56. 2.100 / 56. 2.100 libavdevice 56. 0.100 / 56. 0.100 libavfilter 5. 0.102 / 5. 0.102 libswscale 3. 0.100 / 3. 0.100 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 0.100 / 53. 0.100 Input #0, video4linux2,v4l2, from '/dev/video1': Duration: N/A, start: 1581.872201, bitrate: 248832 kb/s Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 960x720, 248832 kb/s, 30 fps, 30 tbr, 1000k tbn, 1000k tbc File 'test.mp4' already exists. Overwrite ? [y/N] y [cedrus264 @ 0x241ff20] VE Open error. Output #0, mp4, to 'test.mp4': Stream #0:0: Video: h264, q=2-31, 128 kb/s, 30 fps Metadata: encoder : Lavc56.0.101 cedrus264 Stream mapping: Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (cedrus264)) Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height Ffmpeg was buided from FFmpeg-Cedrus, also we try follow this and use this binaries - result haven't changed. After some inspecting sources of ffmpeg-cedrus we found that ffmpeg try to open /dev/cedar_dev device, which don't exists in our system. Ffmpeg fails on opening device. If we replace /dev/cedar_dev by /dev/video0, where is our cedrus driver, ffmpeg fails on ioctl IOCTL_GET_ENV_INFO. In source, it is 99 or 101 line. We check kernel config for configuration, provided by Sunxi-Cedrus and determine that cedrus was configured right. Also we have tried all described actions on official armbian buster image for nanopi neo air and we have got the same result. What we does wrong? 0 Quote
@lex Posted July 14, 2020 Posted July 14, 2020 Encoding using cedrus264 was for legacy kernel. I think Uboborov has done some work with mainline kernel for encoding with cedrus. Search the forum for "encoding" or uboborov 1 Quote
a.rodionov Posted July 15, 2020 Author Posted July 15, 2020 18 hours ago, @lex said: Encoding using cedrus264 was for legacy kernel. I think Uboborov has done some work with mainline kernel for encoding with cedrus. Search the forum for "encoding" or uboborov Thank you for you answer. What kernel version do you mean as legacy kernel? In armbian build tool legacy kernel is 4.19 kernel and it has no cedrus at all, including /dev/cedar_dev. We found topic from Uboborov(this), and his driver (this) with hardware h264 encoder (this). We build fresh 4.19 kernel, Uboborov's driver and install it to our system. Driver has loaded successfully (determine by lsmod). We change dts, as it changed in his github, but still there isn't /dev/cedar_dev. Also, as i already said in my first post, we also try to use Uboborov's ffmpeg (this), including precompiled binaries (found there). 0 Quote
@lex Posted July 19, 2020 Posted July 19, 2020 Legacy = Kernel 3.x Mainline (?) >= 4.x I have not tested the @ubobrov solution, i think you should go with this one: https://github.com/uboborov/sunxi-cedar-mainline 0 Quote
Werner Posted July 19, 2020 Posted July 19, 2020 1 hour ago, @lex said: Legacy = Kernel 3.x Mainline (?) >= 4.x I have not tested the @ubobrov solution, i think you should go with this one: https://github.com/uboborov/sunxi-cedar-mainline About a year ago this was correct. All 3.x kernels have been dropped due to lack of upstream support. 0 Quote
a.rodionov Posted July 22, 2020 Author Posted July 22, 2020 Thanks to all for help. We have setuped uboborov sunxi-cedar-mainline in 5.7 armbian kernel. I think, early we did some errors in dts. Our current dts we published in https://github.com/Rexarrior/sunxi-cedar-mainline. Big thanks to uboborov! 1 Quote
gounthar Posted July 23, 2020 Posted July 23, 2020 So does the hardware acceleration work for you @a.rodionov ? 0 Quote
a.rodionov Posted July 24, 2020 Author Posted July 24, 2020 18 hours ago, gounthar said: So does the hardware acceleration work for you @a.rodionov ? Yes, it is. On nanopi neo air with armbian 20.08.0 (5.7.8) it works. FFmpeg with 960x720 input from our camera* encode mp4 by h264_omx with 15-20 fps. If i use cedrus264 as codec, ffmpeg can easy provide 30 fps. With default cam500b i get 60 fps 640x480 (that is maximum of the camera). Fps numbers i get from ffmpeg log and i think this results is accurate enough. * our camera isn't ov5640 default camera and 30 fps likely it's maximum fps. We haven't camera's datasheet. 1 Quote
a.rodionov Posted July 24, 2020 Author Posted July 24, 2020 (edited) Full .dts, which is works for us, now is placed in uboborov repository. Edited July 24, 2020 by a.rodionov i did accidentally pasted past answer 2 Quote
matteog Posted May 2, 2021 Posted May 2, 2021 @a.rodionov we are in need of enabling h264 encoding on a Neo Air platform, can you please explain what you did in order to make it work? Custom ffmpeg, kernel rebuild, or both of them? You will be very helpful!! Thanks 0 Quote
a.rodionov Posted May 24, 2021 Author Posted May 24, 2021 02.05.2021 в 18:38, matteog сказал: @a.rodionov we are in need of enabling h264 encoding on a Neo Air platform, can you please explain what you did in order to make it work? Custom ffmpeg, kernel rebuild, or both of them? You will be very helpful!! Thanks Hello. I m sorry for long answer. So, I use rebuilded ffmpeg with cedrus, cedrus driver and modified dts from @ubobrov. Dts and driver is here. You can try to follow this I m hope I could help you. 0 Quote
matteog Posted May 24, 2021 Posted May 24, 2021 32 minutes ago, a.rodionov said: I use rebuilded ffmpeg with cedrus, cedrus driver and modified dts from @ubobrov. Thank you for the reply. So no kernel build necessary? Just the .ko module? On which kernel did you do this? Thanks! 0 Quote
a.rodionov Posted May 24, 2021 Author Posted May 24, 2021 3 часа назад, matteog сказал: Thank you for the reply. So no kernel build necessary? Just the .ko module? On which kernel did you do this? Thanks! You are welcome. Yes, you need just .ko module. I used 5.7 kernel, but everything that i did works fine wih 5.4+ kernels. If i will speak more accuracy, i should to say that i have builded custom kernel in this project, but i did it for another changes, not for h264 encoding. 0 Quote
schunckt Posted May 26, 2021 Posted May 26, 2021 (edited) Hi! That sounds interesting to me as well. I'll give it a try on a NanoPi Duo2 5.10.34-sunxi Does that solution use the vaapi layer? Forgot to mention - possibly this is no longer necessary at all since the cedrus driver already appears as /dev/video0 but im still unsure if and how this is usable ... T. Edited May 26, 2021 by schunckt comment added 0 Quote
lam96pt Posted August 9, 2021 Posted August 9, 2021 On 7/14/2020 at 11:31 PM, @lex said: Encoding using cedrus264 was for legacy kernel. I think Uboborov has done some work with mainline kernel for encoding with cedrus. Search the forum for "encoding" or uboborov On 7/14/2020 at 4:00 PM, a.rodionov said: Armbianmonitor: https://drive.google.com/file/d/1ik7BWZdcjR7WsVOnyZB7M9mV0Qu0JQtY/view?usp=sharing Hi all. I have a board nanopi neo air with armbian linux on it. We with my colleague try to setting up ffmpeg with cedrus264 for hardware accelerated capturing video from ov5640-like camera device. There is my armbianmonitor. There are my v4l2-ctl -d /dev/videox -D out: Reveal hidden contents Driver Info: Driver name : cedrus Card type : cedrus Bus info : platform:cedrus Driver version : 5.4.51 Capabilities : 0x84208000 Video Memory-to-Memory Streaming Extended Pix Format Device Capabilities Device Caps : 0x04208000 Video Memory-to-Memory Streaming Extended Pix Format Media Driver Info: Driver name : cedrus Model : cedrus Serial : Bus info : platform:cedrus Media version : 5.4.51 Hardware revision: 0x00000000 (0) Driver version : 5.4.51 Interface Info: ID : 0x0300000c Type : V4L Video Entity Info: ID : 0x00000001 (1) Name : cedrus-source Function : V4L2 I/O Pad 0x01000002 : 0: Source Link 0x02000008: to remote pad 0x1000004 of entity 'cedrus-proc': Data, Enabled, Immutable Reveal hidden contents Driver Info: Driver name : sun6i-video Card type : sun6i-csi Bus info : platform:camera Driver version : 5.4.51 Capabilities : 0x84200001 Video Capture Streaming Extended Pix Format Device Capabilities Device Caps : 0x04200001 Video Capture Streaming Extended Pix Format Media Driver Info: Driver name : sun6i-csi Model : Allwinner Video Capture Device Serial : Bus info : Media version : 5.4.51 Hardware revision: 0x00000000 (0) Driver version : 5.4.51 Interface Info: ID : 0x03000003 Type : V4L Video Entity Info: ID : 0x00000001 (1) Name : sun6i-csi Function : V4L2 I/O Pad 0x01000002 : 0: Sink, Must Connect Link 0x02000007: from remote pad 0x1000006 of entity 'Borei_VideoDriver 0-003c': Data, Enabled, Immutable After some reconfiguration of dts, we can successfully capture video in low fps with ffmpeg -f v4l2 -framerate 25 -video_size 960x720 -i /dev/video1 output.mkv but with ffmpeg -f v4l2 -channel 0 -video_size 960x720 -i /dev/video1 -pix_fmt nv12 -r 30 -b:v 64k -c:v cedrus264 test.mp4 ffmpeg failed: Reveal hidden contents root@nanopiair:/home/pi# ffmpeg -f v4l2 -channel 0 -video_size 960x720 -i /dev/video1 -pix_fmt nv12 -r 30 -b:v 64k -c:v cedrus264 test.mp4 > ffmpeg_error.txt ffmpeg version git-2015-01-22-f86a076 Copyright (c) 2000-2014 the FFmpeg developers built on Jul 14 2020 09:02:41 with gcc 8 (Debian 8.3.0-6) configuration: --prefix=/usr --enable-nonfree --enable-gpl --enable-vdpau --enable-libx264 --enable-libv4l2 libavutil 54. 6.100 / 54. 6.100 libavcodec 56. 0.101 / 56. 0.101 libavformat 56. 2.100 / 56. 2.100 libavdevice 56. 0.100 / 56. 0.100 libavfilter 5. 0.102 / 5. 0.102 libswscale 3. 0.100 / 3. 0.100 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 0.100 / 53. 0.100 Input #0, video4linux2,v4l2, from '/dev/video1': Duration: N/A, start: 1581.872201, bitrate: 248832 kb/s Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 960x720, 248832 kb/s, 30 fps, 30 tbr, 1000k tbn, 1000k tbc File 'test.mp4' already exists. Overwrite ? [y/N] y [cedrus264 @ 0x241ff20] VE Open error. Output #0, mp4, to 'test.mp4': Stream #0:0: Video: h264, q=2-31, 128 kb/s, 30 fps Metadata: encoder : Lavc56.0.101 cedrus264 Stream mapping: Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (cedrus264)) Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height Ffmpeg was buided from FFmpeg-Cedrus, also we try follow this and use this binaries - result haven't changed. After some inspecting sources of ffmpeg-cedrus we found that ffmpeg try to open /dev/cedar_dev device, which don't exists in our system. Ffmpeg fails on opening device. If we replace /dev/cedar_dev by /dev/video0, where is our cedrus driver, ffmpeg fails on ioctl IOCTL_GET_ENV_INFO. In source, it is 99 or 101 line. We check kernel config for configuration, provided by Sunxi-Cedrus and determine that cedrus was configured right. Also we have tried all described actions on official armbian buster image for nanopi neo air and we have got the same result. What we does wrong? I got the same error on orange pi pc and newest armbian (mainline based kernel 5.10.y) on it. Please show me how did you fix it step by step. I spent 3 days but not work this is my command Quote sudo ffmpeg-3.1.4 -f v4l2 -channel 0 -video_size 1280x720 -i /dev/video0 -pix_fmt nv12 -r 22 -qp 30 -c:v cedrus264 -c:a None night_video_test4_1920x1080.mp4 ffmpeg failed: Quote sudo ffmpeg-3.1.4 -f v4l2 -channel 0 -video_size 1280x720 -i /dev/video0 -pix_fmt nv12 -r 22 -qp 30 -c:v cedrus264 -c:a None night_video_test4_1920x1080.mp4 [sudo] password for lam: ffmpeg version 3.1.4 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 4.8 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.3) configuration: --prefix=/usr --enable-nonfree --enable-gpl --enable-version3 --enable-vdpau --enable-libx264 --enable-libmp3lame --enable-libpulse --enable-libv4l2 --enable-libcedrus264 libavutil 55. 28.100 / 55. 28.100 libavcodec 57. 48.101 / 57. 48.101 libavformat 57. 41.100 / 57. 41.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 47.100 / 6. 47.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 1.100 / 2. 1.100 libpostproc 54. 0.100 / 54. 0.100 Input #0, video4linux2,v4l2, from '/dev/video0': Duration: N/A, start: 109.484156, bitrate: 147456 kb/s Stream #0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 1280x720, 147456 kb/s, 10 fps, 10 tbr, 1000k tbn, 1000k tbc File 'night_video_test4_1920x1080.mp4' already exists. Overwrite ? [y/N] y [cedrus264 @ 0x16e0060] VE Open error. Output #0, mp4, to 'night_video_test4_1920x1080.mp4': Stream #0:0: Unknown: none Metadata: encoder : Lavc57.48.101 cedrus264 Stream mapping: Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (cedrus264)) Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height 0 Quote
schunckt Posted June 23, 2023 Posted June 23, 2023 Regarding the fixed dts, can one provide the original dts? I'd like to have some base to diff because i want to figure out what has been changed. I'll try to port these to a Nannopi Duo2 6.1.30 T. 0 Quote
vk vk Posted September 23, 2023 Posted September 23, 2023 Hi all. for kernels 5.1x and 6.1.xx - is it any working hardware encoding solutions for H3 soc? for Nano Pi neo/neo2 ? 0 Quote
Sajan Posted January 5 Posted January 5 (edited) 26.05.2021 в 17:03, schunckt сказал: Forgot to mention - possibly this is no longer necessary at all since the cedrus driver already appears as /dev/video0 /dev/video0 - usually is the camera V4L driver. Cedrus (sunxi video engine) driver usually is /dev/cedar_dev. Also you can see Edited January 5 by Sajan link added 0 Quote
schunckt Posted January 5 Posted January 5 Zitat Cedrus (sunxi video engine) driver usually is /dev/cedar_dev. Thats not correct. cedar_dev is the outdated and quite useless cedar driver from alwinner et.al. cedrus is the open source, latest by Paul Kocialkowski, bootlin, which decoding works properly appears and as video1 video2. Encoding has some bugs on H3. I made some progress in fixing but still have lot block artifacts... T. 0 Quote
Sajan Posted January 5 Posted January 5 (edited) 5 часов назад, schunckt сказал: cedar_dev is the outdated and quite useless cedar driver from alwinner et.al. cedrus is the open source, latest by Paul Kocialkowski, bootlin, which decoding works properly appears and as video1 video2. Encoding has some bugs on H3. I made some progress in fixing but still have lot block artifacts... Ok, maybe, I have not enough or outdated information. Could you help me to understand latest changes and correct me? 1. I think, camera driver and codec video engine driver - are different things, because there are completely different hardware: CSI video input and videocodec accelerator. 2. I think, video engine driver and video coding software with special codecs - are different things, because a driver does not encode/decode video, it only gives access to videocodec accelerator. And video coding software (app or lib) is not a driver, but uses a driver to get access to the videocodec accelerator. 3. So is it really driver performs video decoding in bootlin? Also, as I understand, bootlin - is not just a driver, but big project with it's own Linux, alternative to Armbian, with builtin specific driver and libs. Can I install bootlin driver on Armbian? 4. Doesn't previously mentioned https://github.com/uboborov/sunxi-cedar-mainline use /dev/cedar_dev path? Is it outdated? 5. About encoding on H3. FFmpeg-Cedrus (https://github.com/agustinov/FFmpeg-Cedrus) maybe is outdated, because uses /dev/cedar_dev, but seems to encode without lots of artifacts. Edited January 5 by Sajan link fixed 0 Quote
schunckt Posted January 6 Posted January 6 (edited) I'll try to explain in some details. 1. Yes these are different things even if they appear all as /dev/videoX devices. In case of camera, hardware video decoder and hardware video encoder one may have /dev/video0, /dev/video1 and /dev/video2 2. no, because really the DRIVER does the encoding or decoding provided there is codec hardware present. The driver provides the userland communication to the hardware. This happens through the v4l2 layer (Video For Linux 2) which does the abstraction for different types of hardware, eg. H3, Hantro, Intel ... Of course this requires a v4l2 kind of driver, whereas the cedar_dev (aka cedar_ve) is NOT. 3. Right, bootlin is a little more 🙂 I mentioned these because they provide the latest cedrus driver with encoding support (with still some bugs...) 4. yes, cedar IS outdated. The most modern concept is v4l2 (see above). Cedar and this specific ffmpeg fork are using a different approach. 5. I never mananged to get this combination to work, at least not on the latest kernel. HTH T. Reference: https://bootlin.com/blog/open-source-linux-kernel-support-for-the-allwinner-v3-v3s-s3-h-264-video-encoder/ Edited January 6 by schunckt 0 Quote
Sajan Posted January 6 Posted January 6 3 часа назад, schunckt сказал: Yes these are different things even if they appear all as /dev/videoX devices. In case of camera, hardware video decoder and hardware video encoder one may have /dev/video0, /dev/video1 and /dev/video2 Oh, I understand. Camera, hardware video decoder and hardware video encoder - they all appear now as /dev/videoX devices, because new hardware videocodec accelerator driver (or standalone video decoder and video encoder drivers) became V4L2 kind of driver. Also thanks for the reference link. 0 Quote
